question sur mon bios
question sur mon bios - Carte mère - Hardware
Marsh Posté le 20-03-2005 à 18:01:53
voila, dans mon bios il y a un valeur modifiable qui s'appelle
" L1 et L2 cache", et j'ai le choix entre:
-enabled
-writethru
-writeback
lequel doit-je choisir ???
Marsh Posté le 20-03-2005 à 18:03:59
Enabled, ne pas modifier ca, ca va ralentir ton CPU et trés surement planter trés vite.
/!\ DO NOT LOOK AT, TOUCH, INGEST OR ENGAGE IN CONVERSATION WITH ANY SUBSTANCES BEYOND THIS POINT. /!\
Marsh Posté le 20-03-2005 à 18:42:56
d'origine il est sur writeback  :pt1cable:
Marsh Posté le 20-03-2005 à 20:56:29
SVP, que signifie "writeback" et "writethru" ???
Marsh Posté le 21-03-2005 à 17:58:30
SVP  :(
Marsh Posté le 24-03-2005 à 11:08:54
simple trad !
-"writeback" = écriture arrière
-"writethru" = écriture à travers.
Après vaschercher le sens ! lol
je vois pas exactement ce que cela signifie
Marsh Posté le 24-03-2005 à 11:12:26
Trouvé sur :
https://wrc.navair-rdte.navy.mil/wa [...] /cmos2.htm
The external memory (or L2 cache memory) setting refers to the high-speed RAM that speeds data transfer between the processor and main memory. All current systems ship with L2 cache memory, and this setting should always be enabled. If you notice that your machine is lethargic, check to make sure that the L2 cache memory setting hasn't automatically switched itself off, as may happen during failed memory checks at start-up. The internal cache memory, or L1 cache, is located on the processor itself and should be turned on if your machine has a 486 or faster processor. These settings are listed separately on some BIOSes.
On recent BIOSes, you can also specify that each cache use the WriteBack or WriteThru caching algorithm; the former is the default, and the latter (which is slightly faster) should be used only if you are unafraid of a possible (but unlikely) loss of data should the PC's power go down. Recommendation: On for cache, WriteThru for type.
Je cherche une version française et place un edit ...
Bon ben pas trouvé, voici une traduction libre:
Le setting de mémoire externe (ou cache L2) réfère à la RAM haute performance qui accélère le transfer de données entre le processeur et la mémoire principale. Tous les chips courants ont une mémoire cache L2 qui doit toujours être activée (enabled). Si vous remarquez que votre machine est léthargique, assurez-vous que le setting de la cache L2 ne s'est pas mise d'elle même en mode non-activé "OFF" comme cela peut se produire lors d'un contrôle mémoire défaillant au démarrage. La cache mémoire interne, ou cache L1, est située sur le processeur lui-même et doit être activée si votre machine a un processeur 486 ou plus rapide. Ces settings sont listés séparément dans certain BIOS.
Dans les BIOS récents, vous pouvez spécifier que chaque cache utilise l'algorithme de cache "writeback" ou le "writethru" ; le premier est l'algorithme utilisé par défaut et le second (qui est légèrement plus rapide) devrait être utilisé si vous n'êtes pas effrayé par une perte de données possible (mais improbable) lorsque le PC s'éteind.
Recommendation: Actif "On" pour la cache, "WriteThru" pour le type d'algorythme.
Message édité par Vobiscum le 24-03-2005 à 11:26:20
Ce qui est affirmé sans preuve peut être nié sans preuve.
