Single versus Double bank connection - Carte mère - Hardware
MarshPosté le 06-03-2008 à 17:49:47
Bonjour, je viens d'ajouter de la mémoire vive à mon portable et la commande dmidecode me dit qu'une de mes barettes est Double et l'autre Single bank connection. Je ne saisis pas toutes les nuances. Est-ce correct? J'ai trois mois de garantie sur ma nouvelle barette. Je suis sous Linux:
dmidecode
... Handle 0x0005, DMI type 5, 20 bytes Memory Controller Information Error Detecting Method: 128-bit ECC Error Correcting Capabilities: Other Supported Interleave: One-way Interleave Current Interleave: One-way Interleave Maximum Memory Module Size: 4096 MB Maximum Total Memory Size: 8192 MB Supported Speeds: Other Supported Memory Types: SDRAM Memory Module Voltage: 3.3 V Associated Memory Slots: 2 0x0006 0x0007 Enabled Error Correcting Capabilities: Unknown
Handle 0x0006, DMI type 6, 12 bytes Memory Module Information Socket Designation: DIM1 Bank Connections: 0 1 Current Speed: 10 ns Type: DIMM SDRAM Installed Size: 512 MB (Double-bank Connection) Enabled Size: 512 MB (Double-bank Connection) Error Status: OK
Handle 0x0007, DMI type 6, 12 bytes Memory Module Information Socket Designation: DIM2 Bank Connections: 2 3 Current Speed: 10 ns Type: DIMM SDRAM Installed Size: 512 MB (Single-bank Connection) Enabled Size: 512 MB (Single-bank Connection) Error Status: OK ...
Marsh Posté le 06-03-2008 à 17:49:47
dmidecode
Other
Supported Speeds:
Other
SDRAM
0x0006
0x0007
Unknown
Type: DIMM SDRAM
Error Status: OK
Type: DIMM SDRAM
Error Status: OK
