Ordinateur qui fonctionne 1 jour seulement - Matériels & problèmes divers - Hardware
Marsh Posté le 08-06-2010 à 08:59:17
Hello, Win 7 64 bit........???
Marsh Posté le 08-06-2010 à 14:05:12
Vérifie ta ram d'abord avec Memtest puis ton disque dur.
Mais il nous faudrait tes écrans bleus, essaie de les récupérer avec Whocrashed.
Marsh Posté le 08-06-2010 à 15:13:43
Bonjour pcokay,
Voici le rapport de whocrashed :
Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Tue 08/06/2010 06:26:06 your computer crashed
This was likely caused by the following module: ntfs.sys
Bugcheck code: 0x24 (0x1904FB, 0x8DB6FA14, 0x8DB6F5F0, 0x82CD3060)
Error: NTFS_FILE_SYSTEM
Dump file: C:\Windows\Minidump\060810-23961-01.dmp
file path: C:\Windows\system32\drivers\ntfs.sys
product: Système d’exploitation Microsoft® Windows®
company: Microsoft Corporation
description: Pilote du système de fichiers NT
The crash took place in a standard Microsoft module. Your system configuration may be incorrect, possibly the culprit is in another driver on your system which cannot be identified at this time.
Conclusion
1 crash dumps have been found and analyzed. Note that it's not always possible to state with certainty whether a reported driver is really responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Marsh Posté le 08-06-2010 à 16:06:53
Commence par vérifier ton disque dans ce cas !
http://www.samsung.com/eu/business [...] ls_fr.html
Marsh Posté le 08-06-2010 à 17:02:18
oui mais je ne comprends pas pourquoi ça plante avec mon DD samsung 500go sata et aussi avec mon maxdator 80go ide.
Le planatage de ce matin avec le rapport ci-dessus a été réalisé sur mon maxdator.
Et là, le PC refonctionne, jusqu'au prochain plantage.
Je ne comprends pas comment de stable ça peut passer à complètement instable et vice versa.
Marsh Posté le 08-06-2010 à 17:13:25
Faudrait voir si t'as les mêmes plantages avec l'autre disque dur, et si c'est toujours le même écran bleu.
Marsh Posté le 09-06-2010 à 12:01:15
| pcokay a écrit : Faudrait voir si t'as les mêmes plantages avec l'autre disque dur, et si c'est toujours le même écran bleu. |
Oui avec les 2 disques. Il a fonctionner toute l'aprem et là ce matin, voici le message que j'ai :
http://www.casimages.com/img.php?i [...] .jpg"
Je craque!!!!
Maintenant, j'ai des écrans noir où j'ai juste le pointeur de la souris!
Marsh Posté le 09-06-2010 à 12:15:57
Salut.
Question : T'a un windows XP SP3 sous le coude ???.
Si oui essai de l'installer avec le minimum syndical pour voir ce qu'il ce passe....
Edit :
Je suis pas spécialement anti Win7 hein
, j'ai trois machines chez moi et toutes en Win7 x64 et aucun souci...
Marsh Posté le 09-06-2010 à 12:40:34
si mais j'ai déjà essayé, ça plante aussi.
Par contre je suis ne train de faire un memtest là,
Pour le moment il a trouvé des erreurs pour les test 7 et 8
Je ne sais pas ce que cela représente.
Je vous tiens au courant.
Marsh Posté le 09-06-2010 à 12:45:51
Problèmes sur tes barrettes mémoires.
Vérifie déjà si elles sont bien enfoncer dans leurs logement.
Si c'est le cas, vérifie qu'elles sont sur les bons emplacement, voir de les changer d'emplacement.
Fait un memtest à chaque manip pour valider que tout marche.
Si t'a toujours des problèmes avec memtest : go chez ton vendeur les remplacées, elles sont défectueuses.
Marsh Posté le 09-06-2010 à 14:13:30
C'est clairement un probleme materiel.
Si memtest indique des erreures, tu as déjà un soucis avec tes barettes.
ATTENTION : cela ne veut pas forcement dire qu'elle sont HS, mais peut-être simplement mal configurées.
Prend la référence de tes barettes, puis vérifie à quels timmings et voltage elles sont certifiées. Il faut après que dans ton bios tout corresponde.
Si tout correspond, teste ton system avec une seule barette à tour de rôle.
Aussi, avec un logiciel comme HW Monitor, relève les températures de tes composants en load et idle.
Marsh Posté le 09-06-2010 à 14:23:45
Les barrettes mémoires sont des corsair XMS3
4gb (2x2gb) DDR3 1333MHz
TW3X4G1333C9A
9-9-9-24 1,50V ver 2.2
Marsh Posté le 09-06-2010 à 14:25:57
Donc dans ton bios, elle sont bien réglées en 9.9.9.24 à 1.5 V ?
Marsh Posté le 09-06-2010 à 14:59:30
dans le bios j'ai vu :
DRAM voltage : 1.545 (auto)
dans la rubrique ai tweaker j'ai :
DRAM CAS# latency 9
DRAM RAS# to CAS# Delay 9
DRAM RAS# PRE Time 9
DRAM RAS# ACT time 24
DRAM read to pre time 5
DRAM Row cycle time 34
DRAM write recovery time 10
DRAM RAS# to RAS# dedlay 5
DRAM read to write delay 8
DRAM write to read delay (DD) 2
DRAM write to read delay (SD) 5
DRAM write to write timing 4
DRAM read to read timing 4
DRAM REF cycle time 110
DRAM refrash rate 7.8
DRAM command rate 2T
Il faut laisser faire combien de cycle à memetest?
Marsh Posté le 09-06-2010 à 16:32:33
La cause de ce type d'erreur peut être une des suivantes :
* Pilote (driver) de carte graphique corrompu
* Ports USB présents dans la séquence d'amorçage du BIOS. Il suffit d'entrer dans le setup du BIOS et de retirer les périphériques USB de la séquence de démarrage : (boot sequence)
* Barrette mémoire (RAM) défectueuse
* Surchauffe du processeur
source
//www.commentcamarche.net/faq/4674-bad-pool-caller-header
as-tu verifié la pile du bios ? (=l'ordinateur conserve la date et tes reglages?)
Marsh Posté le 09-06-2010 à 17:01:21
| golumest a écrit : La cause de ce type d'erreur peut être une des suivantes : |
Si il a fait un Memtest avec des erreurs c'est la barrette sur 90% ou la carte mère mais pas la pile du bios.
Faudrait faire un test croisé avec une autre mémoire.
Marsh Posté le 09-06-2010 à 17:02:13
| driiene a écrit : dans le bios j'ai vu : |
Je dirais 3 ou 4 cycles.
De toute façon si tu a des erreurs dès le premier cycle, tu peut arrêter ^^
Essai de trouver la bonne conf de timing dans les paramètres de ton bios. Ça peut effectivement jouer.
M'enfin je pense que tes barrettes on l'air bonnes à changer...
Marsh Posté le 09-06-2010 à 17:02:39
| pcokay a écrit : |
+ninehundred
Marsh Posté le 09-06-2010 à 17:12:23
En remplaçant la pile de mon bios (donc la date est revenu en janvier 1970), mon antivirus m'a mis une pagaille monstre (passé de 2006 à 1970 l'a fait paniqué) ce qui se soldait par un ecran bleu, mais par contre c'était à chaque demarrage...
Marsh Posté le 09-06-2010 à 17:44:19
Faut tester les barettes une après l'autre. Peut-être n'y a t-il qu'une barette de defectueuse.
Marsh Posté le 09-06-2010 à 18:04:50
C'est difficile de les tester : là je viens de lancer des tests, elles sont bonnes toutes les 2...J'ai l'impression que le problème est intermittent.
Marsh Posté le 09-06-2010 à 21:01:02
Et si c'était un slot de RAM en défaut ???
Va sur ton ordi et fait en une utilisation comme d'hab en utilisant une seule mémoire sur le slot qui est testé sans erreure..... on ne sai jamais ....
Marsh Posté le 10-06-2010 à 09:43:12
J'ai eu un problème Minidump quand je voulais installer Photoshop CS5 sur Seven 32 bits=>ecran bleu+reboot obligatoire.
Memtest ne trouvait aucune erreur.
J'ai mis Seven 64 bits et miracle plus aucun soucis...
Donc installe Seven 64 bits et ca devrait rouler
Marsh Posté le 10-06-2010 à 10:54:54
| Alkinos a écrit : J'ai eu un problème Minidump quand je voulais installer Photoshop CS5 sur Seven 32 bits=>ecran bleu+reboot obligatoire. |
Memtest trouve des erreurs mais pas tout le temps. Il trouve des erreurs lorsque je fais un scan après un reboot de l'ordi.
j'ai changé de slot et j'ai encore eu le problème.
Je vais faire tourner l'ordi seulement sur une barette pour voir laquelle déconne. Cela risque d'être long.
Marsh Posté le 10-06-2010 à 11:07:04
Ah alors effectivement surement un pbm de ram...
Tu as un Seven 64 sous la main? fais le test si tu peux
Marsh Posté le 10-06-2010 à 11:33:36
| Alkinos a écrit : Ah alors effectivement surement un pbm de ram... |
Je n'en ai pas ![]()
Marsh Posté le 14-06-2010 à 18:20:08
Bonjour.
A priori, c'est bien une seule de mes 2 barrettes qui ne fonctionne pas correctement :
-barrettes 1 : fonctionne correctement depuis 5 jours
-barettes 2 : problème après 30sec à 2mm de fonctionnement
Un grand merci à tous ![]()
Marsh Posté le 08-06-2010 à 08:43:57
J'ai monté mon nouveau PC avec Win 7 pour jouer à starcraft 2 ^^
AMD Phenom II X4 965 black
ASUS M4A88TD-M EVO/USB3
CORSAIR XMS3 2x2GB DDR3 montés sur les emplacements bleus de la carte mère
ATI radedon XFX 5770 1go
Alim OCZ 600watts 80+
DD sata samsung 500 go
Pas de problème de fonctionnement pendant une semaine, tout marche nickel.
Puis d'un coup le problème survient, le logiciel antivirus (avira antivir free avec mise à jour effectuer), ati catalyst, windows explorer, chrome, gestionnaire des tâche windows...enfin bref tout les logiciel, affiche des erreurs diverses et varié (virus, matériel, manque un fichier dll, (kermell32.dll, MSVCR90.dll...) fichier corrompu...)
Puis d'un coup, écran bleu avec une page de texte en anglais qui s'affiche pendant 2 sec (le temps de lire "bad pool header" ou sur un autre "cache manager" et le PC reboot.
Une fois rebooté, les même symptômes apparaissent. .
Je formate le tout, réinstalle Win 7, tout les pilotes matériels, tout fonctionne j'allume et éteint plusieurs fois le PC, je lui fait faire un peu de tout, dont un énorme contrôle avec une floppé d'antivirus : rien!
Le lendemain matin, je le rallume, les mêmes symptômes de la veille : Problèmes avec tout les programmes, écran bleu
J'ai rééditer plusieurs fois la réinstallation complète de mon système, le jour où c'est fait, tout marche nickel, le lendemain plus rien de fonctionne, c'est à croire qu'il tombe malade durant la nuit lol, PC sans lendemain qui fonctionne un jour seulement
Je ne comprends pas pourquoi le problème n'intervient que le le lendemain et pas immédiatement.
J'ai lancé un message de détresse dans la partie spyware/virus du forum, nous n'avons rien trouvé en exploitant cette branche. Peut-être un conflit matériel?
J'ai changé de disque dur, j'ai toujours le même souci.
En espérant trouver la solution avec vous...Merci de votre aide.
