DEBIAN - probleme adsl
DEBIAN - probleme adsl - Linux et OS Alternatifs
Marsh Posté le 26-06-2002 à 21:38:08
bonjour
j'utilise debian (unstable, kernel 2.4.18) et me connecte a internet avec pppoe (pppoeconf) sur un sth->stp, et j'ai depuis quelque temps des problemes avec la reconnexion automatique.
apres une deconnexion impromptue, j'obtiens les lignes suivantes dans syslog :
Jun 26 16:04:15 shoebox kernel: NETDEV WATCHDOG: eth0: transmit timed out
Jun 26 16:04:15 shoebox kernel: eth0: Tx timed out, cable problem? TSR=0x16, ISR=0x0, t=24.
Jun 26 16:07:51 shoebox pppd[13328]: No response to 3 echo-requests
Jun 26 16:07:51 shoebox pppd[13328]: Serial link appears to be disconnected.
Jun 26 16:07:58 shoebox pppd[13328]: Connection terminated.
Jun 26 16:07:58 shoebox pppd[13328]: Connect time 466.1 minutes.
Jun 26 16:07:58 shoebox pppd[13328]: Sent 190709847 bytes, received 596277552 bytes.
Jun 26 16:07:58 shoebox pppoe[13329]: read (asyncReadFromPPP): Input/output error
Jun 26 16:07:58 shoebox pppoe[13329]: Sent PADT
Jun 26 16:08:28 shoebox pppd[13328]: Serial connection established.
Jun 26 16:08:28 shoebox pppd[13328]: Using interface ppp0
Jun 26 16:08:28 shoebox pppd[13328]: Connect: ppp0 <--> /dev/pts/0
Jun 26 16:08:59 shoebox pppd[13328]: LCP: timeout sending Config-Requests
Jun 26 16:08:59 shoebox pppd[13328]: Connection terminated.
Jun 26 16:09:03 shoebox pppoe[23196]: Timeout waiting for PADO packets
Jun 26 16:09:29 shoebox pppd[13328]: Serial connection established.
Jun 26 16:09:29 shoebox pppd[13328]: Using interface ppp0
Jun 26 16:09:29 shoebox pppd[13328]: Connect: ppp0 <--> /dev/pts/0
Jun 26 16:10:00 shoebox pppd[13328]: LCP: timeout sending Config-Requests
Jun 26 16:10:00 shoebox pppd[13328]: Connection terminated.
Jun 26 16:10:04 shoebox pppoe[23198]: Timeout waiting for PADO packets
Jun 26 16:10:30 shoebox pppd[13328]: Serial connection established.
Jun 26 16:10:30 shoebox pppd[13328]: Using interface ppp0
Jun 26 16:10:30 shoebox pppd[13328]: Connect: ppp0 <--> /dev/pts/0
Jun 26 16:11:01 shoebox pppd[13328]: LCP: timeout sending Config-Requests
Jun 26 16:11:01 shoebox pppd[13328]: Connection terminated.
Jun 26 16:11:05 shoebox pppoe[23303]: Timeout waiting for PADO packets
Jun 26 16:18:13 shoebox pppd[13328]: Exit.
et apres cela, impossible de se reconnecter sans eteindre/relancer le modem (j'ai vérifié le cable, de toutes facons un simple reboot du modem suffit, meme sans bouger ce meme cable)
j'aimerais donc savoir si le probleme vient de linux, de mon modem ou de wanadoo qui chie dans la semoule, avant de perdre mon temps au 1013/1014 :)
Message édité par gota le 27-06-2002 à 01:15:39
Marsh Posté le 27-06-2002 à 01:16:05
am i smelling the paté pur chiens ?
Marsh Posté le 27-06-2002 à 07:15:44
Un SpeedTouch Pro n'est-il pas censé pouvoir établir une connexion automatiquement ?
Sinon change-le.
Marsh Posté le 27-06-2002 à 16:36:11
Sinon change-le.
c t setup comme ca avant, mais quand le stp s'occupe de la connexion, le nat ne fonctionne pas correctement (probleme insolvable avec le forward d'ident avec oidentd notamment).
