Disque dur non reconnu en sata avec l'abit nf7-s - Carte mère - Hardware
Marsh Posté le 12-02-2003 à 11:57:24
attention le sata sur les abit n'accepte qu'un périph donc tu dois régler le cavalier du hdd en master / single.
Marsh Posté le 12-02-2003 à 12:02:13
Je te remercie de ta reponse, mais le reglage est defa fait
Marsh Posté le 12-02-2003 à 12:07:24
totophe03 a écrit : Je te remercie de ta reponse, mais le reglage est defa fait |
pourtant c'est les symptômes de ce genre de problème. j'avais les mêmes problèmes et j'ai changé les cavaliers.
Marsh Posté le 12-02-2003 à 12:11:35
Nogood a écrit : |
bah alors regardes les reglages sur mon disque dur sont,
device 0 master
device 1 slave
cable select
forcing dev 1 present
j'ai donc mis en master.
sinon y'a le choix 15 ou 16heads ca apporte quoi ca?
Marsh Posté le 12-02-2003 à 12:22:38
totophe03 a écrit : |
c'est un reglage de compatibilite, voici pourquoi
[Known limitations]
There was a limitation of Win95 with 15 logical heads
drives: a maximum of 3 IDE devices were supported instead
of 4.
However, that limitation was corrected in last version of
Win95.
[Upgrade recommendation]
The change from 15 to 16 logical heads is only mandatory
on hard drives larger than 10 GB, featuring 15 logical
heads, prior to Win2000 installation.
It is not necessary for other operating systems.
[FAQ]
Q: Will I lose my data on the disk when changing from 15
to 16 heads?
A: No. The files already present on the disk are not lost
when converting from 15 to 16 heads. However, it is
recommended to perform a backup of the data prior to
conversion.
Q: Why drives have 15 heads instead of 16?
A: This was necessary for supporting 4 IDE devices (2 on
primary, plus 2 on secondary IDE port) under former
versions of Win95.
If the master IDE drive was configured with 16-heads, 4
IDE devices could not be installed. The OS supported only 3.
However, this has been corrected in last versions of Win95.
Q: Are there any side effects caused by the upgrade from
15 to 16 heads?
A: Apart from the limitation described above, nothing else
has been identified.
Marsh Posté le 12-02-2003 à 13:09:14
donc en fait si j'ai bien compris 15 et 16heads c'est pour limiter le nombre de peripheriques ide sur la nappe, dois -je essayer alors de mettre mon dd en 15head?
Marsh Posté le 12-02-2003 à 11:47:02
Salut a tous possesseur de cette mobo,
j'ai un ti probleme depuis quelques temps dont je pensais que les bios 1.2 et 1.3 allaient corrigés mais non,
alors j'ai un disque dur IBM 120GXP 80Go, qui est reconnu seulement disons 1 fois sur 10 lors de l'allumage du pc, si il est detecté, je peux reboot sans blem il le sera encore au prochain demarrage.
Par contre si j'eteint la machine, le disque n'est plus reconnu, alors que sur une nappe ide il n'y aucun probleme, à noter que j'ai un second disque dur IBM egalement mais de generation precedente (30Go) meme probleme constaté.
J'ai bien verifié le montage tout tient bien en place,j'ai la rev 1.0 de la mobo, le bios 1.3, un xp 1800+.
A noter que ce n'est pas un probleme windows vous l'aurez compris car le disque n'etant pas reconnu sous le bios du sata.
Merci de votre aide.
