New Bios Abit KD7 (-Raid) : prise en charge du Barton et du Thorton !
New Bios Abit KD7 (-Raid) : prise en charge du Barton et du Thorton ! - Carte mère - Hardware
MarshPosté le 20-04-2003 à 09:00:55
info Abit :
kd7dn.exe BIOS ID: DN BIOS Compile Date: 4/02/2003 Follow AMD's recommendation that "CPU Disconnect Function" should be implemented to make CPU slow down in idle state, and the default value sets up to Enable. Follow AMD's recommendation to revise the trigger timing of LM90 for Palomino CPU(model 6). Fix the SCSI BIOS malfunction problem when three add-on cards installed together, PCI S3 VGA + GF4MX420 + DC390U3W(at PCI-1). Supports Barton 2600+(333 FSB)and Thorton2000+(266 FSB) / 2200+(266 FSB) / 2400+(266 FSB) / 2600+(333 FSB). Revises some CPU frequency(1466,1666,1916,2166)to be AMD officially suggested figures.(1467,1667,1917,2167). BIOS compile date 4/02/2003.
C'est la première fois que j'entend parler du THORTON ! C'est quoi ?
Marsh Posté le 20-04-2003 à 09:00:55
info Abit :
kd7dn.exe
BIOS ID: DN
