quelle fvitesse de RAM pour ma carte mere? - Carte mère - Hardware
MarshPosté le 18-10-2008 à 01:20:34
salut! voici les caractéristiques de ma carte mere. pouvez vous m indiquer quelle frequence d horloge de RAM mon PC support il SVP?
Motherboard
Manufacturer TOSHIBA Model Portable PC Version Version A0
North Bridge Intel i845E Revision E0 South Bridge Intel 82801DB (ICH4) Revision E0
CPU Intel(R) Pentium(R) 4 CPU 2.53GHz Cpu Socket Socket 478 mPGA
System Slots 2 PCMCIA
Memory Summary Maximum Capacity 2048 MBytes Maximum Memory Module Size 1024 MBytes Memory Slots 2 Error Correction None
Property Value Maximum Capacity 2048 MBytes Maximum Memory Module Size 1024 MBytes Memory Slots 2 Error Correction None DRAM Frequency 133.0 MHz Memory Timings 2-3-3-6 (CL-RCD-RP-RAS)
Device Locator Slot 1 Manufacturer Kingmax Semiconductor Part Number MSAC22D-38KX3-MAN Capacity 512 MBytes Memory Type DDR (PC2700) Speed 166 MHz Supported Frequencies 133 MHz, 166 MHz Memory Timings 2-3-3-6-0 at 133 MHz, at 2.5 volts (CL-RCD-RP-RAS-RC) Memory Timings 2-3-3-7-0 at 166 MHz, at 2.5 volts (CL-RCD-RP-RAS-RC) Data Width 64 bits EPP SPD Support No XMP SPD Support No
Marsh Posté le 18-10-2008 à 01:20:34
salut!
Motherboard
Model Portable PC
Version Version A0
Memory Summary
Memory Slots 2
Property Value
Memory Slots 2
Capacity 512 MBytes
Speed 166 MHz
Data Width 64 bits
EPP SPD Support No
XMP SPD Support No
merci!
