[Résolu ???] Freeze aleatoire Asus A7V8X-X
Freeze aleatoire Asus A7V8X-X [Résolu ???] - Matériels & problèmes divers - Hardware
Marsh Posté le 19-03-2007 à 14:39:00
Bonjour, j'ai un problème de freeze avec mon pc depuis 2 semaines a peu pres avec cette configuration :
"Field Value
Computer
Operating System Microsoft Windows XP Professional
OS Service Pack Service Pack 2
DirectX 4.09.00.0904 (DirectX 9.0c)
Computer Name ****
User Name ****
Motherboard
CPU Type AMD Athlon XP, 1917 MHz (11.5 x 167) 2600+
Motherboard Name Asus A7V8X-X (6 PCI, 1 AGP, 3 DDR DIMM, Audio, LAN)
Motherboard Chipset VIA VT8377 Apollo KT400
System Memory 1024 MB (PC3200 DDR SDRAM)
BIOS Type Award Modular (09/02/04)
Display
Video Adapter NVIDIA GeForce 6600 (256 MB)
3D Accelerator nVIDIA GeForce 6600 AGP
Monitor LG StudioWorks 776M [17" CRT]
Multimedia
Audio Adapter VIA AC'97 Enhanced Audio Controller
Storage
IDE Controller VIA Bus Master IDE Controller - 0571
SCSI/RAID Controller Silicon Image SiI 0680 Ultra-133 Medley ATA Raid Controller
Floppy Drive Lecteur de disquettes
Disk Drive WDC WD102AA (9 GB, IDE)
Disk Drive Lecteur de disque (76 GB)
Disk Drive Generic USB CF Reader USB Device
Disk Drive Generic USB MS Reader USB Device
Disk Drive Generic USB SD Reader USB Device
Disk Drive Generic USB SM Reader USB Device
Optical Drive MEMOREX CD-MAXX52 (52x CD-ROM)
Optical Drive PIONEER DVD-RW DVR-110 (DVD+R9:8x, DVD-R9:8x, DVD+RW:16x/8x, DVD-RW:16x/6x, DVD-RAM:5x, DVD-ROM:16x, CD:40x/32x/40x DVD+RW/DVD-RW/DVD-RAM)
SMART Hard Disks Status OK
Partitions
C: (FAT32) 10226 MB (3252 MB free)
D: (NTFS) 56658 MB (9927 MB free)
E: (NTFS) 10236 MB (3367 MB free)
F: (FAT32) 1025 MB (32 MB free)
G: (NTFS) 9781 MB (3551 MB free)
Total Size 85.9 GB (19.7 GB free)
Input
Keyboard Clavier standard 101/102 touches ou clavier Microsoft Natural Keyboard PS/2
Mouse Souris Microsoft PS/2
Network
Network Adapter 802.11g PCI Wireless Adapter (192.168.1.12)
Network Adapter VIA Rhine II Fast Ethernet Adapter (192.168.1.33)
Peripherals
USB1 Controller VIA VT83C572 PCI-USB Controller
USB2 Controller VIA USB 2.0 Enhanced Host Controller
USB Device Périphérique de stockage de masse USB
Problems & Suggestions
Problem Disk free space is only 3% on drive F:."
Au niveau des temperatures :
"CPU : ~40°C
GPU : ~40°C
Motherboard : ~30°C"
J'ai tenté la reinstall a plusieurs reprises sans succès, le pc fonctionne a peu pres normalement en mode vga/sans echec. Si quelqu'un a une idee je suis preneur ^^
Message édité par neothedarkone le 26-03-2007 à 14:32:13
Marsh Posté le 19-03-2007 à 17:30:51
Réinstalle, c'est a dire formatage!?
Marsh Posté le 20-03-2007 à 12:25:30
Par reinstall j'entends formatage du disque, reparation du systeme et reinstall sur un autre disque dur pour tester...
Marsh Posté le 20-03-2007 à 18:59:02
Alimentation?
Marsh Posté le 21-03-2007 à 19:34:27
RomainD2 a écrit :
Alimentation?
Alimentation LC Power 550W neuve (qqs semaines)
Disque dur Maxtor 80Go (que j'ai moi même vérifié)
DDR 400 1Go Kingston (test passé sous memtest)
Carte graphique Galaxy Geforce 6600 (ajouté dissipateurs + ventilo Zalman dernièrement)
Marsh Posté le 21-03-2007 à 19:39:53
La page qui fache :
http://www.matbe.com/articles/lire [...] page25.php
Tu n'as pas d'autres alimentation pour tester?
Marsh Posté le 21-03-2007 à 19:45:46
La LCPower remplace mon alim habituelle mais cela n'y change rien...
Marsh Posté le 23-03-2007 à 20:59:31
Une idée quelqu'un ?
Marsh Posté le 23-03-2007 à 21:01:53
faux contact ptetre
Marsh Posté le 23-03-2007 à 21:03:17
Hmm... j'ai vérifié et il n'y rien...
Marsh Posté le 23-03-2007 à 21:05:54
ptetre ta cm qui est fatigué
Marsh Posté le 23-03-2007 à 21:14:14
Elle n'est pas sollicitée trop durement (pas d'overclock du tout).
Marsh Posté le 26-03-2007 à 14:31:39
Problème résolu ? J'ai temporairement remplacé ma carte Galaxy Geforce 6600 par une Sapphire Radeon 9250 et pour l'instant cela fonctionne de manière stable... Question, j'ai acheté ma Galaxy à Microgate en Septembre, est-elle toujours sous garantie ? et si elle l'est est-ce que le fait que j'ai changé le ventirad et ajouté des dissipateurs pour ram annule ma garantie ?
Marsh Posté le 30-03-2007 à 13:40:18
Quelqu'un peut-il/elle répondre à ma dernière question ?
Marsh Posté le 30-03-2007 à 14:00:43
utilise driver cleaner pour enlever toutes traces/résidus de driver nvidia.
changer de ventilo et de dissipation ram peut effectivement etre un refus de garantie à 80%, il faudrais remettre la carte en ventilo d origine avant de l envoyer ca serais plus prudent :ange:
F: (FAT32) 1025 MB (32 MB free) > libére de la place sur cette partition, s il essaye d y écrire ca peut freezer.
effectue un memtest sur ta ram au cas ou, ca peut venir de là.
supprime tous les fichiers temporaires, vérifie comment est configurée la mémoire virtuelle.
un test avec une autre alim serais aussi bienvenue.
Message édité par carrera le 30-03-2007 à 14:03:32
---I like Scsi---
Marsh Posté le 02-04-2007 à 14:18:42
Effectivement j'ai remis le ventirad d'origine a sa place (vu que ma carte est toujours sous garantie) et que je me doutais que ca poserait probleme. En ce qui concerne la partition F, il s'agit d'une partition de swap :ange: donc il est normal qu'elle soit pleine...
Le memtest a ete effectue lors des premiers freeezes, donc il y a bientot un mois. Les deux barettes ont passe les tests avec succes.
Le test avec une autre alim a deja ete effectue aussi lors des premiers freezes vu que je me doutais que cela pouvait venir de la (mais non...).
