Quelle carte Tuner TV pour un Ecran Sagem Axium 127cm?
Quelle carte Tuner TV pour un Ecran Sagem Axium 127cm? - Matériels & problèmes divers - Hardware
Marsh Posté le 20-09-2004 à 11:20:44
J'ai comme projet de me monter un Media center qui sera branché sur un ecran Haute Définition Sagem Axium de 127cm de diagonale.
Je souhaite donc avoir une carte Tuner TV de trés bonne qualité qui me permettra d'avoir une résolution assez haute pour être projeté sur la télé. Ce Media center me permettra bien entendu de jouer le rôle de magnétoscope numérique d'ou l'intérêt aussi d'avoir une trés bonne résolution.
Merci d'avance pour vos conseils,
Urmi
Marsh Posté le 21-09-2004 à 00:49:39
personne n'a d'idée sur le sujet??
Marsh Posté le 21-09-2004 à 01:57:22
Achete toi ca:  Liteon LVW-5005 "Stand-alone" DVD Recorder with Built in TV Tuner
Finally there is a "stand-alone" DVD recorder that is able to record on DVD+R/RW, DVD-R/RW and CD-R/RW discs. You will have no more confusion on which DVD format to choose. For a long time there have DVD recorders that have been marketed as replacements for VHS recorders, but this model really fits that description and is probably he first machine that does!
Another useful feature is the picturized index title for each video program that you have recorded. You can easily and quickly select any program you have recorded at a glance. Furthermore, with DVD recording, you can now name each video programs which you have recorded.
This recorder also includes a DV-Link (IEEE1394) port, which allows you to connect the LVW-5005 to a DV Camcorder. By connecting the Camcorder directly to the LVW-5005, users can preserve high-quality digital images onto DVDR discs.
This unit also features a "Scart in" socket making it easy to connect to other video equipment i.e DVD player, VHS player, Sky box etc.
A single empty DVD disc offers up to 6 hours of recording time (SLP Mode).
There is an "Easy Guider Menu" to navigate you through the process of basic functions, like record and playback, on a step-by-step basis. This graphic-based Easy Guider provides error-free recording and is suitable for users of all ages. Even adults can understand it!
Standalone recorders are currently getting more and more popular and the market is already full of such devices, but with good design, good build quality and the backup of Liteon (A market leader in DVD writing technology), this recorder is in our opinion the pick of those available in the under £300 catagory. At under £200 it is an absolute bargain!
Dimensions (mm) (WxHxD): 420x66x268
Power supply: AC 140 - 240V. UK 13amp plug
TV standard: NTSC, PAL/SECAM
http://www.blankdiscshop.co.uk/acatalog/HA4088.gif
A+
Marsh Posté le 21-09-2004 à 02:14:54
déjà merci pour ta réponse.
EN ce qui concerne ce DVD recorder, je préfère me monter ma media box moi même pour la bonne et simple raison que c'est beaucoup plus flexible et que je peux donc l'utiliser pour pas mal d'autre chose: Rôle de passerelle, lecture MP3, DivX, photos...etc
Urmi
Marsh Posté le 21-09-2004 à 02:39:55
je comprend, peu etre un Hauppage, c'est tres bien
http://www.hauppage.com
Fais moi sign
A+
Nimo & Nimo_Corp
Marsh Posté le 21-09-2004 à 10:55:18
rn fait j'avais déjà une Haupauge winTV go mais je trouve que la qualité est moyenne est g peur que lors du passage sur un grand écran ca soit vraiment pas top... et comme je n'ai pu tester personnellement d'autres carte Tuner Tv je ne connais pas la qualité ni des tuner en eux même ni de leur blindage etc...
Si quelqu'un a de trés bonnes expériences avec l'une ou l'autre de ces cartes je suis preneur!
Merci encore nimo ;)
Urmi
Marsh Posté le 03-10-2004 à 00:25:34
une carte reception satellite me paraitrait une bonne solution :)
jsuis passé a darty ce matin et jsuis resté comme un gosse devant cet écran magnifique, a mon avis ca fait bien mieux que n'importe quel plasma ;)
si j'avais le budget c'est ce que j'acheterai sans hésiter.
Message édité par gladi4tor le 03-10-2004 à 00:27:13
Marsh Posté le 05-11-2004 à 17:41:29
on a pas du voir les mêmes plasma alors  :heink:
Marsh Posté le 22-08-2006 à 07:49:19
j'attends de voir avec la PEEKBOX 4 de peekton branché en DVI sur le retro pour la HD
