Comment je sais si un modem est mort ?
Comment je sais si un modem est mort ? - Matériels & problèmes divers - Hardware
Marsh Posté le 25-08-2002 à 10:50:04
:hello: Voilà, avant mon modem (Olitec 56k pci) marchait super bien, dl à 4.5ko/s, surf hyper rapide, etc,... Et depuis hier, deconnection, dl à 1.3ko/s maxi, surf hyper lent, j'ai appelé FT, qui m'ont dis que ma ligne était nikel, Free, qui m'ont dis que leur serveur et ma configuration était nikel que ça devait être la même chose, et aol, pareil. J'ai fait un diagnostic mais il est normal, donc ?
DVD |  Ludothèque: BGG
Marsh Posté le 25-08-2002 à 11:26:31
:cry:
Marsh Posté le 25-08-2002 à 11:28:10
si ton modem etait mort tu pourrais meme pas te connecter  :sarcastic:
Marsh Posté le 25-08-2002 à 21:04:17
Et s'il est à moitié mort ?
Marsh Posté le 25-08-2002 à 21:08:13
___________
|  Scene 2  |
|___________|
    [thud]
    [clang]
CART MASTER:  Bring out your dead!
    [clang]
    [clang]
    [clang]
    [clang]
    [cough cough...]
    [clang]
    [...cough cough]
    [clang]
    [clang]
    Bring out your dead!  Ninepence.
    [clang]
    [clang]
    [clang]
    Bring out...
    [rewr!]
    ...your dead!
    [rewr!]
    [clang]
CUSTOMER:  Here's one.
CART MASTER:  Ninepence.
DEAD PERSON:  I'm not dead!
CART MASTER:  What?
CUSTOMER:  Nothing.  Here's your ninepence.
CART MASTER:  'Ere.  He says he's not dead!
CUSTOMER:  Yes, he is.
DEAD PERSON:  I'm not!
CART MASTER:  He isn't?
CUSTOMER:  Well, he will be soon.  He's very ill.
DEAD PERSON:  I'm getting better!
CUSTOMER:  No, you're not.  You'll be stone dead in a moment.
CART MASTER:  Oh, I can't take him like that.  It's against regulations.
DEAD PERSON:  I don't want to go on the cart!
CUSTOMER:  Oh, don't be such a baby.
CART MASTER:  I can't take him.
DEAD PERSON:  I feel fine!
CUSTOMER:  Well, do us a favour.
CART MASTER:  I can't.
CUSTOMER:  Well, can you hang around a couple of minutes?  He won't be long.
CART MASTER:  No, I've got to go to the Robinsons'.  They've lost nine today.
CUSTOMER:  Well, when's your next round?
CART MASTER:  Thursday.
DEAD PERSON:  I think I'll go for a walk.
CUSTOMER:  You're not fooling anyone, you know.  Look.  Isn't there something
    you can do?
DEAD PERSON:  [singing]  I feel happy.  I feel happy.
Marsh Posté le 25-08-2002 à 21:14:54
Ah
Marsh Posté le 25-08-2002 à 22:24:15
Romn a écrit a écrit :
Ah
Oui, bon désolé, c'était un piti délire...
J'ai grillé un modem interne Kortex (à cause de la foudre), et je pouvais plus me connecter DU TOUT. Donc à mon avis ton modem n'est pas mort (ni un peu ni beaucoup).
Si j'étais toi, j'attendrais un ou deux jours pour voir s'il y a du mieux, et au pire un coup de format des familles, ça fait pas de mal...
Marsh Posté le 25-08-2002 à 22:47:10
j'en ai un à vendre si tu veux
olitec 56K PCI 16euros ports inclus
Marsh Posté le 25-08-2002 à 22:50:11
FT ils testent pas si la ligne marche pour ton modem mais pour le téléphone : résultat ta ligne est peut être endommagé mais pas suffisament pour généer leurs tests mais ton modem lui est obligé de ralentir.
On peut rien faire pour ça :( :( (c'est pas dans le contrat FT).
Marsh Posté le 25-08-2002 à 22:50:47
C est comme une ampoule un modem alors ...
Pi si tu te connectes ou est le bleme ?  :sarcastic:
Marsh Posté le 25-08-2002 à 22:52:20
c est simple tu essaye un autre
Marsh Posté le 25-08-2002 à 23:05:49
Celui là de modem je l'ai acheté y a 3semaine, pke avant j'avais un vieux externe et ça m'a fait les mêmes symptome sauf que le diagnostick disait des trucs bizarres et que la carte se balader n'importre comment à l'interieur.
Donc il est encore sous garanti  :D
Marsh Posté le 25-08-2002 à 23:08:32
tu va le renvoyer a leur service il vont le tester il trouveront surement rien et taura des frais de port ke tu devrais payer pour rien :)
Marsh Posté le 25-08-2002 à 23:11:06
Essaie d'abord de voir si la ventilation marche.
POur cela, pose ta joue près de l'orifice pendant env. 10 sec.
Si y a  respiration :
1)tu appelles le 144 et tu le mets dans la position latérale. Mais surtout le force pas s'il est conscient, il faut surtout donner des conseils !
2)Si il est inconcsient, pratique 2 insuflations et 15 massages. Re-vérifie si il respire.
Si il respire fais le 1) autrement, continue jusqu'à l'arrivée des secours.
Marsh Posté le 26-08-2002 à 00:21:11
Pour la connexion free, as-tu télécharger le soft freedial?
J'arrivais plus à me connecter et depuis ça passe.
D'autre part, ouvre un compte à wanadoo accès libre, c'est gratos et ça te permet de voir si ça vient de ton FAI ou de toi.
(tu as essayé avec aol mais wanadoo est + fiable, me semble-t-il)
Marsh Posté le 26-08-2002 à 16:45:12
fallait tenter
Marsh Posté le 26-08-2002 à 17:19:42
NyGL a écrit a écrit :
fallait tenter
Spa grave, une prochaine fois peut-être... (quand le mien sera grillé  :D )
Marsh Posté le 26-08-2002 à 19:41:01
tu peux aussi faire un diag modem via l'icone "modem" (evidemment) du panneau de conf et si t'as une erreur en face d'une commande c'est dead.
Si tu as des pb de debit, augmente les parametre du port au max (meme endroit mais ensuite bouton propriétés, onglet connexion et bouton parametre du port) et met les tampons à fond les ballons.
Marsh Posté le 26-08-2002 à 19:42:43
_john_doe_ a écrit a écrit :
 ___________
|  Scene 2  |
|___________|
    [thud]
    [clang]
    [clang]
    [clang]
    [clang]
    [clang]
    [cough cough...]
    [clang]
    [...cough cough]
    [clang]
    [clang]
    [clang]
    [clang]
    [clang]
    Bring out...
    [rewr!]
    ...your dead!
    [rewr!]
    [clang]
CART MASTER:  What?
    you can do?
:lol:
j'ai revu la scene hier :lol:
Marsh Posté le 26-08-2002 à 19:46:02
remarque ça se finissais pas comme ça  :heink:
Marsh Posté le 26-08-2002 à 19:58:57
Non effectivement, j'ai coupé la fin :
    [whop]
CUSTOMER:  Ah, thanks very much.
CART MASTER:  Not at all.  See you on Thursday.
CUSTOMER:  Right.  All right.
    [howl]
    [clop clop clop]
    Who's that, then?
CART MASTER:  I dunno.  Must be a king.
CUSTOMER:  Why?
CART MASTER:  He hasn't got shit all over him.
Je suis amoureux de ce film  :love:
Marsh Posté le 26-08-2002 à 20:05:33
tu as fait un test hypertrm ?
ca te donnerait une idée sur la vitesse de connexion
Marsh Posté le 26-08-2002 à 21:33:07
    [whop]
    [howl]
    [clop clop clop]
    Who's that, then?
CUSTOMER:  Why?
skoi ce truc :??:
pour le modem à mon avis ça vient de la ligne ou de ta rallonge.
Peut être un téléphone branché sur la même ligne qui merde
Réalisation amplis classe D / T      Topic .Net - C# @ Prog
Marsh Posté le 26-08-2002 à 21:48:15
TotalRecall a écrit a écrit :
skoi ce truc :??:
"Monty Pythons And The Holy Grail"
(pasque romn a dit que son modem était à moitié mort, et que ça m'a rappelé ce film)
Marsh Posté le 27-08-2002 à 01:53:21
salut!!!
ben moi, ce week, ordi debranché , consta>>> modem introduit la foudre dans la carte mere par la prise du telephone (jy avé po penser  :heink: ) et chpafff(enfin, g t po là donc jimagine) et pi maintenant la carte mere salume (accé au bios ) mais c tout ouin!! pas plus loing ke le bios!!!! et le modem, si je le branche, aucun boot!  :ouch:
 :lol:  ça m'énerve!!!!!!  :fou:
www.kookyoo.net | www.rj66.org
Marsh Posté le 27-08-2002 à 02:16:29
Y a aussi:
Passeur: What s your name
Knight1: I m sir Lancelot
Passeur: And what is your quest?
Knight1: I m seeking the holy grail
Passeur: What s your favorite colour?
Knight1: blue
Knight1: I m sir Charles
Passeur: What s the speed of a swallow crossing the atlantic ocean?
Knight1: Uhhh, i don t know that... *PAAAAFFF*
Knight1: I m sir John (me rappelle plus trop des noms :p )
Knight1: yellow... HMMMMM blue *PAAAAFFF*
Knight1: I m sir Arthur, king of the Britons
Knight1: hmmm an african or american one?
Passeur: well, i don t know that *PAAAAFFFF*  :lol:  :lol:
Si je me souviens bien aussi, y a une replique du style:
Peasant: Ohhh your the King? well, i didn t vote for you...  :D
Je me suis pété de rire du debut a la fin, j adore Monty Pythons (ca fait longtemps que je l ai pas revu d ailleurs  :non:  :ange: )
Marsh Posté le 27-08-2002 à 03:22:59
Sujet: Comment je sais si un modem est mort ?
Lorsqu'il ne fonctionne plus.
Marsh Posté le 27-08-2002 à 11:04:33
GF4x3443 a écrit a écrit :
Y a aussi:
Knight1: blue
[:rofl] [:rofl] [:rofl]
Tiens, la scène complète :
____________
|  Scene 23  |
|____________|
    [gurgle]
GALAHAD:  There it is!
ARTHUR:  The Bridge of Death!
ROBIN:  Oh, great.
ARTHUR:  Look!  There's the old man from scene twenty-four!
BEDEVERE:  What is he doing here?
ARTHUR:  He is the keeper of the Bridge of Death.  He asks each traveller
    five questions--
GALAHAD:  Three questions.
ARTHUR:  Three questions.  He who answers the five questions--
ARTHUR:  Three questions may cross in safety.
ROBIN:  What if you get a question wrong?
ARTHUR:  Then you are cast into the Gorge of Eternal Peril.
ROBIN:  Oh, I won't go.
GALAHAD:  Who's going to answer the questions?
ARTHUR:  Sir Robin!
ROBIN:  Yes?
ARTHUR:  Brave Sir Robin, you go.
ROBIN:  Hey!  I've got a great idea.  Why doesn't Launcelot go?
LAUNCELOT:  Yes.  Let me go, my liege.  I will take him single-handed.  I
    shall make a feint to the north-east that s--
ARTHUR:  No, no.  No.  Hang on!  Hang on!  Hang on!  Just answer the five
    questions--
ARTHUR:  Three questions as best you can, and we shall watch... and pray.
LAUNCELOT:  I understand, my liege.
ARTHUR:  Good luck, brave Sir Launcelot.  God be with you.
BRIDGEKEEPER:  Stop!  Who would cross the Bridge of Death must answer me
    these questions three, ere the other side he see.
LAUNCELOT:  Ask me the questions, bridgekeeper.  I am not afraid.
BRIDGEKEEPER:  What... is your name?
LAUNCELOT:  My name is 'Sir Launcelot of Camelot'.
BRIDGEKEEPER:  What... is your quest?
LAUNCELOT:  To seek the Holy Grail.
BRIDGEKEEPER:  What... is your favourite colour?
LAUNCELOT:  Blue.
BRIDGEKEEPER:  Right.  Off you go.
LAUNCELOT:  Oh, thank you.  Thank you very much.
ROBIN:  That's easy!
BRIDGEKEEPER:  Stop!  Who approacheth the Bridge of Death must answer me
ROBIN:  Ask me the questions, bridgekeeper.  I'm not afraid.
ROBIN:  'Sir Robin of Camelot'.
ROBIN:  To seek the Holy Grail.
BRIDGEKEEPER:  What... is the capital of Assyria?
    [pause]
ROBIN:  I don't know that!  Auuuuuuuugh!
BRIDGEKEEPER:  Stop!  What... is your name?
GALAHAD:  'Sir Galahad of Camelot'.
GALAHAD:  I seek the Grail.
GALAHAD:  Blue.  No, yel-- auuuuuuuugh!
BRIDGEKEEPER:  Hee hee heh.  Stop!  What... is your name?
ARTHUR:  It is 'Arthur', King of the Britons.
ARTHUR:  To seek the Holy Grail.
BRIDGEKEEPER:  What... is the air-speed velocity of an unladen swallow?
ARTHUR:  What do you mean?  An African or European swallow?
BRIDGEKEEPER:  Huh?  I-- I don't know that.  Auuuuuuuugh!
BEDEVERE:  How do know so much about swallows?
ARTHUR:  Well, you have to know these things when you're a king, you know.
    [suspenseful music]
    [music suddenly stops]
    [intermission]
    [suspenseful music resumes]
Marsh Posté le 20-09-2002 à 22:40:36
Cataclop, cataclop.  :love:
Sinon je trouve pas l'association d'idée avec le modem a moitié mort ? :??:
Au, fait, ça devait être une mauvaise periode de FT sur la region, pke là ça marche nikel.
