Soyo Dragon Plus! K7V VIA KT266A, PCI USB2.0 CARD PROBLEM!! - Carte mère - Hardware
Marsh Posté le 11-10-2004 à 14:59:22
I know that in some mobos, there is a compatibility issue with USB cards. Why buy it if you have onboard USB ?
Marsh Posté le 11-10-2004 à 15:00:25
| adonai_24 a écrit : I know that in some mobos, there is a compatibility issue with USB cards. Why buy it if you have onboard USB ?  |
onboards usb is 1.1... and i need 2.0 for ipod, digital cam, etc
thx!!
Marsh Posté le 11-10-2004 à 15:03:23
| adonai_24 a écrit : Ok ... Maybe you can try with another USB PCI card !  |
its new... and i bough from internet... u dont know how to fix this??
ty!
Marsh Posté le 11-10-2004 à 15:05:05
Well i don't  do you have some jumpers on the card ? maybe you can give us the model, so we can try to look for information on it !
Marsh Posté le 11-10-2004 à 15:06:30
Try to update your motherboards bios too, and install the board drivers ! from http://www.viaarena.com/default.as [...] D=2&Type=1
Marsh Posté le 11-10-2004 à 15:11:56
| adonai_24 a écrit : Well i don't  |
its a generic "Encore PCI Controller Card the model is ENLUSB2-5PCI-BR"
so and the bios upgrade, i don't know how i do that... im scared with bios upgrade =p
Marsh Posté le 11-10-2004 à 16:02:10
ReplyMarsh Posté le 11-10-2004 à 16:10:52
bios upgrade cannot complete! i dono how upgrade that fuk =/
thats is another way to fix?
Marsh Posté le 11-10-2004 à 16:14:57
well i don't know then. Try to find an english forum, you'll get more help !!!
Marsh Posté le 11-10-2004 à 20:59:16
I HATE THE ENGLISH!!!!! SPEAK FRENCH PLEASE!
Marsh Posté le 11-10-2004 à 14:55:56
i bough pci usb card2.0 and when always i connect everything in my pc just cold and i need to restart him.
im alredy format and install win with sp2, but the plobem still happen.
i dont know what is but i've alredy tried to disable all usb ports onboards, and change PCI slot.
anyone tells me this is IRQ problem.anyone knows?
here are pictures from that. Ty very much
sry about english but i need help please!!
