Je peut plus graver: erreur de fixation ! :( - Hardware
Marsh Posté le 13-11-2001 à 18:05:39
callahan059 a écrit a écrit : as tu nero ??? |
Sous NERO 5.5 c'est une erreur de fixation au de but de la gravure
et sous blindwrite il me met trackfollowing error au debut de la gravure aussi
Marsh Posté le 13-11-2001 à 18:07:06
Pour etre complet un log de Nero:
AutoRun : 1
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 45088768 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 351MB (359924kB)
Free physical memory: 101MB (103852kB)
Memory in use : 71 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry: 1
Wizard: Off
Image CD
31.10.2001
22:18:41 #1 Text 0 File Writer.cpp, Line 125
Writer CRW8424E running
22:19:43 #2 Text 0 File Burncd.cpp, Line 1497
Recorder: YAMAHA CRW8424E;
CDR code: 00 97 31 07; OSJ entry from: Ritek Co.
ATIP Data:
Special Info [hex] 1: C0 00 90, 2: 61 1F 07 (LI 97:31.07), 3: 4A 2D 00 (LO 74:45.00)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
22:19:43 #3 Text 0 File ThreadedTransferInterface.cpp, Line 800
Prepare recorder CRW8424E for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x0 Close Session
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 355676160
22:19:43 #4 Text 0 File ThreadedTransferInterface.cpp, Line 828
Removed 2 run-out blocks from end of track 1.
22:19:43 #5 Text 0 File ThreadedTransferInterface.cpp, Line 665
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (Joliet)
2 indices, index0 (150) not provided
original CD pos #0 + 173520 (173520) = #173520/38:33.45
relocatable, CD pos for caching/writing not required/not required, patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 173518 blocks [CRW8424E ]
22:19:43 #6 Phase 36 File dlgbrnst.cpp, Line 1372
Start of burnprocess at 8x (1200 KB/s)
22:19:45 #7 Text 0 File ThreadedTransferInterface.cpp, Line 1836
Verifying CD position of item 0 (relocatable, no CD pos, patch infos, orig at #0): write at #0
22:20:32 #8 SCSI -1119 File Cdrdrv.cpp, Line 1392
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x023F7070
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x09
Sense Qual: 0x00
CDB Data: 0xAA 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1E 0x00 0x00
Sense Data: 0x70 0x00 0x04 0x78 0x78 0x78 0x71 0x0A
0x00 0x00 0x00 0x00 0x09 0x00
22:20:32 #9 mmc -1119 File Writer.cpp, Line 311
Track following error
22:20:32 #10 Text 0 File ThreadedTransfer.cpp, Line 218
all writers idle, stopping conversion
22:20:32 #11 Text 0 File ThreadedTransfer.cpp, Line 212
conversion idle, stopping reader
22:20:32 #12 CDR -201 File WriterStatus.cpp, Line 162
Invalid writestate
22:20:32 #13 TRANSFER -18 File WriterStatus.cpp, Line 162
Could not perform EndTrack
22:20:32 #14 SCSI -1026 File Cdrdrv.cpp, Line 1183
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x2C
Sense Qual: 0x04
CDB Data: 0x5B 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x2C 0x04
22:20:32 #15 mmc -1026 File WriterStatus.cpp, Line 201
Current program area empty
22:20:32 #16 TRANSFER -19 File WriterStatus.cpp, Line 201
Could not perform Fixation
22:20:32 #17 Text 0 File WriterStatus.cpp, Line 210
falling back to disc fixation
22:20:32 #18 SCSI -1026 File Cdrdrv.cpp, Line 1183
Sense Code: 0x2C
Sense Qual: 0x04
22:20:32 #19 mmc -1026 File WriterStatus.cpp, Line 201
22:20:32 #20 TRANSFER -19 File WriterStatus.cpp, Line 201
22:20:33 #21 Phase 38 File dlgbrnst.cpp, Line 1372
Burnprocess failed at 8x (1200 KB/s)
22:20:33 #22 Text 0 File Scsicmd.cpp, Line 371
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\NeroCD2k.sys': Ver=1.0.0.9, size=44227 bytes, created 22/09/2001 19:50:29
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 10/09/1999 12:06:00
Marsh Posté le 15-03-2002 à 11:06:30
Je viens d'avoir exactement le même problème que toi avec mon Plextor 8432, et pas moyen de graver mes 80 mais que des 74, as tu réussi à corriger ce problème ?
Marsh Posté le 15-03-2002 à 11:08:55
Moi j'ai rencontré pendant une période le même pbl .."Can't make fixation" .. mais les CD marchaient nickel.
Le pbl a été résolu en mettant à jour Nero.
Marsh Posté le 15-03-2002 à 17:20:16
Probleme de fixation héhé rajoute 2 vis et pu de probleme
:gun:
Marsh Posté le 13-11-2001 à 17:45:46
Mon Yamaha 8424 me fait des histoire.
Il ya mois je pouveais plus que gravais en 4x ou aléatoirement en 8x.
Maintenant je peut plus graver du tout: erreur de fixation qu'il me fait
et il arrive plus a lire les 3/4 des cd-vierges
Que faire? Il y-t-il une solution (netoyage du lecteur ?) ?
Merci!
"Si c'est les meilleurs qui partent les premiers, que penser des éjaculateurs précoces" Desproges
