[Topic Unique] ASUS Maximus VI Hero
ASUS Maximus VI Hero [Topic Unique] - Carte mère - Hardware
Marsh Posté le 07-07-2013 à 05:24:13
ASUS Maximus VI hero
Lien constructeur : http://www.asus.com/fr/Motherboards/MAXIMUS_VI_HERO/
http://i61.tinypic.com/28cg1g8.jpg
- Version d'origine ( version 0224 )
- Version  0711
1.Revise help string in BIOS.
2.Fix XMP button issue
3.Improve system compatibility.
- Version  0804
Improve system stability.
- Version  0903
1 Enhance compatibility with some USB device.
2.Revise help string in BIOS.
- Version  1002
- Version  1102
- Version  1203
1. Improve system stability.
2. Support New 4th-Generation Intel Core Processors
3. Before using the new Intel 4th Gen Core processors, we suggest that you first update the BIOS using USB BIOS flashback, or download the BIOS updater for new Intel 4th Gen Core Processors and then update the BIOS using it.
- Version  1301
- Version  v1.5
BIOS updater for New 4th Gen Intel Core Processors
Before using the new Intel 4th Gen Core processors, we suggest that you first download the BIOS updater for new Intel 4th Gen Core Processors and then update the BIOS using this tool.
- Version  1402
- Version  1504
Enhance compatibility for new Anniversary Edition and Devil's Canyon CPU.
Note: Must apply the attached BIOS updater tool first before using the new Intel 4th Gen Core processors.
http://www.asus.com/media/global/products/9JB5jBpArfvcpcNi/P_500.jpg
http://i61.tinypic.com/znjwyb.jpg
Carte appartenant a la famille ROG  ( "Republic of Gamers" ) : http://www.republic-of-gamers.fr/
Caractéristiques général :
•Socket LGA1150 pour processeurs Intel® Core™ i7/i5/i3/Pentium®/Celeron® de 4ème génération
•Chipset Intel® Z87 Express
•SupremeFX - Maîtrisez vos adversaires grâce à une qualité audio supérieure
•Sonic Radar - Visualisez la position de vos adversaires
•Extreme Engine Digi+ III - Alimentation intense grâce à des composants de qualité
•GameFirst II + Intel LAN - Toute la vitesse dont vous avez besoin pour pwner
Caractéristiques détaillées :
http://i40.tinypic.com/dwzvxf.jpg
http://i43.tinypic.com/10wi7b6.jpg
http://i39.tinypic.com/vo1ovl.jpg
http://i41.tinypic.com/2epmtqf.jpg
http://i42.tinypic.com/2eev2ox.jpg
- Le bug de la version C1 c'est quoi ?
En amont du lancement d’Haswell, une rumeur circulait quant au fait que les chipsets série 8 souffraient d’un bug susceptible de déconnecter les clés USB en sortie de veille suivant le contrôleur utilisé. Cette rumeur a été confirmée par Intel, bien que le problème ait plutôt tendance à se manifester lorsque le périphérique USB nécessite plus de 400 mV à la reprise.
Le Stepping C1 est affecté, sachant que le C2 qui règle le problème ne devrait être livré qu’à partir de mi-juillet. Les configurations BGA seront en revanche épargnées dès le lancement puisqu’Intel a pu revoir à temps le chipset de ces cartes mères à processeur soudé.
Jusqu’ici aucun problème de pertes de données n’a fait surface, raison pour laquelle le bug est considéré comme une nuisance.
Les périphériques USB qui pourraient provoquer ce bug ne sont pas nombreux. Pour peu qu’on en ait un, il faudrait alors trouver un autre modèle ou bien être prêt à le reconnecter en sortie de veille/relancer sa lecture de fichier pour peu que ce dernier soit sur ladite clé. Vu les différents cas de figure au cours desquels le problème peut se manifester et les actions nécessaires pour le résoudre, il n’y a pas de quoi reporter sa décision d’achat lorsque le besoin est urgent.
Message édité par Turrican08 le 15-06-2014 à 06:00:51
Le tennis et le ping-pong, c'est pareil. Sauf qu'au tennis, les joueurs sont debout sur la table.
Marsh Posté le 07-07-2013 à 05:42:24
Quelques photos de la carte :
http://i40.tinypic.com/rsh2tt.jpg
http://i39.tinypic.com/2q2fg3b.jpg
http://i42.tinypic.com/jkzul1.jpg
http://i44.tinypic.com/2yuni8y.jpg
http://i39.tinypic.com/30ww1lt.jpg
Ici montée dans mon boitier car évidement je possède cette carte :
http://i42.tinypic.com/2ykax51.jpg
Message édité par Turrican08 le 07-07-2013 à 05:56:44
Marsh Posté le 07-07-2013 à 05:42:41
TUTO overclocking
Core i7 4770K Haswell et Maximus VI Hero
http://www.youtube.com/watch?v=Z7zPu9255ZI
Source : http://rog.asus.com/forum/showthre [...] -Hero-Help
Message édité par Turrican08 le 31-01-2014 à 06:08:12
Marsh Posté le 08-07-2013 à 07:51:53
Marsh Posté le 08-07-2013 à 22:52:32
Carte mère en chemin, en provenance d’Allemagne. hâte de la monter.
Mais j'ai une petite question pour ouvrir les festivités.
La coupure du PCB pour la partie carte son parait sur certain visuel rouge, sur d'autre marron.
Serait-elle lumineuse?
Marsh Posté le 08-07-2013 à 22:53:53
Autre question les condensateurs sont-ils bien noir?
Marsh Posté le 08-07-2013 à 23:26:34
Oui elle est lumineuse, et elle donne un petit plus à l’esthétique de la config (montés dans mon phantom 410 gunmetal, un régal !)
Marsh Posté le 09-07-2013 à 05:43:44
Oui je confirme :
http://i39.tinypic.com/2v2fkhw.jpg
Marsh Posté le 09-07-2013 à 06:30:02
Wahou, la classe!
Marsh Posté le 09-07-2013 à 07:49:46
Pleins de bonnes informations sur les cartes Maximus :
http://kingpincooling.com/forum/showthread.php?t=2304
Message édité par Invite_Surprise le 09-07-2013 à 07:53:45
Marsh Posté le 11-07-2013 à 08:50:37
Kit de mise à jour reçu :) .
Je posterai des photos des que j'aurai finis le montage.
Marsh Posté le 11-07-2013 à 17:19:23
Cool ! Vivement les photos .
Marsh Posté le 12-07-2013 à 09:17:44
Voilà mon lot de MAJ  :) :
http://img6.imageshack.us/img6/9196/v63r.jpg
Et le tout monté dans mon boitier:
http://img46.imageshack.us/img46/8365/175s.jpg
Petit zoom:
http://imageshack.com/a/img713/3387/plh7.jpg
Marsh Posté le 12-07-2013 à 09:30:06
superbe :love:
Marsh Posté le 12-07-2013 à 09:35:19
Merci, il me reste à mettre un petit stickers rouge homemade sur la AX850 et ça sera parfait.
Marsh Posté le 12-07-2013 à 10:39:35
Drap, je monte ceci ce Week end:
760 Watt Seasonic Platinum Modular 80+ Platin
Fractal Design Define R4
Samsung 840 pro 256
ASUS Z87 Maximus VI Hero
be quiet! Dark Rock Pro 2
LG Electronics GH24NS95 DVD-RW SATA
G.Skill Sniper DIMM Kit 16GB PC3-17066U CL11-11-11-30
Intel Core i7-4770K
Lamptron FC5 V2 Fan Controller 5,25 Zoll - black
2048MB Gigabyte GeForce GTX 670
[:volta]
Pier noir la mèr - La chanson par HFR Band - Topic TrueCrypt
Marsh Posté le 12-07-2013 à 17:44:50
@ sangohan26 : superbe , bravo , belle machine .
Marsh Posté le 12-07-2013 à 17:46:51
Samsung 840 pro 256
Intel Core i7-4770K
[:volta]
Config se rapprochant de la mienne :
Boitier : corsair graphite 600T
Carte mére : asus maximus VI hero
Cpu : core I7-4770K Haswell 3.5 Ghz
Ventirad : thermaltake frio OCK
Alim : corsair HX  1050W
Ram : corsair vengeance 2x4 GO x 2 DDR3 1600 ( 16Go en tout ) .
Carte grahique : GTX 780 de chez gainward 3Go ( avec logo qui s'allume en vert )
Stockage : SSD Samsung 840 PRO en 256 GO et un 500GO va pas tarder en remplacement de mon vieux DD mécanique.
optique : Lecteur/Graveur BD liteon.
OS : Windows 8 PRO
Clavier : strike 7
Marsh Posté le 13-07-2013 à 07:12:04
Nouveau BIOS ( version 0711 ) :   http://support.asus.com/Download.a [...] O&p=1&s=45
Marsh Posté le 13-07-2013 à 11:55:27
cool, pour le topic! et merci!!!
je pense que c'est une bonne idée. vu son rapport qualité prix, je pense que cette carte en vaut la peine...un best seller en puissance!
merci pour le bios ( avant de regarder, une idée sur les nouveautés)
NZXT H440/Asus rog maximus VI HERO/intel I7 4770k @ 4.2Ghz/16 go gskill pc 17000 ripjaw z/ SLI evga acx cooler gtx 770/Seasonic platinum 860/AIO Corsair h75/Sound Blaster Z/crucial M4 256Mo/SEAGATE 1x2 to 64mo 2x1to 32mo
Marsh Posté le 13-07-2013 à 12:03:04
Une petite contribution! désolé pour la qualité! avec un zalmann 9900 max blue et une refonte des ventilo du boitier en bleu; le mariage rouge et bleu rend bien!! ( mieux que sur les photos en faite lol )
http://img11.hostingpics.net/thumbs/mini_955254753.jpg
Message édité par toutitsou le 13-07-2013 à 17:52:01
Marsh Posté le 13-07-2013 à 13:41:49
Bon j'ai tout assemblé, par contre:
- Au boot ca me dit "CPU Fan error" et je suis obligé d'aller ds le bios et de baisser le RPM du CPU fan
- Deux LEDs rouges sont allumées, meme quand le PC est branché mais éteint :heink:
- Quand ca tourne, les A3 s'affiche sur le Q-Code, dans le manuel ca dit "IDE Enable"
- Ma RAM est reconnue comme 1600 au lieu de 2133
Des idées ?
Message édité par ParadoX le 13-07-2013 à 13:51:34
Marsh Posté le 14-07-2013 à 21:36:07
Petite oubli de ma part! Quand on flash le bios pour une version superieur, peut on charger le profil oc enregistré? Sur mon ancienne msi, ça me supprimait meme les profils!!
Marsh Posté le 15-07-2013 à 09:30:44
j'ai monté cette carte mère la semaine derniere.
Ma config:
Boitier : Fractal R4
Ventirad : Noctua U-12s
Alim : Seasonic 650W X series
Ram : G.Skill 2*8Gb 2400Mhz
 Stockage : SSD Samsung 840 PRO en 512GO pas de HDD
OS : Windows 7
Clavier : G510
Souris:G500
Des idées ?
Pour le CPU fan error, mmême "soucis", solution va dans mle bios pour abaisser le seuil de détection du CPU fan perso je l'ai mis à 300RPM, plus aucun soucis.
Pour ta RAM, elle est reconnu par défaut à 1600 Mhz, il faut overclocker dans le bios (choisir les paramètres manuellements)
Quand la carte tourne, j'ai aussi un Q-code mais moi c'est A0, ça ne gene en rien de toute façon.
Mon ressentis, tres bonne carte mère
Par contre petit soucis, impossible d'installer Ai Suite 3, je double click sur le setup et puis plus rien....
des idées ??
merci à vous
Message édité par bourrin5 le 15-07-2013 à 13:22:55
Marsh Posté le 15-07-2013 à 09:39:53
Par autorun ou l'exploration du cd?
Marsh Posté le 15-07-2013 à 09:55:33
N'ayant pas de lecteur cd, j'ai mis le contenu du cd d'install sur clef USB. J'ai lancé le setup asus et j'ai beau cliker sur AI suite rien ne se passe.
Marsh Posté le 15-07-2013 à 10:20:51
Peut-être que le copier coller a mal fonctionné.
Essayes de le télécharger ici -> http://www.asus.com/fr/Motherboard [...] t_Download
Marsh Posté le 15-07-2013 à 10:24:31
Merci mais déjà fait
Marsh Posté le 15-07-2013 à 10:50:17
Alors je ne vois pas. Problème avec Windows...
Marsh Posté le 15-07-2013 à 10:51:05
Il me semble qu'il y avait eu des soucis similaires avec les installations de AI Suite 2
Message édité par bourrin5 le 15-07-2013 à 11:04:57
Marsh Posté le 15-07-2013 à 10:54:17
Quels sont ceux d'entre vous qui ont installé l'AI suite?
Est-ce que ça a un réel intérêt pas rapport au réglage BIOS?
Marsh Posté le 15-07-2013 à 11:06:32
Autres choses, il me semblait que les ports USB étaient "actifs" (pour charger un portable par exemple) quand le PC était éteint.Pour ma part ca ne fonctionne pas. La même chose pour vous ?
Marsh Posté le 15-07-2013 à 12:44:52
help me please, je n'arrive pas a mettre à jour mon bios via usb; j'ai activé l'initialisation complete des port; mais je ne trouve pas le fichier sur ma clé!!! vous passez par quoi vous pour mettre à jour?
Marsh Posté le 15-07-2013 à 13:22:01
1/télécharge le bios ici: http://support.asus.com/Download.a [...] O&p=1&s=45
2/ renomme le fichier en M6H.CAP
3/Mettre le fichier à la racine d'une clef USB formaté en FAT32
4/ Mettre la clef de le port spécial update (avoir éteind le pc préalablement)
5/Appuyer 2-3secondes sur le bouton flash bios, ce dernier clignote en bleu
6/Attendre que le bouton s'éteigne
7/et voila c'est pret
Marsh Posté le 15-07-2013 à 14:10:27
ok merci, en faite c'est une de mes cle qui doit avoir un probleme!!! elle n'est pas reconnu par l'utilitaire mais fonctionne parfaitement sous windows!
  une autre clé et tout est rentré dans l'ordre...dans la précipitation je n'avais pas enregistré mon profil oc sur une clé du coup, tout le parametrage à refaire! mais pas grave ça me fait la B... comme on dit lol
Marsh Posté le 15-07-2013 à 17:50:32
Les clés doivent être formatées en fat 32 pas en ntfs pour flasher le bios .
Marsh Posté le 15-07-2013 à 17:53:10
J'avais essayé de passer par cette méthode mais sans succès , merci pour le détail car moi je le faisais pc allumé .
C'est lequel le port usb dédier ?
Message édité par Turrican08 le 15-07-2013 à 17:54:00
Marsh Posté le 15-07-2013 à 17:57:52
Il est entouré de blanc, juste en dessous du bouton flash BIOS.
Marsh Posté le 15-07-2013 à 17:59:25
Ma config:
OS : Windows 7
Clavier : G510
Souris:G500
Des idées ?
Pareil ici, ca tourn correctement ici - le coup des LEDs rouge sont le "LED Lightning FX" à la con, desactivable dans le menu "ROG Effects" :jap:
Marsh Posté le 15-07-2013 à 18:16:09
Qq un a une idée pour les USB actif ? et AI suite 3 ?
