Différentes MSI GTX 960. Quelles différences ? - Carte graphique - Hardware
Marsh Posté le 25-02-2015 à 16:27:48
Les 2 premières sont identiques.
La 3eme propose des fréquences moins élevée en sortie de boite, mais cela ne présage rien quant au potentiel d'overcloking de chaque carte.
Marsh Posté le 25-02-2015 à 16:38:27
http://thepcenthusiast.com/msi-gtx [...] -released/
Citation : MSI recently announced their line of the GeForce GTX 960 graphics card. They announced four different models namely: MSI GTX 960 100 Million Edition, MSI GTX 960 Gaming 2G, MSI GTX 960 Overclocked (White) and the MSI GTX 960 2GD5 OC (Vanilla). Each model differs in clock speeds and cooler design. The Gaming and 100 Million Edition features the new Twin Frozr V with Zero Frozr technology and Torx Fan design, while the GTX 960 2GD5T OC features the Armor 2X cooler. All model features 1024 CUDA cores with 2GB of GDDR5 memory running on a 128-bit memory interface. Check out their features, respective specifications, prices and availability below. |
Twin Frozr V Thermal Design
Citation : The new MSI twin Frozr V Thermal Design is the pinnacle of graphics card air cooling. With a smaller than 2-slot design the new Twin Frozr V is able to surpass previous generation’s by a large margin. The new 10cm Torx fans ensure huge amounts of silent airflow and visually complete the bold new look of the Twin Frozr V. The heatsink itself is re-organized through the SuperSU design which increases heatpipe efficiency, especially when combined with Airflow Control Technology. Hybrid Frozr is a throwback to 2008 when MSI was the first to market high-end, zero noise graphics cards thanks to fans that stop spinning in low-temperature situations. |
Armor 2X Thermal Design
Citation : Meanwhile the MSI GTX 960 2GD5T OC, or Overclocked edition, features the Armor 2X thermal design – an all new Black & White cooler design to fit the design of MSI’s Krait series motherboards. Its propeller blade technology produce 20% more airflow compared to traditional fan design, as well as less noise. It also features airflow control technology that deflects more airflow to heatpipes and improves airflow efficiency. It also increases the heatsink area to enhance dissipation efficiency. |
Twin Frozr V with Zero Frozr technology and Torx Fan design vs. Armor 2X cooler
C'est lequel le mieux du coup ?
Marsh Posté le 25-02-2015 à 16:42:45
Sans doutes 1db et 1 degré ...
Prend la moins cher des deux.
Marsh Posté le 25-02-2015 à 16:44:06
Mini_BN a écrit : Sans doutes 1db et 1 degré ... |
L'épaisseur supplémentaire risque aussi d'empiéter sur un 3ème slot peut-être ?
Marsh Posté le 25-02-2015 à 17:06:23
Je pense qu'il s'agit de la zero frozr, j'avais cru comprendre qu'elle avait un meilleur refroidissement.
Marsh Posté le 25-02-2015 à 17:56:04
Mini_BN a écrit : Les 2 premières sont identiques. |
Tu inverse c'est la première qui différ.
Marsh Posté le 25-02-2015 à 18:54:59
en gros la gaming et la gaming million edition : tu a le systeme de ventilo twin frozen, qui est pas mal puisque en bureautique la carte devient fanless (les ventilo s'arretent), la million édition est une édition limité, elle est plus lourde car elle a une backplate, c'est une plaque en alu au dos de la carte graphique qui la rend plus jolie et plus solide (elle se plie moins) par contre pour le prix autant prendre la gaming, l'autre a un autre ventilo msi, si le bruit n'est pas un soucis pour toi tu peut la prendre, en l'overclockant tu arrivera facilement au meme niveau que la gaming
Marsh Posté le 25-02-2015 à 15:48:55
Je ne comprends pas bien les différences entres les différentes versions de GTX 960 chez MSI. En particulier ces 3 là :
- 2GD5T OC : http://www.msi.com/product/vga/GTX [...] o-overview
- Gaming 2G : http://www.msi.com/product/vga/GTX [...] o-overview
- Gaming 100 Million Edition : http://www.msi.com/product/vga/GTX [...] o-overview
Voici un tableau comparatif :
https://www.dropbox.com/s/yhk9uannl [...] n.png?dl=0
Certaines n'ont que leur DIMENSIONS qui diffèrent ??
merci pour vos lumières
A/V/E
