Quel est le meilleur parmi UMAX Astra 1200 S et HP Scanjet 4c ?
Quel est le meilleur parmi UMAX Astra 1200 S et HP Scanjet 4c ? - Hardware
Marsh Posté le 30-06-2003 à 18:08:39
Quel scanner choisir parmi ceux 2 sachant ceci :
ASTRA Umax 1200 S
Type Color Flatbed
Method Single-pass, 30-bit color with BET
Element Color CCD
Light Source Cold Cathode Lamp
Hardware Resolution 600 dpi x 1200 dpi
Maximum Interpolated Resolution 9600 dpi x 9600 dpi
Maximum Scan Size 8.5" x 14"
Document Size Legal, Letter, A4, A5, B5, Business Cards
I/O Buffer 512K
Scan Modes 30-bit color 10-bit gray scale 1-bit halftone 1-bit line art
Hardware Interface SCSI-2
Power Consumption 25 Watts
Voltage 100-240VAC
Frequency 50/60Hz
Dimensions 21.1" x 12.9" x 4.1"
Net Weight 12.8 lbs.
System Support Macintosh Windows 3.1 Windows 95 Windows 98 *Windows NT compatibility through the driver
Transparency Adapter OPTIONAL
HP Scanjet 4c
Scanner Type
 Flatbed, color and monochrome
Image Processing Options
 Dithering, thresholding, gamma adjustment, mirroring, data inversion, filtering, color correction, scaling, interpolation
Scanning Modes
 1-bit (black and white)
4-bit (16 grayscale levels)
8-bit (256 grayscale levels)
10-bit internal (1024 grayscale levels) automatically mapped to optimal 8-bit
24-bit (16.7 million colors)
30-bit internal automatically mapped to optimal 24-bit
Resolution
 2400 dpi enhanced resolution
600 dpi optical
Selectable Resolution
 12 to 2250 dpi at 100% scaling
HP AccuPage Technology
 Automatic page optimization for OCR, document management, and PC fax applications version 2.0 for PC, v 1.0 for Macintosh
Scanning Speeds
 Preview: 4 seconds
200 dpi, grayscale, letter size: 3.3 seconds
300 dpi, black and white, letter size: 7.5 seconds
600 dpi, color, letter size: 30 seconds
Scaling
 2 to 400% in 1% increments at 600-dpi (depends on resolution)
Color
 24-bit (16.7 million colors) external; 30-bit (1 billion colors) internal
Grayscale
 4-bit (16 grayscale levels) external
8-bit (256 grayscale levels) external
10-bit (1024 grayscale levels) internal
Maximum Document Size
 8.5 by 14 inches (215 x 356 mm)
Scanning Element
 Charged-coupled device
Light Source
 Single fluorescent lamp
Interface
 SCSI-2
ADF
 Yes, 50 pages
Comment départager ces deux scanners , lequel choisir ?
Marsh Posté le 01-07-2003 à 09:41:20
donnez moi au moins quels sont les paramètres à comparer ?
