CTX 19'' PR960F P0,24 TRINITRON USB BNC (232/30-110/1920*1440)
CTX 19'' PR960F P0,24 TRINITRON USB BNC (232/30-110/1920*1440) - Hardware
Marsh Posté le 23-04-2002 à 11:16:46
Vous en pensez quoi?
PR960F
http://www.ctxintl.com/images/pr960f_s.jpg
19" FD Trinitron® CRT (18" diagonal Viewable Image Size)
0.24mm Pitch Aperture Grille (Center)
ARAG® Screen Treatment
USB Hub
Frequency Range
Horizontal: 30-110kHz
Vertical: 50-160Hz
Screen Resolutions
1800 x 1440 @ 72Hz
1600 x 1200 @ 87Hz
1280 x 1024 @ 102Hz
1024 x 768 @ 136Hz
800 x 600 @ 160Hz
Video Input
Bandwidth: 232MHz
Input Signal
Video: RGB analog (0.7V p-p, 75 ohms)
Sync: Separate TTL H/V +/-, Composite, Sync-on-green
Input Connector
15-pin mini D-sub (Detachable cable)
BNC Connector
Compatibility
IBM® PC and PC compatibles
Mac® (up to 1152 x 864)
Power Requirement
100-120/220-240V AC (auto switch), 50/60Hz
Power Consumption
Operation Mode: 125W (maximum)
User Controls
Front Panel Controls:
Power On/Off, Key1, Key2, Up, Down
On-Screen Menu Controls:
Brightness/Contrast, H/V Position, H/V Size, Rotation,
Pin-Balance, Side-Pin, Trapezoid, Parallelogram,
Moire canellation, Reset, Multi-language, Degauss, Status,
Convergence, Recall, BNC/D-sub Select, Self-diagnosis
Color Adjustment (3 setting modes, 1 user mode)
Input Freq. Display, Fre. Out of Range Alarm
Regulation Compliant
Safety: UL, CE, cUL, Nemko, FCC-B, CB, BCIQ, TCO'99
X-Ray: DHHS
Ergonomics: ISO9241-3 & ISO9241-8
Plug & Play: DDC-1, DDC-2B
Power Management
Energy Star®, VESA® DPMSTM, TCO'99
Operating Condition
Temperature: 32° F to 104° F (0° to 40° C)
Humidity: 20%-80% (non-condensing)
Dimensions (W x H x D)
Carton:
24.3" x 22.2" x 20.3"
Monitor:
18.1" x 18.5" x 19.1"
Weight
Gross: 61.7 lbs
Net: 57.2 lbs
Warranty
Three year limited warranty on parts, labor and CRT
http://www.ctxintl.com/products/pr960f.htm
Marsh Posté le 23-04-2002 à 11:21:14
j'en ai un et j'en suis très content.
En plus, le SAV CTX est très bon (on sais jamais).
La sagesse et la Connaissance commencent quand on sait que l'on ne sait rien.
Marsh Posté le 23-04-2002 à 11:23:13
merci!
tu la payé combien?
640?
Marsh Posté le 23-04-2002 à 11:28:50
Nan, je l'ai payé beaucoup, beaucoup moins cher (BCoze i'm Revendeur)
Marsh Posté le 23-04-2002 à 11:35:29
MOI je le paye 549....t'en penses quoi nivo prix??
sinon, tu es content à tous nivo?
Marsh Posté le 23-04-2002 à 11:37:04
549 ?, ça me parait bien.
Je suis content à tous les niveaux, mais la qualité d'affichage d'un moniteur est une notion très subjective je trouve (hors spécification techniques bien sûr).
Marsh Posté le 23-04-2002 à 11:39:28
oui c vrai.. mais je voulais juste avoir un avis rassurant pour que je puisse l'acheter les yeux fermés... merci!
Un lcd c bien aussi ;)
Marsh Posté le 26-04-2002 à 11:13:38
c bon, je l'ai acheté!
c lourd!
mais quelle qualité d'image!!!!!!!
 :crazy:
Marsh Posté le 26-04-2002 à 11:17:15
Et oui.
Tu vas pleurer si tu va faire des lan souvent (30 kg je crois).
Marsh Posté le 26-04-2002 à 11:21:08
Et oui.
en effet... je vais me muscler!
Mais après la mort de mon 17 pouces (je vais d'ailleurs faire un topic) j'ai décider d'acheter un moniteur, ou un LCD pour 369 euros ou le CTX pour 549 Euros un promo, je suis content de ce dernier choix!
dommage que le hub ne soit pas en USB 2.0 mais c déjà bien! :hello:
Marsh Posté le 26-04-2002 à 11:32:40
HT où 7 écran ?
c'est pas une dalle plate ?
Marsh Posté le 26-04-2002 à 11:33:38
reunionf a écrit a écrit :
HT où 7 écran ?
SI DALLE PLATE TRINITRON
Marsh Posté le 26-04-2002 à 11:33:48
Si c'est une dalle plate, le tube est du Trinitron.
pitch de 0,24 si ma mémoire est bonne.
edit: grillé
[jfdsdjhfuetppo]--Message édité par Arcord le 26-04-2002 à 11:34:06--[/jfdsdjhfuetppo]
Marsh Posté le 26-04-2002 à 11:37:23
Vous l'achetez où ?
dalle plate à grille ?
Marsh Posté le 26-04-2002 à 12:08:37
j'suis content pour vous
j'avais ht un LaCie 19" aux mêmes carctétisques (avec 2 a 3 trucs en + : usb mouse + keyboard + output rgb)
=> ben le vendeur à garde mon fric et l'écran ....
=> c la panacé pour me faire rembourser...
=> depuis g une merde de 19" : iiyama LS902UT g les yeux bouffis en 5min....
1+1=10
Marsh Posté le 26-04-2002 à 12:13:55
Vous l'achetez où ?
personne !
Marsh Posté le 26-04-2002 à 12:21:05
Vous l'achetez où ?
Regarde mon deuxième post, tu verras que je ne peux pas te répondre, je ne serais pas objectif. :)
