[debian] Probleme a l'installation des drivers nvidia.
Probleme a l'installation des drivers nvidia. [debian] - Installation - Linux et OS Alternatifs
Marsh Posté le 25-12-2002 à 22:55:41
Bonjour j'viens d'installer une debian sur mon athlon. J'ai changé le kernel en 2.4.20.i686 mais quand j'essaye d'installer les drivers nvidia ca se chioum. Quelqu'un aurait une idée ?
kaiska@miaoumix:~/NVIDIA_kernel-1.0-4191$ make
echo \#define NV_COMPILER \"`cc -v 2>&1 | tail -1`\" > nv_compiler.h
cc -c -Wall -Wimplicit -Wreturn-type -Wswitch -Wformat -Wchar-subscripts -Wparentheses -Wpointer-arith -Wcast-qual -Wno-multichar  -O -MD -D__KERNEL__ -DMODULE -D_LOOSE_KERNEL_NAMES -DNTRM -D_GNU_SOURCE -D_LOOSE_KERNEL_NAMES -D__KERNEL__ -DMODULE  -DNV_MAJOR_VERSION=1 -DNV_MINOR_VERSION=0 -DNV_PATCHLEVEL=4191  -DNV_UNIX   -DNV_LINUX   -DNV_INT64_OK   -DNVCPU_X86       -I. -I/usr/src/linux/include -Wno-cast-qual nv.c
cc -c -Wall -Wimplicit -Wreturn-type -Wswitch -Wformat -Wchar-subscripts -Wparentheses -Wpointer-arith -Wcast-qual -Wno-multichar  -O -MD -D__KERNEL__ -DMODULE -D_LOOSE_KERNEL_NAMES -DNTRM -D_GNU_SOURCE -D_LOOSE_KERNEL_NAMES -D__KERNEL__ -DMODULE  -DNV_MAJOR_VERSION=1 -DNV_MINOR_VERSION=0 -DNV_PATCHLEVEL=4191  -DNV_UNIX   -DNV_LINUX   -DNV_INT64_OK   -DNVCPU_X86       -I. -I/usr/src/linux/include -Wno-cast-qual os-agp.c
cc -c -Wall -Wimplicit -Wreturn-type -Wswitch -Wformat -Wchar-subscripts -Wparentheses -Wpointer-arith -Wcast-qual -Wno-multichar  -O -MD -D__KERNEL__ -DMODULE -D_LOOSE_KERNEL_NAMES -DNTRM -D_GNU_SOURCE -D_LOOSE_KERNEL_NAMES -D__KERNEL__ -DMODULE  -DNV_MAJOR_VERSION=1 -DNV_MINOR_VERSION=0 -DNV_PATCHLEVEL=4191  -DNV_UNIX   -DNV_LINUX   -DNV_INT64_OK   -DNVCPU_X86       -I. -I/usr/src/linux/include -Wno-cast-qual os-interface.c
os-interface.c:690: warning: `wb_list' defined but not used
cc -c -Wall -Wimplicit -Wreturn-type -Wswitch -Wformat -Wchar-subscripts -Wparentheses -Wpointer-arith -Wcast-qual -Wno-multichar  -O -MD -D__KERNEL__ -DMODULE -D_LOOSE_KERNEL_NAMES -DNTRM -D_GNU_SOURCE -D_LOOSE_KERNEL_NAMES -D__KERNEL__ -DMODULE  -DNV_MAJOR_VERSION=1 -DNV_MINOR_VERSION=0 -DNV_PATCHLEVEL=4191  -DNV_UNIX   -DNV_LINUX   -DNV_INT64_OK   -DNVCPU_X86       -I. -I/usr/src/linux/include -Wno-cast-qual os-registry.c
ld -r -o nv-linux.o nv.o os-agp.o os-interface.o os-registry.o
ld -r -o nvidia.o nv-linux.o nv-kernel.o
size nvidia.o
   text    data     bss     dec     hex filename
1248411   92824   32940 1374175  14f7df nvidia.o
Please run "make install" as root.
kaiska@miaoumix:~/NVIDIA_kernel-1.0-4191$ sudo make install
size nvidia.o
depmod: *** Unresolved symbols in /lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol __get_free_pages_Rsmp_4784e424
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol create_proc_entry_Rsmp_83f569d5
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol proc_root_Rsmp_b4c94c07
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol pci_read_config_byte_Rsmp_3ccefab4
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol free_irq_Rsmp_f20dabd8
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol change_page_attr_Rsmp_9d42b338
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol pci_find_device_Rsmp_c584f4e3
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol strncpy_from_user_Rsmp_24428be5
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol boot_cpu_data_Rsmp_0657d037
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol securebits_Rsmp_abe77484
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol del_timer_Rsmp_fc62f16d
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol __global_restore_flags_Rsmp_54dd1dcb
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol mod_timer_Rsmp_1f13d309
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol iounmap_Rsmp_5fb196d4
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol inter_module_get_request_Rsmp_b69f826b
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol __generic_copy_to_user_Rsmp_d523fdd3
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol pci_write_config_byte_Rsmp_364fc2a2
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol irq_stat_Rsmp_40a7690d
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol __pollwait_Rsmp_ad8b7db3
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol unregister_chrdev_Rsmp_c192d491
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol init_mm_Rsmp_543867be
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol __vmalloc_Rsmp_79995c5b
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol pci_read_config_dword_Rsmp_0bf170e2
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol remove_proc_entry_Rsmp_0e547d5f
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol __global_cli_Rsmp_64576b05
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol sprintf_Rsmp_1d26aa98
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol pci_write_config_dword_Rsmp_77f7f940
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol schedule_timeout_Rsmp_17d59d01
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol pci_write_config_word_Rsmp_f23d8795
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol __ioremap_Rsmp_9eac042a
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol pci_find_class_Rsmp_643cfa42
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol pm_register_Rsmp_027ebe5e
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol __wake_up_Rsmp_127fda83
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol proc_root_driver_Rsmp_e558a624
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol printk_Rsmp_1b7d4074
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol kfree_Rsmp_037a0cba
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol tq_immediate_Rsmp_0da0dcd1
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol inter_module_get_Rsmp_f6a0ce24
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol remap_page_range_Rsmp_69d01e73
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol __global_save_flags_Rsmp_5d902e96
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol tqueue_lock_Rsmp_b7a0c0b5
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol free_pages_Rsmp_9941ccb8
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol kill_proc_Rsmp_932da67e
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol vfree_Rsmp_2fd1d81c
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol inter_module_put_Rsmp_6b99f7d8
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol pci_find_slot_Rsmp_391edc78
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol kmalloc_Rsmp_93d4cfe6
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol mem_map_Rsmp_3578ee61
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol smp_num_cpus_Rsmp_3b86334d
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol __const_udelay_Rsmp_eae3dfd6
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol __udelay_Rsmp_9e7d6bd0
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol pm_unregister_Rsmp_94097bd6
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol high_memory_Rsmp_8a7d1c31
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol vsprintf_Rsmp_13d9cea7
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol __generic_copy_from_user_Rsmp_116166aa
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol jiffies_Rsmp_0da02d67
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol pci_read_config_word_Rsmp_923654cb
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol request_irq_Rsmp_0c60f2e0
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol bh_task_vec_Rsmp_284177b8
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol register_chrdev_Rsmp_6e1b6381
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol do_gettimeofday_Rsmp_72270e35
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: unresolved symbol __tasklet_hi_schedule_Rsmp_60ea5fe7
Hint: You are trying to load a module without a GPL compatible license
      and it has unresolved symbols.  Contact the module supplier for
      assistance, only they can help you.
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: insmod /lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o failed
/lib/modules/2.4.20-686/kernel/drivers/video/nvidia.o: insmod nvidia failed
make: *** [package-install] Error 255
Marsh Posté le 25-12-2002 à 23:07:40
Marsh Posté le 26-12-2002 à 00:08:19
merci bocoup mais je n'y arrive malheureusement pas avec cette methode :
kaiska@miaoumix:/usr/src$ sudo dpkg -i nvidia-glx_1.0.4191-1_i386.deb
Selecting previously deselected package nvidia-glx.
(Reading database ... 59150 files and directories currently installed.)
Unpacking nvidia-glx (from nvidia-glx_1.0.4191-1_i386.deb) ...
dpkg: dependency problems prevent configuration of nvidia-glx:
 nvidia-glx depends on nvidia-kernel; however:
  Package nvidia-kernel is not installed.
dpkg: error processing nvidia-glx (--install):
quelqu'un a une autre solution ??
Marsh Posté le 26-12-2002 à 00:25:40
C'est sûr que si tu ne fais pas les choses dans l'ordre, ça ne risque pas de marcher...
Le paquet "nvidia-kernel" doit être installé avant de mettre "nvidia-glx".
EDIT: Je viens de m'appercevoir qu'il y a un problème dans ma méthode! Il faut d'abords s'occuper du paquet "kernel" avant celui pour le "GLX", je vais corriger ça...
Message édité par eL_Shaman___ le 26-12-2002 à 00:29:11
Marsh Posté le 26-12-2002 à 00:40:56
ben ouhai mais tu vois bien sur mon premier post que meme en commencant par kernel ca chiuoum.  :cry:
Marsh Posté le 26-12-2002 à 00:50:04
On ne peut pas comparer avec ta façon de faire.
En installant le paquet fait par Debian, il va y avoir un script qui va s'exécuter et des tests de présence de paquets.
Je t'encourage à suivre la méthode Debian pour avoir quelque chose de PROPRE.
Message édité par eL_Shaman___ le 26-12-2002 à 00:53:33
