Super bios pour booster la k7s5a!!! par ici... - Hardware
Marsh Posté le 12-07-2002 à 15:37:04
(ca fait perpete k'il est sorti cuilà nan? )
Marsh Posté le 12-07-2002 à 22:00:35
pcever a écrit a écrit : Pas vu sur ton site ?? ![]() |
ben si http://www.materiel.be/cm/k7s5a/k7s5a_vbios.htm#oc
et sur k7s5a.free.fr aussi
Marsh Posté le 12-07-2002 à 22:02:17
pcever a écrit a écrit : http://forum.ocworkbench.com/ocwbc [...] forum&f=37 C'est le bios chb029.rom ![]() Nouvo fsb de 143 et 147... chb0429.rom non-lan Version chb0429l.rom lan version chb0429f.rom lan version with fastwrites enabled (disable lan in bios Setup to use it on a non-lan board) Release notes: - Adjust timing for stability and compatibility ![]() - FSB modes reprogrammed: "100/100 MHz" changed from 99.6 to 100.9 MHz "133/133 MHz" changed from 132.77 to 133.9 MHz No more underclocking by default! - Several FSB modes added. New list of available modes: 100/100 MHz 100/133 MHz 133/133 MHz -> Default modes 66/66 MHz (H/W Trap) 112/112 MHz 124/124 MHz 138/138 MHz 150/150 MHz 166/166 MHz -> Already present in the "OC" bios 110/110 MHz * (replaces 107/107 from the previous cheepobios) 133/100 MHz 143/143 MHz 147/147 MHz 133/166 MHz 160/120 MHz 200/200 MHz Please note that the "166 MHz no-boot issue" hasn't been dealt with in this bios modification. It seems that bios timings need to be adjusted to allow booting at such speed. This issue could also affect 160/120 and 200/200 settings. - Extra memory settings: - RAS Precharge Time=2T - RAS Active Time=4T, 5T - Full screen logo can be enabled/disabled via bios menu Ca marche super bien et stable... ![]() Athlon 1800+@2000+ 11.5x147=1690 Avec ce bios, la K7s5a n'a + de defaut. Au passage merci a pentier : http://k7s5a.free.fr/ ![]() |
tu refroidis avec quoi pour overclocker comme ca?
Marsh Posté le 13-07-2002 à 01:24:23
Avec un simple ventilo aqua (genre 690 mais non base cuivre).
Comme on touche pas au voltage le proce reste a la meme temperature...
Le FSB 143 est passe a coup sur.
Marsh Posté le 13-07-2002 à 02:11:56
ha bah cool je vais tester ca
tjrs bon a prendre quelques mhz en plus facilement
Marsh Posté le 13-07-2002 à 03:40:29
bah voila
est-ce que tu crois que c'est jouable xp 2100+?
Marsh Posté le 13-07-2002 à 13:27:30
Chez moi le FSB 147 passe sans probleme donc essai...
J'ai tenter le 150 (2100+) , ca boot sur win mais freeze.
Avec de la memoire de qualiter et soudage sur la k7s5a ca doit le faire sans trop de mal.
Marsh Posté le 13-07-2002 à 13:33:23
pcever a écrit a écrit : Chez moi le FSB 147 passe sans probleme donc essai... ![]() J'ai tenter le 150 (2100+) , ca boot sur win mais freeze. Avec de la memoire de qualiter et soudage sur la k7s5a ca doit le faire sans trop de mal. ![]() |
la mienne ne passe k'à 143 par ce bios, mais à 147 avec speedfan par ex...
Marsh Posté le 13-07-2002 à 14:03:43
La mienne est à 147Mhz (XP 1600 en XP 1800) depuis un moment, rock stable
Marsh Posté le 13-07-2002 à 14:05:01
skeye a écrit a écrit : la mienne ne passe k'à 143 par ce bios, mais à 147 avec speedfan par ex... |
speedfan?
moi a 143mhz no prob mais a 147 mhz ce bloque a l'ecran de login de winxp
Marsh Posté le 13-07-2002 à 14:30:51
euh juste une question
c et kel bios qu il faut prendre? et quel prog de flash?
Marsh Posté le 13-07-2002 à 14:35:32
moi avec ce bios chb029.rom je suis a un fsb 150mhz et mon 1600+ est détecté à 1900+ mouahhhhhhhhhh
je crois que j'ai de la chance
Marsh Posté le 13-07-2002 à 14:48:54
Citation : |
Lis le 1er message
Marsh Posté le 13-07-2002 à 15:21:39
je sais j ai fait le con
desoler
par contre pour booter sous dos est ce qu une disquette formater ms dos suffit (sous xp)?
Marsh Posté le 13-07-2002 à 15:37:25
j ai un probleme
quand je veux flasher il me dit:
ERROR5- file not of proper size
j ai pris le bios sans lan (j ai pas le lan) le 1er
pk??
Marsh Posté le 13-07-2002 à 15:37:47
ma methode de flash:
Boot sur diskette win98
inserer et install soft de flash sur une autre diskette...
Marsh Posté le 13-07-2002 à 15:39:55
Va voir le specialiste de cette mobo
Marsh Posté le 13-07-2002 à 15:39:56
j ai fait ca
j ai telecharger une disquette de boot
le pc boot sous dos normalement
je lance la procedure:
aminf332.exe CHB0429.ROM
et la il me marque l erreur
Marsh Posté le 13-07-2002 à 15:41:48
pcever a écrit a écrit : Va voir le specialiste de cette mobo ![]() http://k7s5a.free.fr/ http://k7s5a.free.fr/ ![]() |
je sais j ai tout lu et j ai suivis les explications
mais toujours cette erreur
ps: le bios fastwrtie c est pourkoi?
Marsh Posté le 13-07-2002 à 15:46:02
fastwrite pas utile
boot sur diskette win98 sans prise en charge cd t'aura + de mem...
ensuite insere ta diskette avec le flash et a:aminf332.exe CHB0429.ROM
Marsh Posté le 13-07-2002 à 15:51:35
desoler de mon acharnement mais :
je suis sous xp, comment je fait pour creer une disquette boot 98?
Marsh Posté le 13-07-2002 à 16:12:47
c est ce que j ai fait:
boot sans prose en charge du lecteur cd
je lance la procedure de flash:
Chipset type: SiS 735
Flash Part: Winbond 49F002 (on un truc du genre)
ERROR5 ........
Marsh Posté le 13-07-2002 à 16:15:43
pentier il est trop fort
il est trop beau
son site il est trop bien
pentier je t'aime
Marsh Posté le 13-07-2002 à 16:16:39
a mon avis mon fichier ROM ne dois pas etre de la bonne taille
ou alors je teste avec la version amin 3.29
un peu d aide svp
Marsh Posté le 13-07-2002 à 16:36:58
j ai flashé avec le 3.29 et ca a marcher
bon maitnenant les chose serieuses
j aurai (je croi) encore besoin de vous
Marsh Posté le 13-07-2002 à 16:49:19
bon bah voila athlon xp 1600+@1900+
2*150 sans plantages (pour le moment)
par contre comment on vire la page de boot au demarrage, pour revenir comme avant (j aime bien voir mon matos charger dans le bios)
et encore un truc, apres le 150 je pue tester koi?
temperature cpu 42° c est beaucoup?
Marsh Posté le 13-07-2002 à 21:03:04
pcever a écrit a écrit : Option logo dans le bios : disable 42 deg. c'est bon ![]() |
j'ai beau chercher je la trouve pas cette option de *erde
Marsh Posté le 22-07-2002 à 12:33:28
fo appuyer sur tab pdt le boot...c tout!
Marsh Posté le 22-07-2002 à 13:31:44
Au passage quel version de bios OC utilisez vous? celle avec Fast write ou sans,différences?
Marsh Posté le 12-07-2002 à 15:17:43
Release notes:
100/100 MHz
100/133 MHz
112/112 MHz
124/124 MHz
138/138 MHz
150/150 MHz
133/100 MHz
143/143 MHz
147/147 MHz
133/166 MHz
160/120 MHz
200/200 MHz
Athlon 1800+@2000+
11.5x147=1690
