ki a entendu parler de la KD7-G avec reseau GIGABYTE integrer
ki a entendu parler de la KD7-G avec reseau GIGABYTE integrer - Carte mère - Hardware
Marsh Posté le 26-11-2002 à 13:57:27
KD7-G
Feature
AGP 8X
AGP 3.0 8X spec support high performance graphic process purpose and at a peak bandwidth of 2.1 GB/s.
DDR400
Supports up to 2GB DDR400 at a peak bandwidth of 3.2GB/s for maximum gaming performance.
Serial ATA 150
Serial ATA is an evolutionary replacement for the Parallel ATA storage interface. This new high-speed interface burst data transfer rate up to 150 Mbytes/sec and more flexible power tolerances, cables can be smaller and more efficient.
5bit FID (Frequency ID)
By ABIT 5-bits FID Override technology, users can get variety of CPU over-clocking sets.
ABIT CPU H.T.P (Hardware Thermal Protection)
ABIT CPU H.T.P. uses pure hardware detection, which not like others use software detection to prevent CPU overheating. ABIT CPU H.T.P provides more reliable result for customers' investment.
Gigabit LAN
The KD7-G with Gigabit LAN is the networking standard for the future to handle large of data such as video
ABIT SoftMenu?
The overclocking function includes CPU frequency, Vcore, multiplier, chipset & DDR voltage and AGP VDDQ voltage adjustment available to maximize your system performance.
USB 2.0
Support speed up to 480 Mbps. Approximately forty times faster than conventional USB 1.1
elle sort kand en france et dispo ou ca à montgallet
Marsh Posté le 29-11-2002 à 21:11:58
pour ce modele precis je sai po mai j'ai depuis qques heures une KD7 et jlaime deja cette cm.... no stress, le contraire de ma KT3  :whistle: .....
le rezo semble bien marcher...jai juste qques doutes sur la corres des sondes sous mbm
