Rétroéclairage LED, faible consommation, design sympa, 5ms et pas cher du tout.
Quelqu'un aurait plus d'infos?
Type 24" (23.6" viewable) Wide Color TFT Active Matrix LCD Display Area 20.5" horizontal x 11.5" vertical; 23.6" diagonal Resolution 1920x1080 Contrast Ratio 1000:1 (typ); 20,000,000:1 (dynamic) Viewing Angles 170º horizontal, 160º vertical @ contrast ratio > 10:1 Response Time 5ms (typ) Light Source Long life, 30,000 hrs. (typ) Brightness 300 cd/m2 (typ) Panel Surface Anti-glare, hard-coating (3H) VIDEO INPUT
Analog RGB analog (75 ohms, 0.7/1.0 Vp-p) Digital DVI-D (TMDS, 100 ohms) Frequency Fh: 24~83kHz, Fv: 50~76Hz Sync Separate Sync/Composite Sync/SOG COMPATIBILITY
PC VGA up to 1920x1080 non-interlaced Mac® Power Mac™ up to 1920x1080 CONNECTOR
Analog 15-pin mini D-sub (VGA) Digital DVI-D Power 3-pin plug (CEE22) Audio 3.5 mm audio in / 3.5 mm audio out AUDIO
Speakers 2x2.5-watt POWER
Voltage AC 100–240V (universal), 50/60Hz Consumption 23W (typ) ERGONOMICS
Tilt: Down 5º, Up 20º CONTROLS
Basic Power, 1, up, down, 2 OSD Auto Image Adjust, Contrast/Brightness, Input Select (D-SUB, DVI), Audio Adjust (Volume, mute), Color Adjust (sRGB, 9300K, 7500K, 6500K, 5000K, User Color [R, G, B]), Information, Manual Image Adjust (H/V Position, Horizontal Size, Fine Tune, Sharpness, Dynamic Contrast, Aspect Ratio, Display Mode, ECO Mode ), Setup Menu (Language, Resolution Notice, OSD Position, OSD Timeout, OSD Background, Auto Power Off, Sleep), Memory Recall OPERATING CONDITIONS
Temperature 32–104º F (0–40º C) Humidity 20–90% (non-condensing) DIMENSIONS (WxHxD)
Physical With Stand 22.3" x 17.4" x 8.4" (566.2mm x 443.2mm x 214.5mm) Physical Without Stand 22.3" x 14.5" x 2.0" (566.2mm x 369.5mm x 49.9mm) Packaging 25.6" x 20.4" x 5.2" (651mm x 518mm x 133mm) WEIGHT
Gross 13.7 lb. (6.2 kg) Net With Stand 9.9 lb. (4.5 kg) Net Without Stand 8.9 lb. (4.0 kg) REGULATIONS
LCD Display, power cable, audio cable, VGA cable, Quick Start Guide, ViewSonic Wizard CD (User Guide and drivers) WARRANTY
Three-year limited warranty on parts, labor and backlight
Message édité par Juicy le 07-02-2011 à 19:57:16
--------------- Notre loi se résume en ces mots : faites ce que vous avez à faire. La satisfaction s'obtient en utilisant le pouvoir pour changer le monde. Les moyens justifient la fin. Seul l'echec est inacceptable.
Marsh Posté le 07-02-2011 à 19:56:25
http://www.viewsonic.com/products/ [...] 0wmled.htm
Je cherche des infos sur le Viewsonic VX2450wm-LED.
il semble avoir assez bonne presse/avis : http://www.testfreaks.fr/moniteurs/viewsonic-vx2450wm/
VIDEO INPUT
COMPATIBILITY
CONNECTOR
Digital DVI-D
AUDIO
Speakers 2x2.5-watt
POWER
ERGONOMICS
CONTROLS
DIMENSIONS (WxHxD)
WEIGHT
REGULATIONS
BSMI, CCC, PSB, C-Tick, KC, e-standby, CE, Ergo, Gost-R/Hygienic, Ukraine, SASO, UL/cUL, FCC-B, ICES-B,TUV-S/UL-AR S Mark, NOM, WEEE, RoHS
WALL MOUNT
VESA® 100mm x 100mm
POWER MANAGEMENT
ENERGY STAR® standards
PACKAGE CONTENTS
WARRANTY
