aide pour traduire notice d'installation d'un firmware
aide pour traduire notice d'installation d'un firmware - Matériels & problèmes divers - Hardware
Marsh Posté le 09-05-2003 à 13:34:05
j'aimerais installer un firmware plus récent, pour mon lecteur dvd (matshita sr 8583a) mais la notice est en anglais et j'y comprend rien.
donc si quelqu'un veut bien m'aider.
merci d'avance.
        Down load procedure for PC  (Ver.3)
<Note>
  When you flash FW of DVD-ROM, please use utilitise in MD-DOS MODE or
  COMMAND PROMPT MODE.
<Connect DVD-ROM to PC>
  Please set drive to Slave of Primary port.
<Option switch of V3FWMKE>
 When enter "V3FWMKE" on the DOS prompt, help message appears as bellow.
 Please add opion switch if drive is set except Master of Secondary.
Flash Write for MKEV3DVD 980402
usage:v3fwmke [-options ...] F/WFile BootFile HeaderFile
-P:Primary -S:Secondary or -$xxx:ide port base address  default:Secondary
-M:Master -L:sLave  default:Master
-C:"*.MOT" -> "*.BIN" Convert only
-Ofile:Odc file name
-Dfile:Dsc file name
-Ux:LUN  default:0
-A:set ControlByte 'A' and offset 0
-.:debug mode
<Procedure to download>
  Please confirm following files are in same directry.
    a. SC15C_PM.MOT  (F/W file)
    b. V3FWMKE.EXE  (execute file)
    c. V1050.MOT    (F/W file : constant module)
    d. MKEV3DVD     (parameter file)
  Please use batch file T.BAT.
  T.bat is "V3FWMKE SC15C_PM.MOT V1050.MOT MKEV3DVD".
  This V3FWMKE will make the file SC15C_PM.MOT V1050.MOT MKEV3DVD integrate
  into one file. Then a command is issued from host PC for download to
  DVD-ROM and transfer F/W data.
  An indication on PC when this file is executed is as follows.
C:>V3FWMKE SC15C_PM.MOT V1050.MOT MKEV3DVD <Enter>
   sum:xxxx(800-BFD)
   sum:xxxx(C00-FFD)
   sum:xxxx(1010-1FFFF)
   Program Change Command success
   Write Microcode Command ........ x.xxs success
   Read Microcode Command...........x.xxs success <== complete transferring
   Verify success
   Synchronize MIcrocode Command <== start to write into Flash ROM
   ( Check-sum data may be diferrence from actual value as indicated.)
After the process is completed with the above indication, the prompt is on PC.
You should power off/on in order to re-start DVD-ROM.
Marsh Posté le 09-05-2003 à 13:41:17
en gros
tu mets ton DVD en esclave sur le premier port IDE
tu flashes en mode MSDOS pur et dur (le plus simple est de faire avec une disquette DOS sans config.sys ni autoexec.bat)
la disquette doit contenir les fichiers
SC15C_PM.MOT,V3FWMKE.EXE, V1050.MOT, MKEV3DVD et T.BAT
tu bootes sur la disquette et tu lances T.BAT
ca va lancer :
  sum:xxxx(800-BFD)
  sum:xxxx(C00-FFD)
  Verify success
Quand c'est fait tu rebootes
Marsh Posté le 09-05-2003 à 13:46:24
ok merci,
j'vais essayer tout ça.
merci encore
Marsh Posté le 09-05-2003 à 17:22:04
bon ben ça marche pas,
j'ai le message suivant qui apparait.
Program Change Command WaitSetDrq timeout: ff
ça veut dire quoi ???
Marsh Posté le 09-05-2003 à 18:28:48
personne pour m'aider ????
