[Topic Unique] MSI K8N Neo2 Platinum - Athlon 64 socket 939 - nForce 3
MSI K8N Neo2 Platinum - Athlon 64 socket 939 - nForce 3 [Topic Unique] - Carte mère - Hardware
Marsh Posté le 03-01-2005 à 19:59:11
Bon suite à l'arret de la mise à jour du topic unique précédent disponible ici http://forum.hardware.fr/forum2.ph [...] =0&subcat= et vu le nombre de questions récurrentes, je recréé un topic unique avec principalement une FAQ (voir 2ième post du topic :))
pour commencer une petite reprise du poste original :p :
 Et voici la MSI K8N Neo2 Platinum
http://www.msi.com.tw/images/product_img/other/mainboard/pic/nforce3_250gb.gif =>  :love:
http://images.anandtech.com/reviews/chipsets/roundups/2004/socket939roundup/k8n.jpg
Pour ceux créeant des RAID 0 sous NForce 3 :
Unfortunately, Intel, NVIDIA, SiS, and VIA don't agree on a common default stripe size. Intel suggests a 128KB strip size; NVIDIA prefers 32KB; and SiS and VIA default to 64KB. I trust that each company has a firm enough grasp of the unique performance characteristics of its RAID controller to recommend the best stripe size for its chipsets, so we'll be using default stripe sizes throughout.
Coté technique :
CPU
  • Supports Socket 939 for AMD® Athlon™ 64FX/64 processor
• Supports 3500+, 3800+ Athlon 64FX 53, or higher CPU   :ange:
Chipset
  • nVIDIA® nForce3 Ultra Chipset   :pt1cable:
- HyperTransport link to the AMD Athlon 64/Athlon 64FX CPU
- HyperTransport supporting speed up to 1GHz (2000MT/s)
- AGP3.0 8X interface at 533MT/s (million transfers per second)
- Two independent SATA controllers, for four drives
- IEEE 802.3 NVIDIA MAC for 1000BASE-T
- Dual Fast ATA-133 IDE controllers
Main Memory
  • Supports dual channel DDR 266/333/400, using four 184-pin DDR DIMMs.
• Supports the memory size up to 4GB
• Supports 2.5v DDR SDRAM DIMM
Due to the High Performance Memory design, motherboards or system configurations may or may not operate smoothly at the JEDEC (Joint Electron Device Engineering Council) standard settings (BIOS Default on the motherboard) such as DDR voltage, memory speeds and memory timing. Please confirm and adjust your memory setting in the BIOS accordingly for better system stability.
Example: Kingston HyperX DDR500 PC4000 operates at 2.65V, 3-4-4-8, CL=3.
For more information about specification of high performance memory modules, please check with your Memory Manufactures for more details.
Slots
  • One AGP (Accelerated Graphics Port) 1.5V 4X/8X slot
• Five 32-bit v2.3 Master PCI bus slots (support 3.3v/5v PCI bus interface).
On-Board IDE/SATA
  • An IDE controller on the nVIDIA nForce3 Ultra chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA133/100/66 operation modes.
- Can connect up to 4 IDE devices
• Supports 4 SATA ports. Transfer rate is up to 150MB/s
• NV RAID (Software)
• Supoprt up to 4 SATA & 4 ATA133 Hard drives
- RAID 0 or 1, 0+1, JBOD is supported
- RAID function work w/ATA133 + SATA H/D
BIOS
  • The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatically.
• The mainboard provides a Desktop Management Interface (DMI) function which records your mainboard specifications.
Audio
  • 7.1 channel audio codec RealTek ALC850.
- Compliance with AC97 v2.3 Spec.
- Meet PC2001 audio performance requirement.
LAN
  • Supports dual LAN jacks
- 1 LAN supports 10/100/1000 Fast Ethernet by Marvell 88E1111 PHY
- 1 LAN supports 10/100/1000 Fast Ethernet by Realtek 8110S (1000Mbps)
IEEE1394
  • VIA 6306 chipset
- Supports up to 3 x 1394 ports
- Transfer rate is up to 400Mbps
On-Board Peripherals
  - 1 floppy port supports 1 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes
- 1 serial port
- 1 parallel port supports SPP/EPP/ECP mode
- 1 audio jack (5-in-1), coaxial/fibre SPDIF out
- 8 USB 2.0 ports (Rear x 4 / Front x 4)
- 2 RJ45 LAN jack
- 3 IEEE 1394 connectors (Rear x 1/ Front x 2)
Dimension
  30.5cm(L) x 24.5cm(W) ATX Form Factor
Mounting
  6 mounting holes
Tableaux Récapitulatifs :
http://zic3.aurel.free.fr/Forum/tab.jpg http://www.x86-secret.com/pics/cpu/s939/nf3sch.png
Les Testes :
x86-secret (comparatif Asus A8V (K8T800Pro) conter MSI K8N Neo2 Platinium (nForce3 250 Gb) )
Les Awards
http://images.anandtech.com/gold_award.jpg
Elle est sortie gagnante de la "Battle at the Top" faite par AnandTech et opposant 6 cartes-meres socket 939  :sol:
Le lien
Liens utiles
- le lien pour les drivers son, nforce, corecenter, bios officiels, drivers réseau, utilitaires...etc :
http://www.msi.com.tw/program/support/downlo [...] il.php?UID=607&kind=1
- et le lien avec TOUS les drivers officiels et les moddés etc :
http://www.lejabeach.com/MSIK8N/k8nneo2.html
merci à titi14518
- Lien vers le topic unic Neo du forum extremsys en Uk pas mal de tips pour les ocs fou ;)
http://xtremesystems.org/forums/sh [...] ht=k8n+neo
Message édité par le_pere_noel2 le 03-01-2005 à 22:28:21
Nothing to Say
Marsh Posté le 03-01-2005 à 19:59:27
FAQ :
Comment installé le RAID:
voila un ptit guide d'installation du RAID SATA sous NForce3 MSI :
http://forums.pcper.com/showthread.php?t=340514
Merci lovingbenji
Comment avoir le Cool'n quiet:
- Activé le cool'n quiet dans le bios
- Installer le pilote Amd
- Mettre dans la gestion de l'énergie au minimale pour cela : propriétés d'affichage -> Ecran de veille -> Gestion de l'alimentation -> Gestion d'alimentation minimale
Attention le C'nQ ne fonctionne que si vous garder le coeff de départ de votre CPU
Comment monitorer ma CM:
- je ne saurais trop vous conseillez de ne pas installer core center, chez beaucoup de monde il fait planter le pc  [:mlc2]
- l'un des meilleurs soft à l'heure actuel est speedfan
Mes voltages sont tout pourris:
-évitez de vous fiez aux données du bios ou des softs de monitoring ca dit n'importe quoi à ce niveau là :/ essayez plutot le voltmetre..
Options cachées du bios:
merci MAxens pour le résumé :jap:
Pour l'activé : Dans le bios faire SHIFT+F2 et ensuite ALT+F3
les options disponibles en plus
  • integrated peripheral > Onboard device
  - Mac Lan Media
   option possible : RGMII (defaut)
                     MII
                     Pin strap
Utilité ???
  • Cell menu
  - NV/Ati speed up
Enable par defaut. Mettre sur disable de préférence.
Utilité : permets un o/c dynamique de la carte graphique.
   - DRAM drive strenght
Normal (defaut) ou weak.
Utilité ??
   - PCI Clock autodetect
enable (defaut) ou disable.
utilité : permet de desactiver le pci lock. laissé sur enable
Mon ventilo de chipset fait trop de bruit:
Dans ce cas là plusieurs solutions :
- installer speedfan et réduire la vitesse du ventilo
- brancher le ventilo chipset sur un réhobus
- ou encore mettez un radiateur passif du type Zalman. Attention avec le rad zalman les CG trop longue ne passeront pas
Comment utiliser le dual:
- il faut mettre 2 ou 4 barrettes afin de pouvoir profiter du dual. Dans le cas où vous utilisez 2 barrettes uniquements il faut placer les barrettes dans un port violet et un port vert.
Dans le cas où vous utilisez 4 barrettes double facescelles-ci ne fonctionneront qu'en 333MHZ pas 400
http://www.x86-secret.com/pics/cpu/s939/banks.png
J'ai un DD sata et je ne peux pas OC a plus de 22x:
- Attention seuls les ports SATA3 et SATA 4 sont pci lock.
Je ne peux pas changer le HT dans le bios:
- Depuis le bios 1.3 il ne faut pas appuyer sur "entré" pour changer l'HT sinon le bios freeze. Pour le changer il faut uniquement utiliser les boutons Page down et Page up sur la ligne du HT
HT a moins de 1000 ca change quoi en perf:
- le ht n'a quasi aucune influence sur les perfs (si ce n'est meme aucune 200*4 ou 200*5 vous ne verez aucune diff)
Quel bios choisir:
- Aucun bios ne se détache du lot. Seuls les bios inférieur à 1.3 sont à déconseiller pour les winchester (proco en 0.09)
Ca crache tout le temps que faire :
Certains problèmes de freeze ou de reboot aléatoires ont été résolus de la sorte :
- changement de la RAM*
- màj du bios
- comme souligné par le_pere_noel2, une "vraie" alim est necessaire, avec au moins 24A sur le 12V (au moins 26A avec une carte gfx avec Molex)**
- changement de slot pour les barettes (slots 1 & 2 les plus stables, le plus souvent)
- baisse des timings mémoires
- baisse du HT à 800 Mhz (4X)
- remplacement des claviers/souris PS2 par des équivalent USB !
- désactiver Nv/ATI speedup
- désactiver le spread spectrum
- fixer l'AGP à 67Mhz
* Tester votre RAM avec MemTest. Adata ou Samsung originale semble un bon choix. Twinmos & Memory Solution semblent de mauvais choix.
Liste de compatibilité MSI K8N Neo2 avec RAM-PS-HDD-VGA :
http://www.msi.com.tw/program/prod [...] MD=MS-7025
** Plus d'info sur les alims ici : http://www.extremeoverclocking.com [...] ide_1.html
En cas de gros crash ou pas de Post, faire un "vrai" clear cmos :
1) deconnecter le cordon d'alim
2) appuyer sur le bouton de Power ON du PC pour vider les condo
3) déplacer le jumper CMOS en position 2-3
4) attendre au moins 1 minute
4) remettre le jumper CMOS en position originale 1-2
6) rebrancher le cable d'alim
7) redémarrer le PC
8) entrer dans le bios et selectionner load optimized Bios defaults puis save & exit
9) laisser rebooter le PC après la sauvegarde du bios
10) retourner dans le bios si necessaire pour modifier vos parametres
Comment Flasher :
- Depuis Windows :
  • il faut d'abord installer le live update qui installe les utilitaires de flashage (d'ailleurs live update peut lui même se live updater)
  • lancer : c:\Program Files\MSI\Live update 3\flashuty\award\winflash.exe
  ->options : update bios (là il demande le fichier bios à charger)
  et update all, voila
- Depuis le bios
  • booter sur une disquette et mettre les parametres suivant :
  AWFL833D.exe W7030NMS.xxx /py/sn/wb/cc/cd/cp/f/r
  /f = pour forcer le bios à se reprogrammer
  et
  /LD = detruit le cheksum du cmos (reprogramme tout)
C'est quoi ATI/NV speed:
- ca Oc automatiquement la CG, je vous conseille de le désactiver dans tous les cas
Est ce que mon Alim 350w no name va suffir:
- je ne saurais trop que vous conseillez d'investir dans une bonne alim. Certains problèmes de reboot aléatoires ont été résolus grâce à un changement d'alim.
Pour les pocesseurs d'ANTEC NEOPOWER le bios 1.4 améliore à priori certains problèmes de boot à froid. Personnellement je n'ai jamais rencontré de pb avec la mienne
Comment utiliser le Firwall de nVidia
  Ben en fait c'est très simple ! Nvidia fournir le driver du firewall
(NVIDIA ForceWare network Access Manager)dans le pack des driver du nForce3 (nForce unified driver) disponible sur le site de NVIDIA (http://www.nvidia.com/object/nforce_udp_winxp_4.27) et sur le site de MSI (http://www.msi.com.tw/program/support/download/dld/spt_dld_detail.php?UID=572&kind=1).
Personnellement, j'ai installé les drivers (version 4.27) fournit par nvidia, mais ça doit être les memes qui sont fournit sur le site de msi.
Cocher toutes les fonctionnalités et répondre oui à la question "voulez vous installer la "network suite"    C'est le logiciel qui permet de configurer le firewall intégré.
C'est là qu'il y a un bug, car le forceWare utilise le groupe Users pour fonctionner. Le problème est que sur les version françaises de Windows XP, le groupe "Users" ne s'appele pas "Usres", mais "Utilisateurs", donc il faut créer un nouveau groupe "Users" avec les mêmes membres que le groupe "Utilisateurs" avant d'installer le forceWare....
cela fonctionne aussi si l'on créer un utilisateur "Users". C'est utile, car Windows XP Home ne permet pas la création de groupe (à ma connaissance).
Donc pour créer un nouveau groupe sous Windows XP Pro, clique-droit sur le poste de travail, puis gérer. Dans la fenêtre "Gestion de l'ordinateur" -> Utilisateurs et groupes locaux->Groupes : clique-droit et "nouveau groupe" pour créer le groupe Users. Ensuite ajoutez les mêmes groupes/utilisateurs qui sont présent dans le groupe "Utilisateurs", afin que le nouveau groupe se comporte comme l'ancien (c'est certainement pas obligatoire).
Et pour Windows XP home, il faut créer un nouveau compte faute de pouvoir créer un groupe (arrêtez moi si je dit des conneries, mais je masterise pas trop WinXP*), il faut créer un nouveau compte "Users" : Démarrer->Paramètres->Panneau de configuration->Comptes d'utilisateurs. Là choisir "Créer un nouveau compte" et dans nom mettez "Users".
Voilà ! Une fois installé, redémarrer puis pour accéder à l'interface de configuration du firewall, utiliser le lien créer sur le bureau ou bien : Clique-droit sur Favoris réseau -> propriété. Là, clique-droit sur votre connexion Internet (chez moi ça s'appelle Connexion au réseau local)->Propriété pour ouvrir la configuration de la connexion résau. Ensuite, en-dessous de "NVIDIA nForce Netorking Controller", cliquer sur "configurer..." pour ouvir les propriétés du pilote nForce. Dans l'onglet Configuration y'a un bouton firewall qui lance l'interface de configuraition.
  http://membres.lycos.fr/burnoutlan [...] orking.jpg
  Et Voilà, c'est tout   après reste plus qu'a créer un profile perso à partir d'un profile existant et d'ajouter vos règles.
  http://membres.lycos.fr/burnoutlan [...] rewall.jpg
  http://membres.lycos.fr/burnoutlan [...] _perso.jpg
Comment faire le mod vddr:
suffit de suivre la tof :)
http://www.lejabeach.com/MSIK8N/VdimmMod/k8nneo2-4.jpg
Message édité par le_pere_noel2 le 09-03-2005 à 18:49:17
Nothing to Say
Marsh Posté le 03-01-2005 à 19:59:34
Ram compatible testé par des utilisateurs de la CM
- A-DATA quelque soit le type (4000-4500-4800)
- BH5 avec bios 1.36 ou plus. Le mieux pour ces barrettes est un petit vmod ou utiliser l'ocz booster
Ram posant des problèmes sur cette CM par des utilisateurs
- Corsair XL (pas chez tout le monde et il semblerait qu'une augmentation du voltage et une légère baisse des timmings améliorent les choses)
Radiateurs compatibles et testés par des utilisateurs de la CM
- Zalman 7000B-AlCu ou cu
http://nononice.free.fr/Photo%20008.jpg
- XP90 (mecri MAXENS  :jap: )
http://maxens3.free.fr/open/xp90/2.jpg
J'attends votre contribution pour cette partie
Message édité par le_pere_noel2 le 03-01-2005 à 20:58:08
Nothing to Say
Marsh Posté le 03-01-2005 à 20:14:39
ok je vais détailler un peu plus :)
Message édité par le_pere_noel2 le 03-01-2005 à 20:20:32
Nothing to Say
Marsh Posté le 03-01-2005 à 20:19:56
merci ;)
Marsh Posté le 03-01-2005 à 20:37:55
Excellente initiative  :D  ;)
" Il n'y a pas pire sot que celui qui croit tout savoir "
Marsh Posté le 03-01-2005 à 20:52:32
:drapal:
Marsh Posté le 03-01-2005 à 20:55:56
Bien joué :)
Sinon: maxens, tu cherchais des barettes qui tiennent le 200Mhz de FSB en 2-2-2-X ?
Mes Corsair le tiennent TRES bien le 2-2-2-5 ! et ce jusqu'a 212Mhz environ.
Actuellement je reste gentil à 235 en 2-3-3-6.
Life is like a box of chocolate you never know what you gonna get.
Marsh Posté le 03-01-2005 à 21:12:23
drapal
Marsh Posté le 03-01-2005 à 21:58:04
heu une petite section oc en 4 eme position :)
avec les oc et tout et tout avec un petit tableaux qui va bien
[:athome]
ok je sort
Marsh Posté le 03-01-2005 à 22:09:44
[:athome]
ok je sort
pourquoi pas faudrait juste que Gamil delete son poste et j'en ferais un petit :)
Nothing to Say
Marsh Posté le 03-01-2005 à 22:10:27
go gamil out :)
Marsh Posté le 03-01-2005 à 22:11:41
drapal, nice job man ! ;)
Chic not Geek
Marsh Posté le 03-01-2005 à 22:12:16
au pire je peux le mettre à la fin du premier poste c'est aussi simple :)
par contre si quelqu un a de quoi faire un truc en php ou je sais pas quoi histoire de faire un truc simple et leger.
mais pas moi car je n'y connais rien la dedans :p
Message édité par le_pere_noel2 le 03-01-2005 à 22:12:34
Nothing to Say
Marsh Posté le 03-01-2005 à 22:12:41
n'hésitez pas à me dire si vous voyez des choses qui manquent
Message édité par le_pere_noel2 le 03-01-2005 à 22:12:57
Nothing to Say
Marsh Posté le 03-01-2005 à 22:22:06
pour le 2eme post :
le lien sur la page officielle de la K8N2 sur le site de MSI : les drivers son, nforce, corecenter, bios officiels, drivers réseau, utilitaires...etc :
http://www.msi.com.tw/program/supp [...] 607&kind=1
Marsh Posté le 03-01-2005 à 22:28:38
titi14518 a écrit :
pour le 2eme post :
ajouté  [:esheep]
Nothing to Say
Marsh Posté le 03-01-2005 à 22:48:16
Dans le cas où vous utilisez 4 barrettes celles-ci ne fonctionneront qu'en 333MHZ pas 400
ceci est partiellement faux .
elles fonctionneront uniquement en DDR333 si c des DD soit double face .
si c 4 x SD (simple face) c en DDR400 .
cf la notice .
Marsh Posté le 03-01-2005 à 22:49:23
cf la notice .
au temps pour moi je corrige :)
Nothing to Say
Marsh Posté le 03-01-2005 à 22:49:49
Pims a écrit :
Bien joué :)
ouaip, mais le pb c'est que rien ne me dit que tes XL ne font pas bugger sur ma machine :/
Feed-back {|~|} Site d'urbex dans l'est : http://www.urbanx.fr
Marsh Posté le 03-01-2005 à 22:55:42
peut etre un tableau recapitulatif des différents o/c obtenu avec cette carte mère??
Pour les ventilo, le XP-120 ^passe sur cette mobo seul un condo va faire un peu la tronche
Marsh Posté le 03-01-2005 à 22:57:34
ouais j'avais vu mais je considere pas trop que ca passe t'as vu la gueule du condo  :ouch:
sinon le tableau j'attend juste quelqu un pour me faire un truc plus simple qu'excel et je le met en ligne :p
Nothing to Say
Marsh Posté le 03-01-2005 à 23:26:58
Belle intiative Mr le Pere noel :jap:
Edit : sondage K8N Neo 2 : sujet 650867 ;)
Message édité par amdmanu le 03-01-2005 à 23:30:03
Team HFr ArmA - Aujourd'hui, je sauve une vie ... ou deux !
Marsh Posté le 03-01-2005 à 23:42:21
mm pas besoin de rad passif ;) ca chauffe pas des masses le chipset
Psn : bkn_panda || XBL : bkn Panda || Steam : bknpanda
Marsh Posté le 03-01-2005 à 23:48:00
bah y en a qui ne veulent absolument pas de venrtilo [:proy]
Marsh Posté le 03-01-2005 à 23:51:56
ya comme un non sens dans ta phrase  :D
Chic not Geek
Marsh Posté le 04-01-2005 à 00:02:45
j'ai mit un radiateur revoltec dessus et bien apres 5 mins t'as plus trop confiance quand tu met la main dessus!!
Marsh Posté le 04-01-2005 à 00:04:28
Nouveau topic --> trés bonne idée :) .  je reposte ici comme ça mon post partira pas aux oubliettes ;) .
necmaster a écrit :
Ma ddr est certifié pour certains timings. Or sur ma carte actuelle une NF7 v1.0, les timings annoncés ne sont pas supportés. je me dis que ce bon vieux nForce2 doit être cappricieux :fou:
Est-ce que ces timings seront respecté du fait de l'intégration du contrôleur mémoire dans l'A64 ? :??:
Je poste ici car je viens d'acheter la K8N néo2 :)
une réponse ?
edit: c'est 2x512 double face (TwinMos).
Message édité par necmaster le 04-01-2005 à 00:06:07
Marsh Posté le 04-01-2005 à 00:07:56
c'est quoi la marque des tes barrettes?
par contre rien ne peut garantir que ca passera,mieu [:proy]
Marsh Posté le 04-01-2005 à 00:11:49
c'est de la TwinMos PC3200
Marsh Posté le 04-01-2005 à 00:26:34
pour ceux qui ont de la corsair XL, vous montez a combien au max?
Moi c'est 220MHz en 2,5.3.3.10
Marsh Posté le 04-01-2005 à 00:52:52
Drapal.
Bravo pour la faq, ca va probablement résoudre les problèmes d'un ami :jap:
Viva Manul!
Marsh Posté le 04-01-2005 à 01:17:34
Bonne initiative pere noel !
Je voulais rajouté un petit truc qui, je pense sera utile.
Pour le controleur mémoire, voila un tableau récapitulatif des modes de fonctionnement selon le nombre de barettes, et de faces...
Bon le tableau est certainement plus explicite que moi alors le voilà ;)
Marsh Posté le 04-01-2005 à 01:33:39
Salut a tous !
Tres bonne initiative que de relancer un sujet sur cette sympathique mobo  :D
Donc je vais rajouter un tit truc pour les ceussent qui n'arrivent pas a o/c ( j'etais dans ce cas jusque ce soir ... )
Bien faire attention de virer aggresive timing dans le menu cell du bios si l'on veut augmenter un tant soit peu le fsb  :whistle:
je m'amuse depuis ce soir avec cette option en disable et j'ai enfin réussi a monter en frq (en desynchro certes mais ma corsair value n'aime pas trop etre taquinée au dessus de sa frq d'origine  :sweat: )
je suis donc rendu a 2.4Ghz au lieu des 2ghz d'origine de mon 3200+ et ce juste en augmentant le vcore de +5% :)
Je vais laisser tourner Prime cette nuit et on verra bien ce que ca va donner.
Si qqu'un peut expliquer clairement comment utiliser et activer le FW de la carte nvidia ca serait bien par contre  :sol:
Sans loutres la puissance n'est rien !
Marsh Posté le 04-01-2005 à 02:26:33
C'est tout marqué dans la faq pour le fw :)
C'est pas trop mauvais sur les perfs la ram en désynchro?
Message édité par inti le 04-01-2005 à 02:26:41
Viva Manul!
Marsh Posté le 04-01-2005 à 07:21:37
et en plus je sais pas lire ...
pour les perfs ben j'attends deja de valider avec prime voir ce que ca raconte niveau stabilité et apres on verra
Marsh Posté le 04-01-2005 à 08:04:18
pas grande diff sur A64 la desynch surtout si de bons timmings
Nothing to Say
Marsh Posté le 04-01-2005 à 09:10:46
si qq'un pourrait mettre les vmod de cette carte ce serrait sympatoche ;)
Marsh Posté le 04-01-2005 à 11:15:49
Hmm, la TwinMos est connue pour ne pas etre la meilleure RAM pour nForce3 - K8N Neo2 voir même pour A64 quelque soit le chipset :/
Globalement, je trouve ce nForce3 tres capricieux concernant la RAM. En ce qui me concerne, il m'est impossible d'avoir une config stable avec 4 x 512 Mo ECC en Micron (simple face) à FSB200 :(
Apres divers tests avec un voltmetre, il est clair que les voltages rapportés dans le bios et dans CoreCenter sont erronnés, le plus souvent sous évalués, et ceci au moins jusqu'au bios 1.40. Par exemple mon 12V est à 11.66 dans CoreCenter alors que le voltmetre donne 11.99.
Pour acceder aux options cachées du Bios : Shift+F2 puis ALT+F3
Les meilleurs réglages du bios selon TT-hardware :
http://www.tt-hardware.com/modules [...] =0&thold=0
http://www.tt-hardware.com/img/news4/news190105_2dujour.gif
http://www.tt-hardware.com/img/news4/news190105_3dujour.gif
/!\ Tres peu de modules de DDR supportent des timings aussi bas. Je prefere desactiver l'Agressive timing ainsi que le Spread spectrum.
- màj du bios
- comme souligné par le_pere_noel2, une "vraie" alim semble vitale, avec au moins 24A sur le 12V (au moins 26A avec une carte gfx avec Molex)**
** Certaines configues sont parfaitement stables avec seulement 20A sur le 12V. Plus d'info sur les alims ici : http://www.extremeoverclocking.com [...] ide_1.html
Attention, seuls le SATA VIA est locké en PCI, n'utiliser que les SATA 3 et 4 (proches du cpu) en cas d'overclock.
7) redémarrer le PC
Edit: pas de problème avec CoreCenter qui me permet de regler la vitesse du ventilo du chipset trop bruyant au max (réglage en manuel à 6/8). Par contre la lecture de la température du sys me donne +4°C  :pt1cable:
Autres généralités : le dual channel n'apporte pas grand chose dans la majorité des applis. Par contre le core Winchester s'avere souvent de 3 à 5% plus rapide que son predecesseur :o
Message édité par amdmanu le 20-01-2005 à 22:09:45
Marsh Posté le 04-01-2005 à 11:19:51
Bon bon la suite de mes périgrinations overclockesques.
Alors je suis donc a 200 pour la ram en 2.5 3 3 8 comme certifié par Corsair voltage origine sur la ram.
HT a 4X FSB a 240 et voltage classique CPU avec 8.3% en plus.
Le prime a l'air de tenir sans aucune erreur depuis que j'ai tout lancé je vais bien voir ce soir si le PC est tjs en vie ;)
Quel interet de passer l'AGP a 67Mhz au lieu de 66 ?
