========================================================= Uber Bios 1007 For A7N8X v1.04 - 1.06 =========================================================
Thanks for downloading my Asus A7N8X bios mod.
Its based on the Asus A7N8X 1007 final bios. Its for the A7N8X v1.04 - 1.06 only, and not for use in v2.0 mobos
The latest versions of this bios are always availavble in the Asus forums on www.nforcershq.com
Release notes :-
1) Enhance system stability with certain types of RAM
1)This revision has more AGP voltage and Q-fan options to select. 2)There are also more options for the UART2 connector like 'smart card' and 'ASKIR'. 3)Also the AUTO mode for the printer port IO/IRQ allocation has been made selectable. 4)S3(STR) is now selectable for option 'ACPI Suspend to RAM'. 5)Additional Power On By PS/2 Keyboard/Power On By PS/2 Mouse options are available. 6)2.9V is now available in the DDR Reference Voltage selection choices. 7)1.8V is now available in the AGP VDDQ Voltage selection choices.
Flash this like you would the normal Asus supplied bios.
Here is a list of what I re-enable that Asus have hidden form the users.
Legacy Diskette Video CHIP Voltage Control OnChip IDE Channel Primary Master Primary Slave Primary Master Primary Slave OnChip IDE Channel Secondary Master Secondary Slave Secondary Master Secondary Slave IDE Prefetch Mode IDE HDD Block Mode ACPI function Power Management HDD Power Down Reset Configuration MPS Version Contol Small Logo(EPA) Machine MAC(NV) MAC(NV) Address KB Power ON Pass Hot Key Power ON UR2 Duplex Mode
Je voulais savoir si le bios fonctionnais bien chez vous, car moi depuis que je l'ai installé, mon pc est instable et reboot tout seul!! et aussi, comment etre sur que le chip voltage fonctionne?? car moi j'ai aucune diff en oc en l'augmentant!...
--------------- HiFi: Nad C320BEE + Marantz CD-63 MkII Ki Signature + Boston VR2 | HC: JVC X35 + Onkyo TX-SR875 + Boston VR2 + Boston CR8 + Boston VRC + MJ Acoustic Ref1 Mk2| TV: Panasonic TX-P50ST50E
Marsh Posté le 19-01-2004 à 22:25:26
voilou, le bios est disponible ici:
http://homepage.ntlworld.com/michael.mcclay/
pour rappel:
Release notes :-
Legacy Diskette
Video
OnChip IDE Channel
Primary Master
Primary Slave
Primary Master
Primary Slave
OnChip IDE Channel
Secondary Master
Secondary Slave
Secondary Master
Secondary Slave
IDE Prefetch Mode
IDE HDD Block Mode
ACPI function
Power Management
HDD Power Down
Reset Configuration
MPS Version Contol
Small Logo(EPA)
Machine MAC(NV)
MAC(NV) Address
KB Power ON Pass
Hot Key Power ON
UR2 Duplex Mode
