Asus Maximus Extreme: Le top du top par Asus ! [Topic Unique] - Carte mère - Hardware
Marsh Posté le 14-01-2008 à 10:34:40
Citation : |
Passons aux specifications de la carte :
CPU
LGA775 socket for Intel® Core™2 Extreme / Core™2 Quad / Core™2 Duo / Pentium® Extreme / Pentium® D / Pentium® 4 Processors
Support Intel® next generation 45nm Multi-Core CPU
Compatible with Intel® 06/05B/05A processors
Chipset
Intel® X38/ICH9R with Intel® Fast Memory Access Technology
Front Side Bus
1600 / 1333 / 1066 / 800 MHz
Memory
Dual channel memory architecture
4 x DIMM, max. 8GB, 1800(O.C)/1600(O.C.)/1333/1066, Non-ECC, un-buffered memory
Support Intel® XMP Technology
Expansion Slots
3 x PCIe x16 slot, support dual PCIe2.0 x16 or 1x PCIe2.0 x16, dual x8 speed
2 x PCIe x1, PCIex1_1 (black) is compatible with audio slot
2 x PCI 2.2
VGA
Support ATI CrossFire™ graphics cards
Storage
Southbridge
- 6 x SATA 3.0 Gb/s ports
- Intel Matrix Storage Technology supports RAID 0, 1, 5 and 10
JMicron® JMB363 PATA and SATA controller
- 1 x UltraDMA 133/100/66 for up to 2 PATA devices
- 2 x External SATA 3.0 Gb/s port (SATA On-the-Go)
LAN
Dual Gigabit LAN controllers, both featuring AI NET2
Support Teaming Technology
Audio
SupremeFX II Audio Card
- ADI 1988B 8-channel High Definition Audio CODEC
- Noise Filter
Coaxial, Optical S/PDIF out at back I/O
IEEE 1394
2 x 1394a ports(1 port at back I/O, 1 port onboard)
USB
max. 12 USB2.0/1.1 ports(6 ports at mid-board, 6 ports at back panel)
Overclocking Features
Fusion Block System
Crosslinx Technology
Extreme Tweaker
Loadline Calibration
2-Phase DDR3
Intelligent overclocking tools:
- CPU Level Up
- Memory Level Up
- AI Overclocking (intelligent CPU frequency tuner)
- ASUS AI Booster Utility
- O.C Profile
- Frequency LED
Overclocking Protection:
- COP EX (Component Overheat Protection - EX)
- Voltiminder LED
- ASUS C.P.R.(CPU Parameter Recall)
Special Features
LCD Poster
EL I/O
Onboard Switches: Power / Reset / Clr CMOS(at rear)
Q-Connector
Q-Fan Plus
ASUS EZ Flash2
ASUS CrashFree BIOS3
ASUS MyLogo3
Back Panel I/O Ports
1 x PS/2 Keyboard port(purple)
1 x Optical + 1 x Coaxial S/PDIF Output
2 x External SATA
2 x LAN (RJ45) port
6 x USB 2.0/1.1 ports
1 x IEEE1394a port
1 x Clr CMOS switch
Internal I/O Connectors
3 x USB 2.0 connectors supports additional 6 USB 2.0 ports
1 x Floppy disk drive connector
1 x IDE connector for two devices
6 x SATA connectors
8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
3 x thermal sensor connectors
1 x IEEE1394a connector
1 x S/PDIF output connector
1 x Chassis Intrusion connector
24-pin ATX Power connector
8-pin ATX 12V Power connector
1 x En/Dis-able Clr CMOS
1 x EL I/O Shield Connector
System panel connector
BIOS
16Mb AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.4, ACPI2.0a Multi-Language BIOS
Manageability
WOL by PME, WOR by PME, Chasis Intrusion, PXE
Accessories
Fusion Block System Accessory
DIY Pedestal
ASUS Optional Fan
3 in 1 ASUS Q-Connector Kit
UltraDMA 133/100/66 cable
Floppy disk drive cable
SATA cables
SATA power cables
2-port USB2.0 module+IEEE1394a module
EL I/O Shield
Thermal sensor cables
Cable Ties
User's manual
Support Disc
The hottest 3D Game: S.T.A.L.K.E.R.
Support DVD:
Drivers
ASUS PC Probe II
ASUS Update
ASUS AI Suite
Futuremark ® 3DMark® 06 Advanced Edition
Kaspersky® Anti-Virus
Form Factor
ATX Form Factor, 12"x 10.6" (30.5cm x 26.9cm)
Screenshot de la configuration de test :
Benchmarking Setup
Single Card Benchmarking
* Intel Core 2 Quad Extreme QX9650 (3GHz, 333MHzx9)
* ASUS P5E3 Deluxe WiFi-AP/N - Intel X38 Chipset
* ASUS Maximus Extreme - Intel X38 Chipset
* Corsair Dominator PC3-1800C7D 2GB Kit (1333Mhz, 7-7-7-20)
* Sapphire Radeon HD3870 ( 775MHz/ 1225MHz)
* Enermax Galaxy 1kW reV2.0
* Seagate 7200.7 80GB x 2
* Dell 3007WFP
* Windows Vista SP1 Beta (Build 2175)
* Nvidia Forceware 169.09 Beta
CrossFireX Benchmarking
* Sapphire Radeon HD3850 256MB (670/ 833MHz)
* Sapphire Radeon HD3870 512MB (775MHz/ 1225MHz)
* ATI Radeon Display 8.43
Les resultats des tests :
Marsh Posté le 14-01-2008 à 10:39:02
Tests avec les jeux qui representent les tests les plus representatifs :
Tests avec le Crossfire
Marsh Posté le 14-01-2008 à 11:05:18
Capacites d'Overclocking de la carte mere :
Nous pouvons donc en deduire que malgres sont prix assez eleve, cette carte mere tient bien ses promesses puisque l'overclocking est excellent, au niveau benchmark, elle arrive a depasser une autre mobo haut de gamme d'Asus et que, cerise sur le gateau, le watercooling du chipset n'a pas ete oublie !
J'espere que cette petite introduction vous a satisfait, et que si vous avez les moyens d'acheter cette mobo, vous n'hesiterez pas en regardant ce topic.
Marsh Posté le 14-01-2008 à 15:55:41
Avec un pote, on a achete cette mobo: je vous livre sa config :
Mozart tx
Corsair VX 520
2go de RAM DDR3 GSKILL PC 8500
Asus Maximus Extreme bien sur
Intel E6850
Seagate 320go
8800GTS 512 Leadtek
Rheobus Zalman et Akasa
les composants seuls coutent 1777 euros. En tout ca doit lui faire pour 2000 euros.
le CPU, la 8800, le chipset seront refroidis a l'aide d'un watercooling : 400 euros de watercooling personnalises. On a surtout voulu prendre 2 radiateurs doubles avec 4 Noiseblocker SX2 Pro qui tournent a 1800trs max. Avec les rheobus ca va bien le faire Autant vous dire que le kit perso lui est revenu bien moins cher qu'un kit de marque haut de gamme sans compter les performances thermiques qui deboitent. Montage ce weekend
Marsh Posté le 14-01-2008 à 15:59:47
C'est sur que si y'a 400euros de matos watercooling ca va forcément déchirer
ps : vive le homemade
Marsh Posté le 14-01-2008 à 16:25:53
400 euros certes mais meme si tu mets tout en aircoooling, c'est la mobo la plus puissante au monde, j'hallucine, regardes tout ce cuivre, avec ca le chipset devrait etre bien froid alors avec un watercooling j'imagine meme pas. Par contre les 220 euros pour la ram, ca fait mal mais la Maximus Extreme ne supporte que ce type de RAM
Marsh Posté le 14-01-2008 à 16:47:57
Tout ce cuivre?
Les fines ailettes des rads sont en cuivre,tout ce qui est épais:refroidisseurs des 2 circuits du chipset sont en alu anodisé couleur cuivre ou bleu.
Marsh Posté le 14-01-2008 à 16:48:11
Citation : regardes tout ce cuivre, avec ca le chipset devrait etre bien froid |
ma striker aussi avait plein de cuivre, ça ne l'a pas empéché de cramer
et le lcd, ça me fait peur maintenant avec tout ces petits messages d'erreur, mauvais souvenirs de mon ancienne mobo
reste que c'est une belle carte, mais pour ce qui est des performances et de la solidité face à d'autre x38 ?
Marsh Posté le 14-01-2008 à 19:04:54
Ouch ta striker a cramé c'est fort ca j'ai la P5N32E sli qui est la copie de la striker mais elle a pas les leds bleu : si la tienne a cramé je flippe pour la mienne : le 680i sli est à 45° chez moi
Marsh Posté le 14-01-2008 à 22:29:09
ReplyMarsh Posté le 14-01-2008 à 22:55:15
Fssabbagh a écrit : bientôt des photos de la config |
go go pour tes tofs
Marsh Posté le 15-01-2008 à 17:53:37
c'est en cours : reste plus qu'à branche les hdds, à mettre le waterblock vga et c'est tout. On fait des photos en même temps que le montage. Ca ca chier !!!
Marsh Posté le 15-01-2008 à 17:58:53
euh c'est moi ou les bench de cette cm ne trou pas le cul Surtout que sur certain bench, la P5E3 est devant ! Je sais pas combien elle coute mais les vaut-elle vraiment par rapport a une mobo a base de X38 plus classic ?
Sinon c'est vrai qu'elle est belle.
Marsh Posté le 16-01-2008 à 10:09:21
la mobo est magnifique puisque c est moi qui lapossede et je pense qu elle vaut largement sont prix comparer a X38 classique ca na rien a voir bcp plus d options et niveau perfs ca dois causer on va tester d ici la fin de semaine le montage est presque fini reste a fignoler les branchements et mettre le wtercooling et ca tourne je pense que demain soir la config sera fini car on attends la derniere commande de pieces
voila de tte facon les resultats ainsi que les photos et les temp seront poste d ici peu
et merci a Fssabbagh d avoir participer au projet
Marsh Posté le 16-01-2008 à 10:24:35
mise a jour de la configue qui est definitive
matos
Mozart tx
CORSAIR - HX520 Watts (CMPSU-520HX) - Certifié SLI et Crossfire
G.SKILL - 2Go ( 2*1Go ) 1066MHZz DDR38500 F3-8500CL7D-2GBNQ
ASUS - Maximus Extreme - Chipset Intel® X38/ICH9R
INTEL CORE 2 DUO - E6850 3.0GHz FSB 1333MHz 4Mo cache socket 775 boite
Seagate 320go
LEADTEK - WinFast PX8800 GTS TDH 512
graveur DVD double couche lg
2 neons themaltake UV de 30cm
SAMSUNG - SyncMaster 226CW - 22 pouces Wide - 2ms - Gamut 97 - Design Noir laqué - DVI (HDCP)
clavier G15 refresh
souris G9
niveau watercooling:
Réservoir + Pompe AGB-Eheim 600 Station II 12 Volts
Radiateur DOC eXTreme 240 X 2
WaterBlock CPU TDX Socket 775
WaterBlock VGA Cool-Matic G92 - GeForce 8800GTS
Réservoir Plexi Réactif aux UV 5"1/4 Slot-in Rev2.0
UltraSilentFan SX2 BLUE 120*120*25mm, 34dB, 74.4 CFM, connect. 3 pins carte mère X 4
ainsi que les tuyaux et les raccords necessaire
Marsh Posté le 16-01-2008 à 10:27:55
ReplyMarsh Posté le 16-01-2008 à 11:44:48
noobzed a écrit : http://images3.hiboox.com/vignettes/0308/pzlh0xy7.jpg |
merci tu en est content je suppose ???
Marsh Posté le 17-01-2008 à 14:51:17
4ghz tu tournes au LN2 ou au watercooling ?
Marsh Posté le 19-01-2008 à 11:02:53
mozartjhon a écrit : |
c'est la meilleure mobo que j'ai jamais eu je pense, elle est aussi bien qu'une p5k premium et 10x plus belle que lui demander de plus ?
le sli ? pas la peine la 9800gx2 va sortir et c'est un sli a elle toute seule cette cg
Fssabbagh a écrit : 4ghz |
water ma poule
Marsh Posté le 25-01-2008 à 11:34:03
J'ai cette carte mère depuis une semaine, avec un petit E4500 en attendant les nouveaux quad core, mais j'ai juste un petit problème
J'ai oveclocké mon cpu à 2926 mhz, sans aucun problème, stabilité à toute épreuve et aucune chauffe (41 au repos, et une bonne 50 aine en full).
Le problème se situe au 1er démarrage de la machine, et meme pas immédiatement. Uniquement avec mon pc overclocké, aux réglages par défaut, le problème n'apparait pas.
Le matin par exemple, je boote, et après 2-3 min, le pc freeze, un reset, et c'est reparti, et cette fois ci, je peux faire ce que je veux, il ne bloquera plus.
C'est systématique, après une longue période éteint, le 1er démarrage se solde par un freeze (alors qu'il a déjà chargé windows).
J'ai un dual boot (xp-vista) et ca le fait avec les 2, ce qui penche plutot vers un problème hard.
Est ce que qqun a déjà entendu parler d'un tel problème ? J'ai vu des topics parlant de cold-boot (pour beaucoup de cartes mères asus), mais ici, rien de tel (pas de reboot automatique, pas de passage obligé par le bios), juste un freeze au 1er boot.
J'ai une bonne alim (enermax liberty 620 watts), voir profil pour le reste
Marsh Posté le 25-01-2008 à 12:22:39
Drapal pour ma future cm (vu que la rampage extrem serait apparemment annulé en france)
Marsh Posté le 26-01-2008 à 17:56:34
snakesnake a écrit : J'ai cette carte mère depuis une semaine, avec un petit E4500 en attendant les nouveaux quad core, mais j'ai juste un petit problème |
salut
bios de la carte mère stp ?
peux tu nous donner tes réglages complets aussi
Marsh Posté le 27-01-2008 à 04:31:43
Voilà :
Bios 905 et maintenant, j'ai essayé le 1001 beta, mais meme résultat
Pour les réglages :
Ai Overclock : manual
CPU Ratio 11
FSB 266
Strap 266
PCIE 100
DRAM 1066 mhz
1T
Timings Auto
DRAM Static Read Désactivé
DRAM Dynamic Write Désactivé
Ai Clock Twister strong
Ai Transaction booster activé (2)
volt cpu 1.3375
CPU PLL 1.5
NB 1.31
DRAM 1.80
FSB Termination 1.20
C1E désactivé
Voilà pour les principaux réglages, mais je le répète, à part ce freeze systématique au premier boot, c'est on ne peut plus stable
Marsh Posté le 31-01-2008 à 18:21:50
snakesnake a écrit : Voilà : |
as-tu essayés avec le bios en AUTO ?
je te conseils de virer le 1T pour du 2T.
essaye de voir pour d'autres réglages en manuel et puis sinon test le bios 0505 si tu peux downgrader
Marsh Posté le 01-02-2008 à 16:39:07
heu oui et non, en auto, je l'ai laissé 5 min, il overclockait à 2400 tout seul, avec des voltages de malade
quelle serait l'utilité de repasser au bios 0505 ?
Marsh Posté le 05-02-2008 à 21:58:22
Je pense que je vais laisser tomber le 780i pour ce petit bijou avec une petite x2... Sait on si la maximus est compatible avec ça:
http://ati.amd.com/technology/cros [...] index.html
Et pour le crossfire avec plus de 2 cartes? (2 X2 par exemple). Des infos sur sa disponibilité? La maximus sera-t-elle compatible avec les bons drivers?
Marsh Posté le 06-02-2008 à 09:30:17
oui c'est compatible puisque le x38 ne marche qu'avec le crossfire et non pas avec le sli, d'ou mon ahat personnel pour la P5N32E SLI
Citation : La maximus sera-t-elle compatible avec les bons drivers? |
sans vouloir faire du zeste, tout n'est qu'une question de drivers logiciels, de catalyst si tu preferes
Marsh Posté le 06-02-2008 à 11:53:30
Ouaip, mais le X38 est meilleur pour tout ce qui est raid0 et autre, en overclocking il tient mieux, et le retour SAV n'a rien à voir avec le 780i...
Maintenant, c'est vrai que malheureusement le crossfire de 3870x2 n'est pas encore pssible, ce qui rend le sli plus performant...
Marsh Posté le 06-02-2008 à 12:30:57
en fait il est dispo en bêta :
* Case: Cooler Master Stacker 830
* Power Supply: Cooler Master Real Power Pro 1000
* Motherboard: MSI X48 Platinum
* Processor: Intel Core 2 Extreme QX9770 @ 4.2GHz (400x10.5)
* Hard Drive: 2x Western Digital Raptor 150 10,000RPM
* Video: 2x MSI Radeon HD 3870 X2 (R3870X2-T2D1G-OC 850/1800)
* Memory: 4096MB (4x1024MB) Kingston HyperX PC3 14400
* Optical Drive: ASUS DRW-2014L1
* Cooling: Cooler Master Hyper 212
* Operating System: Microsoft Windows Vista Home Premium 64-bit
* Video Driver: AMD 8.451.2 Quad Vista Evaluation Software
le tri-sli reste plus performant mais trop cher alors que le crossfire X reste plus abordable, enfin façon de parler bien sûr
Marsh Posté le 06-02-2008 à 13:09:12
Ca me plait tout ça...
A quand le crossfire X avec 3 cartes graphiques!
ET que pensez vous du montage avec une carte de série x1000 pour aider au calcul de toute la physique? (cf le lien que j'ai passé plus haut)
Marsh Posté le 06-02-2008 à 13:09:41
Autre remarque, c'est sur du x48... Donc, et pour le x38?
Marsh Posté le 06-02-2008 à 14:43:12
c'est pareil puisque la seule différence qui joue en faveur du x48 c'est la compatibilité avec les cpu à base de fsb 1600mhz, chose déjà possible à 90% avec le x38, tout dépends des mobos sinon c'est du copier-coller
Marsh Posté le 06-02-2008 à 19:01:32
Vous avez vu, les 3870x2 ne sont pas compatibles pour le moment avec le x38... C'est fort dommage...
Marsh Posté le 07-02-2008 à 09:24:19
c'est une vraie connerie, argument pour nous forcer a prendre du x48 alors que les 3/4 des gens ont du x38 et n'ont pas besoin de se faire ch... pour un detail, c'est du copier coller a 100 % alors ils sont juste fait expres de faire en sorte que ca ne soit pas compatible voila tout
Marsh Posté le 07-02-2008 à 09:30:32
arank'thnar a écrit : Vous avez vu, les 3870x2 ne sont pas compatibles pour le moment avec le x38... C'est fort dommage... |
Apparement Matbe l'a testé sur une Maximus et aucun problème
http://www.matbe.com/articles/lire [...] /page3.php
Marsh Posté le 07-02-2008 à 10:18:47
Merci pour le lien matbe.
De plus presence pc l'a testé sur un x38 gigabyte et ça marchait... donc je me fais pas trop de souci!
Vivement Mars! La, je craquerai pour une petite maximus extreme ave 2 3870x2!!
Marsh Posté le 07-02-2008 à 12:01:42
arank'thnar a écrit : Merci pour le lien matbe. |
En mars, tu auras le X48
249€ chez Cdiscount c'est le moment d'en profiter :
http://www.cdiscount.com/informati [...] 3687-_-N/A
Marsh Posté le 14-01-2008 à 10:28:26
Bonjour et bienvenue sur le topic unique dedie a la toute derniere carte mere d'Asus a base de X38 : la Maximus Extreme.Cette carte mere apparteient a la serie Republic Of Gamers et est donc dotees d'un BIOS permettant un overclocking generalement assez pousse. Passons sans plus tarder a la decouverte de cette carte assez particuliere comme vous allez sans doute le voir:
la boite qui contient la mobo
et.. quelques photos de la carte elle-meme:
Les connecteurs :
le systeme de refoidissement avec en option la possibilte de watercooler le chipset :
Le bundle :
Les adaptateurs pour le watercooling du chipset :
Message édité par Fssabbagh le 26-01-2008 à 14:21:05
Messatsu !
