Pourriez vous me corriger cette exposé (english inside) svp ? :D
Pourriez vous me corriger cette exposé (english inside) svp ? :D - Vie pratique - Discussions
Marsh Posté le 26-11-2003 à 12:40:48
Voilà demain je dois passer à l'oral pour un exposé en anglais :sweat: (10min). J'ai choisi mon sujet qui est le wifi et j'ai écris un petit exposé. Cependant je pense qu'il y a au moins 50 fautes par mot :ouch:. Malgré mon accent pourrable je pense que la prof va entendre ces fautes  [:marteau] , c'est pourquoi j'aimerais que vous me corrigiez ce petit exposé.
Voici l'exposé :
The Wifi
1. What is it?
Wifi means Wireless Fidelity. It?s a network protocol. Indeed, Wifi be able to communicate with others computers or devices networks but wireless. For example, he can be used in the street, in a public building, in your car, trains and in future why not planes. The wifi technology uses the radio waves at a specific frequency.
In Wifi, we have ten standards: 802.11a, b, c, d, e, f, g, h, i and j. However, only 3 standards are used: a, b and g.
- 802.11a : it?s the less give off, he use the 5ghz frequency for communicate.
- 802.11b : it?s the more give off, he use the 2.4ghz frequency for communicate.
- 802.11g : it?s the future standard, he has the best rate.
2. How does that work?
In Wifi, there are 2 modes: ad hoc and infrastructure.
First mode, infrastructure. In this mode, computers and network devices communicate with only one network wifi device called access point. Access point manages traffic.
Second mode, ad-hoc. In this mode, computers and network communicate with all. There don?t have a device who manages traffic.
The Infrastructure mode is better but more expensive. Indeed, traffic is managed by one device so we can see who is on the network, we have a better rate than ad-hoc mode but we must buy an access point so that more expensive.
I will describe wifi devices and wifi software.
So, this is 2 wifi router. A wifi router is composed to a router and a access point. Router can be able to connect and share a network connection for example internet and access point can be able to access to the router from a wifi computer. This is a wifi card, she can be able to access to the router from a computer. This card is connected in a computer. However, there are others interfaces cards for example usb, pcmcia.
3. Range, Rate and Security
In this part, I will talk about only 802.11b and g because 802.11a is the less give off.
- Range :
In Wifi, the rate depends to distance and environment. We can see on the picture that the theoretical rate in function of distance. In black, it is the rate out of building, in green it?s the rate in a building without wall and in blue it?s the rate in building with wall. We can see that in theoretical the range is about 400 meters out of building and about 100 meters in building. However, this is a theoretical range, in practical the rangeis divided by 2 so 50m in building and 200m outside.
- Rate
For the 802.11b, the theoretical rate is 11megabits by second and for the 802.11g the theoretical rate is 54 megabits by second. However this rate depends to distance and environment and it is a theoretical rate.
Always on this picture we see that the rate compared with distance and environment. The rate isn?t very stable. Indeed, wifi use high frequencies and this are very sensitive to noise. So more is the distance is long more the signal is bad. We can see that the maximal rate is possible on a small distance. It?s a big inconvenient!
For 802.11g the maximal rating is shorter.
Moreover, on this picture this is a theoretical rate. In practice, the rate is about 60 percent of the theoretical.
- Security
A lot of firm would like install wifi network however for a firm security is very important. Indeed, wifi use frequencies and this propagates every where. So we will see the different ways to secure a wifi connection:
First, wep key. Wep key is a combination of characters. If this one is activate, to connect you to a wifi network you must enter the key. For a maximal security the key is long of 64, 128 or 256bits.
Second, filtering mac. Each network card has a address mac. This address is single in the world. So on the access point we can authorize or not an address mac to connect to the wifi network. This way is very efficient.
Third, we have the VPN. VPN means virtual network protocol. This one is very use to create a network connection on the web between to firm for example. To secure a wifi network we can use this way. This way is use by firms because is the hardest to hack.
Si vous avez des conseils je suis aussi preneur :)
Merci par avance de votre aide.  :hello:
Message édité par tomtom41 le 26-11-2003 à 12:41:04
Marsh Posté le 26-11-2003 à 13:31:50
Pas le courage de faire une correction, il y en a trop effectivement, je me contenterai de signaler "the less give off" qui ne veut rien dire du tout.
Par contre mon conseil, oui: ca aurait ete de ne pas jouer au pur geek en prenant un sujet a la noix qui n'interesse personne et que personne n'ecoutera, d'autant que c'est tro pdetaille pour le mec qui s'en fout et pas assez pour le mec que ca interesse.
Et puis tu rentres dans des details de normes etc, alors meme que tu passes sur les principes generaux en 1/2 ligne.
Bref, un sujet de geek mene comme par ungeek, sans vouloir t'offenser.
Tu aurais mieux fait de choisir un sujet sur la culture des arbres a Curly et ses synergies avec l'elevage de poissons volants, au moins tu aurais pu retenir l'attention du public en disant des conneries.
En bref: ne jamais prendre un sujet serieux dont tout le monde a vaguement entendu parler, surtout pour le traiter en 10mn et soit etre obscur soit ne rien apprendre a personne.
Toujours choisir un sujet en fonction de ce qui va interesser les gens.
En encore plus bref: c'est deja trop tard pour faire un expose interessant
Desole pour la critique
Marsh Posté le 26-11-2003 à 13:46:27
Bon, jme suis arrêté là, paske c un pti peu lourdingue à lire en effet... pi bon, ste fraze elle veut rien dire :)
Mais je te trouve sévère Greg avec lui... tout le monde ne peut pas avoir un gros niveau d'anglais... Tu sais même pas ni à quel niveau il est, ni ce ke lui a demandé le prof !!
Alors oui, c très scolaire, mais ya de la bonne volonté !! C structuré, ya plus ou moins les fameux "mots de liaison" pi on lui a pas demandé un exposé technik. C sur ke c pas avec ç kil va capter les foules... mais c pas ce kon lui demande non plus à mon avis. Bref, fo relativiser les exigences !
Marsh Posté le 26-11-2003 à 13:48:18
Je suis en gros d'accord mais bon c'est vrai qu'il y a trop de fautes, que ce soit des fautes de syntaxes ou même de sémantique :/
Profil Steam | Envie de faire un ptit cadeau original ? C'est par ici ! | Profil G+
Marsh Posté le 26-11-2003 à 13:51:04
Ben si on lui a demande unsujet technique,ok.
Mais s'il avait le choix, independamment de son niveau dont il n'est pas responsable et pour lequel je ne saurais le blamer (au passage, je vais relever une erreur par post: on ne dit pas 'he' pour le wifi mais 'it'), il n'aurait jamais du prendre un sujet technique. Ca n'interesse personne pour un expose de 10mn.
Et puis commencer par KeskeC? C'est un protocle reseau!, c'est top super, ca aide vachement.
Soi c'est du charabia total et le mec n'apprendra rien parce qu'il lui manque les bases quine sont pas fournies avec l'expose, soit le mec sait deja tout ce qu'il dit sauf peut-etre si le g est avant ou apres le b ce dont onse fout.
Mais il ne me viendrait pas a l'esprit de me moquer du faible niveau en anglais, ce n'est pas un choix et c'est pour ca qu'ilvient demander de l'aide, c'est tres comprehensible et respectable.
Marsh Posté le 26-11-2003 à 13:52:29
"Wifi be able to communicate with others computers or devices networks but wireless." ne veut rien dire
In the future why not in planes
Marsh Posté le 26-11-2003 à 14:02:56
comme te le répètent les profs jusqu'en maitrise :
il n'est pas souhaitable d'établir de correspondances directes et systèmatiques entre deux langues
sinon j'ai vu bien pire quand je donne des cours de soutien  :D
j'ai pas une grande envie d'essayer de le corriger, ptet passke le sujet ne m'emballe pas plus que ca...
Marsh Posté le 26-11-2003 à 14:17:11
J'ai édité pour quelques dernières retouches.
C'est sans doute loin d'être parfait, mais bon....
:sleep:
Voici l'exposé :
The Wifi
1. What is it?
Wifi means Wireless Fidelity. It?s a network protocol. Indeed, Wifi is able to communicate with others computers or devices networks using radio waves instead of cables. For example, he can be used in the street, in a public building, in your car, trains and even on planes in the future. The wifi technology uses the radio waves at a specific frequency.
In Wifi, there are ten standards: 802.11a, b, c, d, e, f, g, h, i and j. However, only 3 standards are used: a, b and g.
- 802.11a : it?s the less give off (???), it uses the 5ghz frequency to communicate.
- 802.11b : it?s the more give off, it uses the 2.4ghz frequency to communicate.
- 802.11g : it?s the future standard, it has the best rate.
2. How does WIFI work?
Wifi can be set on 2 modes: infrastructure and ad-hoc.
First mode, infrastructure. On this mode, computers and network devices communicate with only one network wifi device called access point. The Access point manages the traffic.
Second mode, ad-hoc. On this mode, computers and network communicate with all others. There isn?t a device to manage the traffic.
The Infrastructure mode is better but more expensive. Indeed, traffic is managed by one device so we can see who is on the network, and we have a better rate than with ad-hoc mode but we must buy an access point so it will be more expensive.
These are 2 wifi router. A wifi router is composed of a router and a access point. Routers are able to connect and share a network connection (for example internet) and access point is able to access to the router from a wifi computer. This is a wifi card, it is able to access to the router from a computer. This card is connected to a computer. However, there are others interfaces cards such as usb or pcmcia.
In this part, I will only talk about 802.11b and g because 802.11a is the less give off    ????.
- Range :
In Wifi, the rate depends on distance and environment. We can see on the picture that the theoretical rate in (is ?) function of distance. In black, it is the rate out of building, in green it?s the rate in a building without wall and in blue it?s the rate in building with walls. We can see that in theory the range is about 400 meters outdoors and about 100 meters indoors. However, this is a theoretical range, in practice the range_is divided by 2 so 50m in building and 200m outside. (200/2=50 ???)
- Rate
With a 802.11b, the theoretical rate is 11_megabits by second and 54 megabits by second with a 802.11g . However this rate depends on distance and environment and it is a theoretical rate (déjà dit).
We also see on this picture that the rate compared with distance and environment. The rate isn?t very stable. Indeed, wifi uses high frequencies which are very sensitive to noise. Therefore, longer is the distance worse is the signal. We can see that the highiest rate is only possible on a small distance. It?s a major drawback!
For 802.11g the highiest rate is shorter.
Furthermore, on this picture this is a theoretical rate. In practice, the rate is about 60 percent of the theoretical.
- Security
Many firms would like to install wifi network. However security is very important <-> for a firm. Indeed, wifi uses frequencies and they propagates without limit. So we will see the different ways to secure a wifi connection:
Firstly, wep key. Wep key is a combination of characters. If this one is activated, you must enter the key <-> to access you to a wifi network. For maximum security, the key should be 64, 128 or 256 bits long.
Secondly, filtering mac. Each network card has a mac address. This address is unique. So on the access point we can authorize or not a mac address to connect to the wifi network. This way is most efficient.
Thirdly, we have the VPN. VPN means virtual network protocol. This one is often used to create a network connection on the web between to firms for example. To secure a wifi network we can use this way (inutile). This way is use by firms because it is the hardest to hack.
Message édité par NINOH le 26-11-2003 à 14:29:26
Marsh Posté le 26-11-2003 à 14:40:30
correction de la correction:
"Therefore, longer is the distance worse is the signal. We can see that the highiest rate is only possible on a small distance. It?s a major drawback!
For 802.11g the highiest rate is shorter."
The longer the distance, the worse the signal, et pas ce qui est ci-dessus.
Highest ne s'ecrit pas highiest
Et pas small distance mais short distance.
enfin, "the highest rate is shorter" ne veut rien dire.
Par ailleurs, il reste que cet expose n'a pas de sens.
Ne serait-ce qu'un autre exemple, la securite: tu parles de comment securiser, tu n'as meme pas expose le probleme. Tu crois que qqn qui a besoin d'un tel expose fait automatiquement le lien entre propagation des ondes et absence de securite?
Et il y a un bon gros paque t de points comme ca, il y a un nombre de raccourcis hallucinants qui font que personne qui ne sait pas deja tout ce que tu dis ne peut comprendre.
En plus, toujours dans la securite, tu donnes trois options sans jamais citer le mot cryptage, sans parler de ce qu'elles ont de commun qui est le principal, sans expliquer ce que signifient les differences, bref, on dirait un copier coller de morceaux de phrases du web.
Relis toi: en gros tu dis:
Il faut securiser parce que les ondes se propagent. Pour ca on peut entrer une cle de 64, 128 ou 256 bits, ou alors utilise rune limitation mac, ou bien faire un VPN, et c'est ca le mieux.
Vachment interessant. C'est du vent, il n'y a aucune teneur en information la-dedans, et en plus, tu as meme tendance a faire croire n'importe quoi a celui qui ecoute. En plus, bravo VPN qui d'apres toi veut dire virtual network protocol...
Franchement, reprend tout a zero, ca serait mieux.
Marsh Posté le 26-11-2003 à 14:41:47
D'ailleurs, c'est facile, lis ca en francais a ta mere ou a n'importe qui qui n'y connait rien, et demande lui un resume apres.
Tu vas voir qu'il n'y aura RIEN qui aura ete integre, rien de chez rien.
