[ECS A929] Infos, avis ....
Infos, avis .... [ECS A929] - Hardware
Marsh Posté le 27-04-2003 à 16:57:13
ECS (EliteGroup) A929
http://www.ecsusa.com/images/a928_front.jpg
http://www.ecsusa.com/images/md-4.gif
SPECIFICATION
Processor:
AMD CPGA Duron processor with 128KB on die L2 cache, 200MHz system bus, 0.18u process technology
Speed at 850MHz/ 900MHz/ 950MHz/ 1GHz/ 1.1GHz/ 1.2GHz/ 1.3GHz
AMD OPGA AtholonXP with 256 KB on die L2 cache, 266MHz system bus, 0.13u/0.18u process technology. Speed at 2000+ (1.667GHz)/ 2100+ (1.73GHz), Thoroughbred core (0.13u); Speed at 1500+ (1.333GHz)/ 1600+ (1.4GHz)/ 1700+ (1.467GHz)/ 1800+ (1.533GHz)/ 1900+ (1.6GHz)/ 2000+ (1.667GHzz), Palomino core (0.18u)
AMD CPGA Atholon with on die 256 L2 cache, 200/266MHz system bus, 0.18u process technology Speed at 1.2GHz/ 1.333GHz/ 1.4GHz, Thunderbird core
Socket 462 for CPGA/OPGA package
QuantiSpeed architecture support
Core Logic:
SiS 740 & SiS 961, 4X AGP bus interface, supports host bus at 266MHz
ACPI V1.0b, AGP V2.0 and 3.3V PCI version 2.2 compliant
533MB/s high bandwidth MuTIOL between SiS 740 & SiS 961
System Memory:
128/256/512MB DDR-SDRAM for Factory/Dealer installed
Upgradeable to 1GB on one DIMM socket, support DDR 266 / PC2100 specification
BIOS:
AMI Mobile PC Bios; PnP, ACPI, DMI
AMI 512K Flash BIOS, supports password, Plug & Play, ACPI and DMI
Bootable from USB FDD and CD-ROM
Display:
14.1" / 15.0" XGA TFT LCD with 1024x768 resolutions ( 16.7M colors )
Video & Graphic:
Built-in SiS 315 graphic core and AGP 4X supported
High performance 256bit 3D graphics engine up to 143MHz 3D engine clock speed
Video bridge supported by SiS 301LV, TV-out function provided
Share Memory Architecture supports up to 64MB DDR frame buffer
Audio:
Dual full-duplex Direct Sound Channels
Hardware SoundBlaster Pro for real-mode DOS legacy compatible
Built-in two high quality stereo speakers with chamber and mic
Optical storage:
Equipped with 8X DVD-ROM, 12.7 mm height.
Factory option: 24X CD-ROM, CD-RW and Combo Drive (DVD-ROM + CD-RW)
Hard Disk Drive:
ATA 33/66/100 and Enhanced IDE (PIO mode 4) supported, 2.5" 9.5mm height
Upgradeable easily, optional capacity of 15/20/30/40 GB
Communication:
Onboard full duplex 10/100 Base-T Ethernet, MAC : SiS 961 built-in
56K / V.90 Conexant PCI software data/fax modem
Built-in SIR transceiver module, IrDA 1.3 standard compliant up to 4.0Mbps
Pointing Device & Keyboards:
Synaptics touch pad with scrolling up/down button
12 function keys and Windows function key, 19mm key pitch
US/Europe, DOS/V keyboard for Japan, full size keyboard alike pitch
2 shortcut keys (Internet and E-Mail), 3.0mm key travel, inverted-T cursor layout
IEEE 1394:
Incorporates with one 1394 port supporting power, transfer rate up to 400Mbps
1394 OHCI v1.0 and v1.1 compliant
Integrated IEEE 1394 OHCI-link and three ports of IEEE 1394 PHY
USB 2.0:
Incorporates with four USB 2.0 ports, transfer rate up to 480Mbps
Integrated 2 UHCI host controller for full-speed (12Mbps) and low-speed (1.5Mbps) USB device
Integrated 1 EHCI host controller for high-speed (480Mbps) USB device
I / O Interface:
1 x Parallel port
1 x external VGA port
1 x S-Video TV-out port
1 x RJ-11 jack for Modem
1 x RJ-45 for Ethernet
1 x SIR port
1 x 1394 port
4 x USB 2.0 ports
1 x MIC-in jack
1 x headphone jack
1 x 3-pin DC-in jack for AC adapter / external battery pack
LED Indicator: Power, Suspend/Resume, HDD, Number Lock, Caps Lock and Scroll Lock on/off
Security: BIOS password protection and Kensington Lock hole provided
External Battery:
Optional external 12 Cells 2000mAh, 88Wh Li-Ion battery pack
SMBus V1.1 implemented, battery low beep warning and 5 LEDs display supported
Dimension : 216 x 98 x 28 mm
AC Adapter: Input : 100~240V AC, 50-60Hz universal; Output : 20V DC, 6.0A, 120W
Dimensions & Weight:
332 x 281 x 39.7(min) / 44.7(max) mm, 13.07" x 10.81" x 1.56"/1.76"
3.18 kg, 7.0 lbs (with 15.0" panel and DVD-ROM Drive installed)
System Compliance: Microsoft Windows XP/ Windows 2000 Professional / Windows ME/ Windows 98SE compliant
Power Management:
PC 2001, ACPI compliant
Support suspend to RAM (S3), suspend to Disk (S4) and Soft Off (S5)
Accessories: S-Video Cable, Phone Cord, AC Adapter, Power Cord, Quick Guide and Driver CD Title
Si vous l'avez testé, vos avis, remarques et autres critiques sont les bien venue.
