Carte d'acquisition (ADS Tech) Pyro Basic DV : Prob de driver sous XP! - Matériels & problèmes divers - Hardware
Marsh Posté le 06-07-2004 à 01:27:54
Sunly a écrit : Salut à tous, |
Slt
essaies ici:
http://www.adstech.com/support/Dow [...] %20BasicDV
je crois???
c'est le site de ADSTECH le lien te dirige vers les drivers pour ta carte
Amick@
Marsh Posté le 06-07-2004 à 01:32:30
voilà encore quelques infos utiles
Bonne lecture
My camcorder is not being detected and I`m using Windows 98 Second Edition, How do I fix it? To appear in your Device Manager the DV camcorder must be connected, using a power supply and powered on in the PLAY, VCR, or VTR mode depending on the brand of the DV camcorder.
If the camcorder is still not detected, do the following.
While your DV camcorder is ON and connected please go to your Device Manager remove "1394 DV camcorder" ,"other " or "unknown device"
Once it`s removed, turn off or disconnect your DV camcorder.
Download the file UnTI.EXE and copy it to your desktop.
If you do not have this file, you can download the file from our download area.
Run UNTI.exe to uninstall the TI DV camcorder drivers from your PC and then reboot your PC.
Once the PC is done booting up, download DirectX 8.x and the Digital Video Update from http://www.microsoft.com/directx/ . Run both of those applications to install the latest Microsoft DV camcorder drivers and then reboot the PC when the installation is finished.
After the Reboot, now connect your DV camcorder and you should see a new window which reads "Building Driver Information Database." You may be prompted for a Windows 98 CD. (if you get a version conflict question, always click on "yes" to keep the latest file)
Your DV camcorder should appear as "Microsoft DV cam and VCR" under "Imaging Device" in your Device Manager
If it still doesn`t appear, please reinstall the PYRO card to another PCI slot and try again. When you attempt this, please make sure that the computer is OFF.
Other tips:
- If your computer is using an VIA chipset, it`s highly recommended that you download the latest driver/patches for the motherboard called "VIA 4in1drivers". You can download the 4in1 drivers from http://www.viatech.com/
- If your computer is using AMD chipset, it`s recommended that you download and install the latest chipset drivers. You can obtain the drivers from this website. http://www.amd.com/products/cpg/bin/
Amick@
Marsh Posté le 06-07-2004 à 01:33:15
Tiens moi au courant
Marsh Posté le 25-06-2004 à 19:28:08
Salut à tous,
J'ai un problème! Mon système (windows XP pro + SP1) ne reconnait pas mon "Contrôleur IEEE 1394" (carte firewire ADS Tech Pyro basic dv). Si quelqu'un sait où je peux trouver le driver de cette carte pour Win XP, ce serait vraiment cool...
