Help pour installation Theme KDE 3 plz...
Help pour installation Theme KDE 3 plz... - Débats - Linux et OS Alternatifs
Marsh Posté le 16-10-2002 à 18:50:39
Pas tapper je suis Newbee  :D
Bon oui je lis les readme et les autres posts du forum mais ya probleme qd même.
J'ai dl mon theme je l'ai décompressé... Déjà pas de "fichier theme" donc pas moyen d'utiliser le Gestionnaire de Thèmes (ds look and feel).
Donc je vais ds mon dossier et je fait
su root (pour etre en root deès le depart)
make -f Makefile.cvs (là tt va bien)
This Makefile is only for the CVS repository
This will be deleted before making the distribution
*** YOU'RE USING AUTOCONF 2.13. We suggest updating
*** autocnf 2.52 works best for now, we will drop
*** support for autoconf 2.13 soon
*** Creating acinclude.m4
!!! If you get recursion errors from autoconf, it is advisable to set the
    environment variable M4 to something including "--nesting-limit=500"
*** Creating list of subdirectories
*** Creating configure.in
*** Creating aclocal.m4
*** Creating config.h template
*** Creating Makefile templates
*** Postprocessing Makefile templates
*** Creating date/time stamp
*** Finished
    Don't forget to run ./configure
    If you haven't done so in a while, run ./configure --help
Bon...
Je fait ./configure --prefix=/coockie (coockie c mon nome de session sous KDE)
loading cache ./config.cache
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking build system type... i686-pc-linux-gnu
checking for a BSD compatible install... (cached) /usr/bin/install -c
checking for -p flag to install... yes
checking whether build environment is sane... yes
checking whether make sets ${MAKE}... (cached) yes
checking for working aclocal-1.4... found
checking for working autoconf... found
checking for working automake-1.4... found
checking for working autoheader... found
checking for working makeinfo... found
checking for gcc... (cached) gcc
checking whether the C compiler (gcc   ) works... yes
checking whether the C compiler (gcc   ) is a cross-compiler... no
checking whether we are using GNU C... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking how to run the C preprocessor... (cached) gcc -E
checking for c++... (cached) c++
checking whether the C++ compiler (c++   ) works... yes
checking whether the C++ compiler (c++   ) is a cross-compiler... no
checking whether we are using GNU C++... (cached) yes
checking whether c++ accepts -g... (cached) yes
checking whether c++ supports -fno-exceptions... (cached) yes
checking whether c++ supports -fno-check-new... (cached) yes
checking whether c++ supports -fexceptions... (cached) yes
checking how to run the C++ preprocessor... (cached) c++ -E
checking whether c++ supports -frepo... (cached) yes
checking for ld used by GCC... (cached) /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... (cached) yes
checking for /usr/bin/ld option to reload object files... (cached) -r
checking for BSD-compatible nm... (cached) /usr/bin/nm -B
checking whether ln -s works... (cached) yes
checking how to recognise dependant libraries... (cached) pass_all
checking for ranlib... (cached) ranlib
checking for strip... (cached) strip
checking for Cygwin environment... (cached) no
checking for mingw32 environment... (cached) no
loading cache ./config.cache within ltconfig
checking whether -lc should be explicitly linked in... (cached) yes
checking for objdir... .libs
checking for gcc option to produce PIC...  -fPIC -DPIC
checking if gcc PIC flag  -fPIC -DPIC works... (cached) yes
checking if gcc static flag  works... (cached) no
finding the maximum length of command line arguments... (cached) 73729
checking if gcc supports -c -o file.o... (cached) yes
checking if gcc supports -fno-rtti -fno-exceptions ... yes
checking whether the linker (/usr/bin/ld) supports shared libraries... yes
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking command to parse /usr/bin/nm -B output... ok
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
checking for dlfcn.h... (cached) yes
checking whether a program can dlopen itself... (cached) yes
checking whether a statically linked program can dlopen itself... (cached) yes
creating libtool
ltcf-cxx: with_gcc=yes ; with_gnu_ld=yes
checking for c++ option to produce PIC... -fPIC -DPIC
checking if c++ PIC flag -fPIC -DPIC works... yes
checking if c++ static flag -static works... no
checking if c++ supports -c -o file.o... (cached) yes
checking if c++ supports -fno-rtti -fno-exceptions ... yes
appending configuration tag "CXX" to libtool
checking for object suffix... o
checking for executable suffix... no
checking for msgfmt... /usr/bin/msgfmt
checking for gmsgfmt... /usr/bin/msgfmt
checking for xgettext... /usr/bin/xgettext
checking for main in -lutil... yes
checking for main in -lcompat... no
checking for crypt in -lcrypt... yes
checking for socklen_t... socklen_t
checking for dnet_ntoa in -ldnet... no
checking for dnet_ntoa in -ldnet_stub... no
checking for inet_ntoa... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for res_init... no
checking for killpg in -lucb... no
checking size of int... 4
checking size of long... 4
checking size of char *... 4
checking size of char... 1
checking for dlopen in -ldl... (cached) yes
checking for shl_unload in -ldld... no
checking for extra includes... no
checking for extra libs... no
checking for libz... configure: error: not found. Check your installation and look into config.log
Voilà ce que ca donne. Bon il parle de lib donc il m'en manque peut etre mais lesquelles ???
Help plz
Marsh Posté le 16-10-2002 à 18:53:06
probablement libz...
a moins ke config.log dise autre chose...
si c une deb, apt-cache search libz, pis ensuite pat-get install nom_de_la_lib
"Je brandirai une épée d'orichalque, je m'assouvirai sur des Templiers." | "Avec dans son sillage l'Ombre du Diable, Leirn appelait les morts pour une danse macabre et déchainaît les horreurs de la nuit..."
Marsh Posté le 16-10-2002 à 18:57:02
J'ai pas compris grd chose :??: ... Mais bon, il est ou le log déjà ??
Marsh Posté le 17-10-2002 à 20:19:45
Un tt petit plus d'aide encore svp....
Si je n'arrive pas à regler ce problème je pourrais utiliser des thèmes avec ce fichier thème présent pour pouvoir utiliser l'installateur automatique.....
Mais ou donc trouver ces thèmes ?
Marsh Posté le 17-10-2002 à 20:24:36
vroum
Marsh Posté le 17-10-2002 à 20:33:37
EpoK a écrit a écrit :
vroum
Pouet pouet !
Oui, mais a part ca.... [:zeuartisan]
Marsh Posté le 18-10-2002 à 15:56:39
[:coockie_jr]
bioactif.net Un blog de bio et quoi encore...
