Multimédia Intel Corporation:6 Series/C200 Series Chipset Family High Definition Audio Controller: P8P67 Deluxe Motherboard Materiel non reconnu (V:nVidia Corporation,D:0xe0c)
Ponts Intel Corporation:2nd Generation Core Processor Family DRAM Controller: P8P67 Deluxe Motherboard Intel Corporation:Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port Intel Corporation:6 Series/C200 Series Chipset Family PCI Express Root Port 1 Intel Corporation:6 Series/C200 Series Chipset Family PCI Express Root Port 5 Intel Corporation:6 Series/C200 Series Chipset Family PCI Express Root Port 7 Intel Corporation:6 Series/C200 Series Chipset Family PCI Express Root Port 8 Intel Corporation 67 Express Chipset Family LPC Controller: P8P67 Deluxe Motherboard PLX Technology, Inc. EX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch PLX Technology, Inc. EX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch PLX Technology, Inc. EX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch PLX Technology, Inc. EX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch PLX Technology, Inc. EX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch PLX Technology, Inc. EX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch PLX Technology, Inc. EX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch PLX Technology, Inc. EX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch Materiel non reconnu (V:1b21,D:0x1080)
Communications Intel Corporation:6 Series/C200 Series Chipset Family HECI Controller #1: P8P67 Deluxe Motherboard
Bus Séries Intel Corporation:6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2: P8P67 Deluxe Motherboard Intel Corporation:6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1: P8P67 Deluxe Motherboard Intel Corporation:6 Series/C200 Series Chipset Family SMBus Controller: P8P67 Deluxe Motherboard Vr4181A USB Host or Function Control Unit:uPD720200 USB 3.0 Host Controller: P8P67 Deluxe Motherboard Vr4181A USB Host or Function Control Unit:uPD720200 USB 3.0 Host Controller: P8P67 Deluxe Motherboard VIA Technologies, Inc.:VT6315 Series Firewire Controller: P8P67 Deluxe Motherboard
Périphérique USB Logitech, Inc. Webcam C250 (Logitech USB Camera (Webcam 250)) Logitech, Inc. Webcam C250 (Logitech Webcam 250) Logitech, Inc. Webcam C250 (Logitech Mic (Webcam 250)) Logitech, Inc. Logitech HID-compliant G1 Optical Mouse (USB Input Device) Intel Corp. Integrated Rate Matching Hub (Generic USB Hub) Clavier Standard PS/2 Keyboard Souris HID-compliant mouse Ecran(s) Acer X233H ( X233H)
voila pour la config et maintenant ou cela bloque (petit triangle jaune):
Carte de bouclage microsoft
Realtek PCIe GBE Familly Controller
Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26 (a savoir que le -1C2D identique a celui ci n'a aucun problème)
Renesas Electronics USB 3.0 Host Controllers ( les deux ne fonctionnes pas )
voila c'est deja pas mal ah oui je voudrais savoir pourquoi mon disc dur ssd et reconnu comme une clé usb et aussi savoir pourquoi son indice windows et passé de 7.6 a 7.4 même aprés défragmentation et nettoyage rien a faire merci d'avance au personne voulant bien se pencher sur mon cas ^^
Marsh Posté le 26-09-2011 à 15:12:42
Bonjour a tous alors j'ai un gros souci c'est que mes drivers s'en vont a chaque redémarrage
du pc j'ai réinstaller les drivers d'origine j'ai essayer d'en installer des nouveaux a partir de
l'outil ma config ect rien a faire voici ma config :
Informations générales
Version du plugin
5.1.4.1
Version de la base
19
Date de la détection
17/09/2011 07:10
Modules
Système d'exploitation
Windows 7 Edition Intégrale (x64) (build 7601) Service Pack 1
Navigateur web par défaut: Mozilla Firefox
Client e-mail par défaut: Microsoft Office Outlook
WinSAT
Note Générale 7.4 (Processeur: 7.6, Mémoire vive: 7.6, Graphiques: 7.9, Graphiques de jeu: 7.9, Disque dur principal: 7.4 )
Carte mère
SMBios version 2.6
ASUSTeK Computer INC. P8P67 DELUXE Rev 1.xx
Bios: American Megatrends Inc. 1502 03/02/2011 taille: 4096Kb
Chipset
Northbridge: Intel Sandy Bridge
Southbridge: Intel P67
P
rocesseur
Intel Core i7 2600K Sandy Bridge Socket 1155 LGA (@32 nm) 3400 Mhz ( L1I: 4 x 32 Ko, L1D: 4 x 32 Ko, L2: 4 x 256 Ko, L3: 8192 Ko )
Mémoire
Mémoire physique totale: 4096 Mo, Type: DDR3, @668.9MHz, 9.0-9-9-24-1T
DDR3 Corsair CMX4GX3M2A1600C9 2048 Mo PC3-10700H (667 Mhz)
Carte Graphique
NVIDIA GeForce GTX 560 Ti
Périphériques ATA
OCZ-VERTEX2 1.32 (SSD SATA II, 111.79 Go)
WDC WD2000JS-00MHB0 02.01C03 (SATA II, 186.31 Go, Cache: 8 Mo)
Lecteurs CD/DVD
DTSOFT Virtual CdRom Device
Optiarc DVD RW AD-7260S 1.03 (DVD+R/DL Recorder)
Disque dur
OCZ-VERTEX2 ATA Device
WDC WD2000JS-00MHB0 ATA Device
Cartes PCI/AGP
Stockage
Intel Corporation:6 Series/C200 Series Chipset Family 6 port SATA AHCI Controller: P8P67
Deluxe Motherboard
JMicron Technology Corp.:JMB362 AHCI Controller: P8P67 Deluxe Motherboard
Marvell Technology Group Ltd.:88SE9128 PCIe SATA 6 Gb/s RAID controller with HyperDuo: P8P67 Deluxe Motherboard
Réseau
Intel Corporation:82579V Gigabit Network Connection: P8P67 Deluxe Motherboard
Realtek Semiconductor Co., Ltd.:RTL8111/8168B PCI Express Gigabit Ethernet controller: P8P67 Deluxe Motherboard [Realtek RTL8111E]
Affichage
nVidia Corporation:GF110 [GeForce GTX 560 Ti]:
Multimédia
Ponts
Intel Corporation
Communications
Bus Séries
Périphérique USB
Clavier
Souris
HID-compliant mouse
Ecran(s)
Acer X233H ( X233H)
