je trouve que j'ai une bonne perf sous 3D mark 2001 SE - Carte graphique - Hardware
Marsh Posté le 10-12-2002 à 11:47:29
1) spa mal pour un proco de merde
2) tu sors.
Marsh Posté le 10-12-2002 à 11:50:58
en 800x600 et en 16b ?
Marsh Posté le 10-12-2002 à 11:53:00
ce n'est pas de l'autosatisfaction!
c'est de l'étonnement
comparé aux configs de "zonebench"
je constate que ma config n'est pas si mauvaise
Marsh Posté le 10-12-2002 à 11:55:21
"en 800x600X 16"
non !
3DMARK2001 PROJECT FILE
PROJECT
Name My Benchmark
Description
Registration Name
Registration Key
3DMark Version 300
DISPLAY
Platform NVIDIA GeForce4 Ti 4200
CPU Optimization D3D Pure Hardware T&L
Width 1024
Height 768
Depth 32 bit
Z-Buffering 24 bit
Texture Format Compressed
Buffering Double
Refresh Rate 60 Hz
FSAA Mode None
OPTIONS
Show Title Screens Yes
Continuous Benchmark No
Benchmark Run Count 1
Demo Sounds Enabled Yes
Continuous Demo No
Game Sound Effects Enabled Yes
Game Music Enabled Yes
Game Detail Level Low
RESULTS
3DMark Score 9309
Game 1 - Car Chase - Low Detail 130.0 fps
Game 1 - Car Chase - High Detail 42.7 fps
Game 2 - Dragothic - Low Detail 173.5 fps
Game 2 - Dragothic - High Detail 95.6 fps
Game 3 - Lobby - Low Detail 119.4 fps
Game 3 - Lobby - High Detail 53.0 fps
Game 4 - Nature 62.7 fps
Fill Rate (Single-Texturing) 887.9 MTexels/s
Fill Rate (Multi-Texturing) 1931.8 MTexels/s
High Polygon Count (1 Light) 44.9 MTriangles/s
High Polygon Count (8 Lights) 10.4 MTriangles/s
Environment Bump Mapping 89.8 fps
DOT3 Bump Mapping 122.6 fps
Vertex Shader 82.3 fps
Pixel Shader 101.0 fps
Advanced Pixel Shader 81.4 fps
Point Sprites 26.1 MSprites/s
SYSTEM INFO
System Info Version 2.2
Installation ID 0x00000000
OEM ID
CPU INFO
CENTRAL PROCESSING UNITS
Manufacturer AMD
Family AMD Athlon(TM) XP1600+
Internal Clock 1.39 GHz
Internal Clock Maximum 1.39 GHz
External Clock 133 MHz
Socket Designation SOCKET A
Type Central
Upgrade <unknown>
Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE
Version Modèle 6, niveau 2
CPUID 0x00000662
CACHES
Level 1
Capacity 128 KB
Type <unknown>
Type Details <unknown>
Error Correction Type <unknown>
Associativity <unknown>
Level 2
Capacity 256 KB
Type <unknown>
DIRECTX INFO
DirectX Version 8.1
DIRECTDRAW INFO
DirectDraw Version 5.1.2600.1106
DISPLAY DEVICES
Description Pilote d'affichage principal
Manufacturer NVIDIA
Name NVIDIA GeForce4 Ti 4200
Total Local Video Memory 64 MB
Total Local Texture Memory 64 MB
Total AGP Memory 126 MB
Display Driver nv4_disp.dll
Display Driver Version 6.13.10.4072
Driver WHQL Certified Yes
Max Texture Width 4096
Max Texture Height 4096
Max User Clipping Planes 0
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Textures In Single Pass 4
Vertex Shader Version 1.1
Pixel Shader Version 1.3
Max Vertex Blend Matrices 0
Max Texture Coordinates 8
Vendor ID 0x10de
Device ID 0x0253
Sub-System ID 0x013210de
Revision 0xa3
MEMORY INFO
Total Physical Memory 512 MB
Free Physical Memory 366.49 MB
Total Pagefile Memory 1.22 GB
Free Pagefile Memory 1.11 GB
MEMORY ARRAYS
Max Module Capacity 512 MB
Location <unknown>
Use <unknown>
Supported Error D&C <unknown>
Supported Speeds <unknown>
Supported Types <unknown>
Supported Voltages <unknown>
MEMORY SLOTS
Installed & Enabled Size 256 MB
Form Factor DIMM
Frequency 0 Hz
Slot DDR 1
Manufacturer <unknown>
Type <unknown>
Enabled Size 256 MB
Total Bit Width 72
Data Bit Width 0
Form Factor DIMM
Frequency 0 Hz
Slot DDR 2
Type <unknown>
Enabled Size 256 MB
Total Bit Width 72
Data Bit Width 0
MOTHERBOARD INFO
Manufacturer ASUSTeK Computer INC.
Model A7A266-E
Version REV 1.xx
BIOS Vendor Award Software, Inc.
BIOS Version ASUS - 42302e31
BIOS Release Date 25/02/02
BIOS Properties Plug and Play, Flash, AGP
OPERATING SYSTEM INFO
Operating System Microsoft Windows XP
Version 5.1.2600
Service Pack Service Pack 1
Locale FR
Desktop Width 1024
Desktop Height 768
Desktop BPP 32
Marsh Posté le 10-12-2002 à 11:55:22
ben tu es bien reglé tes 512 et ta gf4 suffisent en fait pour ce resultat tu es limité par ton proc qui traine un peu par rapport à ta cg
Marsh Posté le 10-12-2002 à 11:59:03
tableix a écrit : ben tu es bien reglé tes 512 et ta gf4 suffisent en fait pour ce resultat tu es limité par ton proc qui traine un peu par rapport à ta cg |
Et oui c'est tout.
avec un xp 2000 mon pote fait du 10500 avec une conf similaire dc ton score est logique.
Marsh Posté le 10-12-2002 à 12:02:31
damon19 a écrit : |
jfais environ 10100 avec un xp1700+
Marsh Posté le 10-12-2002 à 11:29:16
Pour mon matos
Operating System: Microsoft Windows XP
Processor: AMD AMD Athlon(TM) XP1600+ @ 1.38 GHz
Graphics Card: PNY GeForce4 Ti 4200 non o/C (250/513)
Total Physical Memory: 512 MB pc 2100
Motherboard Manufacturer: ASUSTeK Computer INC.
Motherboard Model: A7A266-E
resultat 9309 sans O/C proc ni o/c CG
votre avis?
c'est quoi le point fort de ma config?
