pb (bizarre) de fonts avec xfree 4.2.99.3 (debian)...
pb (bizarre) de fonts avec xfree 4.2.99.3 (debian)... - Installation - Linux et OS Alternatifs
Marsh Posté le 23-01-2003 à 09:51:34
salut,
j ai reinstalle une debian en unstable pour mettre xfree 4.2.99.3
le pb, c est que lorsque je teste ou lance X, il plante car il ne trouve pas les fonts "fixed" !
c est koi ces fonts??j en ai installe plusieurs mais rien n y fait :(
ke faire ??
voilou
ps : je vous donne mes fichiers XF86Config-4 et XFree86.0.log ;)
XF86Config-4:
  1. ### BEGIN DEBCONF SECTION
  2. # XF86Config-4 (XFree86 server configuration file) generated by dexconf, the
  3. # Debian X Configuration tool, using values from the debconf database.
  4. #
  5. # Edit this file with caution, and see the XF86Config-4 manual page.
  6. # (Type "man XF86Config-4" at the shell prompt.)
  7. #
  8. # If you want your changes to this file preserved by dexconf, only make changes
  9. # before the "### BEGIN DEBCONF SECTION" line above, and/or after the
  10. # "### END DEBCONF SECTION" line below.
  11. #
  12. # To change things within the debconf section, run the command:
  13. #   dpkg-reconfigure xserver-xfree86
  14. # as root.  Also see "How do I add custom sections to a dexconf-generated
  15. # XF86Config or XF86Config-4 file?" in /usr/share/doc/xfree86-common/FAQ.gz.
  16. Section "Files"
  17. #FontPath "unix/:7100"   # local font server
  18. # if the local font server has problems, we can fall back on these
  19. #FontPath "/usr/lib/X11/fonts/misc"
  20. FontPath "/usr/lib/X11/fonts/cyrillic"
  21. FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
  22. FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
  23. FontPath "/usr/lib/X11/fonts/Type1"
  24. FontPath "/usr/lib/X11/fonts/Speedo"
  25. FontPath "/usr/lib/X11/fonts/100dpi"
  26. FontPath "/usr/lib/X11/fonts/75dpi"
  27. EndSection
  28. Section "Module"
  29. Load "GLcore"
  30. Load "bitmap"
  31. Load "dbe"
  32. Load "ddc"
  33. Load "dri"
  34. Load "extmod"
  35. Load "freetype"
  36. Load "glx"
  37. Load "int10"
  38. Load "record"
  39. Load "speedo"
  40. Load "type1"
  41. Load "vbe"
  42. EndSection
  43. Section "InputDevice"
  44. Identifier "Generic Keyboard"
  45. Driver  "keyboard"
  46. Option  "CoreKeyboard"
  47. Option  "XkbRules" "xfree86"
  48. Option  "XkbModel" "pc105"
  49. Option  "XkbLayout" "fr"
  50. EndSection
  51. Section "InputDevice"
  52. Identifier "Configured Mouse"
  53. Driver  "mouse"
  54. #Option  "CorePointer"
  55. Option  "Device"  "/dev/psaux"
  56. Option  "Protocol"  "ImPS/2"
  57. #Option  "Emulate3Buttons" "true"
  58. Option  "ZAxisMapping"  "4 5"
  59. EndSection
  60. #Section "InputDevice"
  61. #Identifier "Generic Mouse"
  62. #Driver  "mouse"
  63. #Option  "SendCoreEvents" "true"
  64. #Option  "Device"  "/dev/input/mice"
  65. #Option  "Protocol"  "ImPS/2"
  66. #Option  "Emulate3Buttons" "true"
  67. #Option  "ZAxisMapping"  "4 5"
  68. #EndSection
  69. Section "Device"
  70. Identifier "Generic Video Card"
  71. Driver  "ati"
  72. #Option  "UseFBDev"  "true"
  73. EndSection
  74. Section "Monitor"
  75. Identifier "Generic Monitor"
  76. HorizSync 30-70
  77. VertRefresh 50-160
  78. Option  "DPMS"
  79. EndSection
  80. Section "Screen"
  81. Identifier "Default Screen"
  82. Device  "Generic Video Card"
  83. Monitor  "Generic Monitor"
  84. DefaultDepth 24
  85. SubSection "Display"
  86.  Depth  15
  87.  Modes  "1280x1024" "1024x768" "800x600" "640x480"
  88. EndSubSection
  89. SubSection "Display"
  90.  Depth  16
  91.  Modes  "1280x1024" "1024x768" "800x600" "640x480"
  92. EndSubSection
  93. SubSection "Display"
  94.  Depth  24
  95.  Modes  "1280x1024" "1024x768" "800x600" "640x480"
  96. EndSubSection
  97. EndSection
  98. Section "ServerLayout"
  99. Identifier "Default Layout"
  100. Screen  "Default Screen"
  101. InputDevice "Generic Keyboard"
  102. InputDevice "Configured Mouse"
  103. InputDevice "Generic Mouse"
  104. EndSection
  105. Section "DRI"
  106. Mode 0666
  107. EndSection
  108. ### END DEBCONF SECTION
Et le le log d XFree : XFree86.0.log
  1. This is a pre-release version of XFree86, and is not supported in any
  2. way.  Bugs may be reported to XFree86@XFree86.Org and patches submitted
  3. to fixes@XFree86.Org.  Before reporting bugs in pre-release versions,
  4. please check the latest version in the XFree86 CVS repository
  5. (http://www.XFree86.Org/cvs)
  6. XFree86 Version 4.2.99.3 (Debian 4.2.99.3-1 20030107194641 acid@abydos.naquadah.org) / X Window System
  7. (protocol Version 11, revision 0, vendor release 6600)
  8. Release Date: 21 December 2002
  9. If the server is older than 6-12 months, or if your card is
  10. newer than the above date, look for a newer version before
  11. reporting problems.  (See http://www.XFree86.Org/)
  12. Build Operating System: Linux 2.4.20-openmosix-1 i686 [ELF]
  13. Module Loader present
  14. Markers: (--) probed, (**) from config file, (==) default setting,
  15.          (++) from command line, (!!) notice, (II) informational,
  16.          (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
  17. (==) Log file: "/var/log/XFree86.0.log", Time: Wed Jan 22 19:49:51 2003
  18. (++) Using config file: "/root/XF86Config.new"
  19. (==) ServerLayout "XFree86 Configured"
  20. (**) |-->Screen "Screen0" (0)
  21. (**) |   |-->Monitor "Monitor0"
  22. (**) |   |-->Device "Card0"
  23. (**) |-->Input Device "Mouse0"
  24. (**) |-->Input Device "Keyboard0"
  25. (==) Keyboard: CustomKeycode disabled
  26. (WW) The directory "/usr/X11R6/lib/X11/fonts/misc/" does not exist.
  27. Entry deleted from font path.
  28. (WW) The directory "/usr/X11R6/lib/X11/fonts/Speedo/" does not exist.
  29. Entry deleted from font path.
  30. (WW) The directory "/usr/X11R6/lib/X11/fonts/Type1/" does not exist.
  31. Entry deleted from font path.
  32. (WW) The directory "/usr/X11R6/lib/X11/fonts/CID/" does not exist.
  33. Entry deleted from font path.
  34. (**) FontPath set to "/usr/X11R6/lib/X11/fonts/75dpi/,/usr/X11R6/lib/X11/fonts/100dpi/"
  35. (**) RgbPath set to "/usr/X11R6/lib/X11/rgb"
  36. (**) ModulePath set to "/usr/X11R6/lib/modules"
  37. (--) using VT number 7
  38. (WW) Open APM failed (/dev/apm_bios) (No such file or directory)
  39. Couldn't open RGB_DB '/usr/X11R6/lib/X11/rgb'
  40. (II) Module ABI versions:
  41. XFree86 ANSI C Emulation: 0.2
  42. XFree86 Video Driver: 0.6
  43. XFree86 XInput driver : 0.4
  44. XFree86 Server Extension : 0.2
  45. XFree86 Font Renderer : 0.4
  46. (II) Loader running on linux
  47. (II) LoadModule: "bitmap"
  48. (II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
  49. (II) Module bitmap: vendor="The XFree86 Project"
  50. compiled for 4.2.99.3, module version = 1.0.0
  51. Module class: XFree86 Font Renderer
  52. ABI class: XFree86 Font Renderer, version 0.4
  53. (II) Loading font Bitmap
  54. (II) LoadModule: "pcidata"
  55. (II) Loading /usr/X11R6/lib/modules/libpcidata.a
  56. (II) Module pcidata: vendor="The XFree86 Project"
  57. compiled for 4.2.99.3, module version = 1.0.0
  58. ABI class: XFree86 Video Driver, version 0.6
  59. (II) PCI: Probing config type using method 1
  60. (II) PCI: Config type is 1
  61. (II) PCI: stages = 0x03, oldVal1 = 0x00000000, mode1Res1 = 0x80000000
  62. (II) PCI: PCI scan (all values are in hex)
  63. (II) PCI: 00:00:0: chip 1106,0305 card 147b,a401 rev 03 class 06,00,00 hdr 00
  64. (II) PCI: 00:01:0: chip 1106,8305 card 0000,0000 rev 00 class 06,04,00 hdr 01
  65. (II) PCI: 00:07:0: chip 1106,0686 card 147b,0000 rev 22 class 06,01,00 hdr 80
  66. (II) PCI: 00:07:1: chip 1106,0571 card 1106,0571 rev 10 class 01,01,8a hdr 00
  67. (II) PCI: 00:07:4: chip 1106,3057 card 1106,3057 rev 30 class 06,80,00 hdr 00
  68. (II) PCI: 00:0b:0: chip 1106,3065 card 1186,1400 rev 43 class 02,00,00 hdr 00
  69. (II) PCI: 00:0d:0: chip 1073,0010 card 1073,0010 rev 02 class 04,01,00 hdr 00
  70. (II) PCI: 00:13:0: chip 1103,0004 card 1103,0001 rev 03 class 01,80,00 hdr 00
  71. (II) PCI: 01:00:0: chip 1002,514c card 1002,013a rev 00 class 03,00,00 hdr 00
  72. (II) PCI: End of PCI scan
  73. (II) Host-to-PCI bridge:
  74. (II) Bus 0: bridge is at (0:0:0), (0,0,1), BCTRL: 0x0008 (VGA_EN is set)
  75. (II) Bus 0 I/O range:
  76. [0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
  77. (II) Bus 0 non-prefetchable memory range:
  78. [0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
  79. (II) Bus 0 prefetchable memory range:
  80. [0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
  81. (II) PCI-to-PCI bridge:
  82. (II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x000c (VGA_EN is set)
  83. (II) Bus 1 I/O range:
  84. [0] -1 0 0x00009000 - 0x000090ff (0x100) IX[B]
  85. [1] -1 0 0x00009400 - 0x000094ff (0x100) IX[B]
  86. [2] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
  87. [3] -1 0 0x00009c00 - 0x00009cff (0x100) IX[B]
  88. (II) Bus 1 non-prefetchable memory range:
  89. [0] -1 0 0xec000000 - 0xedffffff (0x2000000) MX[B]
  90. (II) Bus 1 prefetchable memory range:
  91. [0] -1 0 0xe0000000 - 0xe7ffffff (0x8000000) MX[B]
  92. (II) PCI-to-ISA bridge:
  93. (II) Bus -1: bridge is at (0:7:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
  94. (--) PCI:*(1:0:0) ATI Technologies Inc Radeon R200 QL [Radeon 8500 LE] rev 0, Mem @ 0xe0000000/27, 0xed000000/16, I/O @ 0x9000/8
  95. (II) Addressable bus resource ranges are
  96. [0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
  97. [1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
  98. (II) OS-reported resource ranges:
  99. [0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
  100. [1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
  101. [2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
  102. [3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
  103. [4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
  104. [5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
  105. [6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
  106. (II) PCI Memory resource overlap reduced 0xe8000000 from 0xebffffff to 0xe7ffffff
  107. (II) Active PCI resource ranges:
  108. [0] -1 0 0xef000000 - 0xef007fff (0x8000) MX[B]
  109. [1] -1 0 0xef008000 - 0xef0080ff (0x100) MX[B]
  110. [2] -1 0 0xe8000000 - 0xe7ffffff (0x0) MX[B]O
  111. [3] -1 0 0xed000000 - 0xed00ffff (0x10000) MX[B](B)
  112. [4] -1 0 0xe0000000 - 0xe7ffffff (0x8000000) MX[B](B)
  113. [5] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
  114. [6] -1 0 0x0000c400 - 0x0000c403 (0x4) IX[B]
  115. [7] -1 0 0x0000c000 - 0x0000c007 (0x8) IX[B]
  116. [8] -1 0 0x0000bc00 - 0x0000bc03 (0x4) IX[B]
  117. [9] -1 0 0x0000b800 - 0x0000b807 (0x8) IX[B]
  118. [10] -1 0 0x0000b400 - 0x0000b403 (0x4) IX[B]
  119. [11] -1 0 0x0000b000 - 0x0000b03f (0x40) IX[B]
  120. [12] -1 0 0x0000ac00 - 0x0000acff (0x100) IX[B]
  121. [13] -1 0 0x0000a000 - 0x0000a00f (0x10) IX[B]
  122. [14] -1 0 0x00009000 - 0x000090ff (0x100) IX[B](B)
  123. (II) Active PCI resource ranges after removing overlaps:
  124. [0] -1 0 0xef000000 - 0xef007fff (0x8000) MX[B]
  125. [1] -1 0 0xef008000 - 0xef0080ff (0x100) MX[B]
  126. [2] -1 0 0xe8000000 - 0xe7ffffff (0x0) MX[B]O
  127. [3] -1 0 0xed000000 - 0xed00ffff (0x10000) MX[B](B)
  128. [4] -1 0 0xe0000000 - 0xe7ffffff (0x8000000) MX[B](B)
  129. [5] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
  130. [6] -1 0 0x0000c400 - 0x0000c403 (0x4) IX[B]
  131. [7] -1 0 0x0000c000 - 0x0000c007 (0x8) IX[B]
  132. [8] -1 0 0x0000bc00 - 0x0000bc03 (0x4) IX[B]
  133. [9] -1 0 0x0000b800 - 0x0000b807 (0x8) IX[B]
  134. [10] -1 0 0x0000b400 - 0x0000b403 (0x4) IX[B]
  135. [11] -1 0 0x0000b000 - 0x0000b03f (0x40) IX[B]
  136. [12] -1 0 0x0000ac00 - 0x0000acff (0x100) IX[B]
  137. [13] -1 0 0x0000a000 - 0x0000a00f (0x10) IX[B]
  138. [14] -1 0 0x00009000 - 0x000090ff (0x100) IX[B](B)
  139. (II) OS-reported resource ranges after removing overlaps with PCI:
  140. [0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
  141. [1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
  142. [2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
  143. [3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
  144. [4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
  145. [5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
  146. [6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
  147. (II) All system resource ranges:
  148. [0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
  149. [1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
  150. [2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
  151. [3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
  152. [4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
  153. [5] -1 0 0xef000000 - 0xef007fff (0x8000) MX[B]
  154. [6] -1 0 0xef008000 - 0xef0080ff (0x100) MX[B]
  155. [7] -1 0 0xe8000000 - 0xe7ffffff (0x0) MX[B]O
  156. [8] -1 0 0xed000000 - 0xed00ffff (0x10000) MX[B](B)
  157. [9] -1 0 0xe0000000 - 0xe7ffffff (0x8000000) MX[B](B)
  158. [10] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
  159. [11] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
  160. [12] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
  161. [13] -1 0 0x0000c400 - 0x0000c403 (0x4) IX[B]
  162. [14] -1 0 0x0000c000 - 0x0000c007 (0x8) IX[B]
  163. [15] -1 0 0x0000bc00 - 0x0000bc03 (0x4) IX[B]
  164. [16] -1 0 0x0000b800 - 0x0000b807 (0x8) IX[B]
  165. [17] -1 0 0x0000b400 - 0x0000b403 (0x4) IX[B]
  166. [18] -1 0 0x0000b000 - 0x0000b03f (0x40) IX[B]
  167. [19] -1 0 0x0000ac00 - 0x0000acff (0x100) IX[B]
  168. [20] -1 0 0x0000a000 - 0x0000a00f (0x10) IX[B]
  169. [21] -1 0 0x00009000 - 0x000090ff (0x100) IX[B](B)
  170. (II) LoadModule: "dbe"
  171. (II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
  172. (II) Module dbe: vendor="The XFree86 Project"
  173. compiled for 4.2.99.3, module version = 1.0.0
  174. Module class: XFree86 Server Extension
  175. ABI class: XFree86 Server Extension, version 0.2
  176. (II) Loading extension DOUBLE-BUFFER
  177. (II) LoadModule: "dri"
  178. (II) Loading /usr/X11R6/lib/modules/extensions/libdri.a
  179. (II) Module dri: vendor="The XFree86 Project"
  180. compiled for 4.2.99.3, module version = 1.0.0
  181. ABI class: XFree86 Server Extension, version 0.2
  182. (II) Loading sub module "drm"
  183. (II) LoadModule: "drm"
  184. (II) Loading /usr/X11R6/lib/modules/linux/libdrm.a
  185. (II) Module drm: vendor="The XFree86 Project"
  186. compiled for 4.2.99.3, module version = 1.0.0
  187. ABI class: XFree86 Server Extension, version 0.2
  188. (II) Loading extension XFree86-DRI
  189. (II) LoadModule: "extmod"
  190. (II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
  191. (II) Module extmod: vendor="The XFree86 Project"
  192. compiled for 4.2.99.3, module version = 1.0.0
  193. Module class: XFree86 Server Extension
  194. ABI class: XFree86 Server Extension, version 0.2
  195. (II) Loading extension SHAPE
  196. (II) Loading extension MIT-SUNDRY-NONSTANDARD
  197. (II) Loading extension BIG-REQUESTS
  198. (II) Loading extension SYNC
  199. (II) Loading extension MIT-SCREEN-SAVER
  200. (II) Loading extension XC-MISC
  201. (II) Loading extension XFree86-VidModeExtension
  202. (II) Loading extension XFree86-Misc
  203. (II) Loading extension XFree86-DGA
  204. (II) Loading extension DPMS
  205. (II) Loading extension FontCache
  206. (II) Loading extension TOG-CUP
  207. (II) Loading extension Extended-Visual-Information
  208. (II) Loading extension XVideo
  209. (II) Loading extension XVideo-MotionCompensation
  210. (II) Loading extension X-Resource
  211. (II) LoadModule: "glx"
  212. (II) Loading /usr/X11R6/lib/modules/extensions/libglx.a
  213. (II) Module glx: vendor="The XFree86 Project"
  214. compiled for 4.2.99.3, module version = 1.0.0
  215. ABI class: XFree86 Server Extension, version 0.2
  216. (II) Loading sub module "GLcore"
  217. (II) LoadModule: "GLcore"
  218. (II) Loading /usr/X11R6/lib/modules/extensions/libGLcore.a
  219. (II) Module GLcore: vendor="The XFree86 Project"
  220. compiled for 4.2.99.3, module version = 1.0.0
  221. ABI class: XFree86 Server Extension, version 0.2
  222. (II) Loading extension GLX
  223. (II) LoadModule: "record"
  224. (II) Loading /usr/X11R6/lib/modules/extensions/librecord.a
  225. (II) Module record: vendor="The XFree86 Project"
  226. compiled for 4.2.99.3, module version = 1.13.0
  227. Module class: XFree86 Server Extension
  228. ABI class: XFree86 Server Extension, version 0.2
  229. (II) Loading extension RECORD
  230. (II) LoadModule: "xtrap"
  231. (II) Loading /usr/X11R6/lib/modules/extensions/libxtrap.a
  232. (II) Module xtrap: vendor="The XFree86 Project"
  233. compiled for 4.2.99.3, module version = 1.0.0
  234. Module class: XFree86 Server Extension
  235. ABI class: XFree86 Server Extension, version 0.2
  236. (II) Loading extension DEC-XTRAP
  237. (II) LoadModule: "speedo"
  238. (II) Loading /usr/X11R6/lib/modules/fonts/libspeedo.a
  239. (II) Module speedo: vendor="The XFree86 Project"
  240. compiled for 4.2.99.3, module version = 1.0.1
  241. Module class: XFree86 Font Renderer
  242. ABI class: XFree86 Font Renderer, version 0.4
  243. (II) Loading font Speedo
  244. (II) LoadModule: "type1"
  245. (II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
  246. (II) Module type1: vendor="The XFree86 Project"
  247. compiled for 4.2.99.3, module version = 1.0.2
  248. Module class: XFree86 Font Renderer
  249. ABI class: XFree86 Font Renderer, version 0.4
  250. (II) Loading font Type1
  251. (II) Loading font CID
  252. (II) LoadModule: "ati"
  253. (II) Loading /usr/X11R6/lib/modules/drivers/ati_drv.o
  254. (II) Module ati: vendor="The XFree86 Project"
  255. compiled for 4.2.99.3, module version = 6.4.17
  256. Module class: XFree86 Video Driver
  257. ABI class: XFree86 Video Driver, version 0.6
  258. (II) LoadModule: "mouse"
  259. (II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
  260. (II) Module mouse: vendor="The XFree86 Project"
  261. compiled for 4.2.99.3, module version = 1.0.0
  262. Module class: XFree86 XInput Driver
  263. ABI class: XFree86 XInput driver, version 0.4
  264. (II) ATI: ATI driver (version 6.4.17) for chipsets: ati, ativga
  265. (II) R128: Driver for ATI Rage 128 chipsets: ATI Rage 128 RE (PCI),
  266. ATI Rage 128 RF (AGP), ATI Rage 128 RG (AGP), ATI Rage 128 RK (PCI),
  267. ATI Rage 128 RL (AGP), ATI Rage 128 SM (AGP),
  268. ATI Rage 128 Pro PD (PCI), ATI Rage 128 Pro PF (AGP),
  269. ATI Rage 128 Pro PP (PCI), ATI Rage 128 Pro PR (PCI),
  270. ATI Rage 128 Pro ULTRA TF (AGP), ATI Rage 128 Pro ULTRA TL (AGP),
  271. ATI Rage 128 Pro ULTRA TR (AGP), ATI Rage 128 Mobility LE (PCI),
  272. ATI Rage 128 Mobility LF (AGP), ATI Rage 128 Mobility MF (AGP),
  273. ATI Rage 128 Mobility ML (AGP)
  274. (II) RADEON: Driver for ATI Radeon chipsets: ATI Radeon QD (AGP),
  275. ATI Radeon QE (AGP), ATI Radeon QF (AGP), ATI Radeon QG (AGP),
  276. ATI Radeon VE QY (AGP), ATI Radeon VE QZ (AGP),
  277. ATI Radeon Mobility M7 LW (AGP), ATI Radeon Mobility M7 LX (AGP),
  278. ATI Radeon Mobility M6 LY (AGP), ATI Radeon Mobility M6 LZ (AGP),
  279. ATI Radeon 8500 QL (AGP), ATI Radeon 8500 QN (AGP),
  280. ATI Radeon 8500 QO (AGP), ATI Radeon 8500 Ql (AGP),
  281. ATI Radeon 8500 BB (AGP), ATI Radeon 7500 QW (AGP),
  282. ATI Radeon 7500 QX (AGP), ATI Radeon 9000 Id (AGP),
  283. ATI Radeon 9000 Ie (AGP), ATI Radeon 9000 If (AGP),
  284. ATI Radeon 9000 Ig (AGP), ATI Radeon Mobility M9 Ld (AGP),
  285. ATI Radeon Mobility M9 Le (AGP), ATI Radeon Mobility M9 Lf (AGP),
  286. ATI Radeon Mobility M9 Lg (AGP), ATI Radeon 9700 ND (AGP),
  287. ATI Radeon 9700 NE (AGP), ATI Radeon 9700 NF (AGP),
  288. ATI Radeon 9700 NG (AGP)
  289. (II) Primary Device is: PCI 01:00:0
  290. (II) ATI:  Candidate "Device" section "Card0".
  291. (--) Chipset ATI Radeon 8500 QL (AGP) found
  292. (II) resource ranges after xf86ClaimFixedResources() call:
  293. [0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
  294. [1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
  295. [2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
  296. [3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
  297. [4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
  298. [5] -1 0 0xef000000 - 0xef007fff (0x8000) MX[B]
  299. [6] -1 0 0xef008000 - 0xef0080ff (0x100) MX[B]
  300. [7] -1 0 0xe8000000 - 0xe7ffffff (0x0) MX[B]O
  301. [8] -1 0 0xed000000 - 0xed00ffff (0x10000) MX[B](B)
  302. [9] -1 0 0xe0000000 - 0xe7ffffff (0x8000000) MX[B](B)
  303. [10] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
  304. [11] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
  305. [12] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
  306. [13] -1 0 0x0000c400 - 0x0000c403 (0x4) IX[B]
  307. [14] -1 0 0x0000c000 - 0x0000c007 (0x8) IX[B]
  308. [15] -1 0 0x0000bc00 - 0x0000bc03 (0x4) IX[B]
  309. [16] -1 0 0x0000b800 - 0x0000b807 (0x8) IX[B]
  310. [17] -1 0 0x0000b400 - 0x0000b403 (0x4) IX[B]
  311. [18] -1 0 0x0000b000 - 0x0000b03f (0x40) IX[B]
  312. [19] -1 0 0x0000ac00 - 0x0000acff (0x100) IX[B]
  313. [20] -1 0 0x0000a000 - 0x0000a00f (0x10) IX[B]
  314. [21] -1 0 0x00009000 - 0x000090ff (0x100) IX[B](B)
  315. (II) Loading sub module "radeon"
  316. (II) LoadModule: "radeon"
  317. (II) Loading /usr/X11R6/lib/modules/drivers/radeon_drv.o
  318. (II) Module radeon: vendor="The XFree86 Project"
  319. compiled for 4.2.99.3, module version = 4.0.1
  320. Module class: XFree86 Video Driver
  321. ABI class: XFree86 Video Driver, version 0.6
  322. (II) resource ranges after probing:
  323. [0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
  324. [1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
  325. [2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
  326. [3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
  327. [4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
  328. [5] -1 0 0xef000000 - 0xef007fff (0x8000) MX[B]
  329. [6] -1 0 0xef008000 - 0xef0080ff (0x100) MX[B]
  330. [7] -1 0 0xe8000000 - 0xe7ffffff (0x0) MX[B]O
  331. [8] -1 0 0xed000000 - 0xed00ffff (0x10000) MX[B](B)
  332. [9] -1 0 0xe0000000 - 0xe7ffffff (0x8000000) MX[B](B)
  333. [10] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
  334. [11] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
  335. [12] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
  336. [13] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
  337. [14] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
  338. [15] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
  339. [16] -1 0 0x0000c400 - 0x0000c403 (0x4) IX[B]
  340. [17] -1 0 0x0000c000 - 0x0000c007 (0x8) IX[B]
  341. [18] -1 0 0x0000bc00 - 0x0000bc03 (0x4) IX[B]
  342. [19] -1 0 0x0000b800 - 0x0000b807 (0x8) IX[B]
  343. [20] -1 0 0x0000b400 - 0x0000b403 (0x4) IX[B]
  344. [21] -1 0 0x0000b000 - 0x0000b03f (0x40) IX[B]
  345. [22] -1 0 0x0000ac00 - 0x0000acff (0x100) IX[B]
  346. [23] -1 0 0x0000a000 - 0x0000a00f (0x10) IX[B]
  347. [24] -1 0 0x00009000 - 0x000090ff (0x100) IX[B](B)
  348. [25] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
  349. [26] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
  350. (II) Setting vga for screen 0.
  351. (II) Loading sub module "vgahw"
  352. (II) LoadModule: "vgahw"
  353. (II) Loading /usr/X11R6/lib/modules/libvgahw.a
  354. (II) Module vgahw: vendor="The XFree86 Project"
  355. compiled for 4.2.99.3, module version = 0.1.0
  356. ABI class: XFree86 Video Driver, version 0.6
  357. (II) RADEON(0): vgaHWGetIOBase: hwp->IOBase is 0x03d0, hwp->PIOOffset is 0x0000
  358. (II) RADEON(0): PCI bus 1 card 0 func 0
  359. (==) RADEON(0): Depth 8, (==) framebuffer bpp 8
  360. (II) RADEON(0): Pixel depth = 8 bits stored in 1 byte (8 bpp pixmaps)
  361. (==) RADEON(0): Default visual is PseudoColor
  362. (II) RADEON(0): Using 8 bits per RGB (8 bit DAC)
  363. (II) Loading sub module "int10"
  364. (II) LoadModule: "int10"
  365. (II) Loading /usr/X11R6/lib/modules/linux/libint10.a
  366. (II) Module int10: vendor="The XFree86 Project"
  367. compiled for 4.2.99.3, module version = 1.0.0
  368. ABI class: XFree86 Video Driver, version 0.6
  369. (II) RADEON(0): initializing int10
  370. (WW) RADEON(0): Bad V_BIOS checksum
  371. (II) RADEON(0): Primary V_BIOS segment is: 0xc000
  372. (WW) RADEON(0): Restoring MEM_CNTL (00000000), setting to 2d002d01
  373. (WW) RADEON(0): Restoring CONFIG_MEMSIZE (04000000), setting to 04000000
  374. (WW) RADEON(0): Restoring MPP_TB_CONFIG<31:24> (04), setting to 01
  375. (--) RADEON(0): Chipset: "ATI Radeon 8500 QL (AGP)" (ChipID = 0x514c)
  376. (--) RADEON(0): Linear framebuffer at 0xe0000000
  377. (--) RADEON(0): MMIO registers at 0xed000000
  378. (--) RADEON(0): VideoRAM: 65536 kByte (64-bit DDR SDRAM)
  379. (II) RADEON(0): CloneDisplay option not set -- defaulting to auto-detect
  380. (II) RADEON(0): Primary Display == Type 1
  381. (II) Loading sub module "ddc"
  382. (II) LoadModule: "ddc"
  383. (II) Loading /usr/X11R6/lib/modules/libddc.a
  384. (II) Module ddc: vendor="The XFree86 Project"
  385. compiled for 4.2.99.3, module version = 1.0.0
  386. ABI class: XFree86 Video Driver, version 0.6
  387. (II) Loading sub module "i2c"
  388. (II) LoadModule: "i2c"
  389. (II) Loading /usr/X11R6/lib/modules/libi2c.a
  390. (II) Module i2c: vendor="The XFree86 Project"
  391. compiled for 4.2.99.3, module version = 1.2.0
  392. ABI class: XFree86 Video Driver, version 0.6
  393. (II) RADEON(0): I2C bus "DDC" initialized.
  394. (II) RADEON(0): PLL parameters: rf=2700 rd=12 min=20000 max=35000; xclk=27500
  395. (==) RADEON(0): Using gamma correction (1.0, 1.0, 1.0)
  396. (II) RADEON(0): Validating modes on Primary head (DDCType: 3) ---------
  397. (II) RADEON(0): I2C device "DDC:ddc2" registered at address 0xA0.
  398. (II) RADEON(0): I2C device "DDC:ddc2" removed.
  399. (II) RADEON(0): I2C device "DDC:ddc2" registered at address 0xA0.
  400. (II) RADEON(0): I2C device "DDC:ddc2" removed.
  401. (II) RADEON(0): I2C EDID Info:
  402. (II) RADEON(0): Manufacturer: API  Model: 9808  Serial#: 13916
  403. (II) RADEON(0): Year: 2000  Week: 25
  404. (II) RADEON(0): EDID Version: 1.2
  405. (II) RADEON(0): Analog Display Input,  Input Voltage Level: 0.700/0.300 V
  406. (II) RADEON(0): Sync:  Separate  Composite
  407. (II) RADEON(0): Max H-Image Size [cm]: horiz.: 31  vert.: 23
  408. (II) RADEON(0): Gamma: 3.00
  409. (II) RADEON(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
  410. (II) RADEON(0): First detailed timing is preferred mode
  411. (II) RADEON(0): redX: 0.635 redY: 0.333   greenX: 0.284 greenY: 0.604
  412. (II) RADEON(0): blueX: 0.151 blueY: 0.067   whiteX: 0.280 whiteY: 0.311
  413. (II) RADEON(0): Supported VESA Video Modes:
  414. (II) RADEON(0): 720x400@70Hz
  415. (II) RADEON(0): 640x480@60Hz
  416. (II) RADEON(0): 640x480@72Hz
  417. (II) RADEON(0): 640x480@75Hz
  418. (II) RADEON(0): 800x600@56Hz
  419. (II) RADEON(0): 800x600@60Hz
  420. (II) RADEON(0): 800x600@72Hz
  421. (II) RADEON(0): 800x600@75Hz
  422. (II) RADEON(0): 1024x768@60Hz
  423. (II) RADEON(0): 1024x768@70Hz
  424. (II) RADEON(0): 1024x768@75Hz
  425. (II) RADEON(0): Manufacturer's mask: 0
  426. (II) RADEON(0): Supported Future Video Modes:
  427. (II) RADEON(0): #0: hsize: 800  vsize 600  refresh: 85  vid: 22853
  428. (II) RADEON(0): #1: hsize: 1024  vsize 768  refresh: 85  vid: 22881
  429. (II) RADEON(0): #2: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
  430. (II) RADEON(0): Supported additional Video Mode:
  431. (II) RADEON(0): clock: 94.5 MHz   Image Size:  310 x 230 mm
  432. (II) RADEON(0): h_active: 1024  h_sync: 1072  h_sync_end 1168 h_blank_end 1376 h_border: 0
  433. (II) RADEON(0): v_active: 768  v_sync: 769  v_sync_end 772 v_blanking: 808 v_border: 0
  434. (II) RADEON(0): Monitor name: Acer 77e
  435. (II) RADEON(0): Serial No: 13916
  436. (II) RADEON(0): Ranges: V min: 50  V max: 120 Hz, H min: 30  H max: 72 kHz, PixClock max 110 MHz
  437. (II) RADEON(0): End of DDC Monitor info
  438. (II) RADEON(0): Monitor0: Using hsync range of 30.00-72.00 kHz
  439. (II) RADEON(0): Monitor0: Using vrefresh range of 50.00-120.00 Hz
  440. (II) RADEON(0): Clock range:  20.00 to 350.00 MHz
  441. (II) RADEON(0): Not using default mode "320x175" (bad mode clock/interlace/doublescan)
  442. (II) RADEON(0): Not using default mode "320x200" (bad mode clock/interlace/doublescan)
  443. (II) RADEON(0): Not using default mode "360x200" (bad mode clock/interlace/doublescan)
  444. (II) RADEON(0): Not using default mode "320x240" (bad mode clock/interlace/doublescan)
  445. (II) RADEON(0): Not using default mode "320x240" (bad mode clock/interlace/doublescan)
  446. (II) RADEON(0): Not using default mode "320x240" (bad mode clock/interlace/doublescan)
  447. (II) RADEON(0): Not using default mode "320x240" (bad mode clock/interlace/doublescan)
  448. (II) RADEON(0): Not using default mode "400x300" (bad mode clock/interlace/doublescan)
  449. (II) RADEON(0): Not using default mode "1280x960" (hsync out of range)
  450. (II) RADEON(0): Not using default mode "640x480" (hsync out of range)
  451. (II) RADEON(0): Not using default mode "1280x1024" (hsync out of range)
  452. (II) RADEON(0): Not using default mode "640x512" (hsync out of range)
  453. (II) RADEON(0): Not using default mode "1280x1024" (hsync out of range)
  454. (II) RADEON(0): Not using default mode "640x512" (hsync out of range)
  455. (II) RADEON(0): Not using default mode "1600x1200" (hsync out of range)
  456. (II) RADEON(0): Not using default mode "800x600" (hsync out of range)
  457. (II) RADEON(0): Not using default mode "1600x1200" (hsync out of range)
  458. (II) RADEON(0): Not using default mode "800x600" (hsync out of range)
  459. (II) RADEON(0): Not using default mode "1600x1200" (hsync out of range)
  460. (II) RADEON(0): Not using default mode "800x600" (hsync out of range)
  461. (II) RADEON(0): Not using default mode "1600x1200" (hsync out of range)
  462. (II) RADEON(0): Not using default mode "800x600" (hsync out of range)
  463. (II) RADEON(0): Not using default mode "1600x1200" (hsync out of range)
  464. (II) RADEON(0): Not using default mode "800x600" (hsync out of range)
  465. (II) RADEON(0): Not using default mode "1792x1344" (hsync out of range)
  466. (II) RADEON(0): Not using default mode "896x672" (hsync out of range)
  467. (II) RADEON(0): Not using default mode "1792x1344" (hsync out of range)
  468. (II) RADEON(0): Not using default mode "896x672" (hsync out of range)
  469. (II) RADEON(0): Not using default mode "1856x1392" (hsync out of range)
  470. (II) RADEON(0): Not using default mode "928x696" (hsync out of range)
  471. (II) RADEON(0): Not using default mode "1856x1392" (hsync out of range)
  472. (II) RADEON(0): Not using default mode "928x696" (hsync out of range)
  473. (II) RADEON(0): Not using default mode "1920x1440" (hsync out of range)
  474. (II) RADEON(0): Not using default mode "960x720" (hsync out of range)
  475. (II) RADEON(0): Not using default mode "1920x1440" (hsync out of range)
  476. (II) RADEON(0): Not using default mode "960x720" (hsync out of range)
  477. (WW) (1400x1050,Monitor0) mode clock 122MHz exceeds DDC maximum 110MHz
  478. (II) RADEON(0): Not using default mode "1400x1050" (hsync out of range)
  479. (II) RADEON(0): Not using default mode "700x525" (hsync out of range)
  480. (II) RADEON(0): Not using default mode "1920x1440" (hsync out of range)
  481. (II) RADEON(0): Not using default mode "960x720" (hsync out of range)
  482. (II) RADEON(0): Not using default mode "2048x1536" (hsync out of range)
  483. (II) RADEON(0): Not using default mode "1024x768" (hsync out of range)
  484. (II) RADEON(0): Not using default mode "2048x1536" (hsync out of range)
  485. (II) RADEON(0): Not using default mode "1024x768" (hsync out of range)
  486. (II) RADEON(0): Not using default mode "2048x1536" (bad mode clock/interlace/doublescan)
  487. (II) RADEON(0): Not using default mode "1024x768" (hsync out of range)
  488. (--) RADEON(0): Virtual size is 1400x1050 (pitch 1408)
  489. (**) RADEON(0): *Default mode "1400x1050": 122.0 MHz, 64.9 kHz, 60.0 Hz
  490. (II) RADEON(0): Modeline "1400x1050"  122.00  1400 1488 1640 1880  1050 1052 1064 1082 +hsync +vsync
  491. (**) RADEON(0): *Default mode "1280x1024": 108.0 MHz, 64.0 kHz, 60.0 Hz
  492. (II) RADEON(0): Modeline "1280x1024"  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync
  493. (**) RADEON(0): *Default mode "1280x960": 108.0 MHz, 60.0 kHz, 60.0 Hz
  494. (II) RADEON(0): Modeline "1280x960"  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync
  495. (**) RADEON(0): *Default mode "1152x864": 108.0 MHz, 67.5 kHz, 75.0 Hz
  496. (II) RADEON(0): Modeline "1152x864"  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync
  497. (**) RADEON(0): *Default mode "1152x768": 65.0 MHz, 44.2 kHz, 54.8 Hz
  498. (II) RADEON(0): Modeline "1152x768"   65.00  1152 1178 1314 1472  768 771 777 806 +hsync +vsync
  499. (**) RADEON(0): *Default mode "1024x768": 94.5 MHz, 68.7 kHz, 85.0 Hz
  500. (II) RADEON(0): Modeline "1024x768"   94.50  1024 1072 1168 1376  768 769 772 808 +hsync +vsync
  501. (**) RADEON(0): *Default mode "1024x768": 78.8 MHz, 60.1 kHz, 75.1 Hz
  502. (II) RADEON(0): Modeline "1024x768"   78.80  1024 1040 1136 1312  768 769 772 800 +hsync +vsync
  503. (**) RADEON(0): *Default mode "1024x768": 75.0 MHz, 56.5 kHz, 70.1 Hz
  504. (II) RADEON(0): Modeline "1024x768"   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync
  505. (**) RADEON(0): *Default mode "1024x768": 65.0 MHz, 48.4 kHz, 60.0 Hz
  506. (II) RADEON(0): Modeline "1024x768"   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync
  507. (**) RADEON(0): *Default mode "1024x768": 44.9 MHz, 35.5 kHz, 87.1 Hz (I)
  508. (II) RADEON(0): Modeline "1024x768"   44.90  1024 1032 1208 1264  768 768 776 817 interlace +hsync +vsync
  509. (**) RADEON(0): *Default mode "832x624": 57.3 MHz, 49.7 kHz, 74.6 Hz
  510. (II) RADEON(0): Modeline "832x624"   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync
  511. (**) RADEON(0): *Default mode "800x600": 56.3 MHz, 53.7 kHz, 85.1 Hz
  512. (II) RADEON(0): Modeline "800x600"   56.30  800 832 896 1048  600 601 604 631 +hsync +vsync
  513. (**) RADEON(0): *Default mode "800x600": 49.5 MHz, 46.9 kHz, 75.0 Hz
  514. (II) RADEON(0): Modeline "800x600"   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync
  515. (**) RADEON(0): *Default mode "800x600": 50.0 MHz, 48.1 kHz, 72.2 Hz
  516. (II) RADEON(0): Modeline "800x600"   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync
  517. (**) RADEON(0): *Default mode "800x600": 40.0 MHz, 37.9 kHz, 60.3 Hz
  518. (II) RADEON(0): Modeline "800x600"   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync
  519. (**) RADEON(0): *Default mode "800x600": 36.0 MHz, 35.2 kHz, 56.2 Hz
  520. (II) RADEON(0): Modeline "800x600"   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync
  521. (**) RADEON(0): *Default mode "700x525": 61.0 MHz, 64.9 kHz, 60.0 Hz (D)
  522. (II) RADEON(0): Modeline "700x525"   61.00  700 744 820 940  525 526 532 541 doublescan +hsync +vsync
  523. (**) RADEON(0): *Default mode "640x512": 54.0 MHz, 64.0 kHz, 60.0 Hz (D)
  524. (II) RADEON(0): Modeline "640x512"   54.00  640 664 720 844  512 512 514 533 doublescan +hsync +vsync
  525. (**) RADEON(0): *Default mode "640x480": 36.0 MHz, 43.3 kHz, 85.0 Hz
  526. (II) RADEON(0): Modeline "640x480"   36.00  640 696 752 832  480 481 484 509 -hsync -vsync
  527. (**) RADEON(0): *Default mode "640x480": 31.5 MHz, 37.5 kHz, 75.0 Hz
  528. (II) RADEON(0): Modeline "640x480"   31.50  640 656 720 840  480 481 484 500 -hsync -vsync
  529. (**) RADEON(0): *Default mode "640x480": 31.5 MHz, 37.9 kHz, 72.8 Hz
  530. (II) RADEON(0): Modeline "640x480"   31.50  640 664 704 832  480 489 491 520 -hsync -vsync
  531. (**) RADEON(0): *Default mode "640x480": 25.2 MHz, 31.5 kHz, 60.0 Hz
  532. (II) RADEON(0): Modeline "640x480"   25.20  640 656 752 800  480 490 492 525 -hsync -vsync
  533. (**) RADEON(0): *Default mode "640x480": 54.0 MHz, 60.0 kHz, 60.0 Hz (D)
  534. (II) RADEON(0): Modeline "640x480"   54.00  640 688 744 900  480 480 482 500 doublescan +hsync +vsync
  535. (**) RADEON(0): *Default mode "720x400": 35.5 MHz, 37.9 kHz, 85.0 Hz
  536. (II) RADEON(0): Modeline "720x400"   35.50  720 756 828 936  400 401 404 446 -hsync +vsync
  537. (**) RADEON(0): *Default mode "640x400": 31.5 MHz, 37.9 kHz, 85.1 Hz
  538. (II) RADEON(0): Modeline "640x400"   31.50  640 672 736 832  400 401 404 445 -hsync +vsync
  539. (**) RADEON(0): *Default mode "576x432": 54.0 MHz, 67.5 kHz, 75.0 Hz (D)
  540. (II) RADEON(0): Modeline "576x432"   54.00  576 608 672 800  432 432 434 450 doublescan +hsync +vsync
  541. (**) RADEON(0): *Default mode "640x350": 31.5 MHz, 37.9 kHz, 85.1 Hz
  542. (II) RADEON(0): Modeline "640x350"   31.50  640 672 736 832  350 382 385 445 +hsync -vsync
  543. (**) RADEON(0): *Default mode "576x384": 32.5 MHz, 44.2 kHz, 54.8 Hz (D)
  544. (II) RADEON(0): Modeline "576x384"   32.50  576 589 657 736  384 385 388 403 doublescan +hsync +vsync
  545. (**) RADEON(0): *Default mode "512x384": 47.2 MHz, 68.7 kHz, 85.0 Hz (D)
  546. (II) RADEON(0): Modeline "512x384"   47.25  512 536 584 688  384 384 386 404 doublescan +hsync +vsync
  547. (**) RADEON(0): *Default mode "512x384": 39.4 MHz, 60.1 kHz, 75.1 Hz (D)
  548. (II) RADEON(0): Modeline "512x384"   39.40  512 520 568 656  384 384 386 400 doublescan +hsync +vsync
  549. (**) RADEON(0): *Default mode "512x384": 37.5 MHz, 56.5 kHz, 70.1 Hz (D)
  550. (II) RADEON(0): Modeline "512x384"   37.50  512 524 592 664  384 385 388 403 doublescan -hsync -vsync
  551. (**) RADEON(0): *Default mode "512x384": 32.5 MHz, 48.4 kHz, 60.0 Hz (D)
  552. (II) RADEON(0): Modeline "512x384"   32.50  512 524 592 672  384 385 388 403 doublescan -hsync -vsync
  553. (**) RADEON(0): *Default mode "512x384": 22.4 MHz, 35.5 kHz, 87.1 Hz (D)
  554. (II) RADEON(0): Modeline "512x384"   22.45  512 516 604 632  384 384 388 409 interlace doublescan +hsync +vsync
  555. (**) RADEON(0): *Default mode "416x312": 28.6 MHz, 49.7 kHz, 74.7 Hz (D)
  556. (II) RADEON(0): Modeline "416x312"   28.64  416 432 464 576  312 312 314 333 doublescan -hsync -vsync
  557. (**) RADEON(0): *Default mode "400x300": 28.1 MHz, 53.7 kHz, 85.3 Hz (D)
  558. (II) RADEON(0): Modeline "400x300"   28.15  400 416 448 524  300 300 302 315 doublescan +hsync +vsync
  559. (**) RADEON(0): *Default mode "400x300": 24.8 MHz, 46.9 kHz, 75.1 Hz (D)
  560. (II) RADEON(0): Modeline "400x300"   24.75  400 408 448 528  300 300 302 312 doublescan +hsync +vsync
  561. (**) RADEON(0): *Default mode "400x300": 25.0 MHz, 48.1 kHz, 72.2 Hz (D)
  562. (II) RADEON(0): Modeline "400x300"   25.00  400 428 488 520  300 318 321 333 doublescan +hsync +vsync
  563. (**) RADEON(0): *Default mode "400x300": 20.0 MHz, 37.9 kHz, 60.3 Hz (D)
  564. (II) RADEON(0): Modeline "400x300"   20.00  400 420 484 528  300 300 302 314 doublescan +hsync +vsync
  565. (--) RADEON(0): Display dimensions: (310, 230) mm
  566. (--) RADEON(0): DPI set to (114, 115)
  567. (II) Loading sub module "fb"
  568. (II) LoadModule: "fb"
  569. (II) Loading /usr/X11R6/lib/modules/libfb.a
  570. (II) Module fb: vendor="The XFree86 Project"
  571. compiled for 4.2.99.3, module version = 1.0.0
  572. ABI class: XFree86 ANSI C Emulation, version 0.2
  573. (II) Loading sub module "ramdac"
  574. (II) LoadModule: "ramdac"
  575. (II) Loading /usr/X11R6/lib/modules/libramdac.a
  576. (II) Module ramdac: vendor="The XFree86 Project"
  577. compiled for 4.2.99.3, module version = 0.1.0
  578. ABI class: XFree86 Video Driver, version 0.6
  579. (II) Loading sub module "xaa"
  580. (II) LoadModule: "xaa"
  581. (II) Loading /usr/X11R6/lib/modules/libxaa.a
  582. (II) Module xaa: vendor="The XFree86 Project"
  583. compiled for 4.2.99.3, module version = 1.1.0
  584. ABI class: XFree86 Video Driver, version 0.6
  585. (II) RADEON(0): AGP Fast Write disabled by default
  586. (II) RADEON(0): Depth moves disabled by default
  587. (II) Loading sub module "shadow"
  588. (II) LoadModule: "shadow"
  589. (II) Loading /usr/X11R6/lib/modules/libshadow.a
  590. (II) Module shadow: vendor="The XFree86 Project"
  591. compiled for 4.2.99.3, module version = 1.0.0
  592. ABI class: XFree86 ANSI C Emulation, version 0.2
  593. (**) RADEON(0): Disabling page flipping
  594. (!!) RADEON(0): For information on using the multimedia capabilities
  595. of this adapter, please see http://gatos.sf.net.
  596. (II) do I need RAC?  No, I don't.
  597. (II) resource ranges after preInit:
  598. [0] 0 0 0xed000000 - 0xed00ffff (0x10000) MX[B]
  599. [1] 0 0 0xe0000000 - 0xe7ffffff (0x8000000) MX[B]
  600. [2] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
  601. [3] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
  602. [4] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
  603. [5] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
  604. [6] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
  605. [7] -1 0 0xef000000 - 0xef007fff (0x8000) MX[B]
  606. [8] -1 0 0xef008000 - 0xef0080ff (0x100) MX[B]
  607. [9] -1 0 0xe8000000 - 0xe7ffffff (0x0) MX[B]O
  608. [10] -1 0 0xed000000 - 0xed00ffff (0x10000) MX[B](B)
  609. [11] -1 0 0xe0000000 - 0xe7ffffff (0x8000000) MX[B](B)
  610. [12] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B](OprU)
  611. [13] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B](OprU)
  612. [14] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B](OprU)
  613. [15] 0 0 0x00009000 - 0x000090ff (0x100) IX[B]
  614. [16] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
  615. [17] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
  616. [18] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
  617. [19] -1 0 0x0000c400 - 0x0000c403 (0x4) IX[B]
  618. [20] -1 0 0x0000c000 - 0x0000c007 (0x8) IX[B]
  619. [21] -1 0 0x0000bc00 - 0x0000bc03 (0x4) IX[B]
  620. [22] -1 0 0x0000b800 - 0x0000b807 (0x8) IX[B]
  621. [23] -1 0 0x0000b400 - 0x0000b403 (0x4) IX[B]
  622. [24] -1 0 0x0000b000 - 0x0000b03f (0x40) IX[B]
  623. [25] -1 0 0x0000ac00 - 0x0000acff (0x100) IX[B]
  624. [26] -1 0 0x0000a000 - 0x0000a00f (0x10) IX[B]
  625. [27] -1 0 0x00009000 - 0x000090ff (0x100) IX[B](B)
  626. [28] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
  627. [29] 0 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU)
  628. (==) RADEON(0): Write-combining range (0xe0000000,0x4000000)
  629. (EE) RADEON(0): [dri] RADEONInitVisualConfigs failed (depth 8 not supported).  Disabling DRI.
  630. (II) RADEON(0): Memory manager initialized to (0,0) (1408,8191)
  631. (II) RADEON(0): Reserved area from (0,1050) to (1408,1052)
  632. (II) RADEON(0): Largest offscreen area available: 1408 x 7139
  633. (II) RADEON(0): Using XFree86 Acceleration Architecture (XAA)
  634. Screen to screen bit blits
  635. Solid filled rectangles
  636. 8x8 mono pattern filled rectangles
  637. Indirect CPU to Screen color expansion
  638. Solid Lines
  639. Dashed Lines
  640. Scanline Image Writes
  641. Offscreen Pixmaps
  642. Setting up tile and stipple cache:
  643.  32 128x128 slots
  644.  32 256x256 slots
  645.  16 512x512 slots
  646. (II) RADEON(0): Acceleration enabled
  647. (==) RADEON(0): Backing store disabled
  648. (==) RADEON(0): Silken mouse enabled
  649. (II) RADEON(0): Using hardware cursor (scanline 1052)
  650. (II) RADEON(0): Largest offscreen area available: 1408 x 7116
  651. (**) Option "dpms"
  652. (**) RADEON(0): DPMS enabled
  653. (II) RADEON(0): Direct rendering disabled
  654. (II) Initializing built-in extension MIT-SHM
  655. (II) Initializing built-in extension XInputExtension
  656. (II) Initializing built-in extension XTEST
  657. (II) Initializing built-in extension XKEYBOARD
  658. (II) Initializing built-in extension LBX
  659. (II) Initializing built-in extension XC-APPGROUP
  660. (II) Initializing built-in extension SECURITY
  661. (II) Initializing built-in extension XINERAMA
  662. (II) Initializing built-in extension XFree86-Bigfont
  663. (II) Initializing built-in extension RENDER
  664. (II) Initializing built-in extension RANDR
  665. (**) Option "Protocol" "auto"
  666. (**) Mouse0: Protocol: "auto"
  667. (**) Option "CorePointer"
  668. (**) Mouse0: Core Pointer
  669. (**) Option "Device" "/dev/mouse"
  670. (**) Mouse0: Emulate3Buttons, Emulate3Timeout: 50
  671. (==) Mouse0: Buttons: 3
  672. (II) Keyboard "Keyboard0" handled by legacy driver
  673. (II) XINPUT: Adding extended input device "Mouse0" (type: MOUSE)
  674. Couldn't load XKB keymap, falling back to pre-XKB keymap
  675. (--) Mouse0: PnP-detected protocol: "ImPS/2"
  676. (II) Mouse0: ps2EnableDataReporting: succeeded
  677. Fatal server error:
  678. could not open default font 'fixed'
  679. When reporting a problem related to a server crash, please send
  680. the full server output, not just the last messages.
  681. This can be found in the log file "/var/log/XFree86.0.log".
  682. Please report problems to debian-x@lists.debian.org.
whaou, c est long :D
Marsh Posté le 23-01-2003 à 14:31:23
svp un petit coup de pouce :(
Marsh Posté le 23-01-2003 à 15:05:09
'tain, c'est pas dur, il cherche la fonte "fixed", qui est dans le paquet xfonts-base. Décommente ta ligne :
et hop.
Marsh Posté le 23-01-2003 à 15:07:38
bah nan !!!
j ai installe les xfonts-base, et avec ou sans le commentaire pour misc (ou les autres fonts d ailleurs) ca me sort cette erreur
donc suis bien in ze mouize moi :D
Marsh Posté le 23-01-2003 à 15:26:44
Tu les as chopé où tes paquets du nouvel Xfree ?
Marsh Posté le 23-01-2003 à 15:35:57
j ai reinstalle la debian, et kan il m a demande pour les src d apt, j ai rajoute ca en unstable : http://people.debian.org/~acid/dists/
c est la ke se trouve les packages 4.2.99.3 pour debian
j ai aussi mis ftp.fr.debian.org en unstable, puis j ai lance la suite de l installe (dl des packages + installe)
j ai ensuite installe xserver-xfree86, et voila les merdes :(
Marsh Posté le 23-01-2003 à 18:29:18
up siouplait  :hello:
Marsh Posté le 23-01-2003 à 20:51:20
Ta locale serait pas fr_FR@euro ?
Marsh Posté le 23-01-2003 à 21:00:19
ah peut etre !!
mais j ai regle le pb en installant xfree 4.2.99.4 :D
mais tjs po de DRI :(
et je sais po pk snif
