Je viens d'acheter un hauppauge nova-t (tnt), sous windows ca marche imp mais sous linux j'ai utilise xdtv pour scan tv mais j'ai rien ca marche pas par contre je pense que le driver est bien installe et la carte est reconnu ? voila ce que donne :
xdtv -c /dev/video
This is xdtv 2.1.1 running on Linux/i686 (2.6.10-rc2). scandir: No such file or directory filename = /root/.xdtv/xdtvrc *** to enable xvtv or xvtv_overlay use xvtvport option /dev/video [v4l2]: no overlay support xdtv_v4l-conf had some trouble, trying to continue anyway Warning: Cannot convert string "fileSelectorView" to type Widget Warning: Cannot convert string "fileSelectorView" to type Widget wmhooks: netwm detected wmhooks: netwm state above supported wmhooks: netwm fullscreen supported wmhooks: nothing found... DGA: server=2.0, include=2.0 VidMode: server=2.2, include=2.2 available video mode(s): 1280x1024 1280x1024 1280x1024 1280x960 1280x960 1280x800 1152x864 1152x768 1024x768 1024x768 1024x768 1024x768 1024x768 832x624 1024x480 800x600 800x600 800x600 800x600 800x600 768x576 768x576 640x480 640x480 640x480 640x480 720x400 640x400 640x350 512x384 416x312 400x300 400x300 400x300 400x300 Selected XvImage adaptor with yuyv support: ATI Radeon Video Overlay on port 69 (grabdisplay) No XvVideo port available. *** AUDIO DEVICE TYPE = alsa ioctl VIDIOC_G_FBUF: Invalid argument classical overlay is disabled*** GRABBER DEVICE TYPE = v4l2 VIDIOC_S_CTRL, V4L2_CID_AUDIO_VOLUME: Numerical result out of range *** MIXER DEVICE TYPE = alsa MMX, SSE, AMD MMX extensions, 3DNOW, have been detected. Method mmxext_64K
Marsh Posté le 09-05-2005 à 13:59:28
xdtv -c /dev/video
Method mmxext_64K
de l'aide svp
