Vos avis "Silverstone SST-ST1000-P Strider Plus"
Vos avis "Silverstone SST-ST1000-P Strider Plus" - Alimentation - Hardware
Marsh Posté le 03-06-2012 à 16:44:03
j'aimerai vos avis sur cette alimentation : Silverstone SST-ST1000-P Strider Plus
http://www.silverstonetek.com/images/products/st1000-p/ST1000-P-3-4.jpg
http://www.silverstonetek.com/images/products/st1000-p/ST1000-P-FRONT.jpg
http://www.silverstonetek.com/images/products/st1000-p/ST1000-P-BACK.jpg
http://www.silverstonetek.com/images/products/st1000-p/ST1000-P-INSIDE.jpg
http://i.ebayimg.com/15/!B8M3elgBmk~$(KGrHqR,!mEEy+jC)91gBM2YtLqelg~~0_35.JPG
Model No.
SST-ST1000-P
Max. DC Output
1000W(Peak 1100W)
Load Range
+3.3V +5V +12V1 +12V2 +12V3 +12V4 +5VSB -12V -5V
Max.(Amps)
30A 30A 80A / / / 3.5A 0.3A /
Peak (Amps)
/ / 85A / / / / / /
Min.(Amps)
0A 0.5A 0.1A / / / 0.1A 0A /
Range (%)
±3% ±3% ±3% / / / ±5% ±10% /
Line Reg.(%)
±1% ±1% ±1% / / / ±1% ±1% /
Ripple(mVp-p)
50mV 50mV 120mV / / / 50mV 120mV /
combined +3.3, +5V
180W
combined +12V
960W/80A(Peak 85A)
Input Voltage
90V~264V
Input Frequency Range
47Hz~63Hz
PFC
Active PFC(PF>0.95 at full load)
Efficiency
85%~88%(20% to 100% loading)
MTBF
100,000 hours at 25°C, full load
Operating temperature
0°C ~ 40°C
Protection
Over current protection
Over power protection
Over voltage protection
Under voltage protection
Over temperature protection
Short circuit protection
No load protection
Connectors
1 x 24 / 20-Pin motherboard connector(550mm)
1 x 8 / 4-Pin EPS / ATX 12V connector(750mm)
1 x 8 / 4-Pin EPS / ATX 12V connector(550mm)
4 x 8/6-Pin PCIE connector(550mm)
2 x 6-Pin PCIE connector(550mm / 150mm)
6 x SATA connector(500mm / 250mm / 250mm)
6 x 4-Pin Peripheral connector (500mm / 250mm / 250mm)
2 x 4-Pin Floppy connector(500mm / 250mm / 250mm / 150mm)
Color
Black(Lead-Free Paint)
Cooling System
Silent 135mm fan
Noise Level
19dBA-36dBA
Dimension
150 mm (W) x 86 mm (H) x 160 mm (D)
Weight
3 kg
Form factor
ATX PS/2
Certification
80 PLUS Silver
Other
GPU Support list
Merci !!!
"Il vaut mieux être un raté intelligent , plutôt qu'un con efficace"
Marsh Posté le 03-06-2012 à 17:57:10
Salut! Le mieux selon moi c'est que tu lises cet article. Pour moi c'est le meilleur site concernant les tests PSU!
http://www.jonnyguru.com/modules.p [...] y&reid=180
Intel Core i7 2600K / Corsair H60 / Asus P8P67 Deluxe / Asus GTX 580 DirectCUII / Corsair Vengeance 1866 MHz 2x4 Go CAS9 / NZXT Phantom rouge et blanc / Seasonic X-850 / Corsair Force Series GT 240 Go / Western Digital Caviar Blue 1 To SATA III / Lite-On
Marsh Posté le 03-06-2012 à 19:58:58
Merci pour ce teste :P Je n'ai trouvais pas pour ce modèle là.
Apparemment les rails 3.3v et 5v oscille beaucoup ... Je vais donc allé sur ma première intuition : la CoolerMaster Silent Pro Gold 1000w :)
Marsh Posté le 05-06-2012 à 11:41:45
le 3.3v et le 5v sont peu utilisés de nos jours , la CM SPG par contre niveau ripple pour le 12v ça sux
