Gigabyte 8N-SLI Quad Royal => octo-sli
Gigabyte 8N-SLI Quad Royal => octo-sli - Carte mère - Hardware
Marsh Posté le 03-12-2007 à 14:35:13
Tout est parti de cette photo
http://img225.imageshack.us/img225/323/octalsli5ua0.jpg
Y'en a-t-il parmi vous qui l'ont essayé? Si possible dans ce genre de configuration... D'un point de vue driver, sur xp, est-ce que ça marche fort? C'est le genre de geekerie qui me plait bien...
Spécifications
Processor
   1. LGA775 Intel® Pentium® D / Pentium® 4 prcessor
   2. Supports 1066/800/533MHz FSB
Chipset
   1. Northbridge: NVIDIAl® nForce4 SLI Intel Edition Chipset
   2. Southbridge: NVIDIAl® nForce4 SLI chipset
   3. T.I IEEE 1394 Controller
   4. Dual Gigabit Ethernet Controller
   5. Realtek ALC850 Audio Codec
Memory
   1. Type: Dual channel DDR2 667/ 533 -240pin
   2. Max capacity: Up to 8GB by 4 DIMM slots
Internal I/O Connectors
   1. 4 x Serial ATA 3Gb/s connectors
   2. 2 x UDMA ATA 133/100 connectors
   3. 1 x FDD connector
   4. 1 x IEEE 1394a connector (support 2 ports)
   5. 3 x USB 2.0/1.1 connectors (support 6 ports)
   6. 1 x audio pin header (support 7.1-ch)
   7. 7 x Cooling fan pin headers
   8. 1 x S/PDIF input
   9. 1 x CD-in
Expansion Slots
   1. 4 x PCI Express X16 slots
   2. 2 x PCI Express X1 slots
   3. 1 x PCI slot
Rear Panel I/O
   1. 4 X USB 2.0/1.1 ports
   2. 1 X IEEE 1394a connector
   3. 2 X RJ45 port
   4. 6 X Audio ports (4 X Line-Out/1 X Line-in /1 X MIC)
   5. 1 X Coaxial S/PDIF out
   6. 1 X Optical S/PDIF out
   7. PS/2 Keyboard/Mouse
   8. 1 X LPT port
Form Factor
   1. ATX form factor
   2. 305 x 244mm
H/W Monitoring
   1. System health status auto-detect and report by BIOS
   2. Hardware detecting and reporting for case open, CPU voltage, and fan speed
BIOS
   1. 2 x 4Mb flash ROM, Award BIOS
Other Features
   1. NVIDIA SLI multi-GPU support
   2. Bluetooth function
   3. Support NVIDIA Firewall
   4. Norton Internet Security
   5. XpressTM Installation
   6. XpressTM Recovery 2
   7. C.I.A. 2 (CPU Intelligent Accelerator 2)
   8. M.I.B. 2 (Memory Intelligent Booster 2)
   9. EasyTune™ 5
  10. Download Center
Remark
   1. Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website.
   2. Due to most hardware/software vendors no longer offer support for Win9X/ME. If some vendors still has Win9X/ME drivers available, we will publish on website.
Message édité par arank'thnar le 03-12-2007 à 15:56:36
Topic Bougnat - Mon Topic de A/V - Nos créations 3D - Geek'n Craft 63
Marsh Posté le 03-12-2007 à 15:06:21
si ton alim tien le choc ca marchera, par contre les 4 port PCIE sont limité en 8x chacun bridage de perf ( vu que les GX2 divise deja le debit par 2 ) , de plus Nvidia n'a pas sortie de driver octo-SLI donc ca ne marchera que pour du multi screen
il me semble aussi que les drivers quad SLI ne marche que sur les 7800/7900 et qu'ils sont plus ou moins foireux donc meme un quad 7800GTX marchera pas top
enfin cette carte ne supporte pas de CPU asses perf pour emener correctement un tel système graphique sans entre horriblement CPU limited
en gros ... ce PC tourne mais c'est très loin d'etre un foudre de guerre
j'espere ne pas t'avoir cassé ton reve de octo SLI mais ca ne marchera pas
si tu veut du gros SLI puissant cherche plutot ca
http://www.matbe.com/actualites/25221/
les port sont plus serré donc single slot obligatoire ( WC si GPU haut de gamme ) mais certainement plus a l'aise grace aux CPU intel quad
sinon d'ici qlq temps les version NForce compatible penryn seront dispo et on trouvera certainement un modèle quad PCIE
Message édité par arkrom le 03-12-2007 à 15:09:05
I sit, in my desolate room, no lights, no music, Just anger, I've killed everyone, I'm away forever, but I'm feeling better,How do I feel,What do I say,Fuck you, it all goes away,
Marsh Posté le 03-12-2007 à 15:18:27
arkrom a écrit :
plutot ca
Le 790GX ne supporte pas le SLI mais le crossfire (AMD inside :D )
Marsh Posté le 03-12-2007 à 15:27:56
roo le boulet .
t'as raison c'est moi qui me gourre
edit
je vient de calculer un truc tout con : sur ta photo il y a 4*GX2 soit 8 GPU, ca occupe donc 8 bracket arriere, donc cette config ne pourra jamais se monter dans un boitier ATX standard (7 bracket ) c'est custom/home made obligatoire
Message édité par arkrom le 03-12-2007 à 15:36:39
Marsh Posté le 03-12-2007 à 15:41:29
si sa rentre ;)
La GX2 est composé de 2 PCB mais il n'y a que 2 sorties DVI et elle ne prend pas plus de place qu'une carte double slot donc sa rentre dans n'importe quel boitier ATX ;)
Marsh Posté le 03-12-2007 à 15:52:39
Je ne comptais pas l'acheter. :D Ca me faisait triper... C'est vraiment dommage, mais je me serai bien vu avec un 30" et 2 quad sli par entrée...
Il faudrait la même carte mère mais compatible quad core avec des drivers qui tournent...
Bref, c'est beau... C'est parfait pour jouer à qui a la plus grosse, mais ça sert à rien!
On a presque l'arme ultime du geek suprème!
Marsh Posté le 03-12-2007 à 15:53:03
mais un boitier n'as que 7 slot, hors 4* 2 chez moi ca fait 8 donc ca passe pas,
la derniere carte depasse plus bas que le bord de la mobo et en general y a pas d'espace libre a cet endroit, il faut trouver un boitier evec la carte mere tete en bas pour avoir de l'espace et decouper un 8eme slot pour la ventill du dernier GPU
Marsh Posté le 03-12-2007 à 15:55:56
ET sinon quelle est cette carte? C'est du quad crossfire
http://www.generation-3d.com:8080/UserImgs/imgs/ATi/Crossfire/quad-sli-on-790.jpg
Très intéressant... Je crois que je vais me mettre en quête de plusieurs GX2...
Message édité par arank'thnar le 03-12-2007 à 16:00:36
Marsh Posté le 03-12-2007 à 15:59:12
crossfire X mantenant , ou c'est du quad sur une mobo X38 (asus il me semble )
et les CG je dirait HD3850 ou 3870 vu le rad, mais je peut me tromper je connait mal ces series
Marsh Posté le 03-12-2007 à 16:06:01
C'est ce que je me disais... D'un point de vue driver, les ati sont mieux gérés je crois au delà de 3 CG?
Marsh Posté le 03-12-2007 à 16:34:09
le quad SLI etait un truc trop specifique, les drivers etaient foireux, ca consommais  la mort pour pas grand chose de plus en perf bref c'etais baclé
par contre le TRI SLI sera officiel dans qlq jours et donc on verra ce que peuvent donner 3 88GTX/ultra en //
pour le quad CF j'ai pas vu de test fiable encore, mais il a l'avantage d'etre dispo sur chipset intel X38 ( et X48 bientot )
Marsh Posté le 03-12-2007 à 20:56:40
on verra... Mais j'avoue que je suis un amoureux de la GX2...
On verra ce que ça donne le tri...
