Message d'erreur ? - Hardware
Marsh Posté le 08-03-2002 à 00:07:05
Connaissez vous la signification de ce message ? NT version information: Major version = 5 Minor version = 1 Build number = 2600 Platform ID = 2 ( 3) Scanning "\\.\Scsi0:" ( 8) Error reading Registry for "Hardware\DeviceMap\SCSI\SCSI Port 0" Error = 2 ( 9) Error reading Registry for "Hardware\DeviceMap\SCSI\SCSI Port 0" Error = 2 (10) Driver = "atapi" Adapter 0 PortNumber 0 PathId 0 InitiatorBusId 255 MaximumTransferLength 131072 MaximumPhysicalPages 32 AlignmentMask 1 MaxTransferLen 126976 irq 0 port 0 ( 3) Scanning "\\.\Scsi1:" ( 8) Error reading Registry for "Hardware\DeviceMap\SCSI\SCSI Port 1" Error = 2 ( 9) Error reading Registry for "Hardware\DeviceMap\SCSI\SCSI Port 1" Error = 2 (10) Driver = "atapi" Adapter 1 PortNumber 1 PathId 0 InitiatorBusId 255 MaximumTransferLength 131072 MaximumPhysicalPages 32 AlignmentMask 1 MaxTransferLen 126976 irq 0 port 0 ( 4) Discovered 2 SCSI ports (13) length = 6375 (14) Global (15) Error opening "\\.\Global" Error = 6 (14) D: (17) "\\.\D:" is at SCSI Port 0 Bus 0 Target 1 Lun 0 (20) Driver = "atapi" Type = "DiskPeripheral" (14) NDIS (14) DISPLAY1 (15) Error opening "\\.\DISPLAY1" Error = 5 (14) Root#SYSTEM#0000#{ffbb6e3f-ccfe-4d84-90d9-421418b03a8e} (14) DISPLAY2 (15) Error opening "\\.\DISPLAY2" Error = 5 (14) Root#SYSTEM#0000#{71985f4a-1ca1-11d3-9cc8-00c04f7971e0} (14) Root#MS_PPPOEMINIPORT#0000#{ad498944-762f-11d0-8dcb-00c04fc3358c} (14) DmIoDaemon (14) ACPI#PNP0C0C#2&daba3ff&0#{4afa3d53-74a7-11d0-be5e-00a0c9062857} (14) Ip (14) PCI#VEN_1102&DEV_0004&SUBSYS_00511102&REV_03#4&11d 7ad53&0&4840#{65e8773d-8f56-11d0-a3b9-00a0c9223196 } (15) Error opening "\\.\PCI#VEN_1102&DEV_0004&SUBSYS_00511102&REV _03#4&11d7ad53&0&4840#{65e8773d-8f56-11d0-a3b9-00a 0c9223196}" Error = 2 (14) DISPLAY3 (15) Error opening "\\.\DISPLAY3" Error = 5 (14) {59BFC86D-9267-4FA6-893C-444AFC921BF6} (14) E: (17) "\\.\E:" is at SCSI Port 1 Bus 0 Target 0 Lun 0 (20) Driver = "atapi" Type = "CdRomPeripheral" (xx) New device handle on existing adapter About to send "\\.\E:" into the pipe ... CallNamedPipe failed Error = 2 (14) IPSECDev (14) DISPLAY4 (15) Error opening "\\.\DISPLAY4" Error = 5 (14) {750E1780-25C4-4CA0-8DAC-827AD5E5683B} (14) Root#MS_NDISWANIP#0000#{ad498944-762f-11d0-8dcb-00c04fc3358c} (14) ACPI#PNP0303#4&26102e8&0#{884b96c3-56ef-11d1-bc8c-00a0c91405dd} (15) Error opening "\\.\ACPI#PNP0303#4&26102e8&0#{884b96c3-56ef-11d1-bc8c-00a0c91405dd}" Error = 5 (14) Root#SYSTEM#0000#{9aa4a2cc-81e0-4cfd-802f-0f74526d2bd3} (14) gi_pci (14) $VDMLPT1 (14) PCI#VEN_1102&DEV_0004&SUBSYS_00511102&REV_03#4&11d 7ad53&0&4840#{dff220f3-f70f-11d0-b917-00a0c9223196 } (15) Error opening "\\.\PCI#VEN_1102&DEV_0004&SUBSYS_00511102&REV _03#4&11d7ad53&0&4840#{dff220f3-f70f-11d0-b917-00a 0c9223196}" Error = 2 (14) Root#SYSTEM#0000#{3c0d501a-140b-11d1-b40f-00a0c9223196} (14) Root#SYSTEM#0000#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0} (14) RdpDrDvMgr (15) Error opening "\\.\RdpDrDvMgr" Error = 31 (14) WMIDataDevice (14) F: (17) "\\.\F:" is at SCSI Port 1 Bus 0 Target 1 Lun 0 (20) Driver = "atapi" Type = "CdRomPeripheral" (xx) New device handle on existing adapter About to send "\\.\F:" into the pipe ... CallNamedPipe failed Error = 2 (14) COM1 (14) Volume{a96d3263-2ef8-11d6-971d-806d6172696f} (17) "\\.\Volume{a96d3263-2ef8-11d6-971d-806d6172696f}" is at SCSI Port 1 Bus 0 Target 0 Lun 0 (20) Driver = "atapi" Type = "CdRomPeripheral" (xx) Device handle already exists! (xx) No current drive letter, using existing device handle (14) Root#SYSTEM#0000#{dff220f3-f70f-11d0-b917-00a0c9223196} (14) PIPE (14) SW#{a7c7a5b0-5af3-11d1-9ced-00a024bf0407}#{9B36589 0-165F-11D0-A195-0020AFD156E4}#{d6c5066e-72c1-11d2 -9755-0000f8004788} (14) Root#SYSTEM#0000#{2eb07ea0-7e70-11d0-a5d6-28db04c10000} (14) IDE#CdRomYAMAHA_CRW2200E_________________________1 .0D____#5&2fb342a0&0&0.1.0#{53f56308-b6bf-11d0-94f 2-00a0c91efb8b} (17) "\\.\IDE#CdRomYAMAHA_CRW2200E_________________ ________1.0D____#5&2fb342a0&0&0.1.0#{53f56308-b6bf -11d0-94f2-00a0c91efb8b}" is at SCSI Port 1 Bus 0 Target 1 Lun 0 (20) Driver =
[jfdsdjhfuetppo]--Message édité par sebkane--[/jfdsdjhfuetppo]
Marsh Posté le 08-03-2002 à 00:37:08
Putain !!! QUELLE INSULTE !!!
Major version = 5
Minor version = 1
Build number = 2600
Platform ID = 2
Error = 2
Error = 2
Adapter 0
PortNumber 0
PathId 0
InitiatorBusId 255
AlignmentMask 1
irq 0
port 0
Error = 2
Error = 2
Adapter 1
PortNumber 1
PathId 0
InitiatorBusId 255
AlignmentMask 1
irq 0
port 0
(13) length = 6375
(14) Global
Error = 6
(14) D:
(14) NDIS
(14) DISPLAY1
Error = 5
(14) DISPLAY2
Error = 5
(14) DmIoDaemon
(14) Ip
0c9223196}"
Error = 2
(14) DISPLAY3
Error = 5
(14) E:
Error = 2
(14) IPSECDev
(14) DISPLAY4
Error = 5
Error = 5
(14) gi_pci
(14) $VDMLPT1
0c9223196}"
Error = 2
(14) RdpDrDvMgr
Error = 31
(14) WMIDataDevice
(14) F:
Error = 2
(14) COM1
(14) PIPE
-9755-0000f8004788}
2-00a0c91efb8b}
(20) Driver =
