probleme de lecteur/graveur dvd - CD/DVD/BD - Hardware
MarshPosté le 13-07-2007 à 22:45:38
Bonsoir, jai un probleme avec 2 peripheriques - mon lecteur de dvd et mon graveur dvd - rw. Tout ca a commencer avec l instilation de mon 2eme disque dur. Depuis mon lecteur n'est plus reconnu du tout, et mon graveur ne peut lire aucune disque (ni DVD ni CD) sauf 2 dvd que jai graver avec le meme graveur.
J ai utiliser microsoft autoplay repair wizard et voila le resultat du test -
AutoFix [V5.2.3790.67] Time [2007-07-13 22:32:34] Microsoft Windows Version [5.1 (Service Pack 2) <2600>]
Test [The Shell Hardware Detection service is running.] - Instance [N/A]: Result [AutoStart Setting]: OK Result [The Shell Hardware Detection service is running.]: OK
Test [Policies] - Instance [D:\, Drive Type: 5]: Result [HKCU\...\Policies!NoDrives]: OK {Absent} Result [HKCU\...\Policies!NoDriveAutorun]: OK {Absent} Result [HKCU\...\Policies!NoDriveTypeAutorun]: OK {Present} Result [HKLM\...\Policies!NoDrives]: OK {Absent} Result [HKLM\...\Policies!NoDriveAutorun]: OK {Absent} Result [HKLM\...\Policies!NoDriveTypeAutorun]: OK {Absent} Result [Driver level policies]: OK { HKLM\...\Services\cdrom!Autorun (Present) <Allows> HKLM\...\Services\cdrom\Parameters!Autorun (Absent) <Allows> HKLM\System\CCS\Enum\...!AlwaysEnable (Absent) <Not set> HKLM\System\CCS\Enum\...!AlwaysDisable (Absent) <Not set> }
Test [Drive Notification] - Instance [D:\, Drive Type: 5]: Result [Legacy Notification]: Problems Result [AutoPlay V2 Notification]: Problems { Service (Silent) Shell (Deaf) } >> Repair << [Legacy AutoPlay Event] Step: No steps to take. Result: This AutoPlay setting cannot be fixed. Either the device is malfunctioning, or the wizard cannot determine the problem. >> Repair << [Autoplay V2 Event] Step: No steps to take. Result: This AutoPlay setting cannot be fixed. Either the device is malfunctioning, or the wizard cannot determine the problem.
>> Required action: The wizard found problems but cannot fix them -> None
Oops c'est en anglais ben si vous ne comprenez pas le programme me dis que soit le peripherique ne function pas correctement ou que le wizard ne peut pas reparer le probleme.
J ai voulu faire un reparation de windows mais le disc ne peut pas etre lu
C'est la galere il y a quelq un qui peut m aider a comprendre tout ca? Merci d avance
Marsh Posté le 13-07-2007 à 22:45:38
Service (Silent)
Shell (Deaf) }
