[Topic Unique] ASUS P4C800 & P4P800 (BIOS 1006 officiel) !!!
ASUS P4C800 & P4P800 (BIOS 1006 officiel) !!! [Topic Unique] - Carte mère - Hardware
Marsh Posté le 28-04-2003 à 13:11:19
http://membres.lycos.fr/cybear/Forum/topicR+.gif
Bon voilà,suite à l'acquisition de cette carte-mere géniale,je creer le topic dédié à tous les passionnés de cette carte!! ;)
Tres bon article sur la carte-mere (et par un site serieux... ;)):
http://www.x86-secret.com/popups/a [...] .php?id=77
Ftp directe des derniers Bios dispos (bétas et officiels):
ftp://ftp.asuscom.de/pub/ASUSCOM/ [...] 5p/P4C800/
Bios 1006 officiel:
ftp://ftp.asuscom.de/pub/ASUSCOM/ [...] e/1006.zip
http://www.x86-secret.com/pics/cm/p4c800/box.jpg
http://www.x86-secret.com/pics/cm/p4c800/insidebox.jpg
http://www.x86-secret.com/pics/cm/p4c800/mappes.jpg
http://www.motherboardexpress.com/specs/motherboards/asus/17833_Lg_1_P4C800.jpg
P4C800 Deluxe Introduction:
The P4 CPU on 800MHz FSB, Intel 875P chipset and ASUS' motherboard expertise are exactly what you need if extreme performance is what you are looking for. The P4C800 Deluxe has all of the above plus dual-channel ECC DDR 400 memory, Hyper-Threading Technology support and a whole bunch of advanced innovations for an expert like you.
P4C800 Deluxe also integrates artificial intelligent features such as net-diagnosing utility, audio-jack sensing technology, auto-adjusting CPU Fan and more. The P4C800 Deluxe simply out-performs, out-smarts and out-shines all competition.
Intel 875P chipset
Leveraging the Intel 875P chipset to support 3.2 GHz+ P4 CPU on 800MHz FSB, Dual DDR 400 memory, Intel Hyper-Threading Technology, Intel Performance Acceleration Technology, and a full-range of advanced features, P4C800 Deluxe really delivers a full-value, high-performance solution for today's most demanding tasks.
Dual-Channel DDR400
Dual-channel DDR technology doubles the bandwidth of your system memory and hence boost the system performance to out perform any memory existing solutions in the market. System bottlenecks are eliminated with balanced architecture and peak bandwidths up to 6.4GB/s.
Intel PAT
P4C800 Deluxe's built-in Intel PAT (Intel Performance Acceleration Technology) is a trigger for extreme performance. It helps to boost performance by 3~5%.
Multi-RAID for ATA133 & Serial ATA
The P4C800 Deluxe offers the most complete RAID solution. A Promise SATA controller offers RAID 0, 1 and 10 functions with Max. 2 UltraATA 133 ports and 2 SATA HD ports, enabling users to build a RAID array with any 2, 3 or 4 of the ports. With unique multi-RAID function, RAID 0 and RAID 1 array can co-exist.
AI NET (Gigabit LAN)
The AI Series supports Gigabit LAN by integrating the 3COM 3C940 controller, equipped with a unique net-diagnosing utility-- VCT (Virtual Cable Tester). The controller intelligently detects net connection status up to 100 meters from a remote location and reports the distance of bad cable.
AI AUDIO (6-channel digital audio)
AI series motherboards employed the world's first intelligent audio CODEC. The 6-channel AD1985 audio CODEC automatically detects and identifies what types of peripherals are plugged into the audio I/O jacks and notifies users of inappropriate connection, meaning there will be no more confusion of Line-in, Line-out and Mic jacks.
AI BIOS
CrashFree BIOS 2
Whenever BIOS gets corrupted, ASUS CrashFree BIOS 2 allows users to reboot the computer and perform an smart auto-recovery procedure through the motherboard support CD.
Q-Fan
This unique technology intelligently and automatically adjusts CPU fan speeds according to system load and temperature, enabling users to work in a distraction-free environment with minimal noise.
ASUS POST Reporter
A voice warning design during POST notifies users of any system errors, which means no more complicated LED messages!
AI Overclocking
A unique option in BIOS that enables quick overclocking up to 30% (depends on CPU and RAM). It automatically detects and optimizes every relevant parameter to provide both performance and stability.
The BIOS in AI Series also keeps all the special design for overclocking:
*Flexible CPU Core Voltage Adjustments in 0.025V increments over defaults
*SFS (Stepless Frequency Selection) up to 400MHz at 1MHz increanerts
*Adjustable FSB/DDR ratio. Fixed AGP/PCI frequencies
*ASUS C.P.R.(CPU Parameter Recall)
AGP8X/Pro
AGP8X (AGP 3.0) is the next generation VGA interface specification that enables enhanced graphics performance with high bandwidth up to 2.12GB/s.
4 Serial ATA ports
Serial ATA is the next generation ATA specification that provides scalable performance for today and tomorrow. With up to 150MB/s data transfer rate, Serial ATA is faster than current Parallel ATA, while providing 100% software compatibility.
IEEE 1394 interface
IEEE 1394 interface provides high speed digital interface for audio / video appliances such as digital television, digital video camcorders, storage peripherals & other PC portable devices.
8 USB 2.0 ports supports
USB 2.0 is the latest connectivity standard for next generation components and peripherals.
Backwards compatible with current USB 1.1 peripherals, USB 2.0 delivers transfer speeds up to 40 times faster at 480Mb/s, for easy connectivity and ultra-fast data transfers.
-Tous les drivers et utilitaires Asus:
http://www.asus.com.tw/support/dow [...] Name=Tools
-Ftp directe pour telecharger les derniers Bios:
-Intel Chipset Software Installation Utility:
http://downloadfinder.intel.com/sc [...] ductID=816
ATTENTION!!! Les INTEL APPLICATION ACCELERATOR ne s'installent pas sur cette carte-mere,du moins dans l'immediat!!
Message édité par cybermatos le 21-05-2003 à 00:45:11
Marsh Posté le 28-04-2003 à 13:27:12
voilà le topic que j'attendais. Bravo!
Avec ttes les cartes similaires à la P4C800 je m'y retrouvais plus.
"Pour aimer la gloire, il faut faire grand cas des hommes, il faut croire en eux."
Marsh Posté le 28-04-2003 à 13:27:22
Drapeau !
Est-ce que t'as des infos sur le problème des disques de 8 mo de cache qui ne passent pas dessus ?? C'est résolu ?
Marsh Posté le 28-04-2003 à 13:31:42
drapal,
c ma future carte, je pense qu elle sera mienne la semaine prochaine...
enfin, si les P4C sont dispo a Mont gallet..
sinon, logiquement, on ne peut plus foiré de Flash la dessus ?
Je ne connaîtrai pas la peur, car la peur tue l'esprit. La peur est la petite mort qui conduit à l'oblitération totale.
Marsh Posté le 28-04-2003 à 14:26:52
Autre question. y a du WOL sur cette mobo ?
Marsh Posté le 28-04-2003 à 14:34:36
Il suffisait juste que quelqu'un bouge son petit doigt... :D C'est clair que c'était pas du tout pratique de poser une question dans l'autre topic généraliste I865/I875...
Sinon c'est quoi cette option dans le bios "ACPI 2.0" qui est réglé par defaut sur [NO]??A quoi sert-elle???Faut-il l'activer??
Marsh Posté le 28-04-2003 à 14:37:49
Elle est déjà dispo depuis plus d'1 semaine à Montgallet.Sinon quel aurait été l'interet immediat du topic... ;)
Message édité par cybermatos le 28-04-2003 à 14:38:33
Marsh Posté le 28-04-2003 à 14:49:33
je parle du proc  :kaola: je veux le couple en FSB 800 :whistle:
Marsh Posté le 28-04-2003 à 14:53:36
ah oki!  :jap:
Marsh Posté le 28-04-2003 à 15:45:44
Scuse j'avais pas vu ta question plus tôt.Comme tu vois dans ma config j'ai un Maxtor avec 8Mo de cache dessus,et il passe nikel!! :sol:
Elle me rappelle ma P4PE cette carte-mere,elle est rock-stable!!Meme l'AGP 8X fonctionne nickel maintenant, contrairement aux P4G8X qui malgres plusieurs MAJ de bios et rev. s'entendent tres mal avec certaines cartes graphiques!!
Message édité par cybermatos le 28-04-2003 à 15:50:48
Marsh Posté le 28-04-2003 à 15:58:46
Nan fini.Si tu foires ton flash,avec CrashFree BIOS 2 t'as juste à inserer ton CD ASUS dans le lecteur,et mettre ta machine sur ON et il te restaure tout automatiquement!!  :love:
Tu veux dire quoi par WOL sinon?? :heink:
Message édité par cybermatos le 28-04-2003 à 16:01:28
Marsh Posté le 28-04-2003 à 16:05:07
j'ai reçu la mienne ce matin
j'ai hate de la monter
j'espere qu'en overclockant un P4A on conserve le ration FSB/RAM de 3/4
Marsh Posté le 28-04-2003 à 16:08:56
 :jap: bienvenue au club!! :D
Vas-y fait peter les benchs!! ;) moi ça ne saurait tarder,car je suis au taf pour le moment!! :)
Message édité par cybermatos le 28-04-2003 à 16:10:16
Marsh Posté le 28-04-2003 à 16:10:56
WakeOnLan
Marsh Posté le 28-04-2003 à 16:12:19
:hello: bonjours,
je voudrais acheter cette mobo avec un P4C et de la bonne memoire.
donc 1er question : :D
les P4C seront dispo sur montgallet quand ???
2eme :
ou trouver de la bonne ram en PC3200 ou + le moins cher possible
APN: Nikon D100 / Photosig
Marsh Posté le 28-04-2003 à 16:24:28
Cybermatos> T'as branché ton disque sur quel port ?? Parce que je crois que c'est le chip Promise qui posait problème ! Ils parlaient de mettre une nouvelle révision du chip, je crois... mais je ne suis plus certain !
Fredy>Crucial fait de la bonne ram pas trop chère ... Sinon, la PC3200 pas chère et de bonne qualité devrait débarquer rapidement maintenant : la production en masse de ce type de mémoire a été lancée il y a déjà un petit temps et ça devrait faire baisser les prix :)
Marsh Posté le 28-04-2003 à 16:29:46
DimiBD a écrit :
WakeOnLan
Oui il est bien present!! ;)
Marsh Posté le 28-04-2003 à 16:33:07
Ben justement,c'est bien sur ce port Promise que je l'ai branché,vu qu'il gere l'ATA133 de mon Maxtor,et aucun probleme!! (ma P4C800 est une rev. 1.03)
Marsh Posté le 28-04-2003 à 16:34:43
 :love:
Marsh Posté le 28-04-2003 à 16:52:06
Personne connait cette option??
Marsh Posté le 28-04-2003 à 16:54:32
Parfait alors ^^
Merci pour la réponse :) Je pense que je prendrai cette carte mère également !
Sinon, juste une petite question qui n'a rien à voir : le Wake On Lan permet d'allumer le PC de par le réseau, c'est ça ? Mais une fois allumé, y a-t-il une manière de l'éteindre à distance aussi ?? ^^
C'est parce que si mon futur PC sert de passerelle Internet pour le PC de mon frère, il voudra certainement allumer mon ordi à distance ... mais moi j'aimerais qu'il l'éteigne aussi ... ^^
Marsh Posté le 28-04-2003 à 16:55:53
Parfait alors ^^
pour le couper, c pas le plus dur, avec un soft du genre VNC...
Marsh Posté le 28-04-2003 à 17:14:24
Yes.
Par contre pour l'eteindre je peux pas te dire,jamais essayé par la carte-mere.J'ai plutôt l'habitude d'utiliser PCANYWHERE pour ce genre d'operations!! :D
Message édité par cybermatos le 28-04-2003 à 17:15:26
Marsh Posté le 28-04-2003 à 17:27:21
Yes.
 [:plusun]
par contre, je testerais des que j ai ce petit bijou ;)
Marsh Posté le 28-04-2003 à 17:31:23
Marsh Posté le 28-04-2003 à 17:46:01
http://nonodenice.free.fr/snap004.jpg
C'est parce que la vitesse de la lumiere est supérieur a celle du son, que tant de gens paraissent brillants avant d'avoir l'air con!
Marsh Posté le 28-04-2003 à 17:53:08
Quelqu'un saurait please comment on regle la memoire en 400Mhz??Car contrairement à la notice,j'ai seulement le choix entre 266/333/AUTO,et il me manque l'option 400Mhz...Pourtant j'ai 2*512Mo de Corsair XMS PC3500...Et meme réglé en AUTO ,au demarrage le bios m'affiche comme meme 333Mhz... :cry:
Message édité par cybermatos le 28-04-2003 à 17:54:02
Marsh Posté le 28-04-2003 à 19:12:56
il me semble que l'option 400 pour la memoire ne s'affiche que lorsque ton fsb est à 200
A verifier mais je suis quasi sur
A+
Marsh Posté le 28-04-2003 à 19:22:52
Ca ne se met en 400mhz que lorsque tu as un P4 FSB800  :sarcastic:
Mes configs en détails, Vidéo, Jeux, HCPC
Marsh Posté le 28-04-2003 à 19:29:31
Si quelque pouvais publié une photo du post de cette mobo (juste avant que ca lance winxp, soit avec le DD detecté etc.)...
Juste pour voir la gueule de ce BIOS AMI (qui me desolé car j'aimais ASUS pour leur BIOS Pheonix/Award 6.00
| AMD Ryzen 7 7700X 8C/16T @ 4.5-5.4GHz - 64GB DDR5-6000 30-40-40 1T - AMD Radeon RX 7900 XTX 24GB @ 2680MHz/20Gbps |
Marsh Posté le 28-04-2003 à 20:30:13
Attention quand même en flashant:
L'utilitaire de flashage dos du CD d'origine ne marche pas avec le bios 1004 ( 2 eprom "out" à reprogrammer ) et EZflash ( utilitaire intégré activé par Alt+F2 ) comme le crashfree bios semblent bugger avec certaines cartes Ati.
Citations de Asusboard.com:
 Do NOT, I repeat, do NOT use Aflash.exe, that is an Award flashing utility, the P4C800 has AMI BIOS. And Live update doesn't have the bios listed if you choose from internet, you will have to browse to it. I don't know if Live will work, AFUDOS (the actual flash utility for the AMI) does not flash the 1004 correctly.
I have AIW Radeon8500 128MB and I couldn't flash my bios with EZ-Flash neither
I pulled out the AIW 9700Pro, which is only 6 weeks old and put in a PCI TNT card and EZFlash worked like a charm.
I'lll add another ATi card that doesn't work with EZ-Flash to the list. Have an AIW-7500, same problem as you other ATI owners. AFUDOS flash of 1004 results in a no boot
I have a 9700Pro and the windows-based ASUSupdate works for me.
Et il y en a plein d'autres !
Est ce que quelqu'un a déjà flashé, avec quelle config et comment?
Merci de votre expérience qui permettrait peut être d'aider à résoudre ce problème sur une carte par ailleurs super.
Marsh Posté le 28-04-2003 à 20:36:52
:pt1cable: c'est super! non seulement les bios Asus ne sont pas finalisés mais en plus on peut meme pas les flasher  :non:
je va pas  me prendre une Asus moi! une Abit ou giga-bite plutot  :lol:  :sweat:  :pfff:
Message édité par p@trick le 28-04-2003 à 20:37:45
http://boinc.roadrunners.fr/
Marsh Posté le 28-04-2003 à 20:44:29
La Asus reste la plus complète. Le problème semble plutôt lié à Ati ... une fois de plus !
 :sarcastic:
Marsh Posté le 28-04-2003 à 20:44:30
Moi je l'ai flasher deux fois Bios 1003 et 1004 avec AsusUpdate Vers5.05.01 et je n'ai eu aucun probleme. :D  :D
Marsh Posté le 28-04-2003 à 20:45:47
cte carte elle me dit bien, j'ai déjà 1x512 de corsair en 3200, va falloir en acheter une deuxième :o
sinon, moi je flashe depuis win :o
sinon, pour le WOL, faisez gaffe, me semble (comme toutes les CM asus récentes) qu'elle fait le WOL by PME, c'est à dire sans le cable 3-pins habituels, tout passe par le PCI.
sur ma 533-v, ca marche très très bien avec ma 3c905c qui le supporte, mais ma realtek à trois francs six sous ne supporte pas le wol by pme apparemment, vu que ca marche pas (et la CM n'a pas le 3-pins pour brancher le cable).
Marsh Posté le 28-04-2003 à 20:47:36
Mais tu as une Ge Force ?
Marsh Posté le 28-04-2003 à 20:47:56
Euh... on s'en fou tout est prevu d'office vu que c'est une puce LOM !
Marsh Posté le 28-04-2003 à 20:48:43
Les nouveaux Bios améliorent quoi ? :bounce:
Marsh Posté le 28-04-2003 à 20:49:26
drapal c ma carte pour un an alors je suis ce topic  :hello:
Marsh Posté le 28-04-2003 à 20:49:41
je viend de finir l'install d'XP
je fini de mettre les drv et les soft de base et je passe au test d'o/C
apparement le ration 4/3 est conservé :D
seul reproches pour le moment :
- pas d'equerres usb fournies ( pourtant deux emplacement sur la CM )
- Pas d'adaptateur Serial/ parlelle ATA fourni ( ni d'adapt d'alim )
- vcore limité a 1.6V (mais un reliage de pins en regle devrait arranger ça :D )
