Thermaltake vient d'annoncer son nouveau boitier "ultime". Le Core V71 !
Model Core V71 P/N CA-1B6-00F1WN-00 Case Type Full Tower Dimension (H x W x D) 583 x 230 x 560 mm (23 x 9.1 x 22 inch)
Net Weight 13.2 kg
Side Panel Transparent Window Color Exterior & Interior : Black Material SPCC Cooling System Front (intake) : 200 x 200 x 30 mm Blue LED fan (600~800rpm, 13~15dBA) x 2 Rear (exhaust) : 140 x 140 x 25 mm Turbo fan (1000rpm, 16dBA) Top (exhaust) : 200 x 200 x 30 mm Blue LED fan (600~800rpm, 13~15dBA)
Drive Bays -Accessible : 2 x 5.25’’ - Hidden : 8 x 3.5’’ or 8 x 2.5’’
Expansion Slots 8 Motherboards 9.6” x 9.6” (Micro ATX), 12” x 9.6” (ATX), 12” x 13” (Extend ATX) I/O Port USB 3.0 x 2,USB 2.0 x 2, HD Audio x 1 PSU Standard PS2 PSU (optional) LCS Upgradable Supports 1/2”、3/8”、1/4” water tube
Fan Support Front: - 1 x 120mm or 2 x 120mm or 3 x 120mm - 1 x 140mm or 2 x 140mm - 1 x 200mm or 2 x 200mm
Top: - 1 x 120mm or 2 x 120mm or 3 x 120mm - 1 x 140mm or 2 x 140mm - 1 x 200mm or 2 x 200mm
Rear: - 1 x 120mm or 1 x 140mm
Bottom: - 1 x 120mm or 2 x 120mm
Radiator Support Front: - 1 x 120mm or 1 x 240mm or 1 x 360mm - 1 x 140mm or 1 x 280mm or 1 x 420mm
Top: - 1 x 120mm or 1 x 240mm or 1 x 360mm - 1 x 140mm or 1 x 280mm or 1 x 420mm
Marsh Posté le 20-01-2014 à 02:59:57
Model Core V71
Net Weight 13.2 kg
Material SPCC
Expansion Slots 8
Fan Support Front:
Top:
Rear:
Bottom:
Top:
Rear:
- 1 x 120mm
Bottom:
Other CPU cooler height limitation:
- 185mm
VGA length limitation:
- 310mm (with HDD rack)
- 400mm (without HDD rack)
http://www.thermaltake.com/product [...] C_00002231
