Athlon Xp 1800+ sur abit kt7a Raid, possible ou pas?
Athlon Xp 1800+ sur abit kt7a Raid, possible ou pas? - Hardware
Marsh Posté le 09-04-2002 à 21:05:08
Je voudrais savoir si je pouvais mettre un athlon xp  sur cette carte mère. Si quelqu'un la fait qu'il me donne son avis. Je voudrais aussi connaitre sa tempèrature.
Merci d'avance
Marsh Posté le 09-04-2002 à 21:25:33
:pt1cable:
A mon avis vas voir sur le site de abit pour savoir si il y as une version du bios plus recente qui permet le passage au XP
" Un intellectuel assis va moins loin qu'un con qui marche ."  J.Gabin
Marsh Posté le 09-04-2002 à 21:28:29
http://www.abit.com.tw/abitweb/webjsp/index.htm
Pour la KG-7 ca marche
Marsh Posté le 09-04-2002 à 21:31:58
KT7A-RAID
   kt77n.exe  Bios   Issue Date: 2002/01/31
BIOS ID: 7N
Support up to 137GB HDD and above.
HPT 370 RAID BIOS version 1.11.0402. The RAID function is for KT7-RAID / KT7A-RAID only. This BIOS version is also for non RAID boards and HPT BIOS
   kt764.exe  Bios   Issue Date: 2001/11/07
1. Fine tune the register value of CPU driving strength to enhance the system stability.
2. HPT 370 RAID BIOS version 1.11.0402. The RAID function is for KT7-RAID /KT7A-RAID only.This BIOS version is also for non RAID boards and HPT BIOS
   kt74a.exe  Bios   Issue Date: 2001/08/24
1. Support AMD 1.4GHz(133)CPU.
   kt73r.exe  Bios   Issue Date: 2001/07/13
1. Update BIOS code.
2. Enhance ISA PnP compatibility.
3. Enhance SCSI adapters compatibility.
4. Add 1400(133) Athlon support for KT7A/KT7A-RAID.
5. Add new option "1200 above" for high speed Athlons with 100FSB. KT7 /
   kt73c.exe  Bios   Issue Date: 2001/06/11
1. HPT370 RAID BIOS version 1.11.0402
Attention !!!
Since bios 3C includes HPT bios 1.11, you may need upgrade your HPT370 driver before flashing the bios.
When you upgrade your bios from ZT to 3C, we highly recommend you b
   kt7zt.exe  Bios   Issue Date: 2001/05/11
1. Adds three new options to enhance the system compatibility
- Delay Transaction
-PCI master read
-PCI master time-out Sets above options to Disabled/0 and may help SB Live 5.1 sound issue.
If the system experiences low pe
le problème c'est qu'il ne parle pas des processeurs.
Marsh Posté le 09-04-2002 à 21:32:34
Attention pas avec toutes les versions.
Ratures - Cuisine
Marsh Posté le 09-04-2002 à 21:45:07
et oui c tjs la meme kestion qui reviens et sans avoir de reponse precise...
y en a ki arrive et dautre pas etc....
celui qui a une reponse clair c un fort par contre
/!\ Post powered by Phive-online.com /!\
Marsh Posté le 09-04-2002 à 21:51:21
Tu as réfléchi longtemps avant de pondre ça ?
Dis-moi qui serait habilité à donner une réponse précise sur ce sujet ?
Et surtout, aurait-il une chance de poster sur le forum ? :D
Ratures - Cuisine
Marsh Posté le 09-04-2002 à 21:55:09
il y a bien quelqu'un qui a essayé de mettre un athlon Xp sur une abit kta Raid. Il faut rouver cette personne.
Marsh Posté le 09-04-2002 à 21:55:56
Question : tu es au courant que cette CM, OFFICIELLEMENT, ne supporte pas le XP ?
Ratures - Cuisine
Marsh Posté le 09-04-2002 à 21:59:36
je ne sais pas si c pareil niveau bios entre les KT7a raid et non raid (a mon avis oui).
La KT7a ne supporte les athlons XP que pour les révisions 1.3 (regarde sur ta carte mere au bout du code barre:il existe 4 versions:1.0,1.1,1.2 et 1.3).
Donc si tu as une 1.3 no problemo,pour les autres versions c à la roulette russe:certains y arrivent,d'autre non,mais de toute facon ca passe par un reglage manuel de la vitesse du CPU.
A toi de voir si tu es prêt a tenter le coup
Marsh Posté le 09-04-2002 à 22:08:05
hehe je sais je suis trop fort  :D
mais bon y en a ki disent k'il y sont arriver...donc au passage j'ai une 1.2 avec bios 7N
mais je v pas tester pour le moment un dudu 1200(un chtit peu oc je lavoue) ca me suffit ;)
si un jour ca me predn de changer de porc je changerai mais pas la carte mere et jessairai et si ca marche pas bah je changerai de mobo
voila
ouaww je m'épatte ce soir  :ange:
[jfdsdjhfuetppo]--Message édité par phive--[/jfdsdjhfuetppo]
