Micro saccades jeux - Matériels & problèmes divers - Hardware
Marsh Posté le 02-02-2015 à 21:18:22
Yop,
Eh bien, je prend exemple sur BF4, si je fais une rotation sur moi-même j'ai des arrêts, une sorte de lag. Un lag très très court (peut-être 1ms) mais c'est assez embêtant, ça gâche un peu la fluidité du jeu.
Marsh Posté le 02-02-2015 à 22:15:58
Non, depuis je ne sais pas une semaine on va dire. Je n'ai fait aucun changement matériel entre temps, ni installer un quelconque logiciel..
Marsh Posté le 19-02-2015 à 01:07:09
I have found a solution to our problem that has worked for me so far. Some genius out there on the internet somewhere discovered that the artifacting desktop is coming from frequency swapping which is something that AMD overdrive does automatically. When your computer is idle your frequency goes down to 300mHz which for some mysterious reason is a clock speed that is unstable or may be just the swapping part causes it to become unstable.
So to fix this you first need to disable hardware control in MSI afterburner if you have that software. Then go to CCC via right clicking your desktop. Go to presets>Add Preset> Name it and create it. Then go to start>Accessories>Run and type in %appdata% . This will take you to appdata/roaming but you want to be in local so click on appdata in the address bar and go to local. (you could save all of that mess by just enabling hidden folders in folder and search options). Go to Ati/Ace/Profiles from appdata/local (For people who do not need barney instructions it is in here C:\Users\(your name here)\AppData\Local\ATI\ACE\Profiles). Edit the .xml file in Notepad that you named for the preset. Your values should look like this but make sure you use the default clock speeds to prevent damage. 1080 is my mHz core clock so the value is 108000 and my memory clock is 1550mHz so the value is 155000. Do not worry about Want_3 it will go away after you do this. Save the file and apply it with CCC. Now your your clock speeds should not fluctuate and cause artifacts. Also I am still testing this method but it has worked for me for about 3 hours now.
#<Feature name="CoreClockTarget_PCI_VEN_1002&DEV_6798&SUBSYS_30011682&REV_00_4&14E8F4CB&0&0010A">
<Property name="Want_0" value="108000" />
<Property name="Want_1" value="108000" />
#<Feature name="MemoryClockTarget_PCI_VEN_1002&DEV_6798&SUBSYS_30011682&REV_00_4&14E8F4CB&0&0010A">
<Property name="Want_0" value="155000" />
<Property name="Want_1" value="155000" />
enjoy, à diffuser, jai eu ce pb aussi !!
Marsh Posté le 01-02-2015 à 17:35:29
Bonjour tous le monde,
![:) :)](https://forum-images.hardware.fr/icones/smile.gif)
Depuis quelques temps j'ai remarqué de légères saccades lorsque je suis, en jeux en mode solo..(BF4, Fifa14, NFSMW2 entre autre) et ceci quelque soit la qualité du jeux (le problème est présent que ce soit en low ou en ultra). Pour exemple, BF4 tourne à environ 40fps et Fifa 60.
J'ai essayé pas mal de petit truc dont ceci ->http://www.jeuxvideo.com/forums/1-13937-74345-1-0-1-0-pc-supprimer-le-microstuttering.htm
J'ai également essayer le screen display server en limitant les framerates à 60 et 50.
J'ai désinstaller le pilote graphique actuel pour le remplacer par des plus anciens...sans succès.
J'ai nettoyé mes disques dur, scan antivirus.
J'ai évidemment lancé mes jeux sans application en tâche de fond (sans antivirus, sans parefeu).
Ma config':
-Carte mère: Gigabyte GA-770TA-UD3
-Alimentation: Corsair: Corsair TX - 750W
-CPU: Phenom II x4 black edition 965
-GPU: R9 280X
-RAM: Corsair 2*4GO (1333Mhz)
-Disque dur principal: SSD Kingston 120Go
-Disque dur secondaire: HDD WD 2to (un autre HDD Samsung 500Go)
En vous remerciant par avance pour votre aide.
Message édité par nantais1992 le 02-02-2015 à 17:26:21
