[Toclikunique] Qui veut clicker en mâsse ? Cl Heroes: On re-replonge !
Qui veut clicker en mâsse ? Cl Heroes: On re-replonge ! [Toclikunique] - Loisirs - Discussions
Marsh Posté le 27-11-2014 à 14:40:37
Bienvenue sur le topic des jeux de clics
http://www.clickerheroes.com/
http://www.kongregate.com/games/pl [...] ker-heroes
http://orteil.dashnet.org/cookieclicker/
https://mogron.itch.io/groundhog-life
Topic d'échange autour de ce jeux.
Questions/Réponses.
On verra par la suite s'il est nécessaire de mettre à jour la FP.
Message édité par Perceval_De_Galles le 26-09-2022 à 17:06:40
Appuyez vous sur les principes ils finiront bien par céder.
Marsh Posté le 27-11-2014 à 14:40:47
Liste des Anciens(source Wikipedia) :
http://i.imgur.com/OYGtpL4.jpg
Fortuna (Chance at Triple Gold): This is a good one, though be careful not to spend too many points in it as your DPS will suffer.  It's unknown if this works while offline.
Mammon (+Gold dropped %): Reasonably priced, and you get more gold as a result.  This is a safe pick, provided that you don't level it up too much.  I'd stop at level 5 or so.  It's unknown if this works while offline.
Bhaal (+Damage to critical clicks): This is huge when combined with Lucky strikes.  It will allow you to speed through levels to reach those primals quicker.  And you only need a few points of this to get a large benefit.  Only use this when combining with Vaagur.
Siyalatas (+DPS when not clicking for 5 seconds): Huge bonus and cheap.  Does not actually show your DPS increase on the screen though.  It's unknown if this works while offline.
Libertas (+Gold gained when idle): Huge bonus and cheap.  Combine with Siyaltas for best effect. It's unknown if this works while offline.
Situational
Vaagur (Reduced skill cooldown time): It's great to have, but only worthwhile if you max it, and maxing it is expensive.  You probably will be better off just having the extra souls contributing to your DPS.  If you plan on farming primals after level 200 though, and not idling much, then this is important.
Khrysos (+Starting gold when ascending): Doesn't seem worth it, as you lose more gold in the long run from not having the more valuable ancients.  I don't know what the bonus is at the max level though, but it could be large enough to make it easy to farm souls by ascending over and over.  I already can make it to level 100 pretty quick though.  Starting from level 6, the bonuses are 100K, 400K, 2.5M, 15M, 100M.  But it will cost you nearly 150 souls to max.
*The following four (Dora, Mimzee, Pluto, and Thusia) are good in combination (along with Fortuna and Mammon for more gold dropped across the board). *
Dora (More treasure chests): I could see this one becoming very valuable when combined with others, such as more treasure chest health and other ancients that add to gold find.  Expensive to get them all though.  I wouldn't get this one unless combining with others.
Mimzee (+Gold from treasure chests): Great when combined with Dora
Pluto (+Gold from golden clicks): This is good to use on treasure chests.
Thusia (+Treasure chest life): The bonus from this is huge.  I'd have to test it to see if more treasure chest health means more gold dropped.  If it does, then by all means, combine it with the other gold bonuses here.
Bottom of the barrel
These are just my opinion of what I wouldn't take.  It's possible that with more testing, this could prove to be wrong.  If you had an insanely high amount of souls, this wouldn't be too terrible
Bubos (Reduced Boss life): Most of your time is not spent fighting bosses, and bosses are easily killed as it is.  It won't be worth the return on investment, not by a long shot.
Dogcog (Reduced level up cost): Your money is better spent on treasure chests and the Fortuna ancient.
Any cooldown duration: These don't help you when you're idle (which I hope is a majority of the time in a day).
Solomon (More primal hero souls): Seems way too expensive to me.  Remember, souls are not just a flat currency, but they represent your DPS and click damage as well.
Atman (+Chance of primal bosses): I'd rather have the added damage so that I can actually have more primal bosses to kill rather than this tiny (and very expensive) percentage increase that this one gives you.
Argaiv (+Gilded hero damage bonus): This only has limited value compared with many of the other ones.
Kumawakamaru (Less monsters required to advance to next level): Very expensive.  The most you can reduce it down to is 5 monsters per level, and it costs a whopping 140 souls to do so (plus the cost of having the ancient on the board).  It might help for primal farming, but not as much as the other ancients here.
Chronos (+Time on boss timers): The only time I can imagine that you would need this is if you spent all your souls on this one.  There's no real reason to have this and it won't help you get souls faster.
Morgulis (+Hero Soul DPS):At a cost of only 1 soul for another +1% DPS, this is a very safe ancient to spend points on, as you can never screw yourself by doing so.  The downside is that when you spend all your points in it, you can't have those points available to spend elsewhere. This is actually not very good, unless you use less than 4 ancients, because the cost for each new ancient comes into play, which can possibly put you in the negative for this one.
Broken
Fragsworth (Damage): Completely broken as of the time of this message.  Every point spent will reduce your click damage instead of raise it.
Coût des Rerolls :
http://i.imgur.com/vKB5xO1.jpg
Message édité par Perceval_De_Galles le 03-12-2014 à 14:28:34
Marsh Posté le 27-11-2014 à 14:40:55
[:gnel42]  [:gnel42] NOUVEAUTE [:gnel42]  [:gnel42]
Tout ce qu'il faut savoir sur la transcendance de Clicker Heroes :
https://www.reddit.com/r/ClickerHer [...] eyre_here/
Astuce pour bien démarrer sa trenscendance par Okocedion...
pour le restart après transcend, quelques astuces (je joue full click, donc sans Xyl) http://forum-images.hardware.fr/icones/redface.gif
- La phase critique est d'arriver à passer les 100 premier niveaux
- Une transcend ça se prépare ~48h à l'avance :
  - Ne pas récolter les raids juste avant la trancend. 2 * 4 HS en début de transcendance c'est >>>> à tout ce qu'on peut récolter ensuite
  - Lancer les mercos les jours d'avant sur des quêtes gold, pour en avoir un maximum à récolter au restart
- Avoir quelques rubis en stock est impératif. Dans l'idéal, 140+ : 2 QA, 2 reset CD
dans l'ordre pour le restart :
1) Prendre une QA à 7HS, à ne pas dépenser pour garder les 70% de dps bonus => ça débloque les onglets merco et raid
2) prendre les récompenses de raid de la veille et du jour => +8HS => +80% dps
3) quand on commence à ralentir, utiliser une des quêtes gold, relancer une quête gold < 8h de préférence
4) quand on a fumé toutes les quêtes gold, acheter un reset CD => ça fait du gold pour continuer de monter + ça avance les quêtes des mercos de 8h!! A ne pas négliger, c'est beaucoup + rentable qu'une 2ème QA pour seulement 20 rubis.
5) Si besoin, reprendre à l'étape 3
6) Arrivé au niveau 100, le premier ancien à acheter est Solomon. Avec les 15HS qu'on a en stock on doit arriver à le choper. Grâce à Ponyboy ça devient l'ancien le plus intéressant, car la 2ème QA sera un vrai jackpot! Une QA aux alentours du level 120-130 avec un Ponyboy un peu monté va rapporter quelques centaines de HS => de quoi acheter et leveler quelques anciens pour être confort sur les prochaines ascend.
7) Si on a encore du rubis, continuer les QA quand on commence à trop ralentir (en ayant pris soin de booster Solomon un max avant), sinon ascend.
Pour quelqu'un qui joue idle, donc avec quelques levels dans Xyl, j'imagine qu'il faut chasser Siyalatas/Libertas avec ses 15 premiers HS et Solomon en 3ème.
 Mercenaries have a chance of dying during their quest.
Duration  Death
Chance
 Reward
(multiple of
5 min reward)
 Standardized
(% of 5 min reward)
 Chance of
Surviving 2 days
5 Minutes  0.09%  1  100%  59.53%
15 Minutes  0.26%  2.58  85.94%  60.66%
30 Minutes  0.52%  4.67  77.85%  60.62%
1 hour  1.03%  7.49  62.40%  60.84%
2 hours  2.04%  13.12  54.67%  60.98%
4 hours  4%  22.50  46.87%  61.27%
8 hours  10%  37.47  39.03%  53.14%
1 day  20%  89.99  31.25%  64%
2 days  33.33%  143.98  25%  66.67
Shorter quests have higher reward to time ratio but more likely to kill your mercenary in the long run.
Leveling Edit
It takes 1 days worth of quests to raise mercenary lvl
Lvl  Rank  Reward
Multiplier
1  Noob  x1
2  Rookie  x2
3  Journeyman  x3
4  Expert  x4
5  Master  x5
6  Grandmaster  x6
7  Legend  x7
8  Demigod  x8
9  Demigod+1  x9
Pattern continues for further lvls, adding 1 onto multiplier and demigod +x each lvl.
Rarity Edit
There are tiers to the rarity:
    Common (+/-)5%
    Uncommon (+/-)8%
    Rare (+/-)10%
    Epic (+/-)20%
    Fabled (+/-)50%
    Mythical (+/-)200%
    Legendary (+/-)500%
    Transcendent (+/-)2000%
Mercenaries Personal Bonus Edit
    +% Hero souls
     % Rubies
    +% number of skills activated
    +% gold
    -% time to recruit
Bonuses only affect that mercenary and none of your others
*Note: -% time to recruit can go above 100% and you can instantly hire new mercenaries.
Les CLANS, rejoignez le clan HFR si vous jouez au Taf ou le Clan HRF Taf si vous jouez à la maison - V0.20
https://www.reddit.com/r/ClickerHer [...] clans_faq/
Les Reliques :
Doc qui détail tout ici : http://clickerheroes.wikia.com/wiki/Relics
- Ne pas hésiter a faire une ascension lorsque vous buttez sur un niveau.
- Les HS peuvent être investi "dans l'ancien" ou conservés pour augmenter, de 10%, chacun vos DPS.
- Les HFRiens recommandent Syalatas, DogCog et Morgulis.
- Pour le dark ritual, il faut faire :          - 1 2 3 4 5 7 8 6 9
         - 15 min d'attente
         - 8 9 1 2 3 4 5 7
         - 15 min d'attente
         - recommencer au 1er point
         en ayant le cooldown reduction à fond. pendant les 2ème 15 min d'attente il est possible de faire des 1 2 3 4 plusieurs fois.
Message édité par Perceval_De_Galles le 18-07-2016 à 13:19:48
Marsh Posté le 27-11-2014 à 14:42:12
reservé
T'as déjà vu une exception confirmer une règle toi ???
Marsh Posté le 27-11-2014 à 14:42:17
:o
Marsh Posté le 27-11-2014 à 14:42:56
Plus que 50 boss et je serais à 10K
Marsh Posté le 27-11-2014 à 14:43:05
Marsh Posté le 27-11-2014 à 14:43:20
Le salaud, j'en suis qu'à 7500 :fou:
Marsh Posté le 27-11-2014 à 14:43:56
OSEF :o
Marsh Posté le 27-11-2014 à 14:44:07
Et voila, c'est fait !
Bon en redescendant au lv125, ça va encore plus vite...
J'aurais dû faire ça dès le départ, j'en suis à plus de 2 par seconde :(
Marsh Posté le 27-11-2014 à 14:44:55
J'ai fait à 125 ca a pris 1h30 pour aller de 4500 à 10000
Marsh Posté le 27-11-2014 à 14:45:51
8200 :fou:
Marsh Posté le 27-11-2014 à 14:46:11
Peut-on polluer ce topuc avec vos histoires de broubrou?
Marsh Posté le 27-11-2014 à 14:52:30
J'aime bien les megaman qu'ils viennent de rajouter  [:megaploc]
S'amuser avec son cerveau ça peut etre , tres tres dangereux.....
Marsh Posté le 27-11-2014 à 14:52:36
:love:
Marsh Posté le 27-11-2014 à 14:53:17
Marsh Posté le 27-11-2014 à 14:56:03
 :D
Tu es quel lvl ?
Message édité par Perceval_De_Galles le 27-11-2014 à 14:56:14
Marsh Posté le 27-11-2014 à 15:02:28
prout
The secret of happiness is not in doing what one likes but in liking what one has to do Sir James M. Barrie
Marsh Posté le 27-11-2014 à 15:04:33
Hop, 10,000 boss.
Marsh Posté le 27-11-2014 à 15:07:55
Drap.
Dread Knight lvl 6.
C'est looooong...
Marsh Posté le 27-11-2014 à 15:15:01
J'ai deux sessions :
- une à la K0GIP, level 114 avec 3 heroes souls ;
- une à la maison, level 144 avec une cinquantaine de HS et quelques anciens.
Cordialement,
Gil
Délégué Général Adjoint au pôle "Management des process systémiques par la Performance Communicationnelle et les Initiatives de Croissance Stratégique" de la COGIP Inc. | Consultant indépendant en stratégie d'OTT
Marsh Posté le 27-11-2014 à 15:17:44
gibbonaz a écrit :
Drap.
Dread Knight lvl 6.
C'est looooong...
Peux tu poster une copie d'écran de tes stats.
Marsh Posté le 27-11-2014 à 15:18:21
Ce topic permet de découvrir quelques lurkeurs d'OTT !
Marsh Posté le 27-11-2014 à 15:24:02
http://i.imgur.com/eYU9yUM.png
Marsh Posté le 27-11-2014 à 15:30:10
Ces stats !  :ouch:
Marsh Posté le 27-11-2014 à 15:32:13
Tu fais une ascension dès que ca bloque ou tu farmes pour aller le plus loin possible ?
Marsh Posté le 27-11-2014 à 15:36:53
Ca depend comme je le sens en fait... La derniere ascension que j'ai fait, j'étais au lvl ~340, ca mettait 3 plombes a passer un seul mob, du coup je suis allé voir le prochain boss, c'était pas un primal, j'ai fait fuck it, ascend.  [:fl4me]
J'avoue que le fait de garder des souls en stock accelere vachement la vitesse de progression, c'est pratiquement exponentiel.
Marsh Posté le 27-11-2014 à 15:38:27
Quel est l'interet de ne pas "dépenser" tes héros ?
Marsh Posté le 27-11-2014 à 15:39:47
1 héros soul = +10%dps.
Marsh Posté le 27-11-2014 à 15:39:49
Passe ta souris sur l'endroit ou ya marqué le nombre de héros souls que tu possedes :D
Marsh Posté le 27-11-2014 à 16:03:09
J'ai 2 héros et +13 ascend.
Ca va donner quoi à la prochaine ascension ?
+20% DPS ?
Marsh Posté le 27-11-2014 à 16:08:08
Tu auras 15 héros soul donc +150 dps
Marsh Posté le 27-11-2014 à 16:16:08
C'est superbe comme truc. :D
| Un malentendu du cul | boum boum ! | La roulette
Marsh Posté le 27-11-2014 à 16:20:11
 :D
Tu es quel lvl ?
1204 :o Mais j'avoue que ça fait presqu'un mois que j'ai la flemme de faire une ascension.... :D
http://reho.st/self/21f77402324bacfe989be44e89df7dec1033baaf.jpg
Marsh Posté le 27-11-2014 à 16:20:31
[:cerveau drapal]
Marsh Posté le 27-11-2014 à 16:31:19
putin je suis lvl 24 je comprends rien à ce que vous dites [:cerveau zytrasnif]
Marsh Posté le 27-11-2014 à 16:36:21
il y a moyen d'avoir un autofire sur le clic ?
Marsh Posté le 27-11-2014 à 16:37:28
Je pense oui, mais quitte a tricher je vois pas l'interet de continuer a jouer. :o
C'est un peu comme ceux qui installent des addons pour Cookie Clicker :/
Message édité par gibbonaz le 27-11-2014 à 16:37:47
Marsh Posté le 27-11-2014 à 16:38:54
http://reho.st/self/21f77402324bac [...] 33baaf.jpg
Impressionnant !  :ouch:
Cordialement,
Gil
