Hercules Fortissimo IV et jeux en 5.1 - Matériels & problèmes divers - Hardware
Marsh Posté le 29-09-2006 à 09:11:13
Peut etre n'as tu pas activé les options "5.1" dans le menu "OPTIONS SONS" de tes jeux, en général, elles ne sont pas sélectionnées par défaut.
Marsh Posté le 29-09-2006 à 17:04:27
Si si elles sont activés ci joint mon rapport dxdiag
System Information
Time of this report: 9/29/2006, 17:03:46
Machine name: ARNAUD
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: French (Regional Setting: French)
System Manufacturer: K8UNF
System Model: K8Upgrade-NF3
BIOS: Default System BIOS
Processor: AMD Sempron(tm) Processor 3100+, MMX, 3DNow, ~1.8GHz
Memory: 1024MB RAM
Page File: 428MB used, 2032MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: The file Envy24HF.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 7800 GS
Manufacturer: NVIDIA
Chip type: GeForce 7800 GS
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_00F5&SUBSYS_1FA419F1&REV_A2
Display Memory: 256.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Écran Plug-and-Play
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.9147 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 8/11/2006 21:42:52, 4496128 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 8/11/2006 21:42:42, 3958496 bytes
Device Identifier: {D7B71E3E-43B5-11CF-FA59-AE3F03C2CB35}
Vendor ID: 0x10DE
Device ID: 0x00F5
SubSys ID: 0x1FA419F1
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Envy24 Family Audio (WDM)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1412&DEV_1724&SUBSYS_00011681&REV_01
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: Envy24HF.sys
Driver Version: 5.12.0001.3644 (English)
WHQL Logo'd: No
Date and Size: 10/15/2004 09:17:22, 575424 bytes
Other Files:
Driver Provider: Hercules
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 5000, 96000
Static/Strm HW Mix Bufs: 64, 62
Static/Strm HW 3D Bufs: 64, 62
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Envy24 Family Audio (WDM), Software (Kernel Mode), Output, DLS, Internal
Mappeur MIDI Microsoft [Émulé], Hardware (Not Kernel Mode), Output, No DLS, Internal
SynthÚ. SW table de sons GS Mic [Émulé], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Souris
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Clavier
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Logitech USB Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC30A
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ Concentrateur USB racine
| Vendor/Product ID: 0x10DE, 0x00E7
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/10/2004 10:00:00, 57600 bytes
| Driver: usbd.sys, 8/10/2004 10:00:00, 4736 bytes
+-+ Périphérique d'interface utilisateur USB
| | Vendor/Product ID: 0x045E, 0x0084
| | Matching Device ID: usb\class_03&subclass_01
| | Service: HidUsb
| | Driver: hidclass.sys, 8/10/2004 10:00:00, 36224 bytes
| | Driver: hidparse.sys, 8/10/2004 10:00:00, 24960 bytes
| | Driver: hid.dll, 8/10/2004 10:00:00, 20992 bytes
| | Driver: hidusb.sys, 8/10/2004 10:00:00, 9600 bytes
| +-+ Souris HID
| | | Matching Device ID: hid_device_system_mouse
| | | Service: mouhid
| | | Driver: mouclass.sys, 8/10/2004 10:00:00, 23680 bytes
| | | Driver: mouhid.sys, 8/10/2004 10:00:00, 12288 bytes
Gameport Devices
PS/2 Devices
+ Périphérique clavier PIH
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 8/4/2004 00:45:14, 14848 bytes
| Driver: kbdclass.sys, 8/10/2004 10:00:00, 25216 bytes
+ Pilote clavier de Terminal Server
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 00:55:12, 40840 bytes
+ Souris HID
| Service: mouhid
+ Pilote souris de Terminal Server
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Connexion au réseau local - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1,4 Kbit/s
Voxware SC06 6,4 Kbit/s
Voxware SC03 3,2 Kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 41.2 GB
Total Space: 152.6 GB
File System: FAT32
Model: ST3160021A
Drive: D:
Model: JLMS XJ-HD166S
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (French), 8/10/2004 10:00:00, 49536 bytes
Drive: E:
Model: _NEC DVD_RW ND-2500A
Drive: H:
Model: ZB0517D APK222X SCSI CdRom Device
System Devices
Name: Gamesurround Fortissimo 4 Audio Controller WDM
Device ID: PCI\VEN_1412&DEV_1724&SUBSYS_00011681&REV_01\4&22775069&0&3870
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (French), 8/4/2004 00:54:30, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (French), 8/4/2004 00:55:04, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (French), 8/3/2004 23:15:22, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:00, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/3/2004 23:15:50, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (French), 8/3/2004 23:08:04, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 00:55:04, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\Envy24HF.sys, 5.12.0001.3644 (English), 10/15/2004 09:17:22, 575424 bytes
Driver: C:\WINDOWS\System32\Audio3D.dll, 0.00.0000.0000 (English), 10/7/2004 03:44:00, 254000 bytes
Driver: C:\WINDOWS\System32\A3D.dll, 0.00.0000.0000 (English), 10/7/2004 03:44:00, 254000 bytes
Name: NVIDIA GeForce 7800 GS
Device ID: PCI\VEN_10DE&DEV_00F5&SUBSYS_1FA419F1&REV_A2\4&2E2DECCC&0&0058
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0010.9147 (English), 8/11/2006 21:42:42, 3958496 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0010.9147 (English), 8/11/2006 21:42:52, 4496128 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0010.9147 (English), 8/11/2006 21:42:50, 155715 bytes
Driver: C:\WINDOWS\system32\nvhwvid.dll, 6.14.0010.9147 (), 8/11/2006 21:45:20, 581632 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0010.9147 (), 8/11/2006 21:43:10, 196608 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0010.9147 (English), 8/11/2006 21:42:58, 5636096 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0010.9147 (English), 8/11/2006 21:43:02, 7630848 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0010.9147 (English), 8/11/2006 21:43:04, 86016 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0010.9147 (English), 8/11/2006 21:43:08, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11048 (English), 8/11/2006 21:43:00, 286720 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0010.9147 (English), 8/11/2006 21:45:22, 229376 bytes
Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0010.9147 (English), 8/11/2006 21:45:28, 5611520 bytes
Driver: C:\WINDOWS\system32\nvdispsr.dll, 6.14.0010.9147 (French), 8/11/2006 21:45:30, 5251072 bytes
Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0010.9147 (English), 8/11/2006 21:45:32, 3039232 bytes
Driver: C:\WINDOWS\system32\nvgamesr.dll, 6.14.0010.9147 (French), 8/11/2006 21:45:34, 2928640 bytes
Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0010.9147 (English), 8/11/2006 21:45:38, 188416 bytes
Driver: C:\WINDOWS\system32\nvmccssr.dll, 6.14.0010.9147 (French), 8/11/2006 21:45:40, 458752 bytes
Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0010.9147 (English), 8/11/2006 21:45:42, 888832 bytes
Driver: C:\WINDOWS\system32\nvmoblsr.dll, 6.14.0010.9147 (French), 8/11/2006 21:45:42, 2859008 bytes
Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0010.9147 (English), 8/11/2006 21:45:44, 2904064 bytes
Driver: C:\WINDOWS\system32\nvvitvsr.dll, 6.14.0010.9147 (French), 8/11/2006 21:45:46, 2953216 bytes
Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0010.9147 (English), 8/11/2006 21:45:36, 1236992 bytes
Driver: C:\WINDOWS\system32\nvwssr.dll, 6.14.0010.9147 (French), 8/11/2006 21:45:38, 1732608 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 8/11/2006 21:43:06, 177897 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 8/11/2006 21:43:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0035 (English), 8/11/2006 21:42:44, 35840 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0035 (English), 8/11/2006 21:42:44, 35840 bytes
Name: Pont PCI vers PCI standard PCI
Device ID: PCI\VEN_10DE&DEV_00ED&SUBSYS_00000000&REV_A2\3&267A616A&0&70
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (French), 8/10/2004 10:00:00, 68608 bytes
Name: Contrôleur hôte PCI vers USB standard étendu
Device ID: PCI\VEN_10DE&DEV_00E8&SUBSYS_00E81849&REV_A2\3&267A616A&0&12
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/10/2004 10:00:00, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/10/2004 10:00:00, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (French), 8/10/2004 10:00:00, 77312 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/10/2004 10:00:00, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/10/2004 10:00:00, 7168 bytes
Name: Contrôleur hôte USB OpenHCD standard
Device ID: PCI\VEN_10DE&DEV_00E7&SUBSYS_00E71849&REV_A1\3&267A616A&0&11
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.2180 (English), 8/10/2004 10:00:00, 17024 bytes
Device ID: PCI\VEN_10DE&DEV_00E7&SUBSYS_00E71849&REV_A1\3&267A616A&0&10
Name: NVIDIA nForce3 250 Parallel ATA Controller (v2.6)
Device ID: PCI\VEN_10DE&DEV_00E5&SUBSYS_00E51849&REV_A2\3&267A616A&0&40
Driver: C:\WINDOWS\system32\DRIVERS\nvatabus.sys, 5.10.2600.0446 (English), 6/3/2004 10:40:46, 79360 bytes
Driver: C:\WINDOWS\system32\idecoi.dll, 1.00.0000.0001 (English), 6/3/2004 04:40:48, 294400 bytes
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_00E4&SUBSYS_00E41849&REV_A1\3&267A616A&0&09
Driver: n/a
Name: NVIDIA nForce3 250 Serial ATA Controller (v2.6)
Device ID: PCI\VEN_10DE&DEV_00E3&SUBSYS_00E31849&REV_A2\3&267A616A&0&50
Name: NVIDIA nForce3 250 AGP Host to PCI Bridge
Device ID: PCI\VEN_10DE&DEV_00E2&SUBSYS_00000000&REV_A2\3&267A616A&0&58
Driver: C:\WINDOWS\system32\DRIVERS\nv_agp.SYS, 4.12.0001.0436 (English), 4/2/2004 15:40:00, 21760 bytes
Driver: C:\WINDOWS\system32\NVCOG.DLL, 1.00.0000.0015 (English), 4/2/2004 09:40:00, 32256 bytes
Name: Pont CPU hôte standard PCI
Device ID: PCI\VEN_10DE&DEV_00E1&SUBSYS_00000000&REV_A1\3&267A616A&0&00
Driver: n/a
Name: Pont ISA standard PCI
Device ID: PCI\VEN_10DE&DEV_00E0&SUBSYS_00000000&REV_A2\3&267A616A&0&08
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (French), 8/10/2004 10:00:00, 36224 bytes
Name: NVIDIA Network Bus Enumerator
Device ID: PCI\VEN_10DE&DEV_00DF&SUBSYS_00DF1849&REV_A2\3&267A616A&0&28
Driver: C:\WINDOWS\system32\DRIVERS\nvnetbus.sys, 1.00.0000.0442 (English), 5/17/2004 14:00:54, 12928 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nvnrm.sys, 1.00.0000.0442 (English), 5/17/2004 14:00:42, 56960 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nvsnpu.sys, 1.00.0000.0442 (English), 5/17/2004 14:00:34, 191232 bytes
Driver: C:\WINDOWS\system32\bdco1.dll, 1.00.0000.0000 (English), 5/17/2004 13:48:58, 8192 bytes
Driver: C:\WINDOWS\system32\nvconrm.dll, 1.00.0000.0015 (English), 5/10/2004 08:53:16, 32256 bytes
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&267A616A&0&C3
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&267A616A&0&C2
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&267A616A&0&C1
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&267A616A&0&C0
Driver: n/a
DirectX Components
ddraw.dll: 5.03.2600.2180 French Final Retail 8/10/2004 10:00:00 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/10/2004 10:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 French Final Retail 8/10/2004 10:00:00 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/10/2004 10:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/10/2004 10:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/10/2004 10:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/10/2004 10:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/10/2004 10:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 French Final Retail 8/10/2004 10:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 229888 bytes
dpmodemx.dll: 5.03.2600.2180 French Final Retail 8/10/2004 10:00:00 24064 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/10/2004 10:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 French Final Retail 8/10/2004 10:00:00 57856 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 30208 bytes
dpnsvr.exe: 5.03.2600.2180 French Final Retail 8/10/2004 10:00:00 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 3584 bytes
dpvoice.dll: 5.03.2600.2180 French Final Retail 8/10/2004 10:00:00 213504 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 83456 bytes
dpvvox.dll: 5.03.2600.2180 French Final Retail 8/10/2004 10:00:00 116736 bytes
dpvacm.dll: 5.03.2600.2180 French Final Retail 8/10/2004 10:00:00 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 60928 bytes
dpserial.dll: 5.00.2134.0001 French Final Retail 8/10/2004 10:00:00 54032 bytes
dinput.dll: 5.03.2600.2180 French Final Retail 8/10/2004 10:00:00 165376 bytes
dinput8.dll: 5.03.2600.2180 French Final Retail 8/10/2004 10:00:00 187904 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/10/2004 10:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 French Final Retail 8/10/2004 10:00:00 395264 bytes
joy.cpl: 5.03.2600.2180 French Final Retail 8/10/2004 10:00:00 70144 bytes
gcdef.dll: 5.01.2600.0000 French Final Retail 8/10/2004 10:00:00 77824 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 35328 bytes
gameenum.sys: 5.01.2600.2180 English Final Retail 8/10/2004 10:00:00 10624 bytes
dsound.dll: 5.03.2600.2180 French Final Retail 8/10/2004 10:00:00 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 French Final Retail 8/10/2004 10:00:00 72192 bytes
dmusic.dll: 5.03.2600.2180 French Final Retail 8/10/2004 10:00:00 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 82432 bytes
system.dll: 1.01.4322.0573 English Final Retail 9/28/2006 14:46:36 1216512 bytes
dx7vb.dll: 5.03.2600.2180 French Final Retail 8/10/2004 10:00:00 619008 bytes
dx8vb.dll: 5.03.2600.2180 French Final Retail 8/10/2004 10:00:00 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 French Final Retail 8/10/2004 10:00:00 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/10/2004 10:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/10/2004 10:00:00 1028096 bytes
wsock32.dll: 5.01.2600.2180 French Final Retail 8/10/2004 10:00:00 25088 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/10/2004 10:00:00 70656 bytes
devenum.dll: 6.05.2600.2180 French Final Retail 8/10/2004 10:00:00 59904 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/10/2004 10:00:00 498205 bytes
mciqtz32.dll: 6.05.2600.2180 French Final Retail 8/10/2004 10:00:00 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/10/2004 10:00:00 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/10/2004 10:00:00 14336 bytes
encapi.dll: 5.03.2600.2180 French Final Retail 8/10/2004 10:00:00 20480 bytes
qasf.dll: 11.00.5358.4827 English Final Retail 5/9/2006 22:26:34 201728 bytes
qcap.dll: 6.05.2600.2180 French Final Retail 8/10/2004 10:00:00 192512 bytes
qdv.dll: 6.05.2600.2180 French Final Retail 8/10/2004 10:00:00 279040 bytes
qdvd.dll: 6.05.2600.2180 French Final Retail 8/10/2004 10:00:00 386048 bytes
qedit.dll: 6.05.2600.2180 French Final Retail 8/10/2004 10:00:00 563200 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/10/2004 10:00:00 733696 bytes
quartz.dll: 6.05.2600.2749 French Final Retail 8/30/2005 05:55:44 1293312 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/10/2004 10:00:00 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/10/2004 10:00:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/10/2004 10:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/10/2004 10:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/10/2004 10:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/10/2004 10:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/10/2004 10:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/10/2004 10:00:00 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/10/2004 10:00:00 154624 bytes
mswebdvd.dll: 6.05.2600.2180 French Final Retail 8/10/2004 10:00:00 204800 bytes
msdvdopt.dll: 5.01.2600.0000 French Final Retail 8/28/2001 12:00:00 75776 bytes
ks.sys: 5.03.2600.2180 French Final Retail 8/3/2004 23:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 French Final Retail 8/4/2004 00:55:04 130048 bytes
ksuser.dll: 5.03.2600.2180 French Final Retail 8/4/2004 00:54:30 4096 bytes
stream.sys: 5.03.2600.2180 French Final Retail 8/3/2004 23:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 French Final Retail 8/3/2004 22:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 French Final Retail 8/3/2004 22:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 French Final Retail 8/3/2004 22:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 French Final Retail 8/10/2004 10:00:00 4352 bytes
mpeg2data.ax: 6.05.2700.2180 English Final Retail 8/10/2004 10:00:00 62976 bytes
msvidctl.dll: 6.05.2700.2180 English Final Retail 8/10/2004 10:00:00 1616384 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/10/2004 10:00:00 17408 bytes
wstdecod.dll: 5.03.2600.2180 French Final Retail 8/10/2004 10:00:00 51200 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
WMVideo 8 Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
DivX Decoder Filter,0x00800000,1,1,divxdec.ax,5.00.0005.0830
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749
CyberLink DVD Navigator,0x00600000,0,3,CLNAVX.ax,5.00.0000.1828
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5358.4827
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,10.00.0000.3646
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749
Sonic Audio Depth Converter (Symphony),0x00200000,1,1,AudioDepthConverterS.ax,5.00.0000.0001
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2700.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
HP Frame Grabber Filter,0x00200000,1,1,hpqdsftr.ax,45.04.0157.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
DivX for Blizzard Decoder Filter,0x00800000,1,1,blizzard.ax,5.00.0002.0000
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2749
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
AVS Video Out,0x00200000,0,1,AVSVideoOutFilter.ax,
MPEG Layer-3 Decoder,0x00810000,1,1,L3CODECX.AX,1.09.0000.0311
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
CyberLink Audio Effect,0x00200000,1,1,claudfx.ax,5.00.0000.1316
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
CyberLink Line21 Decoder Filter,0x00200000,0,2,CLLine21.ax,4.00.0000.3924
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2749
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,10.00.0000.3646
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Sonic RTStreamSink (Symphony),0x00200000,1,0,RTStreamSinkS.ax,5.00.0000.0001
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2749
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
CyberLink AudioCD Filter,0x00600000,0,1,CLAudioCD.ax,5.00.0000.1613
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
NSC file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
XviD MPEG-4 Video Decoder,0x00800000,1,1,xvid.ax,
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2749
Windows Media source filter,0x00600000,0,2,wmpasf.dll,10.00.0000.3646
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2700.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2749
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2749
Décodeur audio MPEG non professionnel Sonic (Symphony),0x00200000,1,1,SonicMPEGAudioS.DLL,2.05.0004.1403
LEAD MCMP/MJPEG Codec,0x00100000,1,1,LCodcCMP.dll,1.00.0000.0021
LEAD MCMP/MJPEG Decoder,0x00800000,1,1,LCodcCMP.dll,1.00.0000.0021
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5358.4827
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
Décodeur vidéo MPEG Sonic (Symphony),0x00200000,2,1,SonicMPEGVideoS.DLL,2.05.0004.1041
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
CyberLink Audio Decoder,0x00601000,1,1,claud.ax,5.00.0000.1816
CyberLink Video/SP Decoder,0x00600000,2,3,CLVSD.ax,5.00.0000.1727
CyberLink TimeStretch Filter,0x00200000,1,1,CLAuTS.ax,1.00.0000.1828
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2749
MS2 Wave Rec,0x00200000,0,0,MS2WaveRec.ax,
.RAM file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF URL Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2700.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2749
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2749
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2749
XML Playlist,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
Sonic Cinemaster MPEG Splitter (Symphony),0x00200000,1,2,SonicMPEGSplitterS.dll,1.00.0000.0103
DirectShow Tap (Symphony),0x00200000,1,1,DirectShowTapS.ax,5.00.0000.0001
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2749
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2749
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2749
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2749
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
Transformateurs de répartition de données WDM:
Suppresseur d'écho acoustique (Noyau Microsoft),0x00000000,0,0,,
Synthétiseur de table de sons GC noyau Microsoft,0x00200000,1,1,,5.03.2600.2180
Synthétiseur DLS du noyau Microsoft,0x00200000,1,1,,5.03.2600.2180
Filtre de décodeur DRM (Noyau Microsoft),0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2749
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX 5.0.5 Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
MainConcept DV Codec 2.0.4,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Codec Intel IYUV,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft MPEG-4 Video Codec V2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft MPEG-4 Video Codec V3,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft MPEG-4 Video Codec V1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Vidéo 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
XviD MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2749
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2749
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2749
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2749
MSN Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2749
SHARP G.726,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
NCT ALF2 CD,0x00200000,1,1,quartz.dll,6.05.2600.2749
AC-3 ACM Decompressor,0x00200000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2749
Audio Capture Sources:
Envy24 Family Audio (WDM),0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Synthé. SW table de sons GS Mic,0x00200000,1,0,quartz.dll,6.05.2600.2749
Périphériques de capture de flux WDM:
Envy24 Family Audio (WDM),0x00200000,4,2,,5.03.2600.2180
Périphériques de répartition de rendu WDM:
Périphériques de répartition de mélangeur WDM:
Mélangeur audio Wave de noyau Microsoft,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2700.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2700.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2700.2180
Audio Renderers:
Envy24 Family Audio (WDM),0x00200000,1,0,quartz.dll,6.05.2600.2749
CyberLink Audio Renderer,0x00200000,1,0,CLADR.ax,5.00.0000.1717
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2749
DirectSound: Envy24 Family Audio (WDM),0x00200000,1,0,quartz.dll,6.05.2600.2749
Périphériques système répartis WDM:
Envy24 Family Audio (WDM),0x00200000,14,3,,5.03.2600.2180
Marsh Posté le 02-10-2006 à 00:41:58
Y'a pas de raison pour que tu n'aies pas de 5.1 dans les jeux.
J'aurai l'un de ces petits bijous très bientôt donc je te dirais comment ça se passe pour moi
Pour l'EAX HD c'est normal, les winners de chez Creative interdisent tout bêtement à tout constructeur concurrent de mettre en oeuvre leur implémentation d'EAX 3 et + ( rachat d'Aureal toussa ... ). Longue vie aux moteurs sur mesure comme celui de Doom III
, j'espère qu'un de ces jours une alternative libre émergera et mettra la patée à CL
Marsh Posté le 02-10-2006 à 02:39:00
comme dit ici + haut, l'EAX supérieur au 2 est réservé au produit Créative
c'est eux qui débourse en recherche sur cet API, donc normal qu'il préférre ce garder un + par apport a leur concurent
pour le multicanal que tu as avec les DVD et pas avec les jeux, ta carte son ne serai pas connecté a ampli Home Cinéma via une connection numérique des fois ?!?
si c'est bien cela, c'est normal
ton ampli decode que les flux numerique PCM (stereo only), Dolby Digital (5.1 max) et peut-etre aussi le DTS (5.1 max)
et pour que ta carte son puisse envoyer un flux numerique multicanal a ton ampli, il aurai fallu qu'elle encode en temp réelle dans un format 5.1, hors des carte qui font ça a ma connaisance il n'y a que 2 modele qui propose ça !!
topo ta carte n'a que du PCM (stereo only) a proposé a ton ampli, tu peut donc faire tout ce que tu veut, jamais ta Fortissimo ne donnera du multicanal avec une connextion numerique !
pour les DVD, le signal audio qui plait bien a un ampli Home Cinema est deja sur le disque, le player DVD et la carte son ne font que laisser passer ce flux numerique sans y toucher
si tu veut du multicanal pour tes jeux, branche ta carte son a un ampli en analogique
Marsh Posté le 28-09-2006 à 23:45:38
Bonjour ,
J'ai la carte son hercules fortissimo IV, lorsque je met un dvd il me le lit bien en 5.1 et mon ampli me l'indique bien comme cela .
Par contre lorsque je lance un jeu , impossible d'avoir un jeu en 5.1 , je n'ai que du 2.1 ( eax 2.0 ) , les options eax hd étant grisée donc inaccessible ou alors elle ne marche pas .
J'ai desactivé dans le BIOS le AC97 audio afin d'empecher tout conflit audio, mais rien n'y fait .
De même j'ai désactivé les gameport sound sans succés .
D'ou cela peut il venir ?
j'ai essayé sous FEAR , COD 2 et HL²
Quelqu'un a t'il déja eu ce pb ?
Ma carte même est une asrock F8-KF3 upgrade
Quelqu'un a til déja eu ce probléme ?
Voici un rapport hijack this de mon PC,
Logfile of HijackThis v1.99.1
Scan saved at 23:43:00, on 28/09/2006
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\csrss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\Program Files\TuneUp Utilities 2006\WinStylerThemeSvc.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
C:\Program Files\Alwil Software\Avast4\ashServ.exe
C:\WINDOWS\system32\HPZipm12.exe
C:\WINDOWS\system32\nvraidservice.exe
C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
C:\Program Files\Anti-Blaxx 1.18\Anti-Blaxx.exe
C:\Program Files\Java\jre1.5.0_06\bin\jusched.exe
C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe
C:\Program Files\PowerISO\PWRISOVM.EXE
C:\WINDOWS\system32\RunDLL32.exe
C:\Program Files\HP\HP Software Update\HPWuSchd2.exe
C:\Program Files\Gamesurround Fortissimo 4 mixer\EnMixCPL.exe
C:\Program Files\MSN Messenger\msnmsgr.exe
C:\WINDOWS\system32\rundll32.exe
C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
C:\Program Files\Stardock\ObjectDock\ObjectDock.exe
C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindService.exe
C:\Program Files\HP\Digital Imaging\bin\hpqgalry.exe
C:\WINDOWS\system32\wbem\wmiprvse.exe
C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
C:\WINDOWS\System32\alg.exe
C:\WINDOWS\system32\wbem\unsecapp.exe
c:\warcraft iii\war3.exe
C:\Program Files\Mozilla Firefox\firefox.exe
C:\Documents and Settings\Arnaud RICHARD\Bureau\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.google.fr/
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName = Liens
F3 - REG:win.ini: run=
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: Alcohol Toolbar Helper - {0ACF00E0-C1E4-4F6B-B290-10AC7505C47A} - C:\Program Files\Alcohol Toolbar\v3.0.0.0\AudioGizmo_Toolbar.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O3 - Toolbar: Alcohol Toolbar - {DC59A0D4-0ED6-4A73-B356-1B977F2A7725} - C:\Program Files\Alcohol Toolbar\v3.0.0.0\AudioGizmo_Toolbar.dll
O4 - HKLM\..\Run: [NVRaidService] C:\WINDOWS\system32\nvraidservice.exe
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [NVMixerTray] "C:\Program Files\NVIDIA Corporation\NvMixer\NVMixerTray.exe"
O4 - HKLM\..\Run: [avast!] C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
O4 - HKLM\..\Run: [Anti-Blaxx Manager] C:\Program Files\Anti-Blaxx 1.18\Anti-Blaxx.exe
O4 - HKLM\..\Run: [SunJavaUpdateSched] C:\Program Files\Java\jre1.5.0_06\bin\jusched.exe
O4 - HKLM\..\Run: [RemoteControl] "C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe"
O4 - HKLM\..\Run: [PWRISOVM.EXE] C:\Program Files\PowerISO\PWRISOVM.EXE
O4 - HKLM\..\Run: [NvMediaCenter] RunDLL32.exe NvMCTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [HP Software Update] "C:\Program Files\HP\HP Software Update\HPWuSchd2.exe"
O4 - HKLM\..\Run: [EnvyHFCPL] C:\Program Files\Gamesurround Fortissimo 4 mixer\EnMixCPL.exe
O4 - HKCU\..\Run: [MessengerPlus3] "C:\Program Files\MessengerPlus! 3\MsgPlus.exe" /WinStart
O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\MSN Messenger\msnmsgr.exe" /background
O4 - Startup: Stardock ObjectDock.lnk = C:\Program Files\Stardock\ObjectDock\ObjectDock.exe
O4 - Global Startup: Lancement rapide d'Adobe Reader.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
O4 - Global Startup: HP Digital Imaging Monitor.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
O4 - Global Startup: Démarrage rapide du logiciel HP Image Zone.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Console Java (Sun) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O18 - Protocol: livecall - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\MSNMES~1\MSGRAP~1.DLL
O18 - Protocol: msnim - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\MSNMES~1\MSGRAP~1.DLL
O20 - Winlogon Notify: WgaLogon - WgaLogon.dll (file missing)
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - Unknown owner - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: Automatic LiveUpdate Scheduler - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
O23 - Service: avast! Antivirus - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe" /service (file missing)
O23 - Service: avast! Web Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe" /service (file missing)
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Fichiers communs\InstallShield\Driver\1050\Intel 32\IDriverT.exe
O23 - Service: LiveUpdate - Symantec Corporation - C:\PROGRA~1\Symantec\LIVEUP~1\LUCOMS~1.EXE
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
O23 - Service: Pml Driver HPZ12 - HP - C:\WINDOWS\system32\HPZipm12.exe
O23 - Service: StarWind iSCSI Service (StarWindService) - Rocket Division Software - C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindService.exe
O23 - Service: TuneUp WinStyler Theme Service (TUWinStylerThemeSvc) - TuneUp Software GmbH - C:\Program Files\TuneUp Utilities 2006\WinStylerThemeSvc.exe
MERCI BEAUCOUP
Au revoir
