athlon xp 64 2800 (FBS) 1*200mhz
athlon xp 64 2800 (FBS) 1*200mhz - Carte mère - Hardware
Marsh Posté le 30-01-2005 à 20:06:56
je comprent pas j'ai acheté un xp 64 puis j,ai fait l'analyse avec sisoft sandra puis il me dis que j,ai juste 1X 200mhz de front bus !!!! cpu
voici les info de mon bios et mon processeur avec sisoft sandra
je doit faire quoi dans le bios je connais le bios mais ce processeur s,es tou nouveau pour moi
<<< CPU & BIOS Information >>>
<< System BIOS >>
  < System BIOS >
    Manufacturer:                         American Megatrends Inc.
    Version:                              Version 07.00T
    Date:                                 04/02/01
    Plug & Play Version:                  1.00
    SMBIOS/DMI Version:                   2.30
    (EE)PROM Size:                        256kB  (2Mbit)
  < Features >
    Can be Updated (flashed):             Yes
    Can be Shadowed:                      Yes
    Is Socketed:                          Yes
    Supports APM:                         Yes
    Supports ACPI:                        Yes
    Supports Plug & Play:                 Yes
    Supports ESCD:                        Yes
    Supports Enhanced Disk Drive:         Yes
    Supports Selective Booting:           Yes
    Supports LS-120 Boot:                 Yes
    Supports ZIP Boot:                    Yes
    Supports BIOS Boot Block:             Yes
    Supports Network Boot:                No
    NEC PC-98 Spec Compatible:            No
  < Performance Tips >
    Tip T201:                             System BIOS is old. Check for an update.
    Notice N224:                          SMBIOS/DMI information may be inaccurate.
    Tip T212:                             BIOS can be shadowed so check whether it is.
    Tip T211:                             BIOS is flash-able and socketed so it can be upgraded
                                          when needed.
    Tip T2:                               For more information about tips, press F1 and scroll
                                          to the Tips section.
<< Processor 1 >>
  < Processor(s) >
    Model:                                AMD Athlon(tm) 64 Processor 2800+
    Co-Processor (FPU):                   Built-in
    Speed:                                1.80GHz
    Model Number:                         2800 (estimated)
    Type:                                 Standard
    Generation:                           15th (15x86)
    Revision/Stepping:                    C / 0 (0)
  < Caches >
    Internal Data Cache:                  64kB synchronous write-back (2-way, 64 byte line size)
    Internal Code Cache:                  64kB synchronous write-back (2-way, 64 byte line size)
    L2 On-board Cache:                    512kB ECC synchronous write-back (16-way, 64 byte line
                                          size)
  < Host Interface >
    Front Side Bus Speed:                 1x 200MHz (200MHz data rate)
  < Mainboard Upgradeability >
    Socket/Slot:                          Socket-754
    Supported Speed(s):                   3.00GHz  (or more)
    Supported Voltage(s):                 3.3V, 2.9V
  < Environment Monitor 1 >
    Model:                                Winbond W83697HF ISA
    Version:                              6.00
    Mainboard Specific Support:           No
  < Processor Sensors >
    CPU Temperature:                      28.5°C / 83.3°F
    Auto Fan Speed Control:               No
    CPU Fan Speed:                        2519rpm
    CPU Core Voltage:                     1.49V
  < Features >
    Co-Processor (FPU) Built-in:          Yes
    Virtual Mode Extensions:              Yes
    Debugging Extension:                  Yes
    Page Size Extension:                  Yes
    Time Stamp Counter:                   Yes
    Model Specific Registers:             Yes
    Physical Address Extension:           Yes
    Machine Check Exception:              Yes
    Compare & Exchange Instruction:       Yes
    Local APIC Built-in:                  Yes
    Fast System Call:                     Yes
    Memory Type Range Registers:          Yes
    Page Global Enable:                   Yes
    Machine Check Architecture:           Yes
    Conditional Move Instruction:         Yes
    Page Attribute Table:                 Yes
    36-bit Page Size Extension:           Yes
    Unique Serial Number:                 No
    Cache Line Flush Support:             Yes
    Debug Trace & EMON Store:             No
    ACPI Technology:                      No
    MMX Technology:                       Yes
    Fast Float Save & Restore:            Yes
    SSE Technology:                       Yes
    SSE2 Technology:                      Yes
    Self Snoop:                           No
    Hyper-Threading Technology:           No
    Auto Clock Control:                   No
    IA-64 Technology:                     No
  < Extended Features >
    Extended Fast System Call:            Yes
    Extended AMD MMX Technology:          Yes
    3DNow! Technology:                    Yes
    Extended 3DNow! Technology:           Yes
    MP Capability:                        No
    AA-64 Technology:                     Yes
  < Power Management Features >
    Voltage Control:                      Yes
    Frequency Control:                    Yes
    Thermal Sensor Built-in:              Yes
  < Advanced Settings >
  < Variable Range MTRR Settings >
    MTRR 0:                               00000000-0FFFFFFF (0MB-256MB) WB
Message édité par ironamd le 30-01-2005 à 22:19:04
Marsh Posté le 30-01-2005 à 20:16:33
Voir la site AMD
comme nous
Marsh Posté le 30-01-2005 à 20:46:28
oui mais je veux savoir juste si s,es normal que avec ma msi
k8mm et mon a64 2800+ sa m'écris
< Host Interface >
