[The TOPIC] Asus A8R-MVP (S939 - Ati X-Press200 Crossfire édit° RD480)
Asus A8R-MVP (S939 - Ati X-Press200 Crossfire édit° RD480) [The TOPIC] - Carte mère - Hardware
Marsh Posté le 04-12-2005 à 14:41:34
A en voir les reviews ci-dessous , c'est une nouvelle reine de l'overclocking pour ~130€ fdp in
http://www.gamepc.com/labs/view_co [...] mvp&page=1   (new 21 12 2005)
http://www.anandtech.com/mb/showdoc.aspx?i=2617
http://www.amdzone.com/modules.php [...] 198&page=1
http://www.pcper.com/article.php?a [...] ype=expert
Vous en pensez quoi ?
http://images.anandtech.com/graphs/asus%20a8rmvp_112005111120/9882.png
http://images.anandtech.com/graphs/asus%20a8rmvp_112005111120/9883.png
Asus A8R-MVP
CPU Interface Socket 939 Athlon 64
Chipset ATI RD480 Northbridge - ULi M1575 Southbridge
Bus Speeds 200 to 400MHz in 1MHz Increments
Memory Speeds DDR200, 266, 333, 400 (433, 466, 500 with Rev. E AMD)
PCIe Speeds 100 to 150MHz in 1MHz Increments
PCI/AGP Fixed at 33/66
Core Voltage  Auto, 0.8V to 1.45V in 0.025V increments PLUS 0.2V with vCore Over-voltage (Maximum vCore 1.65V)
CPU Clock Multiplier 4X-25.5X in 0.5X increments
DRAM Voltage Auto, 2.65V to 3.2V in .05V to .1V increments
HyperTransport Frequency 1000MHz (1GHz)
HyperTransport Multiplier Auto, 1X to 5X
PCI Express Voltage  1.2V, 1.3V, 1.4V, 1.5V
Southbridge Overvoltage Enabled (+0.1v)
PEG Link Mode Auto, Disabled, Normal, Fast, Faster
PEG Bugger Length Auto, Short, Long, Longer, Longest
AI Overclocking Manual, Auto*, Standard*, Overclock Profile *Set CPU Frequency and Other Parameters Automatically
Overclock Profile Options 3%, 5%, 10%, 15%, 20%, 30%
Memory Slots Four 184-pin DDR DIMM Slots Dual-Channel Configuration Regular Unbuffered or ECC Memory to 4GB Total
Expansion Slots 2 PCIe x16  1 PCIe x1 3 PCI Slots 1 Asus MVP Switch Card in Secondary (Black) PCIe Slot
Onboard SATA/RAID 4 SATA2 Drives by ULi M1575 (RAID 0, 1, 1+0, 5, JBOD)
Onboard IDE/IDE RAID Two Standard ATA133/100/66 (4 drives)
Onboard USB 2.0/IEEE-1394 8 USB 2.0 ports supported by ULi M1575 2 1394 Firewire by TI 1394
Onboard LAN 1 Gigabit Ethernet PCI Ethernet by Marvel Yukon 88E8001
Onboard Audio Azalia HD Audio by ADI AD1986A Soundmax codec
BIOS Revision AMI 0037 (11/17/05) Beta
Message édité par Cap'tain Kaverne le 21-12-2005 à 17:41:43
Marsh Posté le 04-12-2005 à 15:00:12
http://images.anandtech.com/reviews/motherboards/asus/a8r_mvp/a8r-mb.jpg
deuxieme revision du bios là =>
bios 0309
http://dlsvr01.asus.com/pub/ASUS/m [...] rm0309.zip
Message édité par Cap'tain Kaverne le 01-01-2006 à 22:17:08
Marsh Posté le 04-12-2005 à 15:23:11
je pense qu' il y a un pb sur le test :D
mon topic de vente
Marsh Posté le 04-12-2005 à 15:25:11
lequel ?
celui d'Anandtech est convaincant je trouve
Marsh Posté le 04-12-2005 à 16:04:40
Elle n'a pas été testée encore en France ? ni dans un magasine ?
Marsh Posté le 04-12-2005 à 16:08:49
Pas encore, par contre elle vient d'être dispo à la vente chez Materiel.net =>
http://www.materiel.net/details_A8R-MVP.html
j'en ai commandé une, je testerai ça le week end prochain avec un X2 4400+
Message édité par Cap'tain Kaverne le 04-12-2005 à 16:10:49
Marsh Posté le 04-12-2005 à 16:15:53
et oui, je sais je suis de nantes et j'hésite à faire le pas... on m'oriente vers une DFI mais c'est chère et l'abit fatal1ty an8 ne se fait plus sauf en sli... et ce que je souahite ce sont des ports pci simple car j'ai pas mal de carte à mettre.
Marsh Posté le 04-12-2005 à 18:45:52
La difference avec la DFi (niveau prix j'entends!) est énorme
si tu n'a pas besoin de SLI, prends cette A8R-MVP qui semble promettre...
En pus si tu est Nantais, tu économisera les frais de port
Marsh Posté le 04-12-2005 à 19:11:08
c'est sûr, mais elle vient de sortir et je ne connais pas ses défauts (si elle en a), j'aurais bien aimé un test comparatif ou pas chez Matbe par exemple.
Marsh Posté le 04-12-2005 à 20:41:58
oups, c'est pas pour tout de suite.
Je me documente à l'etranger pour l'instant
Marsh Posté le 05-12-2005 à 12:32:51
Entièrement passive, sans caludoc ... impressionnant si elle sort vraiment comme cela.
Marsh Posté le 05-12-2005 à 12:35:02
Amusante, la fiche de matériel.net :
"1 contrôleur S-ATA II et U-ATA/133 supportant les modes RAID 0, 1, 0+1, 5 et JBOD (intégré au nForce 4)"
:lol:
Message édité par Lodeno le 05-12-2005 à 12:35:12
Marsh Posté le 05-12-2005 à 12:42:18
faut pas regarder les détails, ça reste la fiche technique d'un VPCiste
Par contre quelle soit passive ne m'étonne pas, j'ai eu une x-press200 MSi, ça chauffait pas quand au southbridge ULi, je suis pas étonné qu'il ne chauffe pas.
Ce que tous le monde à constaté par contre , c'est que les NF4 chauffe eux (j'ai eu une chaintech NF4, je confirme que ça chauffe)
Marsh Posté le 05-12-2005 à 13:22:00
D'après le manuel en anglais... si, si elle fait sata 2... d'ailleurs sur le site d'asus c'est prcisé.
http://www.asus.com.tw/products4.a [...] =15&l3=236
Marsh Posté le 05-12-2005 à 20:15:19
http://www.tomshardware.fr/article [...] &NumPage=1
Sujet sur le CrossFire et SLI, avec test de la carte que tu désires
Marsh Posté le 05-12-2005 à 22:11:32
ils la compare à l'Asus A8N32-SLI Deluxe qui coute quand même + de 200roros
Elle s'en sort pas mal comparativement
attendons de voir l'overclocking car pour l'instant, rien n'est dit chez tom's à ce sujet ...
Marsh Posté le 07-12-2005 à 03:10:08
Mmmhh, chez materiel.net la dispo était "5 à 6 jours" puis c'est passé à "en stock" pendant 2/3 jours et c'est repassé à dispo "5 à 6 jours", y t'ont dis quoi pour ta commande?
Marsh Posté le 07-12-2005 à 07:47:54
ma commande est en cours de livraison (parti hier) ils en ont pas eu beaucoup ...
Marsh Posté le 07-12-2005 à 14:02:19
OK, merci.
Marsh Posté le 08-12-2005 à 11:50:00
Ayé !! !j'ai reçu la carte, montage ce soir
Marsh Posté le 09-12-2005 à 00:31:49
...la carte est monté, booté du 1er coup :)
j'ai fait une reinstall propre de windows.
ca ma l'air trés stable a toute première vue
demain je ferais qq test et je mettrai ici des photos que j'ai prise
Marsh Posté le 09-12-2005 à 00:45:21
Tu l'as monté avec quels Proc/ram?
Marsh Posté le 09-12-2005 à 01:35:02
Cap'tain K averne
Ecran 21' CRT "DELL" D1626HT tube Trinitron
  C. Vidéo Point Of View GeForce GF 7800-GTX 512 'Extreme version' (fréq :580/1730 par défault) PCI-Express 16x
C'est ça ta config?
Marsh Posté le 09-12-2005 à 11:46:32
je l'ai monté avec un 4400+ et 2go de ram Infineon PC3200
(cf ma config)
Marsh Posté le 09-12-2005 à 11:46:42
copsc a écrit :
Cap'tain K averne
C'est ça ta config?
Yes, why ?
Marsh Posté le 10-12-2005 à 08:41:41
Bon, là je me sens un peu seul avec cette mobo, j'aurai besoin de partager mon experience !!
Eneffet, j'ai qq soucis non pas de stabilité mais de parametrage du bios. J'ai l'impression que les modif que l'on fait dans certain onglet du bios (gestion mémoire par exemple) sont inoperante!
MA mémoire se desynchro en auto sur 166 et si je veux la mettre en synchro @ 200, je la retrouve sous windows à 166
Pareil pour les timings mémoires qui ne bouge pas en réel si le les change dans le bios.
...il faut dire que pour l'instant, il n'existe qu'un bios (le 201 initial), il est d'urgent d'attendre sa première mise à jou ... ASUS, fais vite !!!
Marsh Posté le 10-12-2005 à 08:57:42
Pour ma prochaine config, je la prendrai, ^^
Donc patience ^^ Sinon change le nom du sujet ^^ Ce n'est plus une simple question, mais ça devient un sujet unique ;)
Marsh Posté le 10-12-2005 à 09:15:14
Tu as raison (deux fois)
-> raison d'en prendre une aussi pour m'aider ;)
-> raison de me suggerer l'idée dans faire un topic genre 'unique'
Marsh Posté le 10-12-2005 à 20:36:32
D'après quels progs sous windows?
Marsh Posté le 11-12-2005 à 18:16:04
CPUZ 1.31 et Everest 2.20
Je précise que c'est un 4400+ (rev E6) + 4 barettes de 512mo Infineon BT-5 double face
Marsh Posté le 12-12-2005 à 10:18:38
Elle m'interresse bien cette ptite CM!elle a pas l'air très cher et très o/c d'ici les futurs bios?
Quel sont tes impressions sur cette cm?
peut-on mettre 2 X800GTO en crossfire?peut-on les transformer en Crossfire ou il faut que ce soit mentionner sur la boite de la carte?
je dessire monter 2*1 go de ram?tu me conseil laquel?
Marsh Posté le 12-12-2005 à 10:31:46
Normalement il faut posséder une carte crossfire edition (sauf pour les X1300/1600) il me semble.
Le crossfire des X800 n'est pas intéressant car limité au 1600x1200 en 60hz, pas de PS3 ni de hdr...
Marsh Posté le 12-12-2005 à 10:33:58
qu'est ce quel ont de plus alors les x1300 et x1600?elles sont crossefire edition d'origine?
Marsh Posté le 12-12-2005 à 20:04:07
up!
Marsh Posté le 13-12-2005 à 21:13:16
Me revoilou les gus !!!
Spanishchoc, je ne pense pas que tu puisse mettre 2 x X800GTO en crossfire, il te faut au moins carte crossfire édition (exception des x1300 et x1600 comme le précise aliss)
Sinon, je suis en attente d'un bios à jour car je pense que mon soucis de ram est insolvable pour l'instant (voir plus haut)
Je pense que le bios actuelle n'autorise pas mon 4400+ rev E6 a gerer correctement 4x512mo PC3200 double face. J'espère qu'Asus travaillera ce point et sortira sa première mise à jour rapidement ...
SInon, la carte est vraiment trés stable, rien à redire, les perf sont honorable mais je ne connais pas encore sont potentiel d'overclocking .
Marsh Posté le 13-12-2005 à 21:56:36
ok!certes je disait que pour l'instant j'allais mettre une seule x800 gto ou gto16 en attendant l'"arrivée en masse du R580 et de là, tester le crossfire!ge pense mettre 2*1 go, de la gskill PC4000.tu en pense koi? c mieux 4*512 ou pas?
Marsh Posté le 13-12-2005 à 21:57:58
g pense mettre un x2 3800+ mais j'espère que d'ici le socket M2, il sortiront des X2 optimisés, voir en 0,65µ (vive noêl) pour notre mobo!
Marsh Posté le 13-12-2005 à 22:01:11
oui; la G-Skill en 2x1go, c'est top et c'est bien mieux gerer par les A64 que 4 barettes (cf ma config, j'ai cette ram dans mon second PC)
quand au M2, il sera sur un nouveau socket (M2) incompatible avec la A8R-MVP ...a moins qu'AMD sorte des 0,65µ pour socket 939
Marsh Posté le 13-12-2005 à 22:04:00
oui ca serait génial des 0,65µ pour du s939!je pense que le socket M2 arrivera vers cet été donc on devrai voir arrivé le 0,65µ cet été!ca serait trop bien!
Marsh Posté le 13-12-2005 à 22:09:05
revons un peu :)
Si tu peux patienter un peu, attends de voir ce que donnera le nouveau bios de l'A8R-MVP, sinon, il il a le chipste ULi1697 single chip qui pointe le bout de son nez (certainement dispo après les fêtes), a mon avis c'est du tout bon ça !
