ASrock K8 Combo-Z - AMD64 - dual socket 939 XOR 754 [Topic Officiel] - Carte mère - Hardware
Marsh Posté le 05-11-2004 à 22:07:58
SPECIFICATIONS :
CPU - Socket 754/Socket 939 combo*design
- Supports AMD 64-bit Athlon 64/Athlon 64FX and 32-bit Sempron    processor
- Supports HyperTransport Technology
*Socket754 and Socket939 are supported separately.
Chipset - Integrated Single Chip: ULi(ALi) M1689
Hybrid Booster - CPU Frequency Stepless control
- CPU Multiplier
- ASRock U-COP
- Boot Failure Guard (B.F.G)
Memory - DIMM slots: 2 supported with socket 754 CPU
- DIMM slots: 3 supported with socket 939 CPU
- Dual channel technology supported with socket 939 Athlon 64FX CPU
- Max. capacity: 2GB
Slots - 1 x AGP8X/4X slot , 1.5V
- 3 x PCI slots( PCI 2.3 compliance)
VGA N/A
Audio  - Realtek 850 7.1channel AC'97 audio codec
LAN - Realtek RTL8201 10/100 Ethernet LAN PHY
- 802.3u, WOL supported
Connector - 2 x SeialATA 1.5Gb/s connectors supports RAID,0,1,JBOD
- 2 x ATA 133/100/66 IDE connectors ( supports 4 x IDE devices)
- 1 x Floppy connector
- CPU/Chassis FAN connectors
- 20 pin ATX power connector
- 4 pin ATX 12V power connector
- IDE LED connector
- CD/AUX audio in header
- Front panel audio connector
- 2 x USB 2.0 port pin header
- 1 x Game/MIDI port pin header
Rear Panel I/O ASRock 8CH I/O
- 4 x USB2.0 ports
- 1 x RJ45 LAN port
- 1 x Serial port (COM1)
- 1 x PS2 Keyboard connector
- 1 x PS2 Mouse connectors
- 1 x Parallel port (LPT1)
- 2 x Audio ports ( Line In/Out, Mic In)
BIOS Feature - 2Mb AMI BIOS with ACPI, SM BIOS 3.0, PnP
Support CD - Drivers, Utilities, PC-cillin 2002 OEM, ASRock PC DIY Demo
- SATA driver and utility
Accessories - Quick Installation Guide, Support CD, I/O shield
- Floppy/ATA 100 cables
- 1 x SerialATA data cable
- 1 x SerialATA 1-to-1 power cable
Form Factor ATX, 305mm x 244mm
Certifications FCC, CE, MS WHQL
LES REVISIONS DE CARTE:
A ma connaissance, la 1.04 est la première révision dispo en masse en France.
A suivre...
Marsh Posté le 05-11-2004 à 22:30:05
...j'ai reçu cette carte, elle est plutôt trés bien fini. je n'attends plus que le reste des composant pour monter un syteme autour...
j'y mettrai un 3500+ Socket 939 et 2 x 256 BH-5 en Dual tout timing à fond ![]()
Marsh Posté le 05-11-2004 à 22:40:31
tu m'interesses
moi qui compte passer en A64 pour la nouvelle année
Marsh Posté le 05-11-2004 à 22:43:37
... et si ma mémoire est bonne, tu as aussi fait parti des afficionados de l'Ali Magik 1 ![]()
Marsh Posté le 05-11-2004 à 22:47:15
tient j'ai l'ai rarement croisée cette carte... c'est pas celle a laquelle on peut rajouter une carte d'extension??
Marsh Posté le 06-11-2004 à 09:50:32
Yes cap'tain
d'ailleurs elle tourne toujours dans le pc de ma femme
Marsh Posté le 06-11-2004 à 20:29:19
J'ai vu ça dans ta config
Sinon, ça y est la machine tourne, pour l'instant j'ai de la Ram Kingston Value avec des timing moyen [2.5-4(rtcd)-3-11]
J'attends mes BH-5
Marsh Posté le 06-11-2004 à 21:23:42
slt a tous elle donne quoi niveau perf? quelqu'un a des test de bench sous la main?
Marsh Posté le 06-11-2004 à 22:41:34
Je préfère la bencher quand j'aurais mis la BH-5 (certainement Merdredi qui vient)
Marsh Posté le 06-11-2004 à 23:12:03
ouai mai je ve dire la comparé aux autres mobo k8n et k8T
Marsh Posté le 07-11-2004 à 11:47:22
ben, il y a un lien dans le 1 er post vers le test d'OCW
j'ai benché avec Super Pi
36min12s Super Pi 32M avec mes 512mo et leurs timings pourri
je donnerai mes résultat quand j'aurai mis les BH-5
En comparaison, je fais 32min13s avec mon prescott 3.0E @ 3570mhz et 1024mo RAm @ 238 mhz (Timings 2.5-4-3-6)
Il y a donc encore a gagner, je sais pas si les timings agressif de la BH-5 permettront de rattraper le retard. Je ne sais pas si 512 mo ou 1024 mo influe beaucoup avec Super Pi ?
Marsh Posté le 07-11-2004 à 15:33:50
ah ui javai pa vu ben didon elle s'en tir plutot bien elle meilleur ke la asus k8V
Marsh Posté le 08-11-2004 à 15:03:07
c'est vrai que les bench d'OCW son pas en mal surtout en regard du prix des concurrente.
... Bien qu'a vrai dire, j'ai un peu de mal a regler mes timing de la ram, les timings auto dtecté sont délirant et selon les bench mémoire (Everest, Sandra ou memtest) ce n'est pas en les baissant que l'on monte en perf! j'attends impatiement de la mémoire differente de ces 'Kingston Value' pour testé. Je devrai recevoir cette semaine 2 BH-5 Adata et 2 Adata chip Adata ... On aura une idée plus précise
C'est dommage que je sois le seul ici avec cette mobo, un peu de soutien serai le bienvenue ...Il y en a bien sur le forum d'OCW mais mon anglais minable me gene pour poser des questions ...
Marsh Posté le 08-11-2004 à 15:12:39
ben oui , quand même au moins pour me situer, si on regarde les benchs mémoire, il devrait etre superieur. Le soucis c'est qu'avec une GF4 Mx 440 dessus, je peu difficilement dire ce que la carte m^re vaut en 3D
Marsh Posté le 08-11-2004 à 21:01:46
Tu as peut etre raison , mais quitte à optimiser au max cette config, autant essayer de grapiller des perfs un peu partout
Marsh Posté le 09-11-2004 à 11:03:53
Toujours content de ta carte?
J'aimerais monter une deuxième config avec un 2800+ et upgrader pour un 4000 S939 quand il sera abordable.
Marsh Posté le 09-11-2004 à 17:09:31
c'est une bonne stategie que tu envisage
attends encore un peu que je teste avec de la ram de qualité pour conclure ... c'est encore un peu jeune, on sens bien que le bios aussi demande à murir
Marsh Posté le 10-11-2004 à 14:08:58
 j'ai craqué: Asrock combo-z (81); Sempron 3100+ (115); Vdata 512Mo DDR400 (69); Heden B9202C9 400W (27)
 Récuperation: GeF3Ti200; Maxtor 20Go 7200tr/min; Ricoh MP9060A; Clavier; souris
 Prochains noëls et achats: (2005) GeF6800 256Mo; (2006) DDR400 512Mo; (2007) A64 4600+ (S939 SSE3?); (2007) Window$ XP 64bits (aves des bugs inside)
Marsh Posté le 10-11-2004 à 14:23:57
J'ai l'ai prise aussi..... après une installation sans problèmes j'ai voulu tester un peu tout ça en mettant ma gforce6800gt point of view et bien ça passe pas,en bureautique c'est nickel par contre quand je veux lancer un jeu ou même 3dmark j'ai droit a un beau reboot.
Marsh Posté le 10-11-2004 à 14:25:08
J'oubliais une review (en allemand, heureusement il y a des images
http://www.au-ja.org/review-3x754-u2.phtml
Marsh Posté le 10-11-2004 à 14:27:45
pour les GeF6xxx il faut le bios 1.34 (beta)
http://www.ocworkbench.com/2004/as [...] tabios.htm
Marsh Posté le 10-11-2004 à 14:51:04
| jonybigoud a écrit :
Ces prix sont extra ! peut-on savoir ou tu as acheté tout cela ?
Marsh Posté le 10-11-2004 à 15:00:34
http://www.rue-montgallet.com/
cm	AXXS Adresse : 171, rue de Charenton 75012 Paris  01 53 44 78 60	Asrock combo-z	81
cpu	3X+Micro  10 rue de Rambouillet 75012 Paris  01 43 07 70 38 Sempron 3100+	115
ram	(la boutique dans la ruelle à coté de surcouf)
	Vdata PC3200 512 Mo DDR	69
boitier	Price Hunter  8 RUE (DE) CHALIGNY 75012 Paris / Métro : REUILLY DIDEROT   01 43 40 30 42	Heden B9202C9 (silver) 400W	27
Marsh Posté le 10-11-2004 à 15:05:54
| jonybigoud a écrit : Ces prix sont extra ! peut-on savoir ou tu as acheté tout cela ?   |
Bon, j'aurais pu m'en douter, Merci quand même ...
Marsh Posté le 10-11-2004 à 15:22:32
Une question, mais je n'y crois pas trop !
Y a t'il un pci/AGP lock sur ce chipset uli ???
D'avance, merci
Marsh Posté le 10-11-2004 à 15:27:51
Merci jonybigoud je viens de flasher avec le bios beta et maintenant ça passe nickel.
J'ai 1000 points de plus a 3dmark2003 comparé a ma config a base d'amd 3000+ et asus a7v8x ce qui n'est pas mal pour un cpu qui a un p-rating inférieur ![]()
Marsh Posté le 10-11-2004 à 15:30:40
| gdronnik a écrit :    |
Non, mais OC max= 250 !!! (cf http://www.ocworkbench.com/asrock) et à 251 ça passe pas ..
Marsh Posté le 11-11-2004 à 19:00:34
Cool !!! je suis content de ne plus etre le seul possesseur, on resoudra nos soucis en commun
bienvenue @ jonybigoud & gladiateur (les autres aussi)
| jonybigoud a écrit : J'oubliais une review (en allemand, heureusement il y a des images   |
J'édit la 1ere page avec ce lien
| gdronnik a écrit : Une question, mais je n'y crois pas trop !   |
Non
  et c'est bien dommage
pour se rassurer, il faut dire que c'est présent sur les chipset VIA pour AMD64 mais ça marche pas correctement. Il n'y a que sur n'Force3 que ça fonctionne vraiment
Put1, elle me fait un peu chier cette mobo pour lui appliquer des timings correcte. j'ai reçu la BH-5, je vais faire un max de test ce long long week end
Dites les gars, vous utilisez quelle timings vous avec cet mobo? ( CPUZ1.24 vous les donne facilement car le bios est compliqué sur ce point, l'ordre n'est pas le même que dans nos habitudes)
Marsh Posté le 11-11-2004 à 22:44:38
| Cap'tain Kaverne a écrit :    |
C'est pour ça que j'ai des envies de meurtre à chaque fois que j'ai à faire à du chipset ALi
Déjà quand on voit toutes les 'bricoles' qui 'devraient' être reglées dans les history logs des updates de bios, ben ça donne franchement pas confiance.
Marsh Posté le 11-11-2004 à 22:47:45
j'ai eu 2 A7A266 et A7A266-E et franchement, j'en conserve le souvenir de cartes sans soucis et performante à l'époque. J'ai eu une iwill XP333-Raid, même chipset et plein de problême d'IDE.
Marsh Posté le 11-11-2004 à 23:16:22
mon A7A266 tourne toujours sur le PC de ma douce
cette carte n'a jamais posé le moindre pb
Marsh Posté le 12-11-2004 à 09:45:04
Après deux jours d'utilisation je peux dire que j'en suis très content.Je voulais l'utiliser pour la bureautique et garder ma première config pour le jeu mais après avoir tout tester j'ai laissé l'asrock avec ma 6800GT car en 3D ça déchire
Je ne regrette pas l'achat mon pc est très stable et a de très bonne perf...
Pour les timings de la mémoire j'ai tout laissé en auto car je ne sais pas trop quoi changer et comme je ne m'y connais pas assez je ne touche pas
Marsh Posté le 13-11-2004 à 13:34:21
Ok, clair que ç'est stable et performant pour un prix modique
tu peux quand me dire ce que te donne CPUZ 1.24 en lecture de tes timings, ça nous donnera dans ton cas ce que la carte mère à choisit automatiquement ?
Ayé! moi j'ai trouvé une cominaison de drivers adéquate et full rock top stable (4h Prime95 + 1h memtest + 1 Super Pi32M)
Mémoire A-Data BH-5 2x 256 en dual channel =>
Cpu host = 'Manual' freq = 200
2.0 - 3 (rTCD) - 2 - 6
row cycle time (tRC) 12T
commande rate 2T
Bank interleave = Disabled
Htt = 800mhz
Marsh Posté le 13-11-2004 à 13:50:10
Heu... Je vais peut-être poser une question bête, mais on peut faire du bi-pro avec en mettant un proc sur chaque socket ou on est obligé de choisir?
Marsh Posté le 13-11-2004 à 13:58:48
N'essaye jamais de faire ça sous peine de tout cramer, c'est ecrit trés GROS dans le manuel ![]()
Marsh Posté le 05-11-2004 à 22:05:48
[Topic Officiel] Carte mère "ASrock K8 Combo-Z" chipset Uli M1689 pour AMD64 K8 Socket 754 ET 939
MISE A JOUR 17/12/2004 @ ~17:47
Voilà un topic qui ne sera sans doute jamais N°1 à l'Audimat mais que je pense indispensable à tous ceux qui acheterons cette carte.
Personnellement, je crois beaucoup en cette carte, Non pas parce qu'elle a les deux socket pour c'est à dire 754 & 939, mais plutôt parce que les chipset Ali (Uli maintenant) sont vraiment d'une stabilité exemplaire et facile à vivre. J'en veux pour preuve les merveilleux souvenir que j'ai eu avec les Asus A7A266 et A7A266-E à base des 2 révisions d'Ali Magik.
Evidement, c'est une Asrock, elle ne sera jamais une bête d'overclocking mais il y aura peut être des bios tweakés ( je l'espère, et nous le dirons ici)
C'est avant tout une base pas cher pour construire un systeme évolutif K8, perenne, et ce permettre d'attendre la baisse à venir du tarif des CPU S939...
Les 'review'...
http://www.pcstats.com/articleview.cfm?articleID=1699 NEW
http://www.pcinpact.com/articles/a/107/1.htm NEW
http://www.phoronix.com/scan.php?p [...] m=99&num=1 NEW
http://www.ocworkbench.com/2004/as [...] o-z/g1.htm
http://www.amd-guide.com/index.php?id=k8combo
http://www.hkepc.com/hwdb/k8comboz-1.htm
http://www.hwinit.it/modules/secti [...] e&artid=42
http://www.darkcrow.co.kr/Communit [...] 1&branch=5
http://www.aswin.co.kr/board/?imod [...] &c_id=1247
http://www.beareyes.com.cn/2/lib/2 [...] 825105.htm
télécharger le manuel : (Acrobat Reader doit être installé)
http://www.asrock.com/Drivers/Manual/K8%20Combo_Z.pdf
Uli officiel drivers download page >
http://www.uli.com.tw/drivers.php
Drivers Uli Integrated V2.093 (17 Nov 2004)
http://www.station-drivers.com/for [...] c4f703636d
Asrock download page (Officiel) Drivers & Bios
http://www.asrock.com/support/Down [...] ombo-z.htm
LES REVISIONS DE BIOS:
1.50
1. BIOS setup should operate correctly if set IDE to Not Installed then set it back to Auto.
2. For few SATA HDD, they should be detected correctly.
1.12C performance bios 'unofficial' chez OCW (Lien plus bas)
1.40
1. Improved AGP signal.
2. Fine tuned Nvidia 6800, 6800 LE, 6800 GT, and 6800 Ultra AGP cards.
3. Improved USB 2.0 timing.
4. Fine tuned Matrox Millennium G550 AGP card.
5. Western Digital WD400EB HDD should be detected correctly.
1.34 béta
Bios béta - Fixes compatibility issue with NV 6800GT, 6600GT cards
1.30
1. Flexibility function should be working correctly.
2. K8 Sempron 3100+ should be working with 2 DIMM of memory installed.
3. Cool' n' Quiet function should be working with K8 Sempron 3100+, Athlon 64 FX-53 and FX-55 CPU.
1.20
1. After resuming from Hibernate of Windows Me, power button should function correctly.
2. Fine tuned Dual-Channel memory mode for AMD K8 version D CPU.
1.10
1. Fine tuned ATi 9600 Pro AGP card.
1.00
1. First released.
Bios béta et/ou performance là >
drivers linux >
Patch AGP (pour M1689) pour linux sur http://marc.free.net.ph/message/20 [...] 8afef.html
utilitaires A64&M1689
A64 Tweaker v05 béta là: http://www012.upp.so-net.ne.jp/ohij2/
permet de modifier des paramêtres qui influencent de manière non négligeables vos performances
Message édité par Cap'tain Kaverne le 17-12-2004 à 16:50:10
