[antec true power 330 W] : risques à l'install ?
: risques à l'install ? [antec true power 330 W] - Matériels & problèmes divers - Hardware
Marsh Posté le 01-11-2002 à 11:16:37
Je viens de lire l'article suivant :
http://www.mikhailtech.com/article [...] age7.shtml
qui m'a convaincu en tous points d'acheter la true power, sauf sur ceci :
"I fried my HDD (Antec didn't idiot-proof their PSU 100%) "
Quelle en est la signification exacte ?
De manière générale, quelles précautions faut-il prendre pour installer une alimentation ?
Marsh Posté le 01-11-2002 à 11:21:31
textuellement:
"Antec n'a pas protégé son alim contre les idiots à 100%"
je suis en train de regarder pourquoi dans la review...
Marsh Posté le 01-11-2002 à 11:29:23
Citation de l'article :
Well, that's my test system. Or at least that was my test system. First off, the lowest beige drive is a 12x Toshiba CD-ROM. That is no longer present. Initially this is what I tested on, but I had a minor incident ... I fried my hard drive. It was my fault though. To make a long story short, I was hooking up the cables after the tests were completed but I couldn't see the FDD pins, so I just did it by touch. Turns out only three of the four pins connected. Or one of the four; I'm not sure. It also turns out that my HDD (a 30gb IBM 75GXP, I know some of you are happy to read this) was connected on the same line. So I fire up the system. Hear a few cracks. Turn it off just in time to see a handful of smoke and smell some burnt plastic.
Good news is, nothing in the power supply was damaged. Although a little brown, the FDD connector still functions perfectly and so does every other component in the system. Except the hard drive. That's the bad news. It was a good drive that lasted me for almost two years and although I had no valuable information on it (except the saved test data) it was still sad to see it go. Oh well, now I have another IBM drive in there, this one even louder and more annoying: a 60GXP.
Donc en gros le testeur a mal branché l'alim de son lecteur de D7 ... et ça a bousillé son DD IBM qui était sur la même nappe d'alim :)
Marsh Posté le 01-11-2002 à 11:33:03
:lol:
mmm k'est-ce qu'il a pu faire....
passke si tu le fous décallé, tu fous le +5V ou le +12V à la masse...
Marsh Posté le 01-11-2002 à 11:33:29
t'inquiète pas, la true power 330 est à côté de ma jambe droite et ça fonctionne très bien, et en silence pour peu qu'il fasse pas trop chaud chez toi... ;)
une très bonne alim
Marsh Posté le 01-11-2002 à 11:48:48
en fait en foutant le +5V ou le +12V en court-jus, l'alim a sortie toutes ses tripes pour maintenir le +5V ou le +12V au connecteur ATX (via les cables de sense), et la ligne à dû monter au plafond pour maintenir une tension correcte, donc l'alim a dû se couper quand le +5V s'est emballé à +6.5V ou le +12V à 14.4V.
En fait ça dû etre rapide, l'alim a laché la tension en court-jus, et au bout de quelques millisecondes l'alim s'est coupée dû à l'overvolt+overcurrent... ça été suffissamment long pour "pchiter" le disque dur, mais il a eu de la chance tout le pc aurait pu morfler...
d'ailleurs je suis étonné que le cable de la ligne en court-jus aye supporté le court-jus (passke 5V à 30A dans le même cable, ou 12V à 17A, hum, elle est rapide la bougresse en auto-protection :D)
Marsh Posté le 01-11-2002 à 11:50:35
moi j'ai HT une 380 :love: hier
Marsh Posté le 01-11-2002 à 11:54:02
enermax550w a la bof lol
je vais la virer et mettre une chieftec ou une ttgi voir en cas une antec lol
