[Topic Unique] Abit AB9 QuadGT
Abit AB9 QuadGT [Topic Unique] - Carte mère - Hardware
Marsh Posté le 13-02-2007 à 11:11:30
CARACTERISTIQUES
Lien vers le site ABIT
http://users.skynet.be/raphantoine/brol/quadgt.jpg
http://users.skynet.be/raphantoine/brol/Abit01.jpg
http://users.skynet.be/raphantoine/brol/Abit02.jpg
http://users.skynet.be/raphantoine/brol/Abit03.jpg
TESTS
Test Anandtech
BIOS
CPU support list
Comment mettre à jour le BIOS?
AWDFLASH revision 20061017172020
BIOS M621E_10.BIN
1. Première édition.
2. Date de compilation du BIOS : 12/11/2006
Beta BIOS M621E_11.B02
1. Correct SPDIF phohe jack to meet Reltek Utility
2. Support 50 ohm ODT
3. Fixing CMOS Checksum error/CPU change message show at the same time.
4. Fixing to adjust CPU VTT 1.2V, MCH 1.25V, ICH 1.05V, ICHIO 1.5V, voltage high limit issue
5. Fixing EM64T string was covered while Clear CMOS
6. Adjust E-SATA signal
7. Fixing BIOS option "Resume by Alarm" to "Wake Up by Alarm"
8. Fixing can't boot from floppy, when I set SATA to RAID/AHCI mode and with the PATA HDD
9. The CPU Core Voltage highest limit is 1.9V
10. Fixing can't boot from SATA HDD, when I install bootable USB device
Beta BIOS M621E_11.B06
1. Quad Core and Vista64 Issues resolved.
2. RAID/IDE issues almost resolved, Intel ICH8R + RAID mode with Intel ICH8R + SATA optical drive is the only issue not resolved now.
3. Use at your own risk, no technical support for it.
BIOS M621E_11.BIN (Dernier Bios Officiel)
Image ISO bootable à partir d'un cd ici
1. Enhanced overclocking ability.
2. Modify the Voltage adjusting function.
3. Fixed an issue that the system hangs during Vista installation, when using a Kentsfield CPU.
4. Fixed an issue where the system sometimes hangs on POST code 2A.
5. Fixed the JMB363 performance issue.
6. JMB363 now works as intended when enabling ICH8R RAID ROM.
7. The "EIST adjusting" function now works as intended.
8. BIOS compiled date: 3/27/2007
MANUELS
Version Anglaise
DRIVERS
INTEL Application Accelerator RAID Driver v 6.2.0.2002 pour 2000/XP/2003/64bit
INTEL Chipset Driver v 8.1.1.1010 pour 2000/XP/2003/64bit
Intel ICH7R/ 8R Raid Installation Disk V1.03 pour 2000/XP/2003/64bit
JMicron Installation Disk V1.01 pour 2000/XP/2003/64bit
JMicron SATA Driver V1.17.07.06 pour 2000/XP/2003/64bit
Realtek 8110SC Gigabit Lan Driver V5.650.616 pour Win9x/Me/2000/XP/2003
Realtek 8111B Gigabit Lan Driver V5.65 pour Win9x/Me/2000/XP/2003
Realtek High Definition Audio Driver R151 pour 2000/XP/2003/Vista/64bit
Sil3132 RAID Installation Disk V1.01 pour Win2000/XP/2003/64bit
Sil3132 RAID Installation Disk V1.02 pour 64bit
64bit driver support list
Utilitaires
abit uGuru 3.1X v3.101 pour 2000/XP/2003/Vista/64bit
Personne ne parle de cette carte mère qui a pourtant la particularité de monter à plus de 500 FSB tout en restant en strap 1066.  :ouch:
Message édité par kozzi le 13-04-2007 à 16:21:53
Marsh Posté le 13-02-2007 à 11:12:23
Drapal, peut être ma prochaine CM  :jap:
EDIT: CF en 2 port PCI-E 8X?  :??:
Message édité par dami1stm le 13-02-2007 à 11:13:31
"La liberté d'expression n'a d'ennemis que ceux qui veulent se réserver le droit de tout faire" - "Seems all have gone insane for gold"
Marsh Posté le 13-02-2007 à 11:27:29
Comme c'est du P965, un pci-e est cablé en X4.
Donc j'imagine que c'est du x16 x4 pour le crossfire mais je me trompe peut-être.
Je ne suis pas spécialiste du CF  :whistle:
Message édité par kozzi le 13-02-2007 à 11:28:02
Marsh Posté le 13-02-2007 à 11:44:21
975 bad axe 2 VS 965 QuadGT
Plus de perte de performance après 400 de FSB  :love:
Topic sur XS
Message édité par kozzi le 13-02-2007 à 11:45:46
Marsh Posté le 13-02-2007 à 11:48:31
Si c'est vraiment ca, je reste sur i975x :/
je vais me renseigner, bonne idée de topic !  :hello:
Marsh Posté le 13-02-2007 à 11:54:27
Il me semble que c'est ca...
P965 : 16x => 16x/4x
i975X : 16x => 8x/8x
Marsh Posté le 13-02-2007 à 12:03:02
Si tu veux absolument le CF ou le SLI, il vaut mieux rester sur i975x ou passer au nforce
Avec le P965, il y a des pertes dans le crossfire. Certe pas énormes mais pertes quand même...
Je ne pense pas que cette carte mère y changera quelque chose.
Message édité par kozzi le 13-02-2007 à 12:03:24
Marsh Posté le 13-02-2007 à 12:04:32
Ptain  :fou:
Ah quand une trés bonne CM en OC + CF  :fou:
La P5B Dlx n'a pas 2XPCI-E 16X?  :??:
Marsh Posté le 13-02-2007 à 12:09:42
Si mais un cablé en X4 qui fonctionne donc en X4 en crossfire.
Pour un bon chipset OC et CF peut-etre le successeur du i975x, le bearlake X38  :??:
Marsh Posté le 13-02-2007 à 12:13:55
Marsh Posté le 13-02-2007 à 12:18:01
http://www.matbe.com/images/biblio/divers/000000051586.png
Mouais, enfin bon quand même :/
Et la P5W64 Pro, elle a 4 port PCI-E mais ils sont cablé comment?  :??:
Marsh Posté le 13-02-2007 à 12:23:15
Avec la P5W64 Pro je pense que tu peux faire tourner deux en X8 chacun ou 4 en X4.
Mais ça demande confirmation.
Marsh Posté le 13-02-2007 à 12:25:25
Oui, mais les tests sont trés rares, et les infos aussi  :)
Dommage parceque cette AB9 me fesait envie  :)
Marsh Posté le 13-02-2007 à 12:28:16
Oui personnellement n'étant pas trop adepte du crossfire ni du sli, elle me fait bien envie.
Cette QuadGT couplée à une X2800 XT(X) devrait faire des ravages sur mon futur Samsung 226BW  :love:
(Ce n'est pas encore pour tout de suite mais c'est bon de rêver  :lol:)
Message édité par kozzi le 13-02-2007 à 12:39:13
Marsh Posté le 13-02-2007 à 15:06:53
Personne n'est interessé par cette carte mère qui fait mieux que la commando pour moins cher?
Marsh Posté le 13-02-2007 à 15:08:55
Son prix  :??:
Gigabyte à une mauvaise image pour les C2D en ce moment d'aprés ce que j'ai compris  :sweat:
Marsh Posté le 13-02-2007 à 15:13:42
Oui mais ici c'est Abit ;)
C'est vrai qu'ils n'ont pas super bonne réputation mais il semblerait qu'ils soient de retour petit à petit.
et le prix : 184.90 € chez computersmsa
195,00€ chez openjl
et ... 249 € chez LDLC  :lol:
Message édité par kozzi le 13-02-2007 à 15:15:09
Marsh Posté le 13-02-2007 à 15:16:36
195,00€ chez openjl
 [:darcktom]  [:darcktom]  [:darcktom]
La buse  :whistle:
Désolé, j'ai écris sans réfléchir et surtout sans relire  :lol:
Marsh Posté le 13-02-2007 à 16:21:26
J'ai rajouté quelques infos dans le premier post.
Je ne sais pas si je peux en faire un topic unique...  :??:
Personne ne se manifeste, mais je vais la tenter.
Je l'ai commandée chez compu.
Je reviendrai quand je l'aurai reçue pour les premiers tests  :whistle:
Marsh Posté le 13-02-2007 à 16:29:01
Choppe toi un QuadCore et dis nous le maxFSB qu'elle peut donner ta p'tite Abit ( :o )
Marsh Posté le 13-02-2007 à 16:29:45
Vivement tes tests perso  :jap:
Je crois que ca peut devenir un topic unique, ca serait plutôt bien  :jap:
Marsh Posté le 13-02-2007 à 16:30:25
[:__canard__]
Marsh Posté le 13-02-2007 à 16:46:29
mouarf  :lol:
Si j'en avais un, ça serait avec plaisir ;)
Marsh Posté le 14-02-2007 à 10:33:49
On voit moult Belges avec des CPUs de la mort.
La Belgique n'est pas un tres grand pays. (par la superficie hein)
Conclusion -> T'as pas d'excuses, trouve un Q6600 :o
Marsh Posté le 18-02-2007 à 19:42:17
alors?  :o
Marsh Posté le 19-02-2007 à 22:54:15
Je suis en train de la tester, pas été beaucoup la du week-end.
Première impression : bios un peu buggué, pas évident à maitriser au début.
Performance mémoire : ca change de la p5b sans changement de strap. Bien plus performant en bande passante et latence
Ex everest en 463 x 8 ram 463 4-4-4-4 : bande passante : 9565, écriture 8440, copie 8290, latence 49
                   411 x 9 ram 514 4-4-4-4 : bande passante : 9836, écriture 7501, copie 8308, latence 44.5
Mon cpu demande aussi moins de tension pour être stable à 3.7 ghz par rapport à la p5b et chauffe moins, c'est un bon point.
Par contre pas moyen d'être stable à 500 de FSB pour le moment et un petit problème de controlleur réseau qui parfois disparait
Donc de bonnes perfs mémoires mais un bios un peu buggué pour le moment...
Message édité par kozzi le 19-02-2007 à 22:55:08
Marsh Posté le 19-02-2007 à 23:19:55
Et vDrop?  :)
Marsh Posté le 19-02-2007 à 23:30:22
Je n'ai pas de multimètre mais je vais te dire ce que je vois via le monitoring uGuru
1.50 mis dans le bios
1.47-1.48 iddle windows
1.45-1.46 full
Marsh Posté le 19-02-2007 à 23:40:50
Ah oui quand même  :D
Et le bundle?   :)
Marsh Posté le 19-02-2007 à 23:52:45
le bundle quel bundle???
Franchement si on peut appeler ca un bundle: 6 cables SATA, une nappe IDE, une nappe FLOPPY et un connecteur avec 2 ports usb et 2 firewire (6 pins et 4 pins)
Assez maigre :D
Message édité par kozzi le 20-02-2007 à 01:01:14
Marsh Posté le 19-02-2007 à 23:54:08
Petit bundle donc  :o  :D
Marsh Posté le 21-02-2007 à 14:35:37
bonne petite carte mere ca !
<°)))>< ... n'hésitez pas à faire appel à moi !
Marsh Posté le 21-02-2007 à 14:41:56
Je viens de la commander chez compu.
On va voir ce que ça donne avec le Quad!
En tout cas meme si Vdrop il y a, c'est mieux que chez Asus(x)
Marsh Posté le 23-02-2007 à 14:51:09
Un ptit update de recherche de stabilité.
Je n'ai besoin que de 1.35V au NB pour être stable à 463 de FSB et 1.3V de vtt tout en restant en strap 1066 :D
Sur l'asus p5b dlx j'avais besoin de 1.55V NB et 1.4V de vtt pour du strap 1333
Sur l'asus je devais mettre 1.55V Vcore à 463 x 8 = 3700. Sur l'abit je mets 1.505V et c'est bon pour du double prime95 pendant 2h.
Message édité par kozzi le 23-02-2007 à 14:54:45
Marsh Posté le 23-02-2007 à 17:38:02
Oula drapal, prochaine CM en vue. :)
| Créateur de feu PC-Updates.fr | Ardent défenseur des formats 21:9 & 16:10 | Ma chaîne YouTube : gameplay de jeux vidéo exclusivement PC |
Marsh Posté le 24-02-2007 à 13:58:35
Je drap aussi meme si je ne compte pas changer de si tot.
Les bios n'étaient pas très au point il y a quelques mois, ça évolue bien ou pas ?
Marsh Posté le 24-02-2007 à 17:00:40
plein de bugs , , j 'ai montée cette carte mere hier, elle va partir en sav
frezzes du bios , il faut que j 'enleve la pile de tps en tps pour demarrer ..etc.. et  le site abit tres souvent en rade , bref abit tjrs pas mieux
Marsh Posté le 24-02-2007 à 17:20:45
T'as essayé de flasher le bios avec le dernier en date?
Marsh Posté le 24-02-2007 à 17:57:18
Kozzi tu avais ces problèmes avec le premier BIOS ? Bon, de toutes façons moi je mettrai directement le dernier, mais c'est pour savoir.
Autre question : avec le dernier BIOS, tu as toujours des bugs ou des problèmes ? Si oui, lesquels ?
Merci ! :jap:
Marsh Posté le 24-02-2007 à 17:59:04
oui  rien a faire
