Alimentations Fanless [Pré- Topic Unique] - Alimentation - Hardware
Marsh Posté le 12-11-2004 à 21:31:41
A. ALIMENTATIONS FANLESS
1. ANTEC Phantom 350
Features:
* Special Features:
* 350 Watts ATX12V2.0
* Fanless design ensures absolutely silent operation
* Ultra-high-efficiency circuitry (at least 85% efficiency at full load) saves energy and reduces heat
* Extruded aluminum casing is directly attached to internal heatsinks, for maximum heat dispersion
* Dedicated output circuits for each voltage eliminate combined-output limitations
* Advanced voltage-feedback circuitry provides maximum system stability by ensuring accurate power delivery
* Dual +12V output circuits provide server-quality power
* 2 SATA connectors to power Serial ATA drives
* Server-grade protection features ensure maximum reliability. Includes over-temperature, over-voltage, over-current, over-power, short-circuit and under-voltage protection
* Gold-plated connectors for superior conductivity
* ATX12V v2.0 compliant compatible with current and newest generation of motherboards
* AQ3 Antec's unbeatable 3-year parts and labor warranty
Lien officiel : http://www.antec.com/us/productDet [...] odID=24350
Tests : http://www.silentpcreview.com/article188-page1.html
Etasis EFN-300
Silentmaxx proSilence Fanless 350
Test : http://www.silentpcreview.com/modu [...] =90&page=1
Silentmaxx proSilence Fanless Pro 420
Silentmaxx proSilence Fanless Pro 423 PCS
Silentmaxx proSilence Fanless Pro 503 CPC
SilverStone SST-ST30NF
Yesico Fanless Power Supply 350W
Yesico Fanless Power Supply 350W TMS
Yesico Fanless Power Supply 420W
Yesico Fanless Power Supply 420W TMS
Yesico Fanless Power Supply 450W TMS
B. ALIMENTATIONS WATERCOOLEES
Alphacool Alimentation ProSilence 350W
Alphacool Alimentation ProSilence 450W
Comparatif de plusieurs modèles :
http://www.cooling-masters.com/art [...] =25&page=0
Marsh Posté le 12-11-2004 à 21:54:11
great topic !!! si tu as les prix peux tu les editer ? ca pourrait etre genial pour avoir une fourchette approximative
merci!!
Marsh Posté le 12-11-2004 à 21:59:42
morb a écrit : great topic !!! si tu as les prix peux tu les editer ? ca pourrait etre genial pour avoir une fourchette approximative |
T'inquiète, je vais mettre toutes les infos ce week-end...
Marsh Posté le 12-11-2004 à 22:06:46
minou a écrit : T'inquiète, je vais mettre toutes les infos ce week-end... |
je vais suivre ca avec attention
Marsh Posté le 13-11-2004 à 13:21:59
morb a écrit : je vais suivre ca avec attention |
J'espère que tu ne seras pas le seul...
D'ailleurs si vous avez des infos, liens, tests, avis... Je suis preneur....
Marsh Posté le 13-11-2004 à 13:25:12
Salut, chouette idée ce topic, surtout que j'envisage l'achat d'une Yesico 420TMS mais comme beaucoup de monde je me pose des questions sur la durée de vie
Et surtout j'ai pas beaucoup vu d'impression des possesseurs de ce type d'alimentation.
Sinon voici :
-une thermaltake : http://www.teschke.de/heatpipes/Ne [...] power.html
-une coolmax :
http://www.extremereviews.net/data [...] ype=review
Marsh Posté le 15-11-2004 à 20:52:01
http://www.pc-look.com/boutik/Silentmaxx.html
quelques alims silentmaxx je n'en possede pas donc je n'emetra pas d'avis objectif
Marsh Posté le 17-11-2004 à 16:14:34
moi j'ai une Yesico 450 W qui fonctionne très bien mais que je veux quand même vendre et je vous explique pourquoi : cette alimentation chauffe, ce qui est normal dans son fonctionnement c'est de l'alu et si les composant peuvent être refroidi c'est parce que l'alim chauffe (les parties métalliques extérieur et le radiateur derrière). Donc je ne suis pas trop inquiet de la durée de vie, mais ce qui me pose problème c'est que j'ai supprimé tous les ventilateurs de ma tour et qu'il est conseillé avec ce type d'alim de conserver au moins un système de refroidissement de l'intérieur de la tour. Comme j'ai un reserator Zalman, je veux acheter un alim watercoolée pour remplacer la yesico, pour l'instant j'ouvre ma tour pour équilibrer la température (surtout que j'ai aussi un radiateur passif sur le chipset qui chauffe pas mal aussi...).
Donc pour conclure, je conseille ces alims sans problème mais en conservant quand même un ventilo 12 cm par exemple en évacuation de la chaleur dans la tour. C'est une alternative interessante au watercooling complet (mais un pau cher je trouve). Au fait je vends ma yesico à 145 euros (facture 29 aout 2004). Bonne continuation !!
Marsh Posté le 17-11-2004 à 16:15:56
par contre je cherche l'Alphacool Alimentation ProSilence 350W à un bon prix !!
Marsh Posté le 21-11-2004 à 23:52:22
Salut à tous,
Il manque une alim dans le topic :
- Thermaltake Silent PurePower Series Fanless 350W : http://www.1000ordi.fr/pics/thermaltake/w0050.jpg
Marsh Posté le 22-11-2004 à 20:40:04
J'adhère
Certainement un de mes prochains achats
Si seulement c'était un poil moins cher
Ah aussi,
Si jamais ton topic se complète, essaie de donner à chaque fois les ampérages disponibles pour le 3.3, 5 et 12V
Il y a vraiment beaucoup de différences entre ces alims fanless.
Tu pourrais meme donner des valeurs de référence
Enfin, c'est juste une idée
Ainsi, on voit que la Silentmaxx 350 est relativement ridicule...
PS : Tiens, salut avoid002
Marsh Posté le 24-11-2004 à 11:42:35
Salut !
Un p'tit up parce que je vais me prendre la Silentmaxx - proSilence Fanless-W 450 (Watercoolée), je vous dirais ce que j'en pense à l'occasion.
Marsh Posté le 24-11-2004 à 12:12:29
Y'en a une d'occas sur Nokytech en ce mooment à 150 fdpin
Marsh Posté le 25-11-2004 à 23:04:45
Alors minou??
On abandonne cette idée?
Marsh Posté le 26-11-2004 à 19:11:40
Bon j'ai commandé ma Yesico 420TMS aujourd'hui et je la reçoit mercredi je mettrais un max de photos (intérieur compris si possible) et mes premières impressions...
MINOU revient!!
Marsh Posté le 28-11-2004 à 08:45:20
Je n'ai pas eu de connexion pdt 2 semaines...
J'essaye d'updater tout ça le WE prochain...
Poster vos liens, vos impressions...
Marsh Posté le 29-11-2004 à 06:45:17
avoid002 a écrit : moi j'ai une Yesico 450 W qui fonctionne très bien mais que je veux quand même vendre et je vous explique pourquoi : cette alimentation chauffe, ce qui est normal dans son fonctionnement c'est de l'alu et si les composant peuvent être refroidi c'est parce que l'alim chauffe (les parties métalliques extérieur et le radiateur derrière). Donc je ne suis pas trop inquiet de la durée de vie, mais ce qui me pose problème c'est que j'ai supprimé tous les ventilateurs de ma tour et qu'il est conseillé avec ce type d'alim de conserver au moins un système de refroidissement de l'intérieur de la tour. Comme j'ai un reserator Zalman, je veux acheter un alim watercoolée pour remplacer la yesico, pour l'instant j'ouvre ma tour pour équilibrer la température (surtout que j'ai aussi un radiateur passif sur le chipset qui chauffe pas mal aussi...). |
Marsh Posté le 29-11-2004 à 06:50:09
Cette alim chauffe tant que cela ?
C'est pour un PC de Salon, mais je pensais la mettre hors du PC !
Sinon elle est toujors à vendre ?
Amitiés
Eric DELEGRANGE
Marsh Posté le 29-11-2004 à 23:54:37
J'ai quand même une question à poser.
Je compte prendre la Yessico 350w TMS.
On peut la trouver a 190 a Montgallet, mais surtout a environ 172 euro a commander sur un site internet avec frais de port.
Je me demande quand même si cette 350w sera pas juste.
J'explique la configue a utiliser avec :
- Carte mere ASUS ché pu koi SOcket 939
- Processeur AMD Athlon 64 3500+
- 2x512 DR PC 3200 SAMSUNG
- Carte graphique Nvidia GeForce 6600GT AGP
- 1 SEULE et UNIKE DISKE DUR 120 GIGA IBM 8mo CACHE
- Lecteur DVD et graveur DVD
- Regulateur de ventilation aerogate 2 sur lekel seront branchés 3 voir 4 ventilos 120 mm tournant a 7v.
- Proc et carte graphique refroidit par watercooling.
Je pense que acheter une 420w dans mon cas serait mettre bcp trop dargent pour kkchose ke ne nexploiterais pas. Même si j'oc (passer mon 3500+ a 2400mhz) sera pas nan plus énorme.
Qu'en pensez vous ?
Pour ce qui est de la ventilation, je possède 2 ventilos 120mm tournant a environ 7v (entre 800 et 900rpm). L'un est situé a l'avant ki fait rentrer l'air dans le boitier, et l'autre derriere ki rejette l'air du boitier. Il n'y aura aucun ventilo vu que j'utiliserais le watercooling, l'air chaud ne s'accumulera donc pas, et je pense donc ke cette alimentation Yessico pourra vivre en paix... Parce-que autrement j'ai pensé a m'acheter un ventilo 80mm Noiserblocker ke je fixererais à l'intérieur devant des trous de lalime, je le ferait tourner de maniere inaudible et ce qui permettrais de rechauffer un peu l'alime...
J'ai pas bcp confiance c'est vrai lol. Dites moi si avec 2 ventilos 120mm tournant tres lentement ce sera suffisament ventilé ? Et si cette puissance me suffira.
Mat
Marsh Posté le 29-11-2004 à 23:57:05
oulala jsuis fatigué, je voulais dire kil n'y aura aucun VENTILO INTERNE dans le boitier, donc proc et carte graphike, mais les ventilos ki font rentrer et ressortir l'air je les garde lol ^^
Et autrmeent je voulais pas dire rechauffer l'air, mais refroidir l'air, mais ca tt le monde a compris lol
Mat
Marsh Posté le 30-11-2004 à 00:02:37
pour la consomation en watt regarde sur ce lien pour te faire une idée (leur chiffres étant largement surélevés pour les hd entre autre)
http://www.jscustompcs.com/power_supply/
Par conte avec ce genre d'alimentation il vaut quand même mieux garder un ventilo pour le boitier en extraction... histoire qu'il y ai quand même un renouvellement de l'air à l'intérieur.
Donc malgré ton watercooling je mettrais un 120mm@5v (ou 7v).
Marsh Posté le 30-11-2004 à 00:10:07
Matrex7 a écrit : |
Euh, regarde sur PC-look
Il y a une promotion jusqu'au 30 novembre sur la 420W à 175...
Marsh Posté le 30-11-2004 à 00:17:43
Gum a écrit : Euh, regarde sur PC-look |
C'est intéressant mais ce n'est pas le modèle tms.
Marsh Posté le 30-11-2004 à 23:51:49
Rhodi a écrit : Salut, |
Oui mais mais je dit justement que je conte garder mes 2 ventilos 120 mm, celui de lavant ki fait rentrer de l'air, et celui de derriere ki le rejette, c'est obliger de toute facon pour refroidire mon radiateur watercooling. Donc 2 ventilos 120 mm ce serait nickel...
Marsh Posté le 02-12-2004 à 23:44:58
Alors voià je l'ai enfin
Yesico 420w tms.
Le tms étant un cable 12v sortant directement de l'alimentation pour connecter un ventilo dessus qui se met en route si l'alimentation touche les 60°c.
Alors j'avais fait plein de photos mais comme mon apareil est nouveau... et que je le connais pas encore très bien... je les aie presque toutes ratées
Mais bon :
Les photos :
Sortie de la boite : un beau package avec plein de connectiques
La bête déployée, magnifique, cables très longs et TOUS gainés
Une fois montée de derrière, ça passe sans aucuns problèmes elle est du même gabarit que mon ancienne antec
Le pack comprend 4 visses et 3 plastics blanc d'attache que l'on voit ici (je connais pas le nom exact)
Maitenant des graphiques pour les tensions sous occt (sans o/c)
12v
3v
5v
Evidement AUCUN bruit, silence TOTAL ce qui m'a permis de constater que c'était mon ventilo du proc qui fait un boucant d'enfer et pas mon ancienne alim
Le rad à l'arrière, après une dizaine d'heures alumé, n'est pas spécialement chaud comme certain le laissait entendre.
Bref, pour l'instant, je suis comblé par cette alimentation, la finition et qualité générale qu'elle montre est grandement suppérieur à toute les alimentations que j'ai eu et pu voir.
Les cables tous gainés, une multitude de connectique,... terrible.
Seul bémol : pas de fiche 7v pour brancher les ventilos du pc, mais c'est vraiment pour redire quelque chose
Marsh Posté le 03-12-2004 à 13:42:21
c'est le boitier sonata que tu as ?
Marsh Posté le 06-01-2005 à 12:00:34
Alors? c'est le Sonata ou pas? j'ai le Sonata et cette alim m'intéresse...
Tu peux donner plus d'infos sur ton expérience avec l'alim?
Rythier
Marsh Posté le 06-01-2005 à 13:53:09
Il y'a un bon tests d'alimentations fanless sur materiel.be (matbe.com), ou il est conclut que la silverstone et l'etasis sont identiques (meme usine) sauf pour le rad qui dépasse à l'arriere sur l'étasis, et que les yesico et silentmaxx sont bien cacateuses malgré leur puissance "sur le papier" qui ne sont pas là en pratique (alors qu'une 300w silverstone tiens nickel sur des grosses configurations)
Pour les alimentations, y'a 400w et 400w
Marsh Posté le 06-01-2005 à 23:21:50
Moi je sens que je vais craquer pour l'Etasis aprés avoir hesiter pour l'Antec Phantom....Elle consomme trés peu, stable en fluctuation et solide.
Marsh Posté le 09-01-2005 à 18:38:36
cool ce topic, quelle est selon vous la meilleure des alims fanless (non WC) avec prises sata, et connecteur 6pin pour pci-express ?
Merci pour le tuyau
Marsh Posté le 09-01-2005 à 18:58:16
Pour les photos, je vois pas l'intéret de payer 180 une alim fanless alors qu'on a un 80mm sur le proc et un 120mm sur le boitier
Marsh Posté le 09-01-2005 à 19:02:19
sur le proc c un 92 il me semble.....
moi j'ai un SE2 sur le proc et 2 papst80 sur le boitier qd je bloque le ventilo de l'alim on entend rien et je suis pas sourd
Marsh Posté le 09-01-2005 à 19:28:26
oui mais c'est parce que tu as un 80mm sur l'alim, sur la face visible de l'exterieur, car un 120mm silencieux sur la face interieur ca s'entends moins qu'un ventilo de proc
Marsh Posté le 09-01-2005 à 20:07:04
hs mode on
au fait pourquoi ce pseudo ? t'as qqchoseà voir avec le milieu pharmaceutqiue ?
hs mode off
merci pour tes précisions
Marsh Posté le 10-01-2005 à 01:13:32
Non aucun rapport, y'a des années c'était le pseudo de mon frere, mais comme c'est moi qui le squattait tout le temps il me l'a laissé et en a pris un autre (sam_barton)
Marsh Posté le 12-11-2004 à 21:31:31
En faisant une recherche, je n'ai pas trouvé de topic qui puisse rassembler les possesseurs ou futurs acquéreurs d'alim Fanless (sans ventilo ou watercoolées...)
Chaque mois, de nouveaux modèles sortent, et le choix devient difficiles... Je vais essayer de rassemnbler ici toutes les caractéristiques de ces alim et les tests parus sur le Net... (dans le week-end)...
J'espère que ce sujet vous intéresse, et que les possesseurs de telles alim viendront donner leur avis...
...voit le mieux le mur. Vente matos
