Probleme install drivers NForce sur MDK 9.2 RC2
Probleme install drivers NForce sur MDK 9.2 RC2 - Installation - Linux et OS Alternatifs
Marsh Posté le 26-09-2003 à 15:48:35
pour les isntaller j'ai essayer de faire comme ça : http://www.nvnews.net/vbulletin/sh [...] adid=16954
(7e post )
 mais j'obtient ça :
[dmey@localhost nvnet]$ ls
adapter.h  basetype.h  Makefile  nvnet.c  nvnet.h  nvnetlib.o  os.h  phy.h  tp*
[dmey@localhost nvnet]$ make
cc -c -Wall -DLINUX -DMODULE -DEXPORT_SYMTAB -D__KERNEL__ -O -Wstrict-prototypes
 -DCONFIG_PM  -fno-strict-aliasing -mpreferred-stack-boundary=2 -march=i686 -fal
ign-functions=4 -DMODULE -I/usr/src/linux-2.4.22/include   nvnet.c
In file included from /usr/include/linux/prefetch.h:13,
                 from /usr/include/linux/list.h:6,
                 from /usr/include/linux/module.h:11,
                 from nvnet.h:20,
                 from nvnet.c:21:
/usr/include/asm/processor.h:55: error: `CONFIG_X86_L1_CACHE_SHIFT' undeclared h
ere (not in a function)
/usr/include/asm/processor.h:55: error: requested alignment is not a constant
In file included from /usr/include/linux/module.h:20,
                 from nvnet.h:20,
                 from nvnet.c:21:
/usr/include/linux/modversions.h:1:2: #error "==================================
/usr/include/linux/modversions.h:2:2: #error "You should not include /usr/includ
e/{linux,asm}/ header"
/usr/include/linux/modversions.h:3:2: #error "files directly for the compilation
 of kernel modules."
/usr/include/linux/modversions.h:4:2: #error ""
/usr/include/linux/modversions.h:5:2: #error "glibc now uses kernel header files
 from a well-defined"
/usr/include/linux/modversions.h:6:2: #error "working kernel version (as recomme
nded by Linus Torvalds)"
/usr/include/linux/modversions.h:7:2: #error "These files are glibc internal and
 may not match the"
/usr/include/linux/modversions.h:8:2: #error "currently running kernel. They sho
uld only be"
/usr/include/linux/modversions.h:9:2: #error "included via other system header f
iles - user space"
/usr/include/linux/modversions.h:10:2: #error "programs should not directly incl
ude <linux/*.h> or"
/usr/include/linux/modversions.h:11:2: #error "<asm/*.h> as well."
/usr/include/linux/modversions.h:12:2: #error ""
/usr/include/linux/modversions.h:13:2: #error "To build kernel modules please do
 the following:"
/usr/include/linux/modversions.h:14:2: #error ""
/usr/include/linux/modversions.h:15:2: #error " o Have the kernel sources instal
led"
/usr/include/linux/modversions.h:16:2: #error ""
/usr/include/linux/modversions.h:17:2: #error " o Make sure that the symbolic li
nk"
/usr/include/linux/modversions.h:18:2: #error "   /lib/modules/`uname -r`/build
exists and points to"
/usr/include/linux/modversions.h:19:2: #error "   the matching kernel source dir
ectory"
/usr/include/linux/modversions.h:20:2: #error ""
/usr/include/linux/modversions.h:21:2: #error " o Now copy /boot/vmlinuz.version
.h to"
/usr/include/linux/modversions.h:22:2: #error "   /lib/modules/`uname -r`/build/
include/linux/version.h"
/usr/include/linux/modversions.h:23:2: #error ""
/usr/include/linux/modversions.h:24:2: #error " o When compiling, make sure to u
se the following"
/usr/include/linux/modversions.h:25:2: #error "   compiler option to use the cor
rect include files:"
/usr/include/linux/modversions.h:26:2: #error ""
/usr/include/linux/modversions.h:27:2: #error "   -I/lib/modules/`uname -r`/buil
d/include"
/usr/include/linux/modversions.h:28:2: #error ""
/usr/include/linux/modversions.h:29:2: #error "   instead of"
/usr/include/linux/modversions.h:30:2: #error ""
/usr/include/linux/modversions.h:31:2: #error "   -I/usr/include/linux"
/usr/include/linux/modversions.h:32:2: #error ""
/usr/include/linux/modversions.h:33:2: #error "   Please adjust the Makefile acc
ordingly."
/usr/include/linux/modversions.h:34:2: #error "=================================
In file included from /usr/include/linux/module.h:297,
                 from nvnet.h:20,
                 from nvnet.c:21:
/usr/include/linux/version.h:2:2: #error "======================================
/usr/include/linux/version.h:3:2: #error "You should not include /usr/include/{l
inux,asm}/ header"
/usr/include/linux/version.h:4:2: #error "files directly for the compilation of
kernel modules."
/usr/include/linux/version.h:5:2: #error ""
/usr/include/linux/version.h:6:2: #error "glibc now uses kernel header files fro
m a well-defined"
/usr/include/linux/version.h:7:2: #error "working kernel version (as recommended
 by Linus Torvalds)"
/usr/include/linux/version.h:8:2: #error "These files are glibc internal and may
 not match the"
/usr/include/linux/version.h:9:2: #error "currently running kernel. They should
only be"
/usr/include/linux/version.h:10:2: #error "included via other system header file
s - user space"
/usr/include/linux/version.h:11:2: #error "programs should not directly include
<linux/*.h> or"
/usr/include/linux/version.h:12:2: #error "<asm/*.h> as well."
/usr/include/linux/version.h:13:2: #error ""
/usr/include/linux/version.h:14:2: #error "To build kernel modules please do the
 following:"
/usr/include/linux/version.h:15:2: #error ""
/usr/include/linux/version.h:16:2: #error " o Have the kernel sources installed"
/usr/include/linux/version.h:17:2: #error ""
/usr/include/linux/version.h:18:2: #error " o Make sure that the symbolic link"
/usr/include/linux/version.h:19:2: #error "   /lib/modules/`uname -r`/build exis
ts and points to"
/usr/include/linux/version.h:20:2: #error "   the matching kernel source directo
ry"
/usr/include/linux/version.h:21:2: #error ""
/usr/include/linux/version.h:22:2: #error " o Now copy /boot/vmlinuz.version.h t
o"
/usr/include/linux/version.h:23:2: #error "   /lib/modules/`uname -r`/build/incl
/usr/include/linux/version.h:24:2: #error ""
/usr/include/linux/version.h:25:2: #error " o When compiling, make sure to use t
he following"
/usr/include/linux/version.h:26:2: #error "   compiler option to use the correct
 include files:"
/usr/include/linux/version.h:27:2: #error ""
/usr/include/linux/version.h:28:2: #error "   -I/lib/modules/`uname -r`/build/in
clude"
/usr/include/linux/version.h:29:2: #error ""
/usr/include/linux/version.h:30:2: #error "   instead of"
/usr/include/linux/version.h:31:2: #error ""
/usr/include/linux/version.h:32:2: #error "   -I/usr/include/linux"
/usr/include/linux/version.h:33:2: #error ""
/usr/include/linux/version.h:34:2: #error "   Please adjust the Makefile accordi
ngly."
/usr/include/linux/version.h:35:2: #error "=====================================
In file included from nvnet.h:20,
                 from nvnet.c:21:
/usr/include/linux/module.h:299: error: syntax error before "UTS_RELEASE"
In file included from /usr/include/linux/mm.h:12,
                 from /usr/include/linux/slab.h:14,
                 from nvnet.h:29,
                 from nvnet.c:21:
/usr/include/linux/mmzone.h:44: error: `CONFIG_X86_L1_CACHE_SHIFT' undeclared he
/usr/include/linux/mmzone.h:44: error: requested alignment is not a constant
In file included from /usr/include/asm/hardirq.h:6,
                 from /usr/include/linux/interrupt.h:46,
                 from nvnet.h:30,
                 from nvnet.c:21:
/usr/include/linux/irq.h:65: error: `CONFIG_X86_L1_CACHE_SHIFT' undeclared here
(not in a function)
/usr/include/linux/irq.h:65: error: requested alignment is not a constant
In file included from /usr/include/linux/interrupt.h:46,
                 from nvnet.h:30,
                 from nvnet.c:21:
/usr/include/asm/hardirq.h:16: error: `CONFIG_X86_L1_CACHE_SHIFT' undeclared her
/usr/include/asm/hardirq.h:16: error: requested alignment is not a constant
In file included from nvnet.h:30,
                 from nvnet.c:21:
/usr/include/linux/interrupt.h:129: error: `CONFIG_X86_L1_CACHE_SHIFT' undeclare
d here (not in a function)
/usr/include/linux/interrupt.h:129: error: requested alignment is not a constant
In file included from nvnet.h:31,
                 from nvnet.c:21:
inux,asm}/ header"
kernel modules."
m a well-defined"
 by Linus Torvalds)"
 not match the"
only be"
s - user space"
<linux/*.h> or"
 following:"
ts and points to"
ry"
o"
he following"
 include files:"
/usr/include/linux/version.h:28:2: #error "   -I/lib/modules/`uname -r`/build/in                                                           clude"
/usr/include/linux/version.h:34:2: #error "   Please adjust the Makefile accordi                                                           ngly."
/usr/include/linux/version.h:35:2: #error "=====================================                                                           =================="
In file included from nvnet.h:35,
                 from nvnet.c:21:
/usr/include/linux/netdevice.h:165: error: `CONFIG_X86_L1_CACHE_SHIFT' undeclare                                                           d here (not in a function)
/usr/include/linux/netdevice.h:165: error: requested alignment is not a constant
                 from nvnet.c:21:
/usr/include/linux/netdevice.h:517: error: `CONFIG_X86_L1_CACHE_SHIFT' undeclare                                                           d here (not in a function)
/usr/include/linux/netdevice.h:517: error: requested alignment is not a constant
nvnet.c:40:41: missing binary operator before token "("
nvnet.c:1284:41: missing binary operator before token "("
make: *** [nvnet.o] Erreur 1
qqn peut m'aider ?
a+
Marsh Posté le 26-09-2003 à 15:56:34
urpmi kernel-source (3eme CD ou bien source main)
Marsh Posté le 26-09-2003 à 16:40:08
je pencherais plus sur une update du kernel et de kernel-source. donc cooker is your friend
Mandriva : parce que nous le valons bien ! http://linux-wizard.net/index.php
Marsh Posté le 26-09-2003 à 16:55:26
En effet : sur RC2, kernel-source est updaté mais pas kernel.
Pour autant, si les drivers nforce ne sont pas installés, il n'a pas accès au net, donc pas d'update cooker, si ? Donc il devrait être synchronisé entre son kernel et ses sources ?
Marsh Posté le 26-09-2003 à 17:00:12
merci à vous deux pour les réponses !
des que zeb_ a repondu j'ai rebooté sous linux, et la je reply depuis linux, le reseau marche enfin !  :pt1cable:
merci bcp !  :jap:
Message édité par dmey le 26-09-2003 à 17:00:29
Marsh Posté le 26-09-2003 à 17:15:43
j'en profite pour poser deux autres questions :
mes deux disques windows : /mnt/win_c et /mnt/win_d ont un cadenas, et ils appartiennent au root, je voulais changer les droit d'acces pour pouvoir les lire, mais je n'ai pas le choix de me logger en root au demarrage, il faut le faire dans une console ?
dans lilo j'ai linux entrepris, linux et linux nonfb, j'ai remarqué aucune difference en bootant sur les trois. ils servent a quoi ?
a+
Marsh Posté le 26-09-2003 à 17:24:27
Si c'est du NTFS tes partitions, tu ne peux pas ecrire dessus.
Pour se loguer en root, c'est possible mais cache car tres deconseille. Ouvre une console et tape su.
Ou dans KDE, tu peux lancer une appli en utilisant "executer" dans le menu "clic droit sur le bureau" et en changeant l'owner.
En console, chown et chmod sont tes amis.
Pour les noyaux :
http://qa.mandrakesoft.com/twiki/b [...] dkKernel92
l'enterprise gere plus que 860Mo de RAM.
Marsh Posté le 26-09-2003 à 18:31:59
je me suis logger en root pour changer les droit d'acces des deux dossier en cochant les cases lecture, mais il me met une petite fenetre  : impossible de modifier les droit d'acces.
Marsh Posté le 26-09-2003 à 19:23:52
http://linux-wizard.tuxfamily.org/ [...] html#fat32
ajouter option user et umask=0 dans /etc/fstab.
Au pire, Mandrake Control Center -> Points de Montage -> Diskdrake -> Passer en mode expert, sélectionner la partition -> Options, cocher user et umask=0
Marsh Posté le 26-09-2003 à 19:30:47
je regarderai tout ça plus tard
Marsh Posté le 27-09-2003 à 18:38:57
ça marche  :jap:
encore une question  :whistle:
qd je sort d'un jeu, et que l'ecran change de resolution pour se remettre a celle du bureau, mon pc freeze.
c quoi le pb ?
Marsh Posté le 27-09-2003 à 22:06:43
Pour changer de résolution tu doit redémarrer ton serveur X
Donc si tu démarre un jeu dans une autre résolution que celle de ton bureau : redémarre ton serveur X
Le plus simple est de paramétrer ton jeu pour qu'il reflète la config de ton serveur X (résolution + couleurs), ou de trouver un compromis...
Marsh Posté le 27-09-2003 à 22:27:38
mais c normal ou c un probleme de driver ?
car je me rappelle avoir jouer a ut2003 ou tux racer sans probleme ya un moment avec la 9.0
Marsh Posté le 28-09-2003 à 09:56:59
Essayes de mettre à jour tes drivers (à moins que ce soit déjà les derniers...)
et regarde si ca change qqch.
Marsh Posté le 28-09-2003 à 10:04:12
ben deja j'ai un kernel panic au boot de puis que j'ai essayé de mettre les driver nvaudio  :cry:
alors va deja falloir reparer ça lol  :pt1cable:
Marsh Posté le 28-09-2003 à 12:24:48
le kernel panic a disparu au reboot suivant lol
# File generated by XFdrake.
# Refer to the XF86Config man page for details about the format of
# this file.
Section "Files"
    # Multiple FontPath entries are allowed (they are concatenated together)
    # By default, Mandrake 6.0 and later now use a font server independent of
    # the X server to render fonts.
    FontPath "unix/:-1"
EndSection
Section "ServerFlags"
    AllowMouseOpenFail # allows the server to start up even if the mouse doesn't work
    #DontZap # disable <Crtl><Alt><BS> (server abort)
    #DontZoom # disable <Crtl><Alt><KP_+>/<KP_-> (resolution switching)
EndSection
Section "Keyboard"
    Protocol "Standard"
    XkbModel "pc105"
    XkbLayout "fr"
    XkbOptions ""
EndSection
Section "Pointer"
    Protocol "IMPS/2"
    Device "/dev/psaux"
    ZAxisMapping 4 5
EndSection
Section "Monitor"
    Identifier "monitor1"
    VendorName "Generic"
    ModelName "1280x1024 @ 60 Hz"
    HorizSync 31.5-64.3
    VertRefresh 50-70
    # Sony Vaio C1(X,XS,VE,VN)?
    # 1024x480 @ 85.6 Hz, 48 kHz hsync
    ModeLine "1024x480"    65.00 1024 1032 1176 1344   480  488  494  563 -hsync -vsync
    # TV fullscreen mode or DVD fullscreen output.
    # 768x576 @ 79 Hz, 50 kHz hsync
    ModeLine "768x576"     50.00  768  832  846 1000   576  590  595  630
    # 768x576 @ 100 Hz, 61.6 kHz hsync
    ModeLine "768x576"     63.07  768  800  960 1024   576  578  590  616
    # This is a set of standard mode timings. Modes that are out of monitor spec
    # are automatically deleted by the server (provided the HorizSync and
    # VertRefresh lines are correct), so there's no immediate need to
    # delete mode timings (unless particular mode timings don't work on your
    # monitor). With these modes, the best standard mode that your monitor
    # and video card can support for a given resolution is automatically
    # used.
    # 640x400 @ 70 Hz, 31.5 kHz hsync
    ModeLine "640x400"     25.175 640  664  760  800   400  409  411  450
    # 640x480 @ 60 Hz, 31.5 kHz hsync
    ModeLine "640x480"     25.175 640  664  760  800   480  491  493  525
    # 800x600 @ 56 Hz, 35.15 kHz hsync
    ModeLine "800x600"     36     800  824  896 1024   600  601  603  625
    # 1024x768 @ 87 Hz interlaced, 35.5 kHz hsync
    ModeLine "1024x768"    44.9  1024 1048 1208 1264   768  776  784  817 Interlace
    # 640x400 @ 85 Hz, 37.86 kHz hsync
    ModeLine "640x400"     31.5   640  672 736   832   400  401  404  445 -HSync +VSync
    # 640x480 @ 75 Hz, 37.50 kHz hsync
    ModeLine "640x480"    31.5   640  656  720  840   480  481  484  500 -HSync -VSync
    # 800x600 @ 60 Hz, 37.8 kHz hsync
    ModeLine "800x600"     40     800  840  968 1056   600  601  605  628 +hsync +vsync
    # 640x480 @ 85 Hz, 43.27 kHz hsync
    ModeLine "640x480"     36     640  696  752  832   480  481  484  509 -HSync -VSync
    # 1152x864 @ 89 Hz interlaced, 44 kHz hsync
    ModeLine "1152x864"    65    1152 1168 1384 1480   864  865  875  985 Interlace
    # 800x600 @ 72 Hz, 48.0 kHz hsync
    ModeLine "800x600"     50     800  856  976 1040   600  637  643  666 +hsync +vsync
    # 1024x768 @ 60 Hz, 48.4 kHz hsync
    ModeLine "1024x768"    65    1024 1032 1176 1344   768  771  777  806 -hsync -vsync
    # 640x480 @ 100 Hz, 53.01 kHz hsync
    ModeLine "640x480"     45.8   640  672  768  864   480  488  494  530 -HSync -VSync
    # 1152x864 @ 60 Hz, 53.5 kHz hsync
    ModeLine "1152x864"   89.9  1152 1216 1472 1680   864  868  876  892 -HSync -VSync
    # 800x600 @ 85 Hz, 55.84 kHz hsync
    ModeLine "800x600"    60.75  800  864  928 1088   600  616  621  657 -HSync -VSync
    # 1024x768 @ 70 Hz, 56.5 kHz hsync
    ModeLine "1024x768"    75    1024 1048 1184 1328   768  771  777  806 -hsync -vsync
    # 1280x1024 @ 87 Hz interlaced, 51 kHz hsync
    ModeLine "1280x1024"   80    1280 1296 1512 1568  1024 1025 1037 1165 Interlace
    # 800x600 @ 100 Hz, 64.02 kHz hsync
    ModeLine "800x600"    69.65  800  864  928 1088   600  604  610  640 -HSync -VSync
    # 1024x768 @ 76 Hz, 62.5 kHz hsync
    ModeLine "1024x768"    85    1024 1032 1152 1360   768  784  787  823
    # 1152x864 @ 70 Hz, 62.4 kHz hsync
    ModeLine "1152x864"   92    1152 1208 1368 1474   864  865  875  895
    # 1280x1024 @ 61 Hz, 64.2 kHz hsync
    ModeLine "1280x1024"  110    1280 1328 1512 1712  1024 1025 1028 1054
    # 1400x1050 @ 60 Hz, 65.5 kHz
    ModeLine "1400x1050" 122.0 1400 1488 1640 1880   1050 1052 1064 1082 +HSync +VSync
    # 1024x768 @ 85 Hz, 70.24 kHz hsync
    ModeLine "1024x768"   98.9  1024 1056 1216 1408   768 782 788 822 -HSync -VSync
    # 1152x864 @ 78 Hz, 70.8 kHz hsync
    ModeLine "1152x864"   110   1152 1240 1324 1552   864  864  876  908
    # 1280x1024 @ 70 Hz, 74.59 kHz hsync
    ModeLine "1280x1024"  126.5 1280 1312 1472 1696  1024 1032 1040 1068 -HSync -VSync
    # 1600x1200 @ 60Hz, 75.00 kHz hsync
    ModeLine "1600x1200"  162   1600 1664 1856 2160  1200 1201 1204 1250 +HSync +VSync
    # 1152x864 @ 84 Hz, 76.0 kHz hsync
    ModeLine "1152x864"   135    1152 1464 1592 1776   864  864  876  908
    # 1280x1024 @ 75 Hz, 79.98 kHz hsync
    ModeLine "1280x1024"  135    1280 1296 1440 1688 1024 1025 1028 1066 +HSync +VSync
    # 1024x768 @ 100Hz, 80.21 kHz hsync
    ModeLine "1024x768"   115.5  1024 1056 1248 1440  768  771  781  802 -HSync -VSync
    # 1400x1050 @ 75 Hz, 82.2 kHz hsync
    ModeLine "1400x1050" 155.8   1400 1464 1784 1912  1050 1052 1064 1090 +HSync +VSync
    # 1600x1200 @ 70 Hz, 87.50 kHz hsync
    ModeLine "1600x1200"  189    1600 1664 1856 2160  1200 1201 1204 1250 -HSync -VSync
    # 1152x864 @ 100 Hz, 89.62 kHz hsync
    ModeLine "1152x864"   137.65 1152 1184 1312 1536   864  866  885  902 -HSync -VSync
    # 1280x1024 @ 85 Hz, 91.15 kHz hsync
    ModeLine "1280x1024"  157.5  1280 1344 1504 1728  1024 1025 1028 1072 +HSync +VSync
    # 1600x1200 @ 75 Hz, 93.75 kHz hsync
    ModeLine "1600x1200"  202.5  1600 1664 1856 2160  1200 1201 1204 1250 +HSync +VSync
    # 1600x1200 @ 85 Hz, 105.77 kHz hsync
    ModeLine "1600x1200"  220    1600 1616 1808 2080  1200 1204 1207 1244 +HSync +VSync
    # 1600x1200 @ 85 Hz, 106.3 kHz hsync
    ModeLine "1600x1200" 229.5   1600 1664 1856 2160  1200 1201 1204 1250 +HSync +VSync
    # 1280x1024 @ 100 Hz, 107.16 kHz hsync
    ModeLine "1280x1024"  181.75 1280 1312 1440 1696  1024 1031 1046 1072 -HSync -VSync
    # 1800x1440 @ 64Hz, 96.15 kHz hsync
    ModeLine "1800X1440"  230    1800 1896 2088 2392 1440 1441 1444 1490 +HSync +VSync
    # 1800x1440 @ 70Hz, 104.52 kHz hsync
    ModeLine "1800X1440"  250    1800 1896 2088 2392 1440 1441 1444 1490 +HSync +VSync
    # 1920x1440 @ 60 Hz, 90.0 kHz hsync
    ModeLine "1920x1440"  234.0  1920 2048 2256 2600 1440 1441 1444 1500 -HSync +VSync
    # 1920x1440 @ 75 Hz, 112.5kHz hsync
    ModeLine "1920x1440"  297.0  1920 2064 2288 2640 1440 1441 1444 1500 -HSync +VSync
    # 512x384 @ 78 Hz, 31.50 kHz hsync
    ModeLine "512x384"    20.160 512  528  592  640   384  385  388  404 -HSync -VSync
    # 512x384 @ 85 Hz, 34.38 kHz hsync
    ModeLine "512x384"    22     512  528  592  640   384  385  388  404 -HSync -VSync
    # Low-res Doublescan modes
    # If your chipset does not support doublescan, you get a 'squashed'
    # resolution like 320x400.
    # 320x200 @ 70 Hz, 31.5 kHz hsync, 8:5 aspect ratio
    ModeLine "320x200"     12.588 320  336  384  400   200  204  205  225 Doublescan
    # 320x240 @ 60 Hz, 31.5 kHz hsync, 4:3 aspect ratio
    ModeLine "320x240"     12.588 320  336  384  400   240  245  246  262 Doublescan
    # 320x240 @ 72 Hz, 36.5 kHz hsync
    ModeLine "320x240"     15.750 320  336  384  400   240  244  246  262 Doublescan
    # 400x300 @ 56 Hz, 35.2 kHz hsync, 4:3 aspect ratio
    ModeLine "400x300"     18     400  416  448  512   300  301  302  312 Doublescan
    # 400x300 @ 60 Hz, 37.8 kHz hsync
    ModeLine "400x300"     20     400  416  480  528   300  301  303  314 Doublescan
    # 400x300 @ 72 Hz, 48.0 kHz hsync
    ModeLine "400x300"     25     400  424  488  520   300  319  322  333 Doublescan
    # 480x300 @ 56 Hz, 35.2 kHz hsync, 8:5 aspect ratio
    ModeLine "480x300"     21.656 480  496  536  616   300  301  302  312 Doublescan
    # 480x300 @ 60 Hz, 37.8 kHz hsync
    ModeLine "480x300"     23.890 480  496  576  632   300  301  303  314 Doublescan
    # 480x300 @ 63 Hz, 39.6 kHz hsync
    ModeLine "480x300"     25     480  496  576  632   300  301  303  314 Doublescan
    # 480x300 @ 72 Hz, 48.0 kHz hsync
    ModeLine "480x300"     29.952 480  504  584  624   300  319  322  333 Doublescan
EndSection
Section "Device"
    Identifier  "NV AGP"
    VendorName  "nvidia"
    Driver   "nvidia"
    BoardName "NVIDIA GeForce4 (generic)"
    Option "power_saver"
EndSection
Section "Screen"
    Driver "svga"
    Device "device1"
    Monitor "monitor1"
    DefaultColorDepth 24
    Subsection "Display"
        Depth 8
        Modes "1280x960" "1152x864" "1024x768" "800x600" "640x480"
    EndSubsection
        Depth 15
    EndSubsection
        Depth 16
    EndSubsection
        Depth 24
    EndSubsection
        Depth 32
    EndSubsection
EndSection
Section "Module"
    Load        "dbe"
    # Load the glx module.
    Load "glx"
    Load        "extmod"
    Load "type1"
    Load "freetype"
EndSection
il me dit "sceens not found" au demarrage, j'ai essayé de changer
 Device "device1" par device "NV AGP" dans section "screen" mais ça fait pareil, j'ai aussi essayer de mettre le fichier d'exemple qui est dans /usr/share/doc/NVIDIA_GLX-1.0/ mais c toujorus pareil.  :cry:
qn peut m'expliquer le pb ?
Message édité par dmey le 28-09-2003 à 12:25:40
Marsh Posté le 29-09-2003 à 21:01:41
personne pour m'aider ?
Marsh Posté le 29-09-2003 à 21:06:19
ton module nvidia est loade ?
:: Light is Right ::
Marsh Posté le 29-09-2003 à 21:53:07
comment je sais ça ?  :ouch:
Marsh Posté le 29-09-2003 à 22:23:10
modprobe nvidia
puis tu relance l interface grapgique : normalement /etc/init.d/dm restart ;)
en root bien evidamment pour tout ca ;)
Marsh Posté le 30-09-2003 à 19:32:29
ça marche merci
mais je doit le faire a chaque fois, ya moyen que ça se fasse au boot ?
Marsh Posté le 30-09-2003 à 19:36:11
dmey a écrit :
ça marche merci
oui tu rajoutes une ligne ds /etc/modules ou tu mets nvidia
et voila il sera loade au boot :hello:
Marsh Posté le 30-09-2003 à 20:03:03
ça marche !
merci  :jap:
Marsh Posté le 30-09-2003 à 20:11:33
dmey a écrit :
ça marche !
merci  :jap:
oui je sais :D
