Probleme de PC
Probleme de PC - Carte mère - Hardware
Marsh Posté le 20-10-2004 à 19:03:37
Bonsoir
Ma Config : AMD athlon 64 3500 socket 939
            Leadtek A400TDH Nvidia 6800
            1 go corsaire DDR400
            abit AV8 K8T800 pro socket 939
J'ai fait un test a 3D mark05 et mon score etai de 757
    Memory Slot 1/4
Installed Enabled Size   1.00 GB
Form Factor   DIMM
Frequency   0.0 Hz
Slot   A0 [Bank0/1]
Manufacturer   None
Type Details
Total Bit Width   0 b
Data Bit Width   0 b
     NVIDIA GeForce 6800        Driver 6.1.7.7
Description   NVIDIA GeForce 6800
Manufacturer   NVIDIA
Total Local Video Memory   128 MB
Total Local Texture Memory   128 MB
Total AGP Memory   128 MB
Driver File   nv4_disp.dll
Driver Version   6.1.7.7
Driver Date   7-15-2004
Driver WHQL Certified   false
Max Texture Width   4096 px
Max Texture Height   4096 px
 Max User Clipping Planes   6
Max Active Hardware Lights   8
Max Texture Blending Stages   8
Fixed Function Textures In Single Pass   8
Vertex Shader Version   3.0
Pixel Shader Version   3.0
Max Vertex Blend Matrices   0
Max Texture Coordinates   8
VGA Memory Clock   702.0 MHz
VGA Core Clock   324.0 MHz
 PCI
Name   NVIDIA GeForce 6800
Vendor ID   0x10de
Device ID   0x0041
SubSystem ID   0x2992107d
Revision ID   0xa1
Motherboard Info
Supported Slot Types   ISA, PCI, AGP
Manufacturer   http://www.abit.com.tw/
Model   AV8 (VIA K8T800P-8237)
Version   1.x
BIOS Vendor   Phoenix Technologies, LTD
BIOS Version   6.00 PG
BIOS Release Date   06/16/2004
BIOS Properties   Plug and Play, Flash, AGP
 AGP
Revision   3.0
Rate   4x, 8x
Available Rate   0x0000000c
Selected Rate   0x00000000
Aperture Size   229 MB
Sideband Addressing   supported (disabled)
Fast Write   supported (disabled)
Card Slots
Slot 1/6 (PCI)
Order   8
Designation   PCI0
Type   PCI
Characteristics   5.0V, PME Signal
Data Bus Width   32 b
Details   Available, Long
IRQ   0
 Slot 2/6 (PCI)
Order   9
Designation   PCI1
Type   PCI
Data Bus Width   32 b
IRQ   0
 Slot 3/6 (PCI)
Order   10
Designation   PCI2
Type   PCI
Data Bus Width   32 b
IRQ   0
Slot 4/6 (PCI)
Order   11
Designation   PCI3
Type   PCI
Data Bus Width   32 b
IRQ   0
 Slot 5/6 (PCI)
Order   12
Designation   PCI4
Type   PCI
Data Bus Width   32 b
IRQ   0
 Slot 6/6 (AGP)
Order   0
Designation   AGP
Type   AGP
Data Bus Width   32 b
IRQ   0
Marsh Posté le 20-10-2004 à 19:05:21
ola calmos avec le copier coller. Installe propre ? drivers CM+CG, pas de cool and quiet ? cpu à la bonne frequence ? Alim bien branché ?
Marsh Posté le 20-10-2004 à 19:09:03
AMD Athlon(tm) 64 Processor 3500+
Manufacturer   AMD
Family   AMD Athlon(tm) 64 Processor 3500+
Architecture   64-bit
Internal Clock   2.2 GHz
 Internal Clock Maximum   3.0 GHz
External Clock   204.0 MHz
Socket Designation   Socket 939
HyperThreadingTechnology   N/A
 Capabilities   MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE, SSE2, PAE, NX
Version   AMD Athlon(tm) 64 Processor 3500+
 Caches
Level 1    128 KB
Level 2    512 KB
 :) normalement tous les branchement son bon
driver carte mere se du cd et de la carte graphique se son les tous derniers 6.1.7.7
Marsh Posté le 20-10-2004 à 19:10:25
Ou esque je peu le voir si mon proc es à a la bonne frequence ?
Je ne suis pas tres doué en imformatique.
Marsh Posté le 20-10-2004 à 19:21:34
http://www.cpuid.com/cpuz.php
If I want to fail and succeed, which I have done ?
Marsh Posté le 20-10-2004 à 19:26:01
de toute façon meme si le cool and quiet etait installer le PC adapterai sa vitesse au bench ! Tu as mis quelle option dans le test aussi ? et sur la CV tu es sur optimal ??
Marsh Posté le 20-10-2004 à 19:29:04
mon proc es a 204.3 mhz
Marsh Posté le 20-10-2004 à 19:31:37
Cool and quiet ? ques que c'est ?
Marsh Posté le 20-10-2004 à 19:38:16
heu la il y a un pb c'est impossible !
En plus le chipser ne gere pas le cool and quiet ! je crois que celle le NF3 le gére !
Marsh Posté le 20-10-2004 à 19:49:29
alors d'ou peu venir se probleme c pas normale que j ai 757 point a 3d mark05
Marsh Posté le 20-10-2004 à 19:54:21
et a tous les tests j ai pas plus de 3 a 4 fps :/
Puis je rame sur pas mal de jeu far cry je suis obliger de mettre les detail au minimum cs source j'ai des tomber de a 30 fps
men of valor meme les detail au minimum il rame !!
claké plus de 10 000 fr pour avoir un ordi qui rame ...
Marsh Posté le 20-10-2004 à 19:59:01
Ou alors sa doit surement venir de la ram
1 go de ram corsaire DDR 400
C'est se que m indique CPU-Z
frequency 204.3
Normalement sa ne devrait pas etre 400 ???
Marsh Posté le 20-10-2004 à 20:03:08
La frequence de mon proc est a 2247.4 Mhz
Marsh Posté le 20-10-2004 à 20:20:26
personne ne sais ?? :(
Marsh Posté le 20-10-2004 à 20:21:52
installe correctement les pilotes....
Marsh Posté le 20-10-2004 à 22:06:40
quand tu fais alt ctrl sup ton proc est utilisé a combien ? juste aprés le boot ?
Marsh Posté le 23-10-2004 à 12:19:53
Alors tu as trouvé sebinfo ?
